Like the title says.
I am on CEST (UTC+2)
Nightcolors work, but are now (in winter time witch is why I noticed it) 2 hours behind.
The times on the settings tab shows correct time, but the colors clearly are 2 hours behind.
I have dualboot window, but Idc if it breaks windows time at this point, I want to go back to “default” settings if that is what is doing this.
Is there a way make nightcolors follow CEST instead or how do I revert to linux only time, so to say?
timedatectl
Local time: Tue 2023-10-10 19:52:19 CEST
Universal time: Tue 2023-10-10 17:52:19 UTC
RTC time: Tue 2023-10-10 17:50:32
Time zone: Europe/Stockholm (CEST, +0200)
System clock synchronized: yes
NTP service: active
RTC in local TZ: yes
Warning: The system is configured to read the RTC time in the local time zone.
This mode cannot be fully supported. It will create various problems
with time zone changes and daylight saving time adjustments. The RTC
time is never updated, it relies on external facilities to maintain it.
If at all possible, use RTC in UTC by calling
'timedatectl set-local-rtc 0'.
$ inxi -Fazy ✔
Kernel: 6.5.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.5-x86_64
root=UUID=700d034d-b99a-482b-880b-9060acf3a6b3 rw rootflags=subvol=@
nvidia_drm.modeset=1 resume=UUID=5ae8fbf5-a704-41ea-be6d-bf26b38325ed
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2 dm: SDDM
Type: Desktop Mobo: Gigabyte model: X670 AORUS ELITE AX v: x.x
serial: <superuser required> UEFI: American Megatrends LLC. v: F11a
date: 07/21/2023
Info: model: AMD Ryzen 9 7900X bits: 64 type: MT MCP arch: Zen 4 gen: 5
level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
model-id: 0x61 (97) stepping: 2 microcode: 0xA601203
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 12 MiB desc: 12x1024 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 400 min/max: 400/5733 scaling: driver: amd-pstate-epp
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400 15: 400 16: 400
17: 400 18: 400 19: 400 20: 400 21: 400 22: 400 23: 400 24: 400
bogomips: 225241
Type: spec_rstack_overflow mitigation: safe RET, no microcode
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA102 [GeForce RTX 3090] vendor: eVga.com. driver: nvidia
v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-09) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-23 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: none empty: DP-1,
DP-2, DP-3, HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:2204 class-ID: 0300
Device-2: AMD Raphael vendor: Gigabyte driver: amdgpu v: kernel
arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: HDMI-A-2 empty: DP-4,DP-5,DP-6
bus-ID: 15:00.0 chip-ID: 1002:164e class-ID: 0300 temp: 51.0 C
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.2.1
compositor: kwin_x11 driver: X: loaded: amdgpu,nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: HDMI-A-2 mapped: HDMI-A-1 model: Asus VX279 serial: <filter>
built: 2015 res: 1920x1080 hz: 60 dpi: 79 gamma: 1.2
size: 621x341mm (24.45x13.43") diag: 690mm (27.2") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast surfaceless:
drv: nvidia x11: drv: radeonsi inactive: gbm,wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics
(raphael_mendocino LLVM 16.0.6 DRM 3.54 6.5.6-1-MANJARO)
device-ID: 1002:164e memory: 500 MiB unified: no
API: Vulkan v: 1.3.264 layers: 9 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3090 driver: nvidia v: 535.113.01
device-ID: 10de:2204 surfaces: xcb,xlib device: 1 type: integrated-gpu
name: AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO) driver: mesa radv
v: 23.1.9-manjaro1.1 device-ID: 1002:164e surfaces: xcb,xlib
Device-1: NVIDIA GA102 High Definition Audio vendor: eVga.com.
bus-ID: 01:00.1 chip-ID: 10de:1aef class-ID: 0403
Device-2: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 15:00.1
chip-ID: 1002:1640 class-ID: 0403
Device-3: AMD Family 17h/19h HD Audio vendor: Gigabyte
bus-ID: 15:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.5.6-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.81 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0e:00.0
IF: enp14s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 0f:00.0
chip-ID: 14c3:0616 class-ID: 0280
IF: wlp15s0 state: down mac: <filter>
Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:5 chip-ID: 0e8d:0616
Local Storage: total: 4.09 TiB used: 1.67 TiB (40.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 46.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD30EFRX-68EUZN0 size: 2.73 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
fw-rev: 0A80 scheme: GPT
ID-1: / raw-size: 122 GiB size: 122 GiB (100.00%) used: 56.07 GiB (46.0%)
fs: btrfs dev: /dev/sda7 maj-min: 8:7
used: 292 KiB (0.1%) fs: vfat dev: /dev/sda5 maj-min: 8:5
ID-3: /home raw-size: 104.53 GiB size: 104.53 GiB (100.00%)
used: 48.97 GiB (46.9%) fs: btrfs dev: /dev/sda8 maj-min: 8:8
ID-4: /var/log raw-size: 122 GiB size: 122 GiB (100.00%)
used: 56.07 GiB (46.0%) fs: btrfs dev: /dev/sda7 maj-min: 8:7
ID-1: swap-1 type: partition size: 38 GiB used: 768 KiB (0.0%) priority: -2
dev: /dev/sda6 maj-min: 8:6
System Temperatures: cpu: 76.4 C mobo: 35.0 C gpu: amdgpu temp: 52.0 C
Fan Speeds (rpm): N/A
Processes: 525 Uptime: 6h 34m wakeups: 0 Memory: total: 32 GiB note: est.
available: 30.5 GiB used: 11.09 GiB (36.3%) Init: systemd v: 254
Packages: 1551 pm: pacman pkgs: 1544 libs: 430 tools: pamac,yay pm: flatpak
pkgs: 7 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: yakuake
inxi: 3.3.30
Edit
I wasn’t sure where to put this question, if its fixable through nighcolors I guess it’s correct. If I have to configure time, I guess it should be in a completely different category. Sorry mods.
