Hi, I find that many components of the interface of the Application Menu, Dolphin etc are not translated or I believe not displayed properly in Chinese (Traditional) but fallback to English. I have another laptop where the components are in Chinese. How can I identify the cause and get it solved? Thank you.
Update
Locale - ArchWiki (My system is still using wrong language) suggests that the issue can be solved by deleting ~/.config/plasma-localerc
. and it does solve the issue on my PC.
