Hi,
After unmounting a stick with the Safely remove button I see only No devices available message. Unplugging and plugging back the stick makes no difference; only relogin helps.
Hi,
Reboot
Note the exact time up to the second
Insert stick
Click safely remove stick
Remove stick
Plug stick back in
Note the exact time again.
Provide the relevant part of the following command:
journalctl --system --boot=0 --priority=3
It’s an applet bug, actually. Inside Dolphin it all works perfectly.
