KDE not started
Hello everyone!
I installed Manjaro… And:
  1. It’s not loading automatically - only if in live cd I choose “other EFI boot”
  2. Kde doesn’t loading. But on VB all going perfect. I think trouble in video driver (nvidia gtx 1050ti) but how could i install it, if i can’t load system?
Sounds like you didn’t install a bootloader.
What steps and settings did you choose in the installer?
Which means your gpu driver is fine. And KDE is fine.
Grub installation needs repair. Follow the tutorial to repair. If more problems, post info to get help.
This time I changed partition table top MBR and created partition work “boot” flag. Booting is fixed now, but kde loading is still problem… (
XFCE did’t start to… So problem is in Manjaro…
On my computer it works perfect, but on laptop not:-(
Here’s my steps:
  1. Booting live cd
  2. Connecting to WLAN
  3. Create new partition table (msdos)
  4. Create new partition (primary) “/home” without flags
  5. Create new (extended) partition “/” with “boot” flag
  6. After install reboot
What ISO version did you use?
I didn’t know you could install UEFI on MBR drives.
Have you read this Tutorial?
Anyway, “repetition is mother of learning” … (Greek quote)
No. I installed legacy way…
No, I didn’t. Because Manjaro booting… After I login it freezes…
But thank you for this tutorial… I’ll see it soon, very interesting
Do you get to the Login screen (SDDM)?
Yes. Typed my password and “Enter”
You have to describe more this behavior.
Have you tried TTY?
Checked journal for errors?
There is another interesting tutorial
Fantastic tutorial!! Thank you very much!! I’ll write later, when read all…
Here is my outputs:
#inxi:
[manjaro /]# inxi -b
12System:    12Host manjaro 12Kernel 4.14.52-1-MANJARO x86_64 12bits 64 12Console N/A
           12Distro Manjaro Linux 17.1.11 Hakoila
12Machine:   12Type Laptop 12System Dell 12product Inspiron 15 7000 Gaming 12v N/A 12serial <filter>
           12Mobo Dell 12model 065C71 12v X02 12serial <filter> 12UEFI [Legacy] Dell 12v 01.00.05
           12date 03/01/2017
12Battery:   12ID-1 BAT0 12charge 74.0 Wh 12condition 64.0/74.0 Wh (87%)
12CPU:       12Quad Core Intel Core i7-7700HQ 12type MT MCP 12speed 800 MHz 12min/max 800/3800 MHz
12Graphics:  12Card-1 Intel 12driver i915 12v kernel
           12Card-2 NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] 12driver nouveau 12v kernel
           12Display 12server X.org 1.19.6 12driver intel,nouveau 12unloaded fbdev,modesetting,nv,vesa
           12tty N/A
           12Message Advanced graphics data unavailable for root. Old System?
12Network:   12Card-1 Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet 12driver r8169
           12Card-2 Intel Wireless 3165 12driver iwlwifi
12Drives:    12HDD Total Size 960.94 GiB 12used 25.98 GiB (2.7%)
12Info:      12Processes 221 12Uptime 6m 12Memory 7.45 GiB 12used 772.2 MiB (10.1%)
           12Client Unknown Client: systemd 12inxi 3.0.12
[manjaro /]# clear
           12date 03/01/2017
12CPU:       12Quad Core Intel Core i7-7700HQ 12type MT MCP 12speed 900 MHz 12min/max 800/3800 MHz
           12tty N/A
12Info:      12Processes 221 12Uptime 6m 12Memory 7.45 GiB 12used 771.7 MiB (10.1%)
[manjaro /]#
#dmesg:
[manjaro /]# dmesg
[    0.000000] microcode: microcode updated early to revision 0x84, date = 2018-01-21
[    0.000000] Linux version 4.14.52-1-MANJARO (builduser@development) (gcc version 8.1.1 20180531 (GCC)) #1 SMP PREEMPT Tue Jun 26 15:24:31 UTC 2018
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1 misobasedir=manjaro misolabel=MJR17111 quiet systemd.show_status=1
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.000000] x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
[    0.000000] x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
[    0.000000] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[    0.000000] e820: BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009c7ff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009c800-0x000000000009ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000006a15dfff] usable
[    0.000000] BIOS-e820: [mem 0x000000006a15e000-0x000000006a15efff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x000000006a15f000-0x0000000078652fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000078653000-0x0000000078694fff] ACPI data
[    0.000000] BIOS-e820: [mem 0x0000000078695000-0x0000000078ff7fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x0000000078ff8000-0x00000000795fefff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000027f7fffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] SMBIOS 3.0.0 present.
[    0.000000] DMI: Dell Inc. Inspiron 15 7000 Gaming/065C71, BIOS 01.00.05 03/01/2017
[    0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000000] e820: last_pfn = 0x27f800 max_arch_pfn = 0x400000000
[    0.000000] MTRR default type: write-back
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF uncachable
[    0.000000]   C0000-FFFFF write-protect
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 0080000000 mask 7F80000000 uncachable
[    0.000000]   1 base 007C000000 mask 7FFC000000 uncachable
[    0.000000]   2 base 007B000000 mask 7FFF000000 uncachable
[    0.000000]   3 disabled
[    0.000000]   4 disabled
[    0.000000]   5 disabled
[    0.000000]   6 disabled
[    0.000000]   7 disabled
[    0.000000]   8 disabled
[    0.000000]   9 disabled
[    0.000000] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.000000] e820: last_pfn = 0x6a15e max_arch_pfn = 0x400000000
[    0.000000] found SMP MP-table at [mem 0x000fce40-0x000fce4f] mapped at [ffffffffff200e40]
[    0.000000] Scanning 1 areas for low memory corruption
[    0.000000] Base memory trampoline at [ffff980a00096000] 96000 size 24576
[    0.000000] Using GB pages for direct mapping
[    0.000000] BRK [0x1b963a000, 0x1b963afff] PGTABLE
[    0.000000] BRK [0x1b963b000, 0x1b963bfff] PGTABLE
[    0.000000] BRK [0x1b963c000, 0x1b963cfff] PGTABLE
[    0.000000] BRK [0x1b963d000, 0x1b963dfff] PGTABLE
[    0.000000] BRK [0x1b963e000, 0x1b963efff] PGTABLE
[    0.000000] BRK [0x1b963f000, 0x1b963ffff] PGTABLE
[    0.000000] BRK [0x1b9640000, 0x1b9640fff] PGTABLE
[    0.000000] RAMDISK: [mem 0x33a9d000-0x35d45fff]
[    0.000000] ACPI: Early table checksum verification disabled
[    0.000000] ACPI: RSDP 0x00000000000EC5D0 000024 (v02 DELL  )
[    0.000000] ACPI: XSDT 0x00000000786600B8 0000EC (v01 DELL   CBX3     01072009 AMI  00010013)
[    0.000000] ACPI: FACP 0x0000000078684040 00010C (v05 DELL   CBX3     01072009 AMI  00010013)
[    0.000000] ACPI: DSDT 0x0000000078660230 023E10 (v02 DELL   CBX3     01072009 INTL 20160422)
[    0.000000] ACPI: FACS 0x0000000078FF1F80 000040
[    0.000000] ACPI: APIC 0x0000000078684150 0000BC (v03 DELL   CBX3     01072009 AMI  00010013)
[    0.000000] ACPI: FPDT 0x0000000078684210 000044 (v01 DELL   CBX3     01072009 AMI  00010013)
[    0.000000] ACPI: FIDT 0x0000000078684258 00009C (v01 DELL   CBX3     01072009 AMI  00010013)
[    0.000000] ACPI: MCFG 0x00000000786842F8 00003C (v01 DELL   CBX3     01072009 MSFT 00000097)
[    0.000000] ACPI: HPET 0x0000000078684338 000038 (v01 DELL   CBX3     01072009 AMI. 0005000B)
[    0.000000] ACPI: SSDT 0x0000000078684370 000372 (v01 SataRe SataTabl 00001000 INTL 20160422)
[    0.000000] ACPI: BOOT 0x00000000786846E8 000028 (v01 DELL   CBX3     01072009 AMI  00010013)
[    0.000000] ACPI: SSDT 0x0000000078684710 0012E1 (v02 SaSsdt SaSsdt   00003000 INTL 20160422)
[    0.000000] ACPI: SSDT 0x00000000786859F8 002927 (v02 PegSsd PegSsdt  00001000 INTL 20160422)
[    0.000000] ACPI: HPET 0x0000000078688320 000038 (v01 INTEL  KBL      00000001 MSFT 0000005F)
[    0.000000] ACPI: SSDT 0x0000000078688358 0008F8 (v02 INTEL  xh_OEMBD 00000000 INTL 20160422)
[    0.000000] ACPI: UEFI 0x0000000078688C50 000042 (v01                 00000000      00000000)
[    0.000000] ACPI: SSDT 0x0000000078688C98 000EDE (v02 CpuRef CpuSsdt  00003000 INTL 20160422)
[    0.000000] ACPI: LPIT 0x0000000078689B78 000094 (v01 INTEL  KBL      00000000 MSFT 0000005F)
[    0.000000] ACPI: WSMT 0x0000000078689C10 000028 (v01 INTEL  KBL      00000000 MSFT 0000005F)
[    0.000000] ACPI: SSDT 0x0000000078689C38 00029F (v02 INTEL  sensrhub 00000000 INTL 20160422)
[    0.000000] ACPI: SSDT 0x0000000078689ED8 003002 (v02 INTEL  PtidDevc 00001000 INTL 20160422)
[    0.000000] ACPI: DBGP 0x000000007868CEE0 000034 (v01 INTEL           00000002 MSFT 0000005F)
[    0.000000] ACPI: DBG2 0x000000007868CF18 000054 (v00 INTEL           00000002 MSFT 0000005F)
[    0.000000] ACPI: SSDT 0x000000007868CF70 004559 (v02 DptfTa DptfTabl 00001000 INTL 20160422)
[    0.000000] ACPI: SSDT 0x00000000786914D0 0000F0 (v02 SgRef  SgPeg    00001000 INTL 20160422)
[    0.000000] ACPI: DMAR 0x00000000786915C0 0000F0 (v01 INTEL  KBL      00000001 INTL 00000001)
[    0.000000] ACPI: NHLT 0x00000000786916B0 00002D (v00 INTEL  EDK2     00000002      01000013)
[    0.000000] ACPI: SSDT 0x00000000786916E0 001C9E (v01 OptRef OptTabl  00001000 INTL 20160422)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] No NUMA configuration found
[    0.000000] Faking a node at [mem 0x0000000000000000-0x000000027f7fffff]
[    0.000000] NODE_DATA(0) allocated [mem 0x27f7fc000-0x27f7fffff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.000000]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000027f7fffff]
[    0.000000]   Device   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000001000-0x000000000009bfff]
[    0.000000]   node   0: [mem 0x0000000000100000-0x000000006a15dfff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000027f7fffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000027f7fffff]
[    0.000000] On node 0 totalpages: 2005241
[    0.000000]   DMA zone: 64 pages used for memmap
[    0.000000]   DMA zone: 21 pages reserved
[    0.000000]   DMA zone: 3995 pages, LIFO batch:0
[    0.000000]   DMA32 zone: 6726 pages used for memmap
[    0.000000]   DMA32 zone: 430430 pages, LIFO batch:31
[    0.000000]   Normal zone: 24544 pages used for memmap
[    0.000000]   Normal zone: 1570816 pages, LIFO batch:31
[    0.000000] Reserving Intel graphics memory at 0x000000007b800000-0x000000007f7fffff
[    0.000000] ACPI: PM-Timer IO Port: 0x1808
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[    0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[    0.000000] smpboot: Allowing 8 CPUs, 0 hotplug CPUs
[    0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.000000] PM: Registered nosave memory: [mem 0x0009c000-0x0009cfff]
[    0.000000] PM: Registered nosave memory: [mem 0x0009d000-0x0009ffff]
[    0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[    0.000000] PM: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[    0.000000] PM: Registered nosave memory: [mem 0x6a15e000-0x6a15efff]
[    0.000000] PM: Registered nosave memory: [mem 0x6a15f000-0x78652fff]
[    0.000000] PM: Registered nosave memory: [mem 0x78653000-0x78694fff]
[    0.000000] PM: Registered nosave memory: [mem 0x78695000-0x78ff7fff]
[    0.000000] PM: Registered nosave memory: [mem 0x78ff8000-0x795fefff]
[    0.000000] PM: Registered nosave memory: [mem 0x795ff000-0x7b7fffff]
[    0.000000] PM: Registered nosave memory: [mem 0x7b800000-0x7f7fffff]
[    0.000000] PM: Registered nosave memory: [mem 0x7f800000-0xdfffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xf0000000-0xfdffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfec01000-0xfedfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
[    0.000000] e820: [mem 0x7f800000-0xdfffffff] available for PCI devices
[    0.000000] Booting paravirtualized kernel on bare hardware
[    0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[    0.000000] random: get_random_bytes called from start_kernel+0x93/0x4d3 with crng_init=0
[    0.000000] setup_percpu: NR_CPUS:128 nr_cpumask_bits:128 nr_cpu_ids:8 nr_node_ids:1
[    0.000000] percpu: Embedded 42 pages/cpu @ffff980c7f400000 s134360 r8192 d29480 u262144
[    0.000000] pcpu-alloc: s134360 r8192 d29480 u262144 alloc=1*2097152
[    0.000000] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1973886
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1 misobasedir=manjaro misolabel=MJR17111 quiet systemd.show_status=1
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Calgary: detecting Calgary via BIOS EBDA area
[    0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[    0.000000] Memory: 7768200K/8020964K available (10252K kernel code, 1162K rwdata, 2864K rodata, 1360K init, 988K bss, 252764K reserved, 0K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] Kernel/User page tables isolation: enabled
[    0.000000] ftrace: allocating 29490 entries in 116 pages
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  RCU restricting CPUs from NR_CPUS=128 to nr_cpu_ids=8.
[    0.000000]  Tasks RCU enabled.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[    0.000000] NR_IRQS: 8448, nr_irqs: 2048, preallocated irqs: 16
[    0.000000] spurious 8259A interrupt: IRQ7.
[    0.000000] Console: colour dummy device 80x25
[    0.000000] console [tty0] enabled
[    0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
[    0.000000] hpet clockevent registered
[    0.003333] tsc: Detected 2800.000 MHz processor
[    0.003333] Calibrating delay loop (skipped), value calculated using timer frequency.. 5618.00 BogoMIPS (lpj=9360000)
[    0.003333] pid_max: default: 32768 minimum: 301
[    0.003333] ACPI: Core revision 20170728
[    0.034022] ACPI Error: [\_SB_.PCI0.XHC_.RHUB.HS11] Namespace lookup failure, AE_NOT_FOUND (20170728/dswload-210)
[    0.034029] ACPI Exception: AE_NOT_FOUND, During name lookup/catalog (20170728/psobject-252)
[    0.034062] ACPI Exception: AE_NOT_FOUND, (SSDT:xh_OEMBD) while loading table (20170728/tbxfload-228)
[    0.036297] ACPI Error: 1 table load failures, 10 successful (20170728/tbxfload-246)
[    0.036322] Security Framework initialized
[    0.036323] Yama: becoming mindful.
[    0.037530] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[    0.038099] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.038134] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.038151] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.038318] CPU: Physical Processor ID: 0
[    0.038318] CPU: Processor Core ID: 0
[    0.038323] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.038323] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[    0.038328] mce: CPU supports 10 MCE banks
[    0.038345] CPU0: Thermal monitoring enabled (TM1)
[    0.038363] process: using mwait in idle threads
[    0.038365] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[    0.038366] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[    0.038367] Spectre V2 : Mitigation: Full generic retpoline
[    0.038368] Spectre V2 : Spectre v2 mitigation: Filling RSB on context switch
[    0.038368] Spectre V2 : Spectre v2 mitigation: Enabling Indirect Branch Prediction Barrier
[    0.038368] Spectre V2 : Enabling Restricted Speculation for firmware calls
[    0.038369] Speculative Store Bypass: Vulnerable
[    0.041720] Freeing SMP alternatives memory: 24K
[    0.043414] smpboot: Max logical packages: 2
[    0.043418] DMAR: Host address width 39
[    0.043419] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[    0.043424] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
[    0.043425] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[    0.043428] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[    0.043429] DMAR: RMRR base: 0x0000007837c000 end: 0x0000007839bfff
[    0.043430] DMAR: RMRR base: 0x0000007b000000 end: 0x0000007f7fffff
[    0.043431] DMAR: ANDD device: 1 name: \_SB.PCI0.I2C0
[    0.043432] DMAR: ANDD device: 2 name: \_SB.PCI0.I2C1
[    0.043434] DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
[    0.043434] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[    0.043435] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[    0.044870] DMAR-IR: Enabled IRQ remapping in x2apic mode
[    0.044871] x2apic enabled
[    0.044881] Switched APIC routing to cluster x2apic.
[    0.049038] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.082080] TSC deadline timer enabled
[    0.082085] smpboot: CPU0: Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz (family: 0x6, model: 0x9e, stepping: 0x9)
[    0.086707] mce: [Hardware Error]: Machine check events logged
[    0.086708] mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 6: ee0000000040110a
[    0.086712] mce: [Hardware Error]: TSC 0 ADDR fef1ffc0 MISC 7880010086
[    0.086716] mce: [Hardware Error]: PROCESSOR 0:906e9 TIME 1531383026 SOCKET 0 APIC 0 microcode 84
[    0.086718] mce: [Hardware Error]: Machine check events logged
[    0.086719] mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 7: ee0000000040110a
[    0.086721] mce: [Hardware Error]: TSC 0 ADDR fef1ce40 MISC 47880010086
[    0.086725] mce: [Hardware Error]: PROCESSOR 0:906e9 TIME 1531383026 SOCKET 0 APIC 0 microcode 84
[    0.086727] mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 8: ee0000000040110a
[    0.086729] mce: [Hardware Error]: TSC 0 ADDR fef1ff40 MISC 7880010086
[    0.086733] mce: [Hardware Error]: PROCESSOR 0:906e9 TIME 1531383026 SOCKET 0 APIC 0 microcode 84
[    0.086736] mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 9: ee0000000040110a
[    0.086738] mce: [Hardware Error]: TSC 0 ADDR fef1ff00 MISC 3880010086
[    0.086741] mce: [Hardware Error]: PROCESSOR 0:906e9 TIME 1531383026 SOCKET 0 APIC 0 microcode 84
[    0.093349] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[    0.093395] ... version:                4
[    0.093395] ... bit width:              48
[    0.093396] ... generic registers:      4
[    0.093396] ... value mask:             0000ffffffffffff
[    0.093397] ... max period:             00007fffffffffff
[    0.093397] ... fixed-purpose events:   3
[    0.093398] ... event mask:             000000070000000f
[    0.100007] Hierarchical SRCU implementation.
[    0.113549] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.120006] smp: Bringing up secondary CPUs ...
[    0.146705] x86: Booting SMP configuration:
[    0.146705] .... node  #0, CPUs:      #1 #2 #3 #4 #5 #6 #7
[    0.307076] smp: Brought up 1 node, 8 CPUs
[    0.307076] smpboot: Total of 8 processors activated (44945.00 BogoMIPS)
[    0.310246] devtmpfs: initialized
[    0.310246] x86/mm: Memory block size: 128MB
[    0.310521] PM: Registering ACPI NVS region [mem 0x6a15e000-0x6a15efff] (4096 bytes)
[    0.310521] PM: Registering ACPI NVS region [mem 0x78695000-0x78ff7fff] (9842688 bytes)
[    0.310521] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.310521] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.310521] pinctrl core: initialized pinctrl subsystem
[    0.310521] RTC time:  8:10:26, date: 07/12/18
[    0.310521] NET: Registered protocol family 16
[    0.310537] cpuidle: using governor ladder
[    0.310537] cpuidle: using governor menu
[    0.310537] Simple Boot Flag at 0x47 set to 0x80
[    0.310537] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.310537] ACPI: bus type PCI registered
[    0.310537] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.310537] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.310537] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[    0.310537] PCI: Using configuration type 1 for base access
[    0.310686] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.310686] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.310686] ACPI: Added _OSI(Module Device)
[    0.310686] ACPI: Added _OSI(Processor Device)
[    0.310686] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.310686] ACPI: Added _OSI(Processor Aggregator Device)
[    0.313788] ACPI: Executed 36 blocks of module-level executable AML code
[    0.324455] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.332441] ACPI: Dynamic OEM Table Load:
[    0.332446] ACPI: SSDT 0xFFFF980C7562E000 000651 (v02 PmRef  Cpu0Ist  00003000 INTL 20160422)
[    0.332655] ACPI: Executed 1 blocks of module-level executable AML code
[    0.332717] ACPI: \_PR_.CPU0: _OSC native thermal LVT Acked
[    0.333526] ACPI: Dynamic OEM Table Load:
[    0.333531] ACPI: SSDT 0xFFFF980C75622400 0003FF (v02 PmRef  Cpu0Cst  00003001 INTL 20160422)
[    0.333726] ACPI: Executed 1 blocks of module-level executable AML code
[    0.334096] ACPI: Dynamic OEM Table Load:
[    0.334101] ACPI: SSDT 0xFFFF980C7562A000 00065C (v02 PmRef  ApIst    00003000 INTL 20160422)
[    0.334479] ACPI: Executed 1 blocks of module-level executable AML code
[    0.334663] ACPI: Dynamic OEM Table Load:
[    0.334666] ACPI: SSDT 0xFFFF980C756E6000 00018A (v02 PmRef  ApCst    00003000 INTL 20160422)
[    0.334857] ACPI: Executed 1 blocks of module-level executable AML code
[    0.337072] ACPI: EC: EC started
[    0.337073] ACPI: EC: interrupt blocked
[    0.339173] ACPI: \_SB_.PCI0.LPCB.ECDV: Used as first EC
[    0.339175] ACPI: \_SB_.PCI0.LPCB.ECDV: GPE=0x14, EC_CMD/EC_SC=0x934, EC_DATA=0x930
[    0.339176] ACPI: \_SB_.PCI0.LPCB.ECDV: Used as boot DSDT EC to handle transactions
[    0.339176] ACPI: Interpreter enabled
[    0.339216] ACPI: (supports S0 S3 S4 S5)
[    0.339217] ACPI: Using IOAPIC for interrupt routing
[    0.339249] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.339780] ACPI: Enabled 8 GPEs in block 00 to 7F
[    0.341286] ACPI: Power Resource [PG00] (on)
[    0.364182] ACPI: Power Resource [PG01] (on)
[    0.364472] ACPI: Power Resource [PG02] (on)
[    0.365990] ACPI: Power Resource [WRST] (on)
[    0.366298] ACPI: Power Resource [WRST] (on)
[    0.366601] ACPI: Power Resource [WRST] (on)
[    0.366907] ACPI: Power Resource [WRST] (on)
[    0.367209] ACPI: Power Resource [WRST] (on)
[    0.367510] ACPI: Power Resource [WRST] (on)
[    0.367816] ACPI: Power Resource [WRST] (on)
[    0.368123] ACPI: Power Resource [WRST] (on)
[    0.368425] ACPI: Power Resource [WRST] (on)
[    0.368729] ACPI: Power Resource [WRST] (on)
[    0.369059] ACPI: Power Resource [WRST] (on)
[    0.369358] ACPI: Power Resource [WRST] (on)
[    0.369658] ACPI: Power Resource [WRST] (on)
[    0.369960] ACPI: Power Resource [WRST] (on)
[    0.370265] ACPI: Power Resource [WRST] (on)
[    0.370563] ACPI: Power Resource [WRST] (on)
[    0.370862] ACPI: Power Resource [WRST] (on)
[    0.371998] ACPI: Power Resource [WRST] (on)
[    0.372299] ACPI: Power Resource [WRST] (on)
[    0.372598] ACPI: Power Resource [WRST] (on)
[    0.387097] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[    0.387103] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[    0.387132] acpi PNP0A08:00: _OSC failed (AE_ERROR); disabling ASPM
[    0.387742] PCI host bridge to bus 0000:00
[    0.387743] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.387745] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.387746] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.387747] pci_bus 0000:00: root bus resource [mem 0x7f800000-0xdfffffff window]
[    0.387748] pci_bus 0000:00: root bus resource [mem 0xfd000000-0xfe7fffff window]
[    0.387750] pci_bus 0000:00: root bus resource [bus 00-fe]
[    0.387757] pci 0000:00:00.0: [8086:5910] type 00 class 0x060000
[    0.387864] pci 0000:00:01.0: [8086:1901] type 01 class 0x060400
[    0.387901] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    0.388060] pci 0000:00:02.0: [8086:591b] type 00 class 0x030000
[    0.388070] pci 0000:00:02.0: reg 0x10: [mem 0xd4000000-0xd4ffffff 64bit]
[    0.388075] pci 0000:00:02.0: reg 0x18: [mem 0xb0000000-0xbfffffff 64bit pref]
[    0.388079] pci 0000:00:02.0: reg 0x20: [io  0xf000-0xf03f]
[    0.388201] pci 0000:00:04.0: [8086:1903] type 00 class 0x118000
[    0.388212] pci 0000:00:04.0: reg 0x10: [mem 0xd5220000-0xd5227fff 64bit]
[    0.388400] pci 0000:00:14.0: [8086:a12f] type 00 class 0x0c0330
[    0.388420] pci 0000:00:14.0: reg 0x10: [mem 0xd5210000-0xd521ffff 64bit]
[    0.388484] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.388664] pci 0000:00:14.2: [8086:a131] type 00 class 0x118000
[    0.388684] pci 0000:00:14.2: reg 0x10: [mem 0xd5238000-0xd5238fff 64bit]
[    0.388924] pci 0000:00:15.0: [8086:a160] type 00 class 0x118000
[    0.389112] pci 0000:00:15.0: reg 0x10: [mem 0xd5237000-0xd5237fff 64bit]
[    0.389999] pci 0000:00:15.1: [8086:a161] type 00 class 0x118000
[    0.390204] pci 0000:00:15.1: reg 0x10: [mem 0xd5236000-0xd5236fff 64bit]
[    0.391032] pci 0000:00:16.0: [8086:a13a] type 00 class 0x078000
[    0.391056] pci 0000:00:16.0: reg 0x10: [mem 0xd5235000-0xd5235fff 64bit]
[    0.391127] pci 0000:00:16.0: PME# supported from D3hot
[    0.391266] pci 0000:00:17.0: [8086:a103] type 00 class 0x010601
[    0.391282] pci 0000:00:17.0: reg 0x10: [mem 0xd5230000-0xd5231fff]
[    0.391289] pci 0000:00:17.0: reg 0x14: [mem 0xd5234000-0xd52340ff]
[    0.391295] pci 0000:00:17.0: reg 0x18: [io  0xf090-0xf097]
[    0.391302] pci 0000:00:17.0: reg 0x1c: [io  0xf080-0xf083]
[    0.391308] pci 0000:00:17.0: reg 0x20: [io  0xf060-0xf07f]
[    0.391315] pci 0000:00:17.0: reg 0x24: [mem 0xd5233000-0xd52337ff]
[    0.391354] pci 0000:00:17.0: PME# supported from D3hot
[    0.391482] pci 0000:00:1c.0: [8086:a114] type 01 class 0x060400
[    0.391546] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.391699] pci 0000:00:1c.5: [8086:a115] type 01 class 0x060400
[    0.391762] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
[    0.391914] pci 0000:00:1f.0: [8086:a152] type 00 class 0x060100
[    0.392132] pci 0000:00:1f.2: [8086:a121] type 00 class 0x058000
[    0.392147] pci 0000:00:1f.2: reg 0x10: [mem 0xd522c000-0xd522ffff]
[    0.392309] pci 0000:00:1f.3: [8086:a171] type 00 class 0x040380
[    0.392336] pci 0000:00:1f.3: reg 0x10: [mem 0xd5228000-0xd522bfff 64bit]
[    0.392366] pci 0000:00:1f.3: reg 0x20: [mem 0xd5200000-0xd520ffff 64bit]
[    0.392416] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[    0.392594] pci 0000:00:1f.4: [8086:a123] type 00 class 0x0c0500
[    0.392655] pci 0000:00:1f.4: reg 0x10: [mem 0xd5232000-0xd52320ff 64bit]
[    0.392725] pci 0000:00:1f.4: reg 0x20: [io  0xf040-0xf05f]
[    0.392939] pci 0000:01:00.0: [10de:1c8c] type 00 class 0x030000
[    0.392951] pci 0000:01:00.0: reg 0x10: [mem 0xd2000000-0xd2ffffff]
[    0.392957] pci 0000:01:00.0: reg 0x14: [mem 0xc0000000-0xcfffffff 64bit pref]
[    0.392963] pci 0000:01:00.0: reg 0x1c: [mem 0xd0000000-0xd1ffffff 64bit pref]
[    0.392967] pci 0000:01:00.0: reg 0x24: [io  0xe000-0xe07f]
[    0.392971] pci 0000:01:00.0: reg 0x30: [mem 0xd3000000-0xd307ffff pref]
[    0.400011] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.400014] pci 0000:00:01.0:   bridge window [io  0xe000-0xefff]
[    0.400016] pci 0000:00:01.0:   bridge window [mem 0xc0000000-0xd30fffff]
[    0.400107] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[    0.400135] pci 0000:02:00.0: reg 0x10: [io  0xd000-0xd0ff]
[    0.400159] pci 0000:02:00.0: reg 0x18: [mem 0xd5104000-0xd5104fff 64bit]
[    0.400175] pci 0000:02:00.0: reg 0x20: [mem 0xd5100000-0xd5103fff 64bit]
[    0.400263] pci 0000:02:00.0: supports D1 D2
[    0.400265] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.410034] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    0.410037] pci 0000:00:1c.0:   bridge window [io  0xd000-0xdfff]
[    0.410039] pci 0000:00:1c.0:   bridge window [mem 0xd5100000-0xd51fffff]
[    0.410145] pci 0000:03:00.0: [8086:3165] type 00 class 0x028000
[    0.410203] pci 0000:03:00.0: reg 0x10: [mem 0xd5000000-0xd5001fff 64bit]
[    0.410400] pci 0000:03:00.0: PME# supported from D0 D3hot D3cold
[    0.420054] pci 0000:00:1c.5: PCI bridge to [bus 03]
[    0.420058] pci 0000:00:1c.5:   bridge window [mem 0xd5000000-0xd50fffff]
[    0.422107] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.422174] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 *10 11 12 14 15)
[    0.422240] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.422305] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.422366] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.422427] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.422490] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.422554] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.423776] ACPI: EC: interrupt unblocked
[    0.423798] ACPI: EC: event unblocked
[    0.423821] ACPI: \_SB_.PCI0.LPCB.ECDV: GPE=0x14, EC_CMD/EC_SC=0x934, EC_DATA=0x930
[    0.423822] ACPI: \_SB_.PCI0.LPCB.ECDV: Used as boot DSDT EC to handle transactions and events
[    0.423878] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[    0.423878] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.423878] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[    0.423878] pci 0000:01:00.0: vgaarb: bridge control possible
[    0.423878] pci 0000:00:02.0: vgaarb: no bridge control possible
[    0.423878] vgaarb: loaded
[    0.423878] EDAC MC: Ver: 3.0.0
[    0.423903] PCI: Using ACPI for IRQ routing
[    0.451378] PCI: pci_cache_line_size set to 64 bytes
[    0.451499] e820: reserve RAM buffer [mem 0x0009c800-0x0009ffff]
[    0.451502] e820: reserve RAM buffer [mem 0x6a15e000-0x6bffffff]
[    0.451503] e820: reserve RAM buffer [mem 0x27f800000-0x27fffffff]
[    0.451585] NetLabel: Initializing
[    0.451585] NetLabel:  domain hash size = 128
[    0.451585] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.451599] NetLabel:  unlabeled traffic allowed by default
[    0.453728] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    0.453733] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[    0.456695] clocksource: Switched to clocksource hpet
[    0.463695] VFS: Disk quotas dquot_6.6.0
[    0.463711] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.463749] pnp: PnP ACPI init
[    0.463950] system 00:00: [io  0x0680-0x069f] has been reserved
[    0.463952] system 00:00: [io  0xffff] has been reserved
[    0.463953] system 00:00: [io  0xffff] has been reserved
[    0.463954] system 00:00: [io  0xffff] has been reserved
[    0.463956] system 00:00: [io  0x1800-0x18fe] has been reserved
[    0.463957] system 00:00: [io  0x164e-0x164f] has been reserved
[    0.463961] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.464042] system 00:01: [io  0x0800-0x087f] has been reserved
[    0.464045] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.464060] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.464087] system 00:03: [io  0x1854-0x1857] has been reserved
[    0.464089] system 00:03: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[    0.464168] pnp 00:04: Plug and Play ACPI device, IDs PNP0303 (active)
[    0.464181] pnp 00:05: Plug and Play ACPI device, IDs DLL0767 PNP0f13 (active)
[    0.464361] system 00:06: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.464362] system 00:06: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.464364] system 00:06: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.464365] system 00:06: [mem 0xe0000000-0xefffffff] has been reserved
[    0.464366] system 00:06: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.464368] system 00:06: [mem 0xfed90000-0xfed93fff] could not be reserved
[    0.464369] system 00:06: [mem 0xfed45000-0xfed8ffff] has been reserved
[    0.464370] system 00:06: [mem 0xff000000-0xffffffff] has been reserved
[    0.464372] system 00:06: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.464373] system 00:06: [mem 0xdffe0000-0xdfffffff] has been reserved
[    0.464376] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.464406] system 00:07: [mem 0xfd000000-0xfdabffff] has been reserved
[    0.464407] system 00:07: [mem 0xfdad0000-0xfdadffff] has been reserved
[    0.464408] system 00:07: [mem 0xfdb00000-0xfdffffff] has been reserved
[    0.464410] system 00:07: [mem 0xfe000000-0xfe01ffff] could not be reserved
[    0.464411] system 00:07: [mem 0xfe036000-0xfe03bfff] has been reserved
[    0.464412] system 00:07: [mem 0xfe03d000-0xfe3fffff] has been reserved
[    0.464414] system 00:07: [mem 0xfe410000-0xfe7fffff] has been reserved
[    0.464417] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.464688] system 00:08: [io  0xff00-0xfffe] has been reserved
[    0.464690] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.465719] system 00:09: [mem 0xfdaf0000-0xfdafffff] has been reserved
[    0.465721] system 00:09: [mem 0xfdae0000-0xfdaeffff] has been reserved
[    0.465722] system 00:09: [mem 0xfdac0000-0xfdacffff] has been reserved
[    0.465725] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.468065] pnp: PnP ACPI: found 10 devices
[    0.475777] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.475806] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.475808] pci 0000:00:01.0:   bridge window [io  0xe000-0xefff]
[    0.475811] pci 0000:00:01.0:   bridge window [mem 0xc0000000-0xd30fffff]
[    0.475815] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    0.475827] pci 0000:00:1c.0:   bridge window [io  0xd000-0xdfff]
[    0.475830] pci 0000:00:1c.0:   bridge window [mem 0xd5100000-0xd51fffff]
[    0.475835] pci 0000:00:1c.5: PCI bridge to [bus 03]
[    0.475838] pci 0000:00:1c.5:   bridge window [mem 0xd5000000-0xd50fffff]
[    0.475844] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.475845] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.475846] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.475848] pci_bus 0000:00: resource 7 [mem 0x7f800000-0xdfffffff window]
[    0.475849] pci_bus 0000:00: resource 8 [mem 0xfd000000-0xfe7fffff window]
[    0.475850] pci_bus 0000:01: resource 0 [io  0xe000-0xefff]
[    0.475851] pci_bus 0000:01: resource 1 [mem 0xc0000000-0xd30fffff]
[    0.475852] pci_bus 0000:02: resource 0 [io  0xd000-0xdfff]
[    0.475853] pci_bus 0000:02: resource 1 [mem 0xd5100000-0xd51fffff]
[    0.475855] pci_bus 0000:03: resource 1 [mem 0xd5000000-0xd50fffff]
[    0.475977] NET: Registered protocol family 2
[    0.476098] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[    0.476204] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[    0.476358] TCP: Hash tables configured (established 65536 bind 65536)
[    0.476384] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[    0.476404] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[    0.476446] NET: Registered protocol family 1
[    0.476457] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.477343] PCI: CLS 0 bytes, default 64
[    0.477371] Unpacking initramfs...
[    3.640295] Freeing initrd memory: 35492K
[    3.640326] DMAR: ACPI device "device:6e" under DMAR at fed91000 as 00:15.0
[    3.640329] DMAR: ACPI device "device:6f" under DMAR at fed91000 as 00:15.1
[    3.640341] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    3.640343] software IO TLB [mem 0x6615e000-0x6a15e000] (64MB) mapped at [ffff980a6615e000-ffff980a6a15dfff]
[    3.640603] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2879c5f06f2, max_idle_ns: 440795220049 ns
[    3.640871] Scanning for low memory corruption every 60 seconds
[    3.641418] Initialise system trusted keyrings
[    3.641424] Key type blacklist registered
[    3.641520] workingset: timestamp_bits=41 max_order=21 bucket_order=0
[    3.642244] zbud: loaded
[    3.644865] Key type asymmetric registered
[    3.644886] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    3.644944] io scheduler noop registered
[    3.644945] io scheduler deadline registered
[    3.644974] io scheduler cfq registered
[    3.644974] io scheduler mq-deadline registered
[    3.644975] io scheduler kyber registered
[    3.644990] io scheduler bfq registered
[    3.645005] io scheduler bfq-sq registered (default)
[    3.645005] BFQ I/O-scheduler: v8r12 (with cgroups support)
[    3.645020] io scheduler bfq-mq registered
[    3.645021] BFQ I/O-scheduler: v8r12 (with cgroups support)
[    3.645683] vesafb: mode is 1280x1024x32, linelength=5120, pages=0
[    3.645684] vesafb: scrolling: redraw
[    3.645685] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    3.645693] vesafb: framebuffer at 0xb0000000, mapped to 0xffffa55742000000, using 5120k, total 5120k
[    3.757687] Console: switching to colour frame buffer device 160x64
[    3.869628] fb0: VESA VGA frame buffer device
[    3.869640] intel_idle: MWAIT substates: 0x11142120
[    3.869641] intel_idle: v0.4.1 model 0x9E
[    3.870217] intel_idle: lapic_timer_reliable_states 0xffffffff
[    3.870606] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    3.871883] rtc_cmos 00:02: RTC can wake from S4
[    3.872316] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
[    3.872399] rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[    3.872406] intel_pstate: Intel P-state driver initializing
[    3.872435] intel_pstate: Disabling energy efficiency optimization
[    3.873280] intel_pstate: HWP enabled
[    3.873578] ledtrig-cpu: registered to indicate activity on CPUs
[    3.873619] vlv2_plat_clk vlv2_plat_clk: vlv2_plat_clk initialized
[    3.873773] NET: Registered protocol family 10
[    3.877475] Segment Routing with IPv6
[    3.877486] NET: Registered protocol family 17
[    3.878378] RAS: Correctable Errors collector initialized.
[    3.878448] microcode: sig=0x906e9, pf=0x20, revision=0x84
[    3.878784] microcode: Microcode Update Driver: v2.2.
[    3.878789] sched_clock: Marking stable (3878781411, 0)->(3882970704, -4189293)
[    3.879148] registered taskstats version 1
[    3.879152] Loading compiled-in X.509 certificates
[    3.879162] zswap: loaded using pool lzo/zbud
[    3.881983] Key type big_key registered
[    3.882827]   Magic number: 10:370:169
[    3.882858] acpi device:32: hash matches
[    3.883037] rtc_cmos 00:02: setting system clock to 2018-07-12 08:10:30 UTC (1531383030)
[    4.016115] Freeing unused kernel memory: 1360K
[    4.016116] Write protecting the kernel read-only data: 16384k
[    4.017525] Freeing unused kernel memory: 2016K
[    4.018955] Freeing unused kernel memory: 1232K
[    4.031714] loop: module loaded
[    4.034017] device-mapper: uevent: version 1.0.3
[    4.034093] device-mapper: ioctl: 4.37.0-ioctl (2017-09-20) initialised: dm-devel@redhat.com
[    4.067457] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[    4.067975] ACPI: Lid Switch [LID0]
[    4.068011] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[    4.068099] ACPI: Power Button [PBTN]
[    4.068164] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2
[    4.068175] ACPI: Sleep Button [SBTN]
[    4.068203] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[    4.068247] ACPI: Power Button [PWRF]
[    4.071831] wmi_bus wmi_bus-PNP0C14:02: WQBC data block query control method not found
[    4.073159] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[    4.073665] i8042: Warning: Keylock active
[    4.075176] serio: i8042 KBD port at 0x60,0x64 irq 1
[    4.075195] serio: i8042 AUX port at 0x60,0x64 irq 12
[    4.085871] Linux agpgart interface v0.103
[    4.089610] ACPI: bus type USB registered
[    4.089624] usbcore: registered new interface driver usbfs
[    4.089628] usbcore: registered new interface driver hub
[    4.089654] usbcore: registered new device driver usb
[    4.090989] SCSI subsystem initialized
[    4.092377] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[    4.092387] r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
[    4.095649] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    4.095655] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[    4.096818] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x00109810
[    4.096827] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[    4.097035] hub 1-0:1.0: USB hub found
[    4.097063] hub 1-0:1.0: 16 ports detected
[    4.097420] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    4.097422] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    4.097425] xhci_hcd 0000:00:14.0: Host supports USB 3.0  SuperSpeed
[    4.097538] hub 2-0:1.0: USB hub found
[    4.097555] hub 2-0:1.0: 8 ports detected
[    4.098464] libata version 3.00 loaded.
[    4.100210] ahci 0000:00:17.0: version 3.0
[    4.100513] ahci 0000:00:17.0: SSS flag set, parallel bus scan disabled
[    4.100539] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x2 impl SATA mode
[    4.100540] ahci 0000:00:17.0: flags: 64bit ncq sntf stag pm led clo only pio slum part ems deso sadm sds apst
[    4.100844] scsi host0: ahci
[    4.101030] scsi host1: ahci
[    4.101065] ata1: DUMMY
[    4.101072] ata2: SATA max UDMA/133 abar m2048@0xd5233000 port 0xd5233180 irq 123
[    4.101155] r8169 0000:02:00.0 eth0: RTL8168h/8111h at 0xffffa55740caa000, d4:81:d7:93:95:01, XID 14100800 IRQ 124
[    4.101156] r8169 0000:02:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[    4.104218] AVX2 version of gcm_enc/dec engaged.
[    4.104218] AES CTR mode by8 optimization enabled
[    4.126704] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[    4.153493] [drm] Memory usable by graphics device = 4096M
[    4.153495] checking generic (b0000000 500000) vs hw (b0000000 10000000)
[    4.153495] fb: switching to inteldrmfb from VESA VGA
[    4.153507] Console: switching to colour dummy device 80x25
[    4.153654] [drm] Replacing VGA console driver
[    4.158844] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    4.158845] [drm] Driver supports precise vblank timestamp query.
[    4.160184] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[    4.160520] [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_01.bin (v1.1)
[    4.167742] MXM: GUID detected in BIOS
[    4.167765] ACPI Warning: \_SB.PCI0.GFX0._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20170728/nsarguments-100)
[    4.167806] ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20170728/nsarguments-100)
[    4.167992] pci 0000:01:00.0: optimus capabilities: enabled, status dynamic power, hda bios codec supported
[    4.167995] VGA switcheroo: detected Optimus DSM method \_SB_.PCI0.PEG0.PEGP handle
[    4.167995] nouveau: detected PR support, will not use DSM
[    4.168009] nouveau 0000:01:00.0: enabling device (0004 -> 0007)
[    4.168140] nouveau 0000:01:00.0: NVIDIA GP107 (137000a1)
[    4.204106] nouveau 0000:01:00.0: bios: version 86.07.3c.00.60
[    4.261089] nouveau 0000:01:00.0: fb: 4096 MiB GDDR5
[    4.265659] vga_switcheroo: enabled
[    4.265755] [TTM] Zone  kernel: Available graphics memory: 3904162 kiB
[    4.265756] [TTM] Zone   dma32: Available graphics memory: 2097152 kiB
[    4.265756] [TTM] Initializing pool allocator
[    4.265760] [TTM] Initializing DMA pool allocator
[    4.265768] nouveau 0000:01:00.0: DRM: VRAM: 4096 MiB
[    4.265768] nouveau 0000:01:00.0: DRM: GART: 1048576 MiB
[    4.265770] nouveau 0000:01:00.0: DRM: BIT table 'A' not found
[    4.265771] nouveau 0000:01:00.0: DRM: BIT table 'L' not found
[    4.265772] nouveau 0000:01:00.0: DRM: TMDS table version 2.0
[    4.265773] nouveau 0000:01:00.0: DRM: DCB version 4.1
[    4.265775] nouveau 0000:01:00.0: DRM: DCB outp 00: 02022f62 00020010
[    4.265776] nouveau 0000:01:00.0: DRM: DCB conn 02: 00010261
[    4.265778] nouveau 0000:01:00.0: DRM: DCB conn 04: 01000446
[    4.265779] nouveau 0000:01:00.0: DRM: DCB conn 05: 02000546
[    4.285712] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    4.285713] [drm] Driver supports precise vblank timestamp query.
[    4.413557] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    4.416091] ata2.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[    4.416092] ata2.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[    4.416094] ata2.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[    4.426702] usb 1-1: new full-speed USB device number 2 using xhci_hcd
[    4.458218] [drm:lspcon_init [i915]] *ERROR* Failed to probe lspcon
[    4.458264] [drm:intel_modeset_init [i915]] *ERROR* LSPCON init failed on port B
[    4.516171] ata2.00: ATA-8: TOSHIBA MQ02ABD100H, HEF01D, max UDMA/100
[    4.516172] ata2.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[    4.517567] ata2.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[    4.517569] ata2.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[    4.517570] ata2.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[    4.520047] ata2.00: configured for UDMA/100
[    4.520310] scsi 1:0:0:0: Direct-Access     ATA      TOSHIBA MQ02ABD1 1D   PQ: 0 ANSI: 5
[    4.523093] sd 1:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[    4.523094] sd 1:0:0:0: [sda] 4096-byte physical blocks
[    4.523113] sd 1:0:0:0: [sda] Write Protect is off
[    4.523114] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    4.523146] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    4.524295]  sda: sda1 sda2 sda3 < sda5 sda6 sda7 >
[    4.525379] sd 1:0:0:0: [sda] Attached SCSI disk
[    4.530593] random: fast init done
[    4.574139] hidraw: raw HID events driver (C) Jiri Kosina
[    4.576250] usbcore: registered new interface driver usbhid
[    4.576251] usbhid: USB HID core driver
[    4.577174] input: Logitech G102 Prodigy Gaming Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:046D:C084.0001/input/input6
[    4.577215] hid-generic 0003:046D:C084.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech G102 Prodigy Gaming Mouse] on usb-0000:00:14.0-1/input0
[    4.577343] input: Logitech G102 Prodigy Gaming Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:046D:C084.0002/input/input7
[    4.626574] nouveau 0000:01:00.0: DRM: MM: using COPY for buffer copies
[    4.627921] [drm] Cannot find any crtc or sizes
[    4.629226] [drm] Cannot find any crtc or sizes
[    4.629243] [drm] Initialized nouveau 1.3.1 20120801 for 0000:01:00.0 on minor 1
[    4.629720] [drm] Initialized i915 1.6.0 20170818 for 0000:00:02.0 on minor 0
[    4.630801] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[    4.631805] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input8
[    4.633563] ACPI: Video Device [PEGP] (multi-head: no  rom: yes  post: no)
[    4.633584] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0a/LNXVIDEO:01/input/input9
[    4.633750] hid-generic 0003:046D:C084.0002: input,hiddev0,hidraw1: USB HID v1.11 Keyboard [Logitech G102 Prodigy Gaming Mouse] on usb-0000:00:14.0-1/input1
[    4.663444] clocksource: Switched to clocksource tsc
[    4.693580] usb 2-2: new SuperSpeed USB device number 2 using xhci_hcd
[    4.719771] usb-storage 2-2:1.0: USB Mass Storage device detected
[    4.719817] scsi host2: usb-storage 2-2:1.0
[    4.719868] usbcore: registered new interface driver usb-storage
[    4.720363] usbcore: registered new interface driver uas
[    4.833338] usb 1-4: new full-speed USB device number 3 using xhci_hcd
[    4.903673] fbcon: inteldrmfb (fb0) is primary device
[    5.096751] usb 1-12: new high-speed USB device number 4 using xhci_hcd
[    6.088627] scsi 2:0:0:0: Direct-Access     JetFlash Transcend 32GB   1100 PQ: 0 ANSI: 6
[    6.089800] sd 2:0:0:0: [sdb] 61702144 512-byte logical blocks: (31.6 GB/29.4 GiB)
[    6.090318] sd 2:0:0:0: [sdb] Write Protect is off
[    6.090322] sd 2:0:0:0: [sdb] Mode Sense: 43 00 00 00
[    6.090982] sd 2:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    6.095357]  sdb: sdb1 sdb2
[    6.097624] sd 2:0:0:0: [sdb] Attached SCSI removable disk
[    6.230949] Console: switching to colour frame buffer device 240x67
[    6.257684] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[    6.314009] ISO 9660 Extensions: RRIP_1991A
[    6.355804] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    6.450264] [drm] RC6 on
[    6.541998] overlayfs: fs on '/run/miso/sfs/livefs' does not support file handles, falling back to index=off.
[    7.302142] random: crng init done
[    7.308432] ip_tables: (C) 2000-2006 Netfilter Core Team
[    7.336805] systemd[1]: systemd 239 running in system mode. (+PAM -AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN +PCRE2 default-hierarchy=hybrid)
[    7.353636] systemd[1]: Detected architecture x86-64.
[    7.364686] systemd[1]: Set hostname to <manjaro>.
[    8.015713] systemd[1]: Reached target Swap.
[    8.017278] systemd[1]: Listening on LVM2 poll daemon socket.
[    8.017483] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    8.017563] systemd[1]: Reached target Login Prompts.
[    8.017649] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    8.017969] systemd[1]: Listening on udev Kernel Socket.
[    8.018077] systemd[1]: Listening on udev Control Socket.
[    8.183977] systemd-journald[316]: Received request to flush runtime journal from PID 1
[    8.304252] ACPI: AC Adapter [AC] (on-line)
[    8.319520] input: Intel HID events as /devices/platform/INT33D5:00/input/input10
[    8.320131] intel-hid INT33D5:00: platform supports 5 button array
[    8.320169] input: Intel HID 5 button array as /devices/platform/INT33D5:00/input/input11
[    8.334265] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    8.337714] ACPI: Battery Slot [BAT0] (battery present)
[    8.367267] (NULL device *): hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
[    8.370891] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[    8.370936] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[    8.370937] (NULL device *): hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
[    8.371473] thermal LNXTHERM:00: registered as thermal_zone7
[    8.371475] ACPI: Thermal Zone [THM] (25 C)
[    8.375169] r8169 0000:02:00.0 enp2s0: renamed from eth0
[    8.403583] input: PC Speaker as /devices/platform/pcspkr/input/input12
[    8.406216] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
[    8.406218] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[    8.406218] RAPL PMU: hw unit of domain package 2^-14 Joules
[    8.406223] RAPL PMU: hw unit of domain dram 2^-14 Joules
[    8.406224] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[    8.406224] RAPL PMU: hw unit of domain psys 2^-14 Joules
[    8.406697] intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
[    8.410227] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[    8.416802] idma64 idma64.0: Found Intel integrated DMA 64-bit
[    8.425073] dell-wmi 9DBB5994-A997-11DA-B012-B622A1EF5492: Detected Dell WMI interface version 1
[    8.425134] input: Dell WMI hotkeys as /devices/platform/PNP0C14:02/wmi_bus/wmi_bus-PNP0C14:02/9DBB5994-A997-11DA-B012-B622A1EF5492/input/input14
[    8.446270] intel-lpss 0000:00:15.1: enabling device (0000 -> 0002)
[    8.447273] idma64 idma64.1: Found Intel integrated DMA 64-bit
[    8.582324] intel_rapl: Found RAPL domain package
[    8.582325] intel_rapl: Found RAPL domain core
[    8.582326] intel_rapl: Found RAPL domain uncore
[    8.582327] intel_rapl: Found RAPL domain dram
[    8.590850] Intel(R) Wireless WiFi driver for Linux
[    8.590851] Copyright(c) 2003- 2015 Intel Corporation
[    8.891955] iTCO_vendor_support: vendor-support=0
[    8.894184] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[    8.897476] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    8.903976] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[    8.904133] iTCO_wdt: Found a Intel PCH TCO device (Version=4, TCOBASE=0x0400)
[    8.904309] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[    8.925282] input: DLL0798:00 06CB:7E92 Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-21/i2c-DLL0798:00/0018:06CB:7E92.0003/input/input16
[    8.925345] hid-multitouch 0018:06CB:7E92.0003: input,hidraw2: I2C HID v1.00 Mouse [DLL0798:00 06CB:7E92] on i2c-DLL0798:00
[    8.933042] mousedev: PS/2 mouse device common for all mice
[    8.940876] iwlwifi 0000:03:00.0: loaded firmware version 29.1044073957.0 op_mode iwlmvm
[    8.977431] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC3246: line_outs=2 (0x14/0x1b/0x0/0x0/0x0) type:speaker
[    8.977433] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    8.977434] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[    8.977434] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    8.977435] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    8.977436] snd_hda_codec_realtek hdaudioC0D0:      Headset Mic=0x19
[    8.977437] snd_hda_codec_realtek hdaudioC0D0:      Headphone Mic=0x1a
[    8.977438] snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x12
[    9.027576] iwlwifi 0000:03:00.0: Detected Intel(R) Dual Band Wireless AC 3165, REV=0x210
[    9.032885] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1f.3/sound/card0/input21
[    9.033827] input: HDA Intel PCH Headphone Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input22
[    9.045745] iwlwifi 0000:03:00.0: base HW address: 70:1c:e7:cb:86:3f
[    9.110101] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[    9.110263] (NULL device *): hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
[    9.110274] thermal thermal_zone9: failed to read out thermal zone (-61)
[    9.122686] iwlwifi 0000:03:00.0 wlp3s0: renamed from wlan0
[    9.506951] media: Linux media interface: v0.10
[    9.584222] Linux video capture interface: v2.00
[    9.624036] Bluetooth: Core ver 2.22
[    9.624051] NET: Registered protocol family 31
[    9.624052] Bluetooth: HCI device and connection manager initialized
[    9.624054] Bluetooth: HCI socket layer initialized
[    9.624056] Bluetooth: L2CAP socket layer initialized
[    9.624059] Bluetooth: SCO socket layer initialized
[    9.721296] uvcvideo: Found UVC 1.00 device Integrated_Webcam_HD (0c45:6a06)
[    9.725580] uvcvideo 1-12:1.0: Entity type for entity Extension 4 was not initialized!
[    9.725583] uvcvideo 1-12:1.0: Entity type for entity Extension 3 was not initialized!
[    9.725586] uvcvideo 1-12:1.0: Entity type for entity Processing 2 was not initialized!
[    9.725589] uvcvideo 1-12:1.0: Entity type for entity Camera 1 was not initialized!
[    9.725726] input: Integrated_Webcam_HD: Integrate as /devices/pci0000:00/0000:00:14.0/usb1/1-12/1-12:1.0/input/input23
[    9.725857] usbcore: registered new interface driver uvcvideo
[    9.725858] USB Video Class driver (1.1.1)
[    9.747103] usbcore: registered new interface driver btusb
[    9.762474] Bluetooth: hci0: read Intel version: 370810011003110e23
[    9.762475] Bluetooth: hci0: Intel device is already patched. patch num: 23
[   10.080588] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   10.080589] Bluetooth: BNEP filters: protocol multicast
[   10.080591] Bluetooth: BNEP socket layer initialized
[   10.674656] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready
[   10.746201] r8169 0000:02:00.0 enp2s0: link down
[   10.746331] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready
[   10.749108] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[   10.839733] st: Version 20160209, fixed bufsize 32768, s/g segs 256
[   10.850269] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[   10.855328] sd 1:0:0:0: Attached scsi generic sg0 type 0
[   10.855349] sd 2:0:0:0: Attached scsi generic sg1 type 0
[   10.960380] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[   11.273847] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[   21.323373] psmouse serio1: Failed to deactivate mouse on isa0060/serio1
[   21.516304] nouveau 0000:01:00.0: gr: intr 00000040
[   21.800166] psmouse serio1: Failed to enable mouse on isa0060/serio1
[   26.070352] input: PS/2 Generic Mouse as /devices/platform/i8042/serio1/input/input13
[   26.276253] psmouse serio1: Failed to enable mouse on isa0060/serio1
[   32.740165] Bluetooth: RFCOMM TTY layer initialized
[   32.740169] Bluetooth: RFCOMM socket layer initialized
[   32.740174] Bluetooth: RFCOMM ver 1.11
[   33.075637] fuse init (API version 7.26)
[   79.608441] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[   79.619412] JFS: nTxBlock = 8192, nTxLock = 65536
[   79.646628] ntfs: driver 2.1.32 [Flags: R/W MODULE].
[   79.726660] raid6: sse2x1   gen() 13545 MB/s
[   79.783320] raid6: sse2x1   xor()  9983 MB/s
[   79.839988] raid6: sse2x2   gen() 17210 MB/s
[   79.896654] raid6: sse2x2   xor() 11478 MB/s
[   79.953320] raid6: sse2x4   gen() 19885 MB/s
[   80.009988] raid6: sse2x4   xor() 12197 MB/s
[   80.066653] raid6: avx2x1   gen() 27720 MB/s
[   80.123319] raid6: avx2x1   xor() 19249 MB/s
[   80.179987] raid6: avx2x2   gen() 34395 MB/s
[   80.236653] raid6: avx2x2   xor() 21049 MB/s
[   80.293319] raid6: avx2x4   gen() 38116 MB/s
[   80.350008] raid6: avx2x4   xor() 23441 MB/s
[   80.350009] raid6: using algorithm avx2x4 gen() 38116 MB/s
[   80.350009] raid6: .... xor() 23441 MB/s, rmw enabled
[   80.350010] raid6: using avx2x2 recovery algorithm
[   80.350831] xor: automatically using best checksumming function   avx
[   80.411444] Btrfs loaded, crc32c=crc32c-intel
[   88.519633] EXT4-fs (sda5): mounted filesystem with ordered data mode. Opts: (null)
[   88.560564] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[manjaro /]#
#journalctl:
[manjaro /]# journalctl
-- Logs begin at Thu 2018-07-12 10:54:26 EEST, end at Thu 2018-07-12 10:58:20 EEST. --
Jul 12 10:54:26 oleg-DELL kernel: microcode: microcode updated early to revision 0x84, date = 2018-01-21
Jul 12 10:54:26 oleg-DELL kernel: Linux version 4.14.52-1-MANJARO (builduser@development) (gcc version 8.1.1 20180531 (GCC)) #1 SMP PREEMPT Tue Jun 26 15:24:31 UTC 2018
Jul 12 10:54:26 oleg-DELL kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-4.14-x86_64 root=UUID=e39ec421-5b13-4ef8-8013-58e096efcd93 rw quiet resume=UUID=a411b67f-ed35-49b5-87c8-c35a2664c064
Jul 12 10:54:26 oleg-DELL kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Jul 12 10:54:26 oleg-DELL kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Jul 12 10:54:26 oleg-DELL kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Jul 12 10:54:26 oleg-DELL kernel: x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
Jul 12 10:54:26 oleg-DELL kernel: x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
Jul 12 10:54:26 oleg-DELL kernel: x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
Jul 12 10:54:26 oleg-DELL kernel: x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
Jul 12 10:54:26 oleg-DELL kernel: x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
Jul 12 10:54:26 oleg-DELL kernel: x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
Jul 12 10:54:26 oleg-DELL kernel: e820: BIOS-provided physical RAM map:
Jul 12 10:54:26 oleg-DELL kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009c7ff] usable
Jul 12 10:54:26 oleg-DELL kernel: BIOS-e820: [mem 0x000000000009c800-0x000000000009ffff] reserved
Jul 12 10:54:26 oleg-DELL kernel: BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
Jul 12 10:54:26 oleg-DELL kernel: BIOS-e820: [mem 0x0000000000100000-0x000000006a15dfff] usable
Jul 12 10:54:26 oleg-DELL kernel: BIOS-e820: [mem 0x000000006a15e000-0x000000006a15efff] ACPI NVS
Jul 12 10:54:26 oleg-DELL kernel: BIOS-e820: [mem 0x000000006a15f000-0x0000000078652fff] reserved
Jul 12 10:54:26 oleg-DELL kernel: BIOS-e820: [mem 0x0000000078653000-0x0000000078694fff] ACPI data
Jul 12 10:54:26 oleg-DELL kernel: BIOS-e820: [mem 0x0000000078695000-0x0000000078ff7fff] ACPI NVS
Jul 12 10:54:26 oleg-DELL kernel: BIOS-e820: [mem 0x0000000078ff8000-0x00000000795fefff] reserved
Jul 12 10:54:26 oleg-DELL kernel: BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
Jul 12 10:54:26 oleg-DELL kernel: BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
Jul 12 10:54:26 oleg-DELL kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
Jul 12 10:54:26 oleg-DELL kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
Jul 12 10:54:26 oleg-DELL kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
Jul 12 10:54:26 oleg-DELL kernel: BIOS-e820: [mem 0x0000000100000000-0x000000027f7fffff] usable
Jul 12 10:54:26 oleg-DELL kernel: NX (Execute Disable) protection: active
Jul 12 10:54:26 oleg-DELL kernel: SMBIOS 3.0.0 present.
Jul 12 10:54:26 oleg-DELL kernel: DMI: Dell Inc. Inspiron 15 7000 Gaming/065C71, BIOS 01.00.05 03/01/2017
Jul 12 10:54:26 oleg-DELL kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Jul 12 10:54:26 oleg-DELL kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
Jul 12 10:54:26 oleg-DELL kernel: e820: last_pfn = 0x27f800 max_arch_pfn = 0x400000000
Jul 12 10:54:26 oleg-DELL kernel: MTRR default type: write-back
Jul 12 10:54:26 oleg-DELL kernel: MTRR fixed ranges enabled:
Jul 12 10:54:26 oleg-DELL kernel:   00000-9FFFF write-back
Jul 12 10:54:26 oleg-DELL kernel:   A0000-BFFFF uncachable
Jul 12 10:54:26 oleg-DELL kernel:   C0000-FFFFF write-protect
Jul 12 10:54:26 oleg-DELL kernel: MTRR variable ranges enabled:
Jul 12 10:54:26 oleg-DELL kernel:   0 base 0080000000 mask 7F80000000 uncachable
Jul 12 10:54:26 oleg-DELL kernel:   1 base 007C000000 mask 7FFC000000 uncachable
Jul 12 10:54:26 oleg-DELL kernel:   2 base 007B000000 mask 7FFF000000 uncachable
Jul 12 10:54:26 oleg-DELL kernel:   3 disabled
Jul 12 10:54:26 oleg-DELL kernel:   4 disabled
Jul 12 10:54:26 oleg-DELL kernel:   5 disabled
Jul 12 10:54:26 oleg-DELL kernel:   6 disabled
Jul 12 10:54:26 oleg-DELL kernel:   7 disabled
Jul 12 10:54:26 oleg-DELL kernel:   8 disabled
Jul 12 10:54:26 oleg-DELL kernel:   9 disabled
Jul 12 10:54:26 oleg-DELL kernel: x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
Jul 12 10:54:26 oleg-DELL kernel: e820: last_pfn = 0x6a15e max_arch_pfn = 0x400000000
Jul 12 10:54:26 oleg-DELL kernel: found SMP MP-table at [mem 0x000fce40-0x000fce4f] mapped at [ffffffffff200e40]
Jul 12 10:54:26 oleg-DELL kernel: Scanning 1 areas for low memory corruption
Jul 12 10:54:26 oleg-DELL kernel: Base memory trampoline at [ffff9d7740096000] 96000 size 24576
lines 1-56
Xorg.0.log
[     9.313] (--) Log file renamed from "/var/log/Xorg.pid-574.log" to "/var/log/Xorg.0.log"
[     9.315]
X.Org X Server 1.19.6
Release Date: 2017-12-20
[     9.315] X Protocol Version 11, Revision 0
[     9.315] Build Operating System: Linux 4.17.0-1-MANJARO x86_64
[     9.315] Current Operating System: Linux oleg-DELL 4.14.52-1-MANJARO #1 SMP PREEMPT Tue Jun 26 15:24:31 UTC 2018 x86_64
[     9.315] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.14-x86_64 root=UUID=e39ec421-5b13-4ef8-8013-58e096efcd93 rw quiet resume=UUID=a411b67f-ed35-49b5-87c8-c35a2664c064
[     9.315] Build Date: 20 May 2018  06:17:37PM
[     9.315]
[     9.315] Current version of pixman: 0.34.0
[     9.315] 	Before reporting problems, check http://wiki.x.org
[     9.315] Markers: (--) probed, (**) from config file, (==) default setting,
[     9.315] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jul 12 10:54:31 2018
[     9.340] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     9.340] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     9.369] (==) No Layout section.  Using the first Screen section.
[     9.369] (==) No screen section available. Using defaults.
[     9.369] (**) |-->Screen "Default Screen Section" (0)
[     9.369] (**) |   |-->Monitor "<default monitor>"
[     9.371] (==) No monitor specified for screen "Default Screen Section".
[     9.371] (==) Automatically adding devices
[     9.371] (==) Automatically enabling devices
[     9.371] (==) Automatically adding GPU devices
[     9.371] (==) Automatically binding GPU devices
[     9.371] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     9.409] (WW) The directory "/usr/share/fonts/OTF/" does not exist.
[     9.409] 	Entry deleted from font path.
[     9.409] (WW) The directory "/usr/share/fonts/Type1/" does not exist.
[     9.416] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi/".
[     9.416] 	Entry deleted from font path.
[     9.416] 	(Run 'mkfontdir' on "/usr/share/fonts/100dpi/").
[     9.416] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi/".
[     9.416] 	(Run 'mkfontdir' on "/usr/share/fonts/75dpi/").
[     9.416] (==) FontPath set to:
	/usr/share/fonts/misc/,
	/usr/share/fonts/TTF/
[     9.416] (==) ModulePath set to "/usr/lib/xorg/modules"
[     9.416] (II) The server relies on udev to provide the list of input devices.
[     9.416] (II) Loader magic: 0x5651a3ec5d40
[     9.416] (II) Module ABI versions:
[     9.416] 	X.Org ANSI C Emulation: 0.4
[     9.416] 	X.Org Video Driver: 23.0
[     9.416] 	X.Org XInput driver : 24.1
[     9.416] 	X.Org Server Extension : 10.0
[     9.417] (++) using VT number 1
[     9.417] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     9.418] (II) xfree86: Adding drm device (/dev/dri/card1)
[     9.419] (II) xfree86: Adding drm device (/dev/dri/card0)
[     9.425] (--) PCI:*(0:0:2:0) 8086:591b:1028:0798 rev 4, Mem @ 0xd4000000/16777216, 0xb0000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x????????/131072
[     9.425] (--) PCI: (0:1:0:0) 10de:1c8c:1028:0798 rev 161, Mem @ 0xd2000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[     9.425] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     9.425] (II) LoadModule: "glx"
[     9.437] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     9.514] (II) Module glx: vendor="X.Org Foundation"
[     9.514] 	compiled for 1.19.6, module version = 1.0.0
[     9.514] 	ABI class: X.Org Server Extension, version 10.0
[     9.514] (==) Matched intel as autoconfigured driver 0
[     9.514] (==) Matched nouveau as autoconfigured driver 1
[     9.514] (==) Matched nv as autoconfigured driver 2
[     9.514] (==) Matched intel as autoconfigured driver 3
[     9.514] (==) Matched modesetting as autoconfigured driver 4
[     9.514] (==) Matched fbdev as autoconfigured driver 5
[     9.514] (==) Matched vesa as autoconfigured driver 6
[     9.514] (==) Assigned the driver to the xf86ConfigLayout
[     9.514] (II) LoadModule: "intel"
[     9.514] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[     9.599] (II) Module intel: vendor="X.Org Foundation"
[     9.599] 	compiled for 1.19.6, module version = 2.99.917
[     9.599] 	Module class: X.Org Video Driver
[     9.599] 	ABI class: X.Org Video Driver, version 23.0
[     9.599] (II) LoadModule: "nouveau"
[     9.599] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[     9.608] (II) Module nouveau: vendor="X.Org Foundation"
[     9.608] 	compiled for 1.19.3, module version = 1.0.15
[     9.608] 	Module class: X.Org Video Driver
[     9.608] 	ABI class: X.Org Video Driver, version 23.0
[     9.608] (II) LoadModule: "nv"
[     9.609] (WW) Warning, couldn't open module nv
[     9.609] (II) UnloadModule: "nv"
[     9.609] (II) Unloading nv
[     9.609] (EE) Failed to load module "nv" (module does not exist, 0)
[     9.609] (II) LoadModule: "modesetting"
[     9.609] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[     9.616] (II) Module modesetting: vendor="X.Org Foundation"
[     9.616] 	compiled for 1.19.6, module version = 1.19.6
[     9.616] 	Module class: X.Org Video Driver
[     9.616] 	ABI class: X.Org Video Driver, version 23.0
[     9.616] (II) LoadModule: "fbdev"
[     9.616] (WW) Warning, couldn't open module fbdev
[     9.616] (II) UnloadModule: "fbdev"
[     9.616] (II) Unloading fbdev
[     9.616] (EE) Failed to load module "fbdev" (module does not exist, 0)
[     9.616] (II) LoadModule: "vesa"
[     9.616] (WW) Warning, couldn't open module vesa
[     9.616] (II) UnloadModule: "vesa"
[     9.617] (II) Unloading vesa
[     9.617] (EE) Failed to load module "vesa" (module does not exist, 0)
[     9.617] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
	i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
	915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
	Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
	GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[     9.617] (II) intel: Driver for Intel(R) HD Graphics
[     9.617] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[     9.617] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[     9.617] (II) NOUVEAU driver
[     9.617] (II) NOUVEAU driver for NVIDIA chipset families :
[     9.617] 	RIVA TNT        (NV04)
[     9.617] 	RIVA TNT2       (NV05)
[     9.617] 	GeForce 256     (NV10)
[     9.617] 	GeForce 2       (NV11, NV15)
[     9.617] 	GeForce 4MX     (NV17, NV18)
[     9.617] 	GeForce 3       (NV20)
[     9.618] 	GeForce 4Ti     (NV25, NV28)
[     9.618] 	GeForce FX      (NV3x)
[     9.618] 	GeForce 6       (NV4x)
[     9.618] 	GeForce 7       (G7x)
[     9.618] 	GeForce 8       (G8x)
[     9.618] 	GeForce GTX 200 (NVA0)
[     9.618] 	GeForce GTX 400 (NVC0)
[     9.618] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[     9.630] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20170818
[     9.630] (II) intel(0): SNA compiled from 2.99.917-829-gd7dfab62
[     9.651] (WW) Falling back to old probe method for modesetting
[     9.651] (II) [drm] nouveau interface version: 1.3.1
[     9.652] (--) intel(0): gen9 engineering sample
[     9.652] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx, avx2; using a maximum of 4 threads
[     9.652] (II) intel(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[     9.652] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[     9.652] (==) intel(0): RGB weight 888
[     9.652] (==) intel(0): Default visual is TrueColor
[     9.653] (II) intel(0): Output eDP1 has no monitor section
[     9.654] (**) intel(0): Found backlight control interface intel_backlight (type 'raw') for output eDP1
[     9.654] (II) intel(0): Enabled output eDP1
[     9.654] (II) intel(0): Output DP1 has no monitor section
[     9.654] (II) intel(0): Enabled output DP1
[     9.654] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[     9.654] (II) intel(0): Output VIRTUAL1 has no monitor section
[     9.654] (II) intel(0): Enabled output VIRTUAL1
[     9.654] (--) intel(0): Output eDP1 using initial mode 1920x1080 on pipe 0
[     9.655] (==) intel(0): TearFree enabled
[     9.655] (==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
[     9.655] (==) intel(0): DPI set to (96, 96)
[     9.655] (II) Loading sub module "dri3"
[     9.655] (II) LoadModule: "dri3"
[     9.655] (II) Module "dri3" already built-in
[     9.655] (II) Loading sub module "dri2"
[     9.655] (II) LoadModule: "dri2"
[     9.655] (II) Module "dri2" already built-in
[     9.655] (II) Loading sub module "present"
[     9.655] (II) LoadModule: "present"
[     9.655] (II) Module "present" already built-in
[     9.655] (--) NOUVEAU(G0): Chipset: "NVIDIA NV137"
[     9.655] (==) NOUVEAU(G0): Depth 24, (--) framebuffer bpp 32
[     9.655] (==) NOUVEAU(G0): RGB weight 888
[     9.655] (==) NOUVEAU(G0): Default visual is TrueColor
[     9.655] (==) NOUVEAU(G0): Using HW cursor
[     9.655] (==) NOUVEAU(G0): Allowed maximum DRI level 2.
[     9.655] (==) NOUVEAU(G0): GLX sync to VBlank enabled.
[     9.655] (==) NOUVEAU(G0): Page flipping enabled
[     9.655] (==) NOUVEAU(G0): Swap limit set to 1 [Max allowed 2]
[     9.655] (==) NOUVEAU(G0): Page flipping synced to vblank by kernel.
[     9.655] (II) NOUVEAU(G0): Initializing outputs ...
[     9.656] (II) NOUVEAU(G0): Output HDMI-1-1 has no monitor section
[     9.656] (II) NOUVEAU(G0): 1 crtcs needed for screen.
[     9.699] (II) NOUVEAU(G0): Allocated crtc nr. 0 to this screen.
[     9.699] (II) NOUVEAU(G0): Allocated crtc nr. 1 to this screen.
[     9.699] (II) NOUVEAU(G0): Allocated crtc nr. 2 to this screen.
[     9.699] (II) NOUVEAU(G0): Allocated crtc nr. 3 to this screen.
[     9.700] (II) NOUVEAU(G0): EDID for output HDMI-1-1
[     9.700] (==) NOUVEAU(G0): Using gamma correction (1.0, 1.0, 1.0)
[     9.700] (--) NOUVEAU(G0): Virtual size is 1024x768 (pitch 0)
[     9.700] (**) NOUVEAU(G0):  Mode "1920x1080": 173.0 MHz (scaled from 0.0 MHz), 67.2 kHz, 60.0 Hz
[     9.700] (II) NOUVEAU(G0): Modeline "1920x1080"x60.0  173.00  1920 2048 2248 2576  1080 1083 1088 1120 -hsync +vsync (67.2 kHz)
[     9.700] (==) NOUVEAU(G0): DPI set to (96, 96)
[     9.700] (II) Loading sub module "fb"
[     9.700] (II) LoadModule: "fb"
[     9.700] (II) Loading /usr/lib/xorg/modules/libfb.so
[     9.725] (II) Module fb: vendor="X.Org Foundation"
[     9.725] 	compiled for 1.19.6, module version = 1.0.0
[     9.725] 	ABI class: X.Org ANSI C Emulation, version 0.4
[     9.725] (II) Loading sub module "shadowfb"
[     9.725] (II) LoadModule: "shadowfb"
[     9.725] (II) Loading /usr/lib/xorg/modules/libshadowfb.so
[     9.731] (II) Module shadowfb: vendor="X.Org Foundation"
[     9.731] 	compiled for 1.19.6, module version = 1.0.0
[     9.731] 	ABI class: X.Org ANSI C Emulation, version 0.4
[     9.731] (II) UnloadModule: "modesetting"
[     9.731] (II) Unloading modesetting
[     9.731] (==) Depth 24 pixmap format is 32 bpp
[    11.895] (EE) NOUVEAU(G0): Failed to initialise context object: 2D_NVC0 (0)
[    11.895] (EE) NOUVEAU(G0): Error initialising acceleration.  Falling back to NoAccel
[    11.895] (**) NOUVEAU(G0): [COPY] acceleration disabled
[    15.965] (II) NOUVEAU(G0): Hardware support for Present enabled
[    15.965] (==) NOUVEAU(G0): Backing store enabled
[    15.965] (==) NOUVEAU(G0): Silken mouse enabled
[    15.965] (==) NOUVEAU(G0): DPMS enabled
[    15.965] (II) NOUVEAU(G0): RandR 1.2 enabled, ignore the following RandR disabled message.
[    16.005] (II) intel(0): SNA initialized with Kabylake (gen9) backend
[    16.005] (==) intel(0): Backing store enabled
[    16.005] (==) intel(0): Silken mouse enabled
[    16.005] (II) intel(0): HW Cursor enabled
[    16.005] (II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[    16.005] (==) intel(0): DPMS enabled
[    16.006] (==) intel(0): Display hotplug detection enabled
[    16.006] (II) intel(0): [DRI2] Setup complete
[    16.006] (II) intel(0): [DRI2]   DRI driver: i965
[    16.006] (II) intel(0): [DRI2]   VDPAU driver: va_gl
[    16.006] (II) intel(0): direct rendering: DRI2 DRI3 enabled
[    16.006] (II) intel(0): hardware support for Present enabled
[    16.006] (--) RandR disabled
[    16.261] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[    16.261] (II) AIGLX: enabled GLX_ARB_create_context
[    16.261] (II) AIGLX: enabled GLX_ARB_create_context_profile
[    16.261] (II) AIGLX: enabled GLX_EXT_create_context_es{,2}_profile
[    16.261] (II) AIGLX: enabled GLX_INTEL_swap_event
[    16.261] (II) AIGLX: enabled GLX_SGI_swap_control
[    16.261] (II) AIGLX: enabled GLX_EXT_framebuffer_sRGB
[    16.261] (II) AIGLX: enabled GLX_ARB_fbconfig_float
[    16.261] (II) AIGLX: enabled GLX_EXT_fbconfig_packed_float
[    16.261] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
[    16.261] (II) AIGLX: enabled GLX_ARB_create_context_robustness
[    16.261] (II) AIGLX: Loaded and initialized i965
[    16.261] (II) GLX: Initialized DRI2 GL provider for screen 0
[    20.266] (II) NOUVEAU(G0): NVEnterVT is called.
[    20.371] (II) intel(0): switch to mode 1920x1080@60.0 on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none
[    20.387] (II) intel(0): Setting screen physical size to 508 x 285
[    20.669] (II) config/udev: Adding input device Power Button (/dev/input/event8)
[    20.669] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    20.669] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    20.669] (**) Power Button: Applying InputClass "system-keyboard"
[    20.669] (II) LoadModule: "libinput"
[    20.669] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    20.683] (II) Module libinput: vendor="X.Org Foundation"
[    20.683] 	compiled for 1.19.6, module version = 0.27.1
[    20.683] 	Module class: X.Org XInput Driver
[    20.683] 	ABI class: X.Org XInput driver, version 24.1
[    20.683] (II) Using input driver 'libinput' for 'Power Button'
[    20.683] (**) Power Button: always reports core events
[    20.683] (**) Option "Device" "/dev/input/event8"
[    20.691] (**) Option "_source" "server/udev"
[    20.692] (II) event8  - Power Button: is tagged by udev as: Keyboard
[    20.692] (II) event8  - Power Button: device is a keyboard
[    20.692] (II) event8  - Power Button: device removed
[    20.710] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input9/event8"
[    20.710] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    20.710] (**) Option "xkb_model" "pc105"
[    20.710] (**) Option "xkb_layout" "us"
[    20.710] (II) event8  - Power Button: is tagged by udev as: Keyboard
[    20.710] (II) event8  - Power Button: device is a keyboard
[    20.710] (II) config/udev: Adding input device Video Bus (/dev/input/event13)
[    20.710] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    20.710] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    20.710] (**) Video Bus: Applying InputClass "system-keyboard"
[    20.710] (II) Using input driver 'libinput' for 'Video Bus'
[    20.710] (**) Video Bus: always reports core events
[    20.710] (**) Option "Device" "/dev/input/event13"
[    20.710] (**) Option "_source" "server/udev"
[    20.710] (II) event13 - Video Bus: is tagged by udev as: Keyboard
[    20.710] (II) event13 - Video Bus: device is a keyboard
[    20.710] (II) event13 - Video Bus: device removed
[    20.750] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input20/event13"
[    20.750] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[    20.750] (**) Option "xkb_model" "pc105"
[    20.750] (**) Option "xkb_layout" "us"
[    20.750] (II) event13 - Video Bus: is tagged by udev as: Keyboard
[    20.750] (II) event13 - Video Bus: device is a keyboard
[    20.750] (II) config/udev: Adding input device Video Bus (/dev/input/event14)
[    20.750] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    20.750] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    20.750] (**) Video Bus: Applying InputClass "system-keyboard"
[    20.750] (II) Using input driver 'libinput' for 'Video Bus'
[    20.750] (**) Video Bus: always reports core events
[    20.750] (**) Option "Device" "/dev/input/event14"
[    20.750] (**) Option "_source" "server/udev"
[    20.750] (II) event14 - Video Bus: is tagged by udev as: Keyboard
[    20.750] (II) event14 - Video Bus: device is a keyboard
[    20.750] (II) event14 - Video Bus: device removed
[    20.800] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0a/LNXVIDEO:01/input/input21/event14"
[    20.800] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[    20.800] (**) Option "xkb_model" "pc105"
[    20.800] (**) Option "xkb_layout" "us"
[    20.800] (II) event14 - Video Bus: is tagged by udev as: Keyboard
[    20.800] (II) event14 - Video Bus: device is a keyboard
[    20.800] (II) config/udev: Adding input device Power Button (/dev/input/event6)
[    20.800] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    20.800] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    20.800] (**) Power Button: Applying InputClass "system-keyboard"
[    20.800] (II) Using input driver 'libinput' for 'Power Button'
[    20.800] (**) Power Button: always reports core events
[    20.800] (**) Option "Device" "/dev/input/event6"
[    20.800] (**) Option "_source" "server/udev"
[    20.801] (II) event6  - Power Button: is tagged by udev as: Keyboard
[    20.801] (II) event6  - Power Button: device is a keyboard
[    20.801] (II) event6  - Power Button: device removed
[    20.820] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input7/event6"
[    20.820] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[    20.820] (**) Option "xkb_model" "pc105"
[    20.820] (**) Option "xkb_layout" "us"
[    20.820] (II) event6  - Power Button: is tagged by udev as: Keyboard
[    20.820] (II) event6  - Power Button: device is a keyboard
[    20.820] (II) config/udev: Adding input device Lid Switch (/dev/input/event5)
[    20.820] (II) No input driver specified, ignoring this device.
[    20.820] (II) This device may have been added with another device file.
[    20.821] (II) config/udev: Adding input device Sleep Button (/dev/input/event7)
[    20.821] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[    20.821] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[    20.821] (**) Sleep Button: Applying InputClass "system-keyboard"
[    20.821] (II) Using input driver 'libinput' for 'Sleep Button'
[    20.821] (**) Sleep Button: always reports core events
[    20.821] (**) Option "Device" "/dev/input/event7"
[    20.821] (**) Option "_source" "server/udev"
[    20.821] (II) event7  - Sleep Button: is tagged by udev as: Keyboard
[    20.821] (II) event7  - Sleep Button: device is a keyboard
[    20.821] (II) event7  - Sleep Button: device removed
[    20.840] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input8/event7"
[    20.840] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 10)
[    20.840] (**) Option "xkb_model" "pc105"
[    20.840] (**) Option "xkb_layout" "us"
[    20.840] (II) event7  - Sleep Button: is tagged by udev as: Keyboard
[    20.840] (II) event7  - Sleep Button: device is a keyboard
[    20.842] (II) config/udev: Adding input device Logitech G102 Prodigy Gaming Mouse (/dev/input/event1)
[    20.842] (**) Logitech G102 Prodigy Gaming Mouse: Applying InputClass "evdev pointer catchall"
[    20.842] (**) Logitech G102 Prodigy Gaming Mouse: Applying InputClass "libinput pointer catchall"
[    20.842] (II) Using input driver 'libinput' for 'Logitech G102 Prodigy Gaming Mouse'
[    20.842] (**) Logitech G102 Prodigy Gaming Mouse: always reports core events
[    20.842] (**) Option "Device" "/dev/input/event1"
[    20.842] (**) Option "_source" "server/udev"
[    20.897] (II) event1  - Logitech G102 Prodigy Gaming Mouse: is tagged by udev as: Mouse
[    20.897] (II) event1  - Logitech G102 Prodigy Gaming Mouse: device is a pointer
[    20.897] (II) event1  - Logitech G102 Prodigy Gaming Mouse: device removed
[    20.933] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:046D:C084.0001/input/input2/event1"
[    20.933] (II) XINPUT: Adding extended input device "Logitech G102 Prodigy Gaming Mouse" (type: MOUSE, id 11)
[    20.933] (**) Option "AccelerationScheme" "none"
[    20.933] (**) Logitech G102 Prodigy Gaming Mouse: (accel) selected scheme none/0
[    20.933] (**) Logitech G102 Prodigy Gaming Mouse: (accel) acceleration factor: 2.000
[    20.933] (**) Logitech G102 Prodigy Gaming Mouse: (accel) acceleration threshold: 4
[    20.990] (II) event1  - Logitech G102 Prodigy Gaming Mouse: is tagged by udev as: Mouse
[    20.991] (II) event1  - Logitech G102 Prodigy Gaming Mouse: device is a pointer
[    20.992] (II) config/udev: Adding input device Logitech G102 Prodigy Gaming Mouse (/dev/input/mouse0)
[    20.992] (II) No input driver specified, ignoring this device.
[    20.992] (II) This device may have been added with another device file.
[    20.993] (II) config/udev: Adding input device Logitech G102 Prodigy Gaming Mouse (/dev/input/event2)
[    20.993] (**) Logitech G102 Prodigy Gaming Mouse: Applying InputClass "evdev keyboard catchall"
[    20.993] (**) Logitech G102 Prodigy Gaming Mouse: Applying InputClass "libinput keyboard catchall"
[    20.993] (**) Logitech G102 Prodigy Gaming Mouse: Applying InputClass "system-keyboard"
[    20.993] (II) Using input driver 'libinput' for 'Logitech G102 Prodigy Gaming Mouse'
[    20.993] (**) Logitech G102 Prodigy Gaming Mouse: always reports core events
[    20.993] (**) Option "Device" "/dev/input/event2"
[    20.993] (**) Option "_source" "server/udev"
[    20.994] (II) event2  - Logitech G102 Prodigy Gaming Mouse: is tagged by udev as: Keyboard
[    20.994] (II) event2  - Logitech G102 Prodigy Gaming Mouse: device is a keyboard
[    20.994] (II) event2  - Logitech G102 Prodigy Gaming Mouse: device removed
[    21.016] (II) libinput: Logitech G102 Prodigy Gaming Mouse: needs a virtual subdevice
[    21.017] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:046D:C084.0002/input/input3/event2"
[    21.017] (II) XINPUT: Adding extended input device "Logitech G102 Prodigy Gaming Mouse" (type: MOUSE, id 12)
[    21.017] (**) Option "AccelerationScheme" "none"
[    21.017] (**) Logitech G102 Prodigy Gaming Mouse: (accel) selected scheme none/0
[    21.017] (**) Logitech G102 Prodigy Gaming Mouse: (accel) acceleration factor: 2.000
[    21.017] (**) Logitech G102 Prodigy Gaming Mouse: (accel) acceleration threshold: 4
[    21.018] (II) event2  - Logitech G102 Prodigy Gaming Mouse: is tagged by udev as: Keyboard
[    21.018] (II) event2  - Logitech G102 Prodigy Gaming Mouse: device is a keyboard
[    21.019] (II) config/udev: Adding input device Integrated_Webcam_HD: Integrate (/dev/input/event12)
[    21.019] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "evdev keyboard catchall"
[    21.019] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "libinput keyboard catchall"
[    21.019] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "system-keyboard"
[    21.019] (II) Using input driver 'libinput' for 'Integrated_Webcam_HD: Integrate'
[    21.019] (**) Integrated_Webcam_HD: Integrate: always reports core events
[    21.019] (**) Option "Device" "/dev/input/event12"
[    21.019] (**) Option "_source" "server/udev"
[    21.020] (II) event12 - Integrated_Webcam_HD: Integrate: is tagged by udev as: Keyboard
[    21.020] (II) event12 - Integrated_Webcam_HD: Integrate: device is a keyboard
[    21.020] (II) event12 - Integrated_Webcam_HD: Integrate: device removed
[    21.066] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-12/1-12:1.0/input/input19/event12"
[    21.066] (II) XINPUT: Adding extended input device "Integrated_Webcam_HD: Integrate" (type: KEYBOARD, id 13)
[    21.066] (**) Option "xkb_model" "pc105"
[    21.066] (**) Option "xkb_layout" "us"
[    21.068] (II) event12 - Integrated_Webcam_HD: Integrate: is tagged by udev as: Keyboard
[    21.068] (II) event12 - Integrated_Webcam_HD: Integrate: device is a keyboard
[    21.069] (II) config/udev: Adding input device DLL0798:00 06CB:7E92 Touchpad (/dev/input/event11)
[    21.069] (**) DLL0798:00 06CB:7E92 Touchpad: Applying InputClass "evdev touchpad catchall"
[    21.069] (**) DLL0798:00 06CB:7E92 Touchpad: Applying InputClass "libinput touchpad catchall"
[    21.069] (II) Using input driver 'libinput' for 'DLL0798:00 06CB:7E92 Touchpad'
[    21.069] (**) DLL0798:00 06CB:7E92 Touchpad: always reports core events
[    21.069] (**) Option "Device" "/dev/input/event11"
[    21.069] (**) Option "_source" "server/udev"
[    21.070] (II) event11 - DLL0798:00 06CB:7E92 Touchpad: is tagged by udev as: Touchpad
[    21.070] (II) event11 - DLL0798:00 06CB:7E92 Touchpad: device is a touchpad
[    21.070] (II) event11 - DLL0798:00 06CB:7E92 Touchpad: device removed
[    21.116] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-DLL0798:00/0018:06CB:7E92.0003/input/input14/event11"
[    21.117] (II) XINPUT: Adding extended input device "DLL0798:00 06CB:7E92 Touchpad" (type: TOUCHPAD, id 14)
[    21.117] (**) Option "AccelerationScheme" "none"
[    21.117] (**) DLL0798:00 06CB:7E92 Touchpad: (accel) selected scheme none/0
[    21.117] (**) DLL0798:00 06CB:7E92 Touchpad: (accel) acceleration factor: 2.000
[    21.117] (**) DLL0798:00 06CB:7E92 Touchpad: (accel) acceleration threshold: 4
[    21.118] (II) event11 - DLL0798:00 06CB:7E92 Touchpad: is tagged by udev as: Touchpad
[    21.118] (II) event11 - DLL0798:00 06CB:7E92 Touchpad: device is a touchpad
[    21.120] (II) config/udev: Adding input device DLL0798:00 06CB:7E92 Touchpad (/dev/input/mouse1)
[    21.120] (II) No input driver specified, ignoring this device.
[    21.120] (II) This device may have been added with another device file.
[    21.120] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event15)
[    21.121] (II) config/udev: Adding input device HDA Intel PCH Headphone Mic (/dev/input/event16)
[    21.121] (II) No input driver specified, ignoring this device.
[    21.121] (II) This device may have been added with another device file.
[    21.122] (II) config/udev: Adding input device Intel HID events (/dev/input/event3)
[    21.122] (**) Intel HID events: Applying InputClass "evdev keyboard catchall"
[    21.122] (**) Intel HID events: Applying InputClass "libinput keyboard catchall"
[    21.122] (**) Intel HID events: Applying InputClass "system-keyboard"
[    21.122] (II) Using input driver 'libinput' for 'Intel HID events'
[    21.122] (**) Intel HID events: always reports core events
[    21.122] (**) Option "Device" "/dev/input/event3"
[    21.122] (**) Option "_source" "server/udev"
[    21.123] (II) event3  - Intel HID events: is tagged by udev as: Keyboard
[    21.123] (II) event3  - Intel HID events: device is a keyboard
[    21.123] (II) event3  - Intel HID events: device removed
[    21.146] (**) Option "config_info" "udev:/sys/devices/platform/INT33D5:00/input/input4/event3"
[    21.146] (II) XINPUT: Adding extended input device "Intel HID events" (type: KEYBOARD, id 15)
[    21.147] (**) Option "xkb_model" "pc105"
[    21.147] (**) Option "xkb_layout" "us"
[    21.148] (II) event3  - Intel HID events: is tagged by udev as: Keyboard
[    21.148] (II) event3  - Intel HID events: device is a keyboard
[    21.149] (II) config/udev: Adding input device Intel HID 5 button array (/dev/input/event4)
[    21.149] (**) Intel HID 5 button array: Applying InputClass "evdev keyboard catchall"
[    21.149] (**) Intel HID 5 button array: Applying InputClass "libinput keyboard catchall"
[    21.149] (**) Intel HID 5 button array: Applying InputClass "system-keyboard"
[    21.149] (II) Using input driver 'libinput' for 'Intel HID 5 button array'
[    21.149] (**) Intel HID 5 button array: always reports core events
[    21.149] (**) Option "Device" "/dev/input/event4"
[    21.149] (**) Option "_source" "server/udev"
[    21.149] (II) event4  - Intel HID 5 button array: is tagged by udev as: Keyboard Switch
[    21.149] (II) event4  - Intel HID 5 button array: device is a keyboard
[    21.149] (II) event4  - Intel HID 5 button array: device removed
[    21.166] (**) Option "config_info" "udev:/sys/devices/platform/INT33D5:00/input/input5/event4"
[    21.166] (II) XINPUT: Adding extended input device "Intel HID 5 button array" (type: KEYBOARD, id 16)
[    21.167] (**) Option "xkb_model" "pc105"
[    21.167] (**) Option "xkb_layout" "us"
[    21.168] (II) event4  - Intel HID 5 button array: is tagged by udev as: Keyboard Switch
[    21.168] (II) event4  - Intel HID 5 button array: device is a keyboard
[    21.169] (II) config/udev: Adding input device Dell WMI hotkeys (/dev/input/event10)
[    21.169] (**) Dell WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[    21.169] (**) Dell WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[    21.169] (**) Dell WMI hotkeys: Applying InputClass "system-keyboard"
[    21.169] (II) Using input driver 'libinput' for 'Dell WMI hotkeys'
[    21.169] (**) Dell WMI hotkeys: always reports core events
[    21.169] (**) Option "Device" "/dev/input/event10"
[    21.169] (**) Option "_source" "server/udev"
[    21.170] (II) event10 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[    21.170] (II) event10 - Dell WMI hotkeys: device is a keyboard
[    21.170] (II) event10 - Dell WMI hotkeys: device removed
[    21.216] (**) Option "config_info" "udev:/sys/devices/platform/PNP0C14:02/wmi_bus/wmi_bus-PNP0C14:02/9DBB5994-A997-11DA-B012-B622A1EF5492/input/input12/event10"
[    21.216] (II) XINPUT: Adding extended input device "Dell WMI hotkeys" (type: KEYBOARD, id 17)
[    21.216] (**) Option "xkb_model" "pc105"
[    21.216] (**) Option "xkb_layout" "us"
[    21.218] (II) event10 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[    21.218] (II) event10 - Dell WMI hotkeys: device is a keyboard
[    21.219] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
[    21.219] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[    21.219] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[    21.219] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[    21.219] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[    21.219] (**) AT Translated Set 2 keyboard: always reports core events
[    21.219] (**) Option "Device" "/dev/input/event0"
[    21.219] (**) Option "_source" "server/udev"
[    21.220] (II) event0  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[    21.220] (II) event0  - AT Translated Set 2 keyboard: device is a keyboard
[    21.220] (II) event0  - AT Translated Set 2 keyboard: device removed
[    21.246] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input0/event0"
[    21.246] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 18)
[    21.246] (**) Option "xkb_model" "pc105"
[    21.246] (**) Option "xkb_layout" "us"
[    21.248] (II) event0  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[    21.248] (II) event0  - AT Translated Set 2 keyboard: device is a keyboard
[    21.249] (II) config/udev: Adding input device PS/2 Synaptics TouchPad (/dev/input/event17)
[    21.249] (**) PS/2 Synaptics TouchPad: Applying InputClass "evdev pointer catchall"
[    21.249] (**) PS/2 Synaptics TouchPad: Applying InputClass "libinput pointer catchall"
[    21.249] (II) Using input driver 'libinput' for 'PS/2 Synaptics TouchPad'
[    21.249] (**) PS/2 Synaptics TouchPad: always reports core events
[    21.249] (**) Option "Device" "/dev/input/event17"
[    21.249] (**) Option "_source" "server/udev"
[    21.250] (II) event17 - PS/2 Synaptics TouchPad: is tagged by udev as: Mouse
[    21.250] (II) event17 - PS/2 Synaptics TouchPad: device is a pointer
[    21.250] (II) event17 - PS/2 Synaptics TouchPad: device removed
[    21.296] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input11/event17"
[    21.296] (II) XINPUT: Adding extended input device "PS/2 Synaptics TouchPad" (type: MOUSE, id 19)
[    21.297] (**) Option "AccelerationScheme" "none"
[    21.297] (**) PS/2 Synaptics TouchPad: (accel) selected scheme none/0
[    21.297] (**) PS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[    21.297] (**) PS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[    21.298] (II) event17 - PS/2 Synaptics TouchPad: is tagged by udev as: Mouse
[    21.298] (II) event17 - PS/2 Synaptics TouchPad: device is a pointer
[    21.298] (II) config/udev: Adding input device PS/2 Synaptics TouchPad (/dev/input/mouse2)
[    21.298] (II) No input driver specified, ignoring this device.
[    21.298] (II) This device may have been added with another device file.
[    21.299] (II) config/udev: Adding input device PC Speaker (/dev/input/event9)
[    21.299] (II) No input driver specified, ignoring this device.
[    21.299] (II) This device may have been added with another device file.
[    21.320] (**) Logitech G102 Prodigy Gaming Mouse: Applying InputClass "evdev keyboard catchall"
[    21.320] (**) Logitech G102 Prodigy Gaming Mouse: Applying InputClass "libinput keyboard catchall"
[    21.320] (**) Logitech G102 Prodigy Gaming Mouse: Applying InputClass "system-keyboard"
[    21.320] (II) Using input driver 'libinput' for 'Logitech G102 Prodigy Gaming Mouse'
[    21.320] (**) Logitech G102 Prodigy Gaming Mouse: always reports core events
[    21.320] (**) Option "Device" "/dev/input/event2"
[    21.320] (**) Option "_source" "_driver/libinput"
[    21.320] (II) libinput: Logitech G102 Prodigy Gaming Mouse: is a virtual subdevice
[    21.320] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:046D:C084.0002/input/input3/event2"
[    21.320] (II) XINPUT: Adding extended input device "Logitech G102 Prodigy Gaming Mouse" (type: KEYBOARD, id 20)
[    21.320] (**) Option "xkb_model" "pc105"
[    21.321] (**) Option "xkb_layout" "us"
[    21.322] (II) intel(0): EDID vendor "BOE", prod id 1721
[    21.322] (II) intel(0): Printing DDC gathered Modelines:
[    21.322] (II) intel(0): Modeline "1920x1080"x0.0  141.40  1920 1968 2000 2142  1080 1083 1089 1100 +hsync -vsync (66.0 kHz eP)
[    21.590] (II) config/udev: Adding input device PS/2 Synaptics TouchPad (/dev/input/mouse2)
[    21.590] (II) No input driver specified, ignoring this device.
[    21.590] (II) This device may have been added with another device file.
[    21.590] (II) config/udev: removing device PS/2 Synaptics TouchPad
[    21.590] (II) event17 - PS/2 Synaptics TouchPad: device removed
[    21.626] (II) UnloadModule: "libinput"
[    21.626] (II) config/udev: Adding input device PS/2 Synaptics TouchPad (/dev/input/event17)
[    21.626] (**) PS/2 Synaptics TouchPad: Applying InputClass "evdev pointer catchall"
[    21.626] (**) PS/2 Synaptics TouchPad: Applying InputClass "libinput pointer catchall"
[    21.626] (II) Using input driver 'libinput' for 'PS/2 Synaptics TouchPad'
[    21.626] (**) PS/2 Synaptics TouchPad: always reports core events
[    21.626] (**) Option "Device" "/dev/input/event17"
[    21.626] (**) Option "_source" "server/udev"
[    21.627] (II) event17 - PS/2 Synaptics TouchPad: is tagged by udev as: Mouse
[    21.627] (II) event17 - PS/2 Synaptics TouchPad: device is a pointer
[    21.627] (II) event17 - PS/2 Synaptics TouchPad: device removed
[    21.666] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input11/event17"
[    21.666] (II) XINPUT: Adding extended input device "PS/2 Synaptics TouchPad" (type: MOUSE, id 19)
[    21.666] (**) Option "AccelerationScheme" "none"
[    21.666] (**) PS/2 Synaptics TouchPad: (accel) selected scheme none/0
[    21.666] (**) PS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[    21.666] (**) PS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[    21.667] (II) event17 - PS/2 Synaptics TouchPad: is tagged by udev as: Mouse
[    21.667] (II) event17 - PS/2 Synaptics TouchPad: device is a pointer
By the way… Same thing is with ubuntu, last linux mint 19… What it can be?
