Hello everyone I have been using Manjaro for about 2 weeks and been loving it so far.
My only issue is something I’ve had since the beginning, KDE Plasma occasionally crashes and has to restart. My windows stay the same but the bottom panel flashes away for a second and comes back. This happens when interacting with Plasma like changing the volume or bringing up the super key menu. Most of the time the effects don’t come back, so the animations tear, no translucency, etc until I reboot. Sometimes the bottom panel just disappears and I have to reboot with Yakuake.
System info:
System: Kernel: 5.10.53-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=2cf91412-22e1-4b59-8ffd-88b13f7bd413 rw
quiet apparmor=1 security=apparmor udev.log_priority=3
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux
base: Arch Linux
Machine: Type: Desktop Mobo: ASRock model: B365M Pro4 serial: <filter> UEFI: American Megatrends v: P4.20
date: 05/15/2019
Battery: Message: No system battery data found. Is one present?
Memory: RAM: total: 15.57 GiB used: 7.33 GiB (47.1%)
CPU: Info: 8-Core model: Intel Core i7-9700K bits: 64 type: MCP arch: Kaby Lake note: check family: 6
model-id: 9E (158) stepping: D (13) microcode: EA cache: L2: 12 MiB bogomips: 57616
Speed: 800 MHz min/max: 800/4900 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800
7: 800 8: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities arch_perfmon art avx
avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp
hwp_act_window hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm
lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep
smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: srbds mitigation: TSX disabled
Graphics: Device-1: NVIDIA TU104 [GeForce RTX 2060] vendor: Micro-Star MSI driver: nvidia v: 470.57.02
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1e89 class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 75 s-size: 1516x487mm (59.7x19.2") s-diag: 1592mm (62.7")
Monitor-1: DP-2 res: 2560x1440 hz: 75 dpi: 109 size: 597x336mm (23.5x13.2") diag: 685mm (27")
Monitor-2: HDMI-0 res: 1920x1080 hz: 60
OpenGL: renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2 v: 4.6.0 NVIDIA 470.57.02 direct render: Yes
Audio: Device-1: Intel 200 Series PCH HD Audio vendor: ASRock driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:a2f0 class-ID: 0403
Device-2: NVIDIA TU104 HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:10f8 class-ID: 0403
Sound Server-1: ALSA v: k5.10.53-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.32 running: yes
Network: Device-1: Intel Ethernet I219-V vendor: ASRock driver: e1000e v: kernel port: f000 bus-ID: 00:1f.6
chip-ID: 8086:15b8 class-ID: 0200
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: e000 bus-ID: 04:00.0 chip-ID: 8086:2723
class-ID: 0280
IF: wlp4s0 state: down mac: <filter>
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-13:5 chip-ID: 8087:0029
class-ID: e001
Logical: Message: No logical block device data found.
RAID: Message: No RAID data found.
Drives: Local Storage: total: 2.3 TiB used: 43.5 GiB (1.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WDS500G2B0C-00PXH0 size: 465.76 GiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter>
rev: 211070WD temp: 43.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000BX500SSD1 size: 931.51 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 030 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: TeamGroup model: T253X2001T size: 953.87 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 4A0 scheme: GPT
Partition: ID-1: / raw-size: 464.76 GiB size: 456.39 GiB (98.20%) used: 43.15 GiB (9.5%) fs: ext4
dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A uuid: 2cf91412-22e1-4b59-8ffd-88b13f7bd413
ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%) used: 366.7 MiB (35.9%) fs: vfat
dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A uuid: 42BE-4994
Swap: Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2 file: /swapfile
Unmounted: ID-1: /dev/sda1 maj-min: 8:1 size: 200 MiB fs: vfat label: EFI uuid: 67E3-17ED
ID-2: /dev/sda2 maj-min: 8:2 size: 931.32 GiB fs: apfs label: N/A
uuid: db5a7242-1c91-4806-9e3a-a43281c7fd49
ID-3: /dev/sdb1 maj-min: 8:17 size: 499.98 GiB fs: ntfs label: N/A uuid: 744618104617D22A
ID-4: /dev/sdb2 maj-min: 8:18 size: 453.87 GiB fs: exfat label: new shared uuid: FD07-7868
USB: Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002
Device-1: 1-3:2 info: Valve Wireless Steam Controller type: Keyboard,HID driver: hid-steam,usbhid
interfaces: 5 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 28de:1142 class-ID: 0300
Device-2: 1-11:3 info: Logitech G502 SE HERO Gaming Mouse type: Mouse,HID driver: hid-generic,usbhid
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 300mA chip-ID: 046d:c08b class-ID: 0300 serial: <filter>
Device-3: 1-12:4 info: Microdia Backlit Gaming Keyboard type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 400mA chip-ID: 0c45:652f
class-ID: 0301
Device-4: 1-13:5 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 8087:0029 class-ID: e001
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.0 speed: 5 Gb/s chip-ID: 1d6b:0003
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003
Sensors: System Temperatures: cpu: 36.0 C mobo: N/A gpu: nvidia temp: 46 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 30%
Info: Processes: 311 Uptime: 5h 44m wakeups: 0 Init: systemd v: 248 tool: systemctl Compilers: gcc: 11.1.0
clang: 12.0.1 Packages: 1349 pacman: 1342 lib: 345 flatpak: 7 Shell: Zsh v: 5.8 running-in: konsole
inxi: 3.3.06
