Hi,
Running Manjaro KDE 64Bit fully updated.
How would I mount and view “img” files using a GUI?
Let me know, thanks!
Jesse
Hi,
Jesse
CD IMG
.There are several options, and I don’t want to recommend something you wouldn’t like, so explore the options yourself.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or
if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
