Greetings!
I wanted to try out Wayland on KDE Plasma 5 for my system, I did install and went to test it on the software I use. I have found some issues that I wasn’t sure if it is Wayland or my computer’s hardware being too weak for Wayland.
Here’s the specs of my machine:
Kernel: 6.1.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=7a0aad6e-4cb5-4be9-8bb0-ab829b6373de rw quiet splash
resume=UUID=0aa27db6-b706-42f2-a5bc-dbc1542ade4d udev.log_priority=3
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_wayland vt: 2
Type: Laptop System: Acer product: Aspire E5-575 v: V1.47
serial: <superuser required>
Mobo: Acer model: Ironman_SK v: V1.47 serial: <superuser required>
UEFI: Insyde v: 1.47 date: 09/06/2018
ID-1: BAT1 charge: 31.4 Wh (67.0%) condition: 46.9/62.2 Wh (75.5%)
volts: 11.5 min: 11.1 model: PANASONIC AS16B5J type: Li-ion serial: <filter>
status: discharging
RAM: total: 3.7 GiB used: 3.09 GiB (83.4%)
Info: model: Intel Core i3-7100U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check gen: core 7 level: v3 note: check built: 2017 process: Intel 14nm
family: 6 model-id: 0x8E (142) stepping: 9 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1520 high: 2400 min/max: 400/2400 scaling:
driver: intel_pstate governor: powersave cores: 1: 2400 2: 680 3: 600 4: 2400
bogomips: 19204
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx
msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg
sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 620 vendor: Acer Incorporated ALI Aspire E5-575G
ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:5916 class-ID: 0300
Device-2: Chicony HD WebCam type: USB driver: uvcvideo bus-ID: 1-7:3
chip-ID: 04f2:b571 class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.7 with: Xwayland v: 22.1.7
compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: 0
Monitor-1: eDP-1 res: 1920x1080 size: N/A modes: N/A
API: OpenGL v: 4.6 Mesa 22.3.5 renderer: Mesa Intel HD Graphics 620 (KBL
GT2) direct-render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI
Aspire E5-575G driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_soc_avs,snd_sof_pci_intel_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound API: ALSA v: k6.1.11-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.65 running: yes
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Lite-On driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
vendor: Acer Incorporated ALI Aspire E5-575G driver: r8169 v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.1
IF: enp3s0f1 state: down mac: <filter>
Device-1: Lite-On Qualcomm Atheros QCA9377 Bluetooth type: USB driver: btusb
v: 0.8 bus-ID: 1-5:2 chip-ID: 04ca:3015 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: N/A rfk-block:
hardware: no software: no address: see --recommends
Local Storage: total: 465.76 GiB used: 28.82 GiB (6.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WDBNCE5000PNC
type: SSD serial: <filter> rev: 20RL scheme: GPT
Optical-1: /dev/sr0 vendor: Slimtype model: DVD A DA8AESH rev: XA11
dev-links: cdrom
ID-1: / raw-size: 54 GiB size: 52.85 GiB (97.87%) used: 18.34 GiB (34.7%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: root
uuid: 7a0aad6e-4cb5-4be9-8bb0-ab829b6373de
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: EFI
uuid: FAEE-CD18
ID-3: /home raw-size: 403.47 GiB size: 396.06 GiB (98.17%)
used: 10.3 GiB (2.6%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: home
uuid: 88df4b9b-42ce-46c6-8e62-37fe04191213
ID-1: swap-1 type: partition size: 8 GiB used: 185.5 MiB (2.3%)
priority: -2 dev: /dev/sda2 maj-min: 8:2 label: swap
uuid: 0aa27db6-b706-42f2-a5bc-dbc1542ade4d
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-5:2 info: Lite-On Qualcomm Atheros QCA9377 Bluetooth
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 04ca:3015 class-ID: e001
Device-2: 1-7:3 info: Chicony HD WebCam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b571
class-ID: 0e02
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 33.0 C pch: 34.0 C mobo: N/A
Processes: 184 Uptime: 26m wakeups: 1 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1233 libs: 358 tools: pamac,paru pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.25
Here are some of the issues I have found using Wayland that I never had on X:
When I go to log out, shutdown, restart, etc. the fullscreen blurred background would make my computer lag, this also applies to blurring the background in Konsole when transparency is enabled.
Scrolling on LibreOffice Writer (fresh version) is laggy.
These are the issues I have found for the few times I’ve tested Wayland on my laptop. If you do have any solutions to the problems I’ve encountered, let me know!
Or if none of these problems can be fixed or my laptop is too weak for Wayland, I’ll just switch back to X11 if that’s the best option for my system.
