The recent applications menu section is no longer updating when apps are opened, the recent documents is however working.
Any idea where to start fixing this as I use it all the time
It might be a new bug. Have you checked the bug database at bugs.kde.org?
Should have indicated… all was fine but I did perform a timeshift restore yesterday and suspect that is when the problem started
Here’s what worked for me:
Right-click on the Manjaro icon (Edit menu items).
In the window that opens => Edit => Restore system settings.
After that you should also see all newly installed programs. After that you can edit the menu again.
Unfortunately did not work ![]()
Ahhhhh…
After another restart it appears it IS working, thank you muchly
This topic was automatically closed 24 hours after the last reply. New replies are no longer allowed.
