The specific manifestation is that the system Settings window closes unexpectedly, and Dr Konqi pops up a prompt asking to report the defect. When you open the application launcher and scroll the wheel, a similar problem will occur, but it will prompt a plasmashell crash. The following is my diary:
May 12 20:02:37 linux systemsettings[18303]: KCrash: Application 'systemsettings' crashing... crashRecursionCounter = 2
#2 0x00007bcb30d6fd47 _ZN6KCrash19defaultCrashHandlerEi (libKF6Crash.so.6 + 0x7d47)
#16 0x00007bcb3086d5f8 _ZN12QQuickWindow5eventEP6QEvent (libQt6Quick.so.6 + 0x26d5f8)
May 12 20:02:39 linux systemd[759]: Started Launch DrKonqi for a systemd-coredump crash (PID 18364/UID 0).
May 12 20:02:47 linux kwin_wayland[809]: kf.config.core: Watching absolute paths is not supported "/home/cxy/.local/share/color-schemes/WhiteSurDark.colors"
may 12 20:03:25 linux kwin_wayland[809]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
May 12 20:04:09 linux systemsettings[18820]: KCrash: Application 'systemsettings' crashing... crashRecursionCounter = 2
#2 0x00007d4dec1a5d47 _ZN6KCrash19defaultCrashHandlerEi (libKF6Crash.so.6 + 0x7d47)
#16 0x00007d4debc6d5f8 _ZN12QQuickWindow5eventEP6QEvent (libQt6Quick.so.6 + 0x26d5f8)
May 12 20:04:10 linux systemd[759]: Started Launch DrKonqi for a Systemd-core dump crash (PID 18880/UID 0).
May 12 20:04:19 linux kwin_wayland[809]: kf.config.core: Watching absolute paths is not supported "/home/cxy/.local/share/color-schemes/WhiteSurDark.colors"
May 12 20:07:30 linux kwin_wayland_wrapper[916]: I2025-05-12 20:07:30.198631 instance.cpp:1232] Running autosave...
May 12 20:07:30 linux kwin_wayland_wrapper[916]: I2025-05-12 20:07:30.234213 instance.cpp:1234] End autosave
May 12 20:12:53 linux systemsettings[20046]: KCrash: Application 'systemsettings' crashing... crashRecursionCounter = 2
#2 0x000078184854fd47 _ZN6KCrash19defaultCrashHandlerEi (libKF6Crash.so.6 + 0x7d47)
#16 0x000078184806d5f8 _ZN12QQuickWindow5eventEP6QEvent (libQt6Quick.so.6 + 0x26d5f8)
May 12 20:12:54 linux systemd[759]: Started Launch DrKonqi for a Systemd-core dump crash (PID 20107/UID 0).
May 12 20:13:22 linux systemsettings[20184]: KCrash: Application 'systemsettings' crashing... crashRecursionCounter = 2
#2 0x000076972db43d47 _ZN6KCrash19defaultCrashHandlerEi (libKF6Crash.so.6 + 0x7d47)
#16 0x000076972d66d5f8 _ZN12QQuickWindow5eventEP6QEvent (libQt6Quick.so.6 + 0x26d5f8)
May 12 20:13:24 linux systemd[759]: Started Launch DrKonqi for a Systemd-core dump crash (PID 20245/UID 0).
May 12 20:15:51 linux plasmashell[3233]: KCrash: Application 'plasmashell' crashing... crashRecursionCounter = 2
#2 0x0000759e39fd4d47 _ZN6KCrash19defaultCrashHandlerEi (libKF6Crash.so.6 + 0x7d47)
#16 0x0000759e38e6d5f8 _ZN12QQuickWindow5eventEP6QEvent (libQt6Quick.so.6 + 0x26d5f8)
May 12 20:15:54 linux systemd[759]: Started Launch DrKonqi for a systemd-coredump crash (PID 20665/UID 0).
May 12 20:15:54 linux drkonqi-coredump-launcher[20770]: #2 0x0000759e39fd4d47 _ZN6KCrash19defaultCrashHandlerEi (libKF6Crash.so.6 + 0x7d47)
May 12 20:15:54 linux drkonqi-coredump-launcher[20770]: #16 0x0000759e38e6d5f8 _ZN12QQuickWindow5eventEP6QEvent (libQt6Quick.so.6 + 0x26d5f8)
May 12 20:17:23 linux kwin_wayland[809]: kf.config.core: Watching absolute paths is not supported "/home/cxy/.local/share/color-schemes/WhiteSurDark.colors"
