Hi,
I tried to switch from Pipewire to Pulse using the following terminal commands:
pamac remove manjaro-pipewire
pamac install manjaro-pulse
pamac install pulseaudio pulseaudio-alsa
BUT used “sudo” with all three above commands.
Currently have no audio on KDE Manjaro…
Can someone explain how to get audio back?
I still would like to use Pulse.
Thank you!
inxi --admin --verbosity=8 --filter --no-host --width
Kernel: 6.12.12-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=e6904fb9-88c7-445f-92eb-bd71124dfe33 rw quiet
cryptdevice=UUID=ea95b186-2441-4a26-bc26-1445436021f6:luks-ea95b186-2441-4a26-bc26-1445436021f6
root=/dev/mapper/luks-ea95b186-2441-4a26-bc26-1445436021f6 splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
serial: <filter> part-nu: SKU uuid: 1dc43fb0-791e-09e2-5630-50ebf6cf13b4
UEFI: American Megatrends v: 5021 date: 09/29/2024
System RAM: total: 64 GiB available: 62.71 GiB used: 5.47 GiB (8.7%)
Device-1: DIMM_A1 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 16 GiB speed: 2133 MT/s volts: curr: 1.2 min: 1.2 max: 1.2
width (bits): data: 64 total: 64 manufacturer: Corsair
part-no: CMK32GX4M2E3200C16 serial: N/A
Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
Device-3: DIMM_B1 type: DDR4 detail: synchronous unbuffered (unregistered)
Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
Slot: 0 type: PCIe status: in use length: long volts: 3.3 bus-ID: 00:03.1
children: 1: 0a:00.0 class-ID: 0300 type: display 2: 0a:00.1 class-ID: 0403
type: audio
Slot: 1 type: PCIe status: available length: long volts: 3.3
bus-ID: 00:1f.7
Slot: 2 type: PCIe status: available length: short volts: 3.3
bus-ID: 00:1f.7
Slot: 3 type: PCIe status: in use length: short volts: 3.3 bus-ID: 02:03.0
Info: model: AMD Ryzen 7 5800X socket: AM4 bits: 64 type: MT MCP arch: Zen 3+
gen: 3 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
family: 0x19 (25) model-id: 0x21 (33) stepping: 2 microcode: 0xA201210
desc: 8x512 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3584 min/max: 550/4851 boost: enabled
base/boost: 3800/4850 scaling: driver: amd-pstate-epp governor: powersave
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3584 2: 3584 3: 3584 4: 3584
5: 3584 6: 3584 7: 3584 8: 3584 9: 3584 10: 3584 11: 3584 12: 3584 13: 3584
14: 3584 15: 3584 16: 3584 bogomips: 121422
cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
affected
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate]
vendor: Micro-Star MSI driver: nvidia v: 550.144.03
alternate: nouveau,nvidia_drm non-free: 550/565.xx+ status: current (as of
2025-01; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: none off: HDMI-A-1 empty: DP-1,DP-2,DP-3
bus-ID: 0a:00.0 chip-ID: 10de:2504 class-ID: 0300
Display: unspecified server: X.Org v: 21.1.15 with: Xwayland v: 24.1.5
compositor: kwin_x11 driver: X: loaded: N/A failed: nvidia
gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 162 s-size: 602x341mm (23.70x13.43")
s-diag: 692mm (27.24")
Monitor-1: HDMI-0 res: mode: 3840x2160 hz: 60 scale: 100% (1) dpi: 163
size: 600x340mm (23.62x13.39") diag: 690mm (27.15") modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia gbm:
drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland
API: OpenGL v: 4.6.0 vendor: nvidia v: 550.144.03 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
memory: 11.72 GiB
API: Vulkan v: 1.4.303 layers: 1 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: N/A device-ID: 10de:2504
surfaces: xcb,xlib
Device-1: NVIDIA GA106 High Definition Audio vendor: Micro-Star MSI
bus-ID: 0a:00.1 chip-ID: 10de:228e class-ID: 0403
vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.12.12-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: n/a (root, process) with:
1: wireplumber status: active 2: pipewire-alsa type: plugin
tools: pw-cat,pw-cli,wpctl
Server-3: PulseAudio v: 17.0-43-g3e2bb status: active (root, process)
with: pulseaudio-alsa type: plugin tools: pacat,pactl
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 05:00.0
chip-ID: 8086:2526 class-ID: 0280
IF: wlp5s0 state: down mac: <filter>
Device-3: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp6s0 state: down mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:2
chip-ID: 8087:0025 class-ID: e001
Device-1: luks-ea95b186-2441-4a26-bc26-1445436021f6 maj-min: 254:0
type: LUKS dm: dm-0 size: 1.82 TiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 1.82 TiB
Local Storage: total: 12.73 TiB used: 396.23 GiB (3.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 38.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST12000VN0008-2YS101
size: 10.91 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: SC60 scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 396.23 GiB (21.6%)
fs: ext4 block-size: 4096 B dev: /dev/dm-0 maj-min: 254:0
mapped: luks-ea95b186-2441-4a26-bc26-1445436021f6 label: N/A
uuid: e6904fb9-88c7-445f-92eb-bd71124dfe33
used: 448 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: 7687-2945
Hub-2: 1-2:2 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 chip-ID: 045b:0209 class-ID: 0900
Hub-3: 1-2.1:4 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
Hub-4: 1-2.3:5 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
Hub-5: 1-2.3.1:7 info: Hitachi ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 045b:0209
Device-1: 1-2.3.4:8 info: Brother Industries DCP-L2550DW series
type: printer driver: usblp interfaces: 2 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 2mA
chip-ID: 04f9:0424 class-ID: 0701 serial: <filter>
Hub-6: 1-5:3 info: Terminus Hub ports: 4 rev: 2.0
chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-5.4:6 info: Realtek Mass Storage Device (Multicard Reader)
type: mass storage driver: usb-storage interfaces: 1 rev: 2.0
chip-ID: 0bda:0151 class-ID: 0806 serial: <filter>
Hub-7: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-8: 2-2:2 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 chip-ID: 045b:0210 class-ID: 0900
Hub-9: 2-2.1:3 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
Hub-10: 2-2.3:4 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
Hub-11: 2-2.3.1:5 info: Hitachi ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 045b:0210
Hub-12: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-5:2 info: Intel Wireless-AC 9260 Bluetooth Adapter
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Device-2: 3-6:3 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:18f3 class-ID: 0300
serial: <filter>
Hub-13: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-14: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-1:2 info: USB Optical Mouse type: mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 30fa:0400 class-ID: 0301
Device-2: 5-2:3 info: China Resource Semico USB Keyboard type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 500mA chip-ID: 1a2c:4094 class-ID: 0300
Hub-15: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 33.8 C mobo: N/A gpu: nvidia temp: 40 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Packages: 1545 pm: pacman pkgs: 1518 libs: 504 tools: pamac pm: rpm pkgs: 0
pm: flatpak pkgs: 27
1: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
3: https://manjaro.ynh.ovh/stable/$repo/$arch
4: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://mirror.koddos.net/manjaro/stable/$repo/$arch
8: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 385
1: cpu: 6.5% command: firefox pid: 2145 mem: 644.4 MiB (1.0%)
2: cpu: 1.9% command: firefox pid: 2312 mem: 302.3 MiB (0.4%)
3: cpu: 1.3% command: kwin_x11 pid: 1284 mem: 505.3 MiB (0.7%)
4: cpu: 1.3% command: konsole pid: 10964 mem: 183.8 MiB (0.2%)
5: cpu: 1.2% command: firefox pid: 2299 mem: 532.9 MiB (0.8%)
Memory top: 5 of 385
1: mem: 683.9 MiB (1.0%) command: plasmashell pid: 1375 cpu: 1.1%
2: mem: 644.4 MiB (1.0%) command: firefox pid: 2145 cpu: 6.5%
3: mem: 532.9 MiB (0.8%) command: firefox pid: 2299 cpu: 1.2%
4: mem: 505.3 MiB (0.7%) command: kwin_x11 pid: 1284 cpu: 1.3%
5: mem: 334.0 MiB (0.5%) command: firefox pid: 2282 cpu: 0.3%
Processes: 385 Power: uptime: 34m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25.05 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Sudo (sudo) v: 1.9.16p2
default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.37
