I have a few autostart programs in KDE Plasma 6.2.4 but they are not starting on boot, logout/login or restart. I have placed *.desktop files with execution permission but no luck.
/home/zeeshan/.config/autostart/
Some of these *.desktop files are pointing toward the script which also has execution permission they are also not working.
/home/zeeshan/.local/bin/
Also tried Settings > Autostart > Program still no luck. This started happen recently it was working fine before. Any help appreciated thanks in advance.
Execution permission should be removed from those files. I have a hazy memory from quite some time ago that an autostart script on my system refused to start until I removed the execution permissions from the .desktop file.
I just checked the permissions of the files in my ~/.config/autostart directory, all of which start successfully when I login. None are executable:
ls -lL ~/.config/autostart
total 40
-rw------- 1 scotty scotty 243 May 10 2024 feathernotes.desktop
-rw------- 1 scotty scotty 131 Dec 13 2023 iloggedinat.desktop
-rw-r--r-- 1 root root 1401 Jan 3 05:52 manjaro-hello.desktop
-rw------- 1 scotty scotty 340 Aug 28 2023 org.kde.yakuake.desktop
-rw-r--r-- 1 scotty scotty 190 May 8 2024 org.moson.matray.desktop
-rw------- 1 scotty scotty 135 Nov 10 2023 ytdlpbatchnew.desktop
-rw------- 1 scotty scotty 153 Nov 10 2023 ytdlpfolder2delaystart.desktop
-rw------- 1 scotty scotty 153 Nov 10 2023 ytdlpfolder3delaystart.desktop
-rw------- 1 scotty scotty 153 Nov 10 2023 ytdlpfolder4delaystart.desktop
-rw------- 1 scotty scotty 151 Nov 10 2023 ytdlpfolderdelaystart.desktop
If changing the permissions to non-executable doesn’t work, then you may need to completely delete those .desktop files, and re-add them (preferably via Plasma’s System Settings). I’m not sure what Plasma does when they are added, but I do know that the systemd-xdg-autostart-generator (which is included in the systemd package) should be adding them to the user’s systemd user id folder at boot/login.
For example, here’s my /run/user/1000/systemd/generator.late/ content (my last boot was 10 days ago, which is why they are dated Jan 15):
ls -lL /run/user/1000/systemd/generator.late/
total 84
-rw-r--r-- 1 scotty scotty 578 Jan 15 16:33 'app-at\x2dspi\x2ddbus\x2dbus@autostart.service'
-rw-r--r-- 1 scotty scotty 389 Jan 15 16:33 app-feathernotes@autostart.service
-rw-r--r-- 1 scotty scotty 474 Jan 15 16:33 'app-geoclue\x2ddemo\x2dagent@autostart.service'
-rw-r--r-- 1 scotty scotty 394 Jan 15 16:33 app-iloggedinat@autostart.service
-rw-r--r-- 1 scotty scotty 392 Jan 15 16:33 'app-manjaro\x2dhello@autostart.service'
-rw-r--r-- 1 scotty scotty 377 Jan 15 16:33 app-msm_notifier@autostart.service
-rw-r--r-- 1 scotty scotty 462 Jan 15 16:33 app-org.kde.discover.notifier@autostart.service
-rw-r--r-- 1 scotty scotty 388 Jan 15 16:33 app-org.kde.kdeconnect.daemon@autostart.service
-rw-r--r-- 1 scotty scotty 505 Jan 15 16:33 'app-org.kde.plasma\x2dfallback\x2dsession\x2drestore@autostart.service'
-rw-r--r-- 1 scotty scotty 382 Jan 15 16:33 app-org.kde.yakuake@autostart.service
-rw-r--r-- 1 scotty scotty 389 Jan 15 16:33 app-org.moson.matray@autostart.service
-rw-r--r-- 1 scotty scotty 478 Jan 15 16:33 'app-pamac\x2dtray@autostart.service'
-rw-r--r-- 1 scotty scotty 482 Jan 15 16:33 'app-pamac\x2dtray\x2dbudgie@autostart.service'
-rw-r--r-- 1 scotty scotty 472 Jan 15 16:33 'app-pamac\x2dtray\x2dplasma@autostart.service'
-rw-r--r-- 1 scotty scotty 486 Jan 15 16:33 'app-print\x2dapplet@autostart.service'
-rw-r--r-- 1 scotty scotty 466 Jan 15 16:33 'app-xapp\x2dsn\x2dwatcher@autostart.service'
-rw-r--r-- 1 scotty scotty 400 Jan 15 16:33 app-ytdlpbatchnew@autostart.service
-rw-r--r-- 1 scotty scotty 427 Jan 15 16:33 app-ytdlpfolder2delaystart@autostart.service
-rw-r--r-- 1 scotty scotty 427 Jan 15 16:33 app-ytdlpfolder3delaystart@autostart.service
-rw-r--r-- 1 scotty scotty 427 Jan 15 16:33 app-ytdlpfolder4delaystart@autostart.service
-rw-r--r-- 1 scotty scotty 424 Jan 15 16:33 app-ytdlpfolderdelaystart@autostart.service
drwxr-xr-x 2 scotty scotty 460 Jan 15 16:33 xdg-desktop-autostart.target.wants
Edit: if the autostart entries exist in your /run/user/[UID - eg 1000]/systemd/generator.late/ directory, then you can also check on their individual statuses by running:
systemctl status --user service-name-including-the-@-autostart.service
Also did this same result. Created using settings > Autostart again same result.
Yes checked this statuses were there and again no issue found.
So I have changed the Splash Screen to none, and it’s working fine now. I noticed that if I log out and login again the application was opening and after suddenly screen splashed and all autostart apps are gone. No idea what the correlation between autostart and Splash Screen but it is fixed.
