When I wake the my computer I will press the space bar to wake the computer and then once it is awake I will type in my password. What is happening with KDE is it is registering the spacebar press as a key in the password. Is there a way to disable this?
With Gnome it works as I expect, press space bar to wake the computer then enter the password. I like KDE better except for this particular feature.
In Plasma, you can start typing the password (without hitting space) and it will unlock.
Gnome seems to have an extra “lock” so you first have to activate it (maybe it’s a button, I don’t know, I don’t use Gnome) which a press of space would do.
Because sometimes operating systems lag and they miss the first key or two and then my logon fails. I use a mac as well as thats exactly what started happening. I guess I will just have to get used to it if I stay in KDE land.
