Hi, hope everyone is well.
I’m having this problem with KDE Partition Manager taking forever to complete its scan.
A few months back, I moved to btrfs and I’d say that’s when I started having issues, although I can’t say for sure. Things seem to be working fine otherwise. I have a Win10 dual boot setup with windows on its own drive (/dev/sdb) and Manjaro on the Samsung nvme. The rest are spare storage drives.
Any thoughts on why the scan would take so long? Are the two not properly aligned partitions causing this issue? If yes, can I realign them without starting over fresh?
❯ partitionmanager
Loaded backend plugin: "pmsfdiskbackendplugin"
"Using backend plugin: pmsfdiskbackendplugin (1)"
"Scanning devices..."
"Device found: Samsung SSD 970 EVO Plus 1TB"
getting temp failed for "/dev/nvme0n1" : Success
getting powered on time failed for "/dev/nvme0n1" : Success
getting power cycles failed for "/dev/nvme0n1" : Success
"Partition ‘/dev/nvme0n1p2’ is not properly aligned (last sector: 1,917,577,739, modulo: 524)."
"Device found: WDC WD5000BEKT-00KA9T0"
"Device found: KINGSTON SA400S37240G"
unknown file system type "" on "/dev/sdb2"
"Partition ‘/dev/sdb3’ is not properly aligned (last sector: 467,835,607, modulo: 728)."
"Device found: My Passport 0820"
"Scan finished."
❯ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 465.8G 0 disk
└─sda1 8:1 0 465.8G 0 part /wd
sdb 8:16 0 223.6G 0 disk
├─sdb1 8:17 0 100M 0 part
├─sdb2 8:18 0 16M 0 part
├─sdb3 8:19 0 223G 0 part /win10
└─sdb4 8:20 0 500M 0 part
sdc 8:32 0 931.5G 0 disk
└─sdc1 8:33 0 931.5G 0 part
sdd 8:48 1 0B 0 disk
sde 8:64 1 0B 0 disk
sr0 11:0 1 1024M 0 rom
sr1 11:1 1 1024M 0 rom
nvme0n1 259:0 0 931.5G 0 disk
├─nvme0n1p1 259:1 0 301M 0 part /boot/efi
├─nvme0n1p2 259:2 0 914.1G 0 part /run/timeshift/backup
│ /var/lib/docker/btrfs
│ /var/cache
│ /var/log
│ /home
└─nvme0n1p3 259:3 0 17.1G 0 part [SWAP]
UUID=XXXX-XXXX /boot/efi vfat umask=0077 0 2
UUID=xxxxxxxxxxxxxxxxxxxxxxxx / btrfs subvol=/@,defaults,noatime,autodefrag,compress=zstd 0 0
UUID=xxxxxxxxxxxxxxxxxxxxxxxx /home btrfs subvol=/@home,defaults,noatime,autodefrag,compress=zstd 0 0
UUID=xxxxxxxxxxxxxxxxxxxxxxxx /var/cache btrfs subvol=/@cache,defaults,noatime,autodefrag,compress=zstd 0 0
UUID=xxxxxxxxxxxxxxxxxxxxxxxx /var/log btrfs subvol=/@log,defaults,noatime,autodefrag,compress=zstd 0 0
UUID=xxxxxxxxxxxxxxxxxxxxxxxx swap swap defaults,noatime 0 0
UUID=xxxxxxxxxxxxxxxxxxxxxxxx /wd ext4 noatime,discard 0 0
UUID=xxxxxxxxxxxxxxxxxxxxxxxx /wdusb ext4 noauto,x-systemd.automount,x-systemd.idle-timeout=10min,nofail,>
UUID=xxxxxxxxxxxxxxxxxxxxxxxx /toshiba ext4 noauto,x-systemd.automount,x-systemd.idle-timeout=10min,nofail,>
#UUID=XXXXXXXXXXXXXXXXXXXX /win10 ntfs uid=1000,gid=1000,rw,user,exec,umask=000 0 0
UUID=XXXXXXXXXXXXXXXXXXXX /win10 ntfs-3g uid=1000,gid=1000,dmask=022,fmask=133,windows_names 0 0
