KDE hotspot provides no internet connection
I can enable the hotspot by clicking the hotspot icon in Plasmas Networks Applet.
The hotspot allows my android/iphone to connect, but does not provide any internet connection.
But hotspot works flawlessly on my colleague’s GNOME with the same hardware and OS.
I don’t remember the exact date when this problem appeared. Probably after [Stable Update] 2022-11-14 - Kernels, GNOME 43.1, Plasma 5.26.3, Systemd 251.8, Firefox 106.0.5, Thunderbird, LXQt,
because I see @rolandd reported the same problem.
inxi -v7azy output:
  Kernel: 5.15.81-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    root=UUID=51335112-b2bd-441f-90fa-4d42349c1b07 rw acpi_backlight=vendor
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 info: latte-dock
    wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
  Type: Desktop System: Apple product: iMac12,1 v: 1.0
    serial: <superuser required> Chassis: type: 13 v: Mac-942B5BF58194151B
  Mobo: Apple model: Mac-942B5BF58194151B serial: <superuser required>
    UEFI: Apple v: 87.0.0.0.0 date: 06/14/2019
  RAM: total: 23.46 GiB used: 9.54 GiB (40.7%)
  Info: model: Intel Core i5-2400S bits: 64 type: MCP arch: Sandy Bridge
    gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
    model-id: 0x2A (42) stepping: 7 microcode: 0x2F
  Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
    desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
    desc: 1x6 MiB
  Speed (MHz): avg: 2130 high: 2196 min/max: 1600/3300 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 2138 2: 2132 3: 2054
    4: 2196 bogomips: 20009
  Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
    constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts ept est
    flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce
    md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
    pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdtscp rep_good
    sep smx ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
    tsc tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology
    xtpr
    disabled
    prctl and seccomp
    STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
    driver: i915 v: kernel arch: Gen-6 process: Intel 32nm built: 2011 ports:
    active: none empty: VGA-2 bus-ID: 00:02.0 chip-ID: 8086:0102 class-ID: 0380
  Device-2: AMD Whistler [Radeon HD 6630M/6650M/6750M/7670M/7690M]
    vendor: Apple driver: radeon v: kernel arch: TeraScale-2 code: Evergreen
    process: TSMC 32-40nm built: 2009-15 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 2 speed: 5 GT/s ports: active: DP-1,eDP-1
    empty: DP-2,DP-3,VGA-1 bus-ID: 01:00.0 chip-ID: 1002:6741 class-ID: 0300
  Device-3: Apple FaceTime HD Camera (Built-in) type: USB driver: uvcvideo
    bus-ID: 1-2:3 chip-ID: 05ac:850b class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
    loaded: modesetting,radeon alternate: fbdev,vesa dri: r600,crocus gpu: radeon
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2970x1680 s-dpi: 96 s-size: 783x443mm (30.83x17.44")
    s-diag: 900mm (35.42")
  Monitor-1: DP-1 mapped: DisplayPort-0 pos: top-left model: Dell E2210
    serial: <filter> built: 2009 res: 1050x1680 hz: 60 dpi: 90 gamma: 1.2
    size: 296x473mm (11.65x18.62") diag: 558mm (22") ratio: 16:10 modes:
    max: 1680x1050 min: 720x400
  Monitor-2: eDP-1 mapped: eDP pos: primary,bottom-r model: Apple iMac
    built: 2010 res: 1920x1080 hz: 60 dpi: 103 gamma: 1.2
    size: 475x267mm (18.7x10.51") diag: 545mm (21.5") ratio: 16:9 modes:
    max: 1920x1080 min: 640x480
  API: OpenGL v: 3.3 Mesa 22.2.4 renderer: AMD TURKS (DRM 2.50.0 /
    5.15.81-1-MANJARO LLVM 14.0.6) compat-v: 3.1 direct render: Yes
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20
    class-ID: 0403
  Device-2: AMD Turks HDMI Audio [Radeon HD 6500/6600 / 6700M Series]
    vendor: Apple driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 16 link-max: gen: 2 speed: 5 GT/s bus-ID: 01:00.1 chip-ID: 1002:aa90
    class-ID: 0403
  Sound API: ALSA v: k5.15.81-1-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.61 running: yes
  Device-1: Broadcom NetXtreme BCM57765 Gigabit Ethernet PCIe driver: tg3
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 02:00.0
    chip-ID: 14e4:16b4 class-ID: 0200
  IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Qualcomm Atheros AR93xx Wireless Network Adapter
    vendor: Apple AirPort Extreme driver: ath9k v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0030 class-ID: 0280
  IF-ID-1: br-1a8510ac685e state: down mac: <filter>
  IF-ID-2: br-5233f8588a94 state: down mac: <filter>
  Message: Output throttled. IPs: 1; Limit: 10; Override: --limit [1-x;-1
    all]
  IF-ID-3: br-ce7c6cb8d150 state: down mac: <filter>
    all]
  IF-ID-4: docker0 state: down mac: <filter>
    all]
  Device-1: Apple Built-in Bluetooth 2.0+EDR HCI type: USB driver: btusb v: 0.8
    bus-ID: 1-1.1.1:6 chip-ID: 05ac:8215 class-ID: fe01 serial: <filter>
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Local Storage: total: 465.76 GiB used: 307.66 GiB (66.1%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3500418AS
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    type: HDD rpm: 7200 serial: <filter> rev: AP2A scheme: GPT
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRW GA32N rev: KE06
    dev-links: cdrom
    rw: cd-r,cd-rw,dvd-r state: running
  ID-1: / raw-size: 464.96 GiB size: 456.59 GiB (98.20%)
    used: 307.64 GiB (67.4%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: 51335112-b2bd-441f-90fa-4d42349c1b07
  ID-2: /boot/efi raw-size: 200 MiB size: 196.9 MiB (98.44%)
    used: 24.5 MiB (12.4%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: EFI
    uuid: 2860-11F4
  Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
  ID-1: swap-1 type: file size: 256 MiB used: 524 KiB (0.2%) priority: -2
    file: /swapfile
  ID-1: /dev/sda3 maj-min: 8:3 size: 619.9 MiB fs: hfsplus label: Recovery HD
    uuid: b6fa5cf5-0229-35c2-9dc4-27338fe2136e
  Hub-1: 1-0:1 info: Full speed or root hub ports: 6 rev: 2.0 speed: 480 Mb/s
  Hub-2: 1-1:2 info: Microchip (formerly SMSC) USB 2.0 Hub ports: 3 rev: 2.0
    speed: 480 Mb/s power: 2mA chip-ID: 0424:2514 class-ID: 0900
  Hub-3: 1-1.1:4 info: Broadcom BCM2046B1 USB 2.0 Hub (part of BCM2046
    Bluetooth) ports: 3 rev: 2.0 speed: 12 Mb/s chip-ID: 0a5c:4500
  Device-1: 1-1.1.1:6 info: Apple Built-in Bluetooth 2.0+EDR HCI
    type: Bluetooth driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s
  Device-2: 1-1.3:5 info: Areson Corp 2.4G Receiver type: Keyboard,Mouse
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA
    chip-ID: 25a7:fa23 class-ID: 0301
  Device-3: 1-2:3 info: Apple FaceTime HD Camera (Built-in) type: Video
    driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA
  Hub-4: 2-0:1 info: Full speed or root hub ports: 8 rev: 2.0 speed: 480 Mb/s
  Hub-5: 2-1:2 info: Microchip (formerly SMSC) USB 2.0 Hub ports: 4 rev: 2.0
  Device-1: 2-1.1:3 info: Apple Internal Memory Card Reader
    type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s
    power: 500mA chip-ID: 05ac:8403 class-ID: 0806 serial: <filter>
  Device-2: 2-1.2:4 info: Apple Built-in IR Receiver type: HID
    driver: appleir,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s power: 100mA
    chip-ID: 05ac:8242 class-ID: 0300
  Device-3: 2-1.4:5 info: Elecom TrackBall Mouse M-DPT1MR Wireless
    type: Keyboard,Mouse,HID driver: hid-generic,usbhid interfaces: 4 rev: 2.0
    speed: 12 Mb/s power: 100mA chip-ID: 056e:0132 class-ID: 0300
    serial: <filter>
  Hub-6: 3-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
    chip-ID: 1d6b:0001 class-ID: 0900
  Hub-7: 4-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
  System Temperatures: cpu: 47.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 1200
  Processes: 307 Uptime: 1d 23h 38m wakeups: 30 Init: systemd v: 251
  default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
  Packages: pm: pacman pkgs: 1843 libs: 467 tools: pamac pm: flatpak pkgs: 0
  Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.23
journalctl -u NetworkManager when enabling hotspot:
Dez 09 11:05:24 imac NetworkManager[983]: <info>  [1670555124.1033] audit: op="statistics" interface="enp2s0" ifindex=2 args="2000" pid=60598 uid=1000 result="success"
Dez 09 11:05:24 imac NetworkManager[983]: <info>  [1670555124.1131] audit: op="statistics" interface="enp2s0" ifindex=2 args="500" pid=60742 uid=1000 result="success"
Dez 09 11:05:25 imac NetworkManager[983]: <info>  [1670555125.5536] device (wlp3s0): Activation: starting connection 'Dif-tor heh smusma' (9e492993-583c-4971-958a-2ec35eded18f)
Dez 09 11:05:25 imac NetworkManager[983]: <info>  [1670555125.5540] audit: op="connection-add-activate" uuid="9e492993-583c-4971-958a-2ec35eded18f" name="Dif-tor heh smusma" pid=60598 uid=1000 result="success"
Dez 09 11:05:25 imac NetworkManager[983]: <info>  [1670555125.5542] device (wlp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Dez 09 11:05:25 imac NetworkManager[983]: <info>  [1670555125.5744] device (wlp3s0): set-hw-addr: reset MAC address to E4:CE:8F:55:2A:F5 (preserve)
Dez 09 11:05:25 imac NetworkManager[983]: <info>  [1670555125.5873] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Dez 09 11:05:25 imac NetworkManager[983]: <info>  [1670555125.5875] device (wlp3s0): Activation: (wifi) access point 'Dif-tor heh smusma' has security, but secrets are required.
Dez 09 11:05:25 imac NetworkManager[983]: <info>  [1670555125.5875] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Dez 09 11:05:25 imac NetworkManager[983]: <info>  [1670555125.5998] device (wlp3s0): supplicant interface state: disconnected -> interface_disabled
Dez 09 11:05:25 imac NetworkManager[983]: <info>  [1670555125.5998] device (p2p-dev-wlp3s0): supplicant management interface state: disconnected -> interface_disabled
Dez 09 11:05:25 imac NetworkManager[983]: <info>  [1670555125.5999] device (wlp3s0): supplicant interface state: interface_disabled -> disconnected
Dez 09 11:05:25 imac NetworkManager[983]: <info>  [1670555125.5999] device (p2p-dev-wlp3s0): supplicant management interface state: interface_disabled -> disconnected
Dez 09 11:05:25 imac NetworkManager[983]: <info>  [1670555125.6310] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Dez 09 11:05:25 imac NetworkManager[983]: <info>  [1670555125.6316] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Dez 09 11:05:25 imac NetworkManager[983]: <info>  [1670555125.6319] device (wlp3s0): Activation: (wifi) connection 'Dif-tor heh smusma' has security, and secrets exist.  No new secrets needed.
Dez 09 11:05:25 imac NetworkManager[983]: <info>  [1670555125.6320] Config: added 'ssid' value 'Dif-tor heh smusma'
Dez 09 11:05:25 imac NetworkManager[983]: <info>  [1670555125.6320] Config: added 'mode' value '2'
Dez 09 11:05:25 imac NetworkManager[983]: <info>  [1670555125.6320] Config: added 'frequency' value '2412'
Dez 09 11:05:25 imac NetworkManager[983]: <info>  [1670555125.6320] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256'
Dez 09 11:05:25 imac NetworkManager[983]: <info>  [1670555125.6320] Config: added 'psk' value '<hidden>'
Dez 09 11:05:25 imac NetworkManager[983]: <info>  [1670555125.6757] device (wlp3s0): supplicant interface state: disconnected -> completed
Dez 09 11:05:25 imac NetworkManager[983]: <info>  [1670555125.6758] device (wlp3s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Started Wi-Fi Hotspot "Dif-tor heh smusma"
Dez 09 11:05:25 imac NetworkManager[983]: <info>  [1670555125.6758] device (p2p-dev-wlp3s0): supplicant management interface state: disconnected -> completed
Dez 09 11:05:25 imac NetworkManager[983]: <info>  [1670555125.6759] device (wlp3s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Dez 09 11:05:25 imac NetworkManager[983]: <info>  [1670555125.7160] dnsmasq-manager: starting dnsmasq...
Dez 09 11:05:25 imac NetworkManager[983]: <info>  [1670555125.7178] device (wlp3s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Dez 09 11:05:25 imac NetworkManager[983]: <info>  [1670555125.7532] device (wlp3s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Dez 09 11:05:25 imac NetworkManager[983]: <info>  [1670555125.7534] device (wlp3s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Dez 09 11:05:25 imac NetworkManager[983]: <info>  [1670555125.7541] device (wlp3s0): Activation: successful, device activated.
Dez 09 11:05:25 imac NetworkManager[983]: <info>  [1670555125.9176] audit: op="statistics" interface="wlp3s0" ifindex=3 args="2000" pid=60598 uid=1000 result="success"
Dez 09 11:05:25 imac NetworkManager[983]: <info>  [1670555125.9277] audit: op="statistics" interface="wlp3s0" ifindex=3 args="500" pid=60742 uid=1000 result="success"
Dez 09 11:05:27 imac NetworkManager[983]: <info>  [1670555127.2053] audit: op="statistics" interface="enp2s0" ifindex=2 args="0" pid=60598 uid=1000 result="success"
Dez 09 11:05:27 imac NetworkManager[983]: <info>  [1670555127.2175] audit: op="statistics" interface="wlp3s0" ifindex=3 args="0" pid=60598 uid=1000 result="success"
Dez 09 11:05:27 imac NetworkManager[983]: <info>  [1670555127.2278] audit: op="statistics" interface="enp2s0" ifindex=2 args="500" pid=60742 uid=1000 result="success"
Dez 09 11:05:27 imac NetworkManager[983]: <info>  [1670555127.2363] audit: op="statistics" interface="enp2s0" ifindex=2 args="500" pid=60742 uid=1000 result="success"
journalctl -u NetworkManager when connecting android
Dez 09 11:08:16 imac dnsmasq-dhcp[116454]: DHCPDISCOVER(wlp3s0) 92:d9:e0:72:b8:bd
Dez 09 11:08:16 imac dnsmasq-dhcp[116454]: DHCPOFFER(wlp3s0) 10.42.0.94 92:d9:e0:72:b8:bd
Dez 09 11:08:16 imac dnsmasq-dhcp[116454]: DHCPREQUEST(wlp3s0) 10.42.0.94 92:d9:e0:72:b8:bd
Dez 09 11:08:16 imac dnsmasq-dhcp[116454]: DHCPACK(wlp3s0) 10.42.0.94 92:d9:e0:72:b8:bd HUAWEI_Mate_30_Pro_5G-1f9
journalctl -u NetworkManager when connecting iphone
Dez 09 11:09:36 imac dnsmasq-dhcp[116454]: DHCPDISCOVER(wlp3s0) 82:c1:19:ea:3d:66
Dez 09 11:09:36 imac dnsmasq-dhcp[116454]: DHCPOFFER(wlp3s0) 10.42.0.101 82:c1:19:ea:3d:66
Dez 09 11:09:37 imac dnsmasq-dhcp[116454]: DHCPREQUEST(wlp3s0) 10.42.0.101 82:c1:19:ea:3d:66
Dez 09 11:09:37 imac dnsmasq-dhcp[116454]: DHCPACK(wlp3s0) 10.42.0.101 82:c1:19:ea:3d:66
journalctl -u NetworkManager -u wpa_supplicant recollect logs form wpa_supplicant:
Dez 09 15:09:36 imac NetworkManager[983]: <info>  [1670569776.1639] audit: op="statistics" interface="enp2s0" ifindex=2 args="2000" pid=132255 uid=1000 result="success"
Dez 09 15:09:36 imac NetworkManager[983]: <info>  [1670569776.1789] audit: op="statistics" interface="enp2s0" ifindex=2 args="500" pid=132275 uid=1000 result="success"
Dez 09 15:09:40 imac NetworkManager[983]: <info>  [1670569780.4325] device (wlp3s0): Activation: starting connection 'Dif-tor heh smusma' (d3df40c7-fb75-424d-899c-898d27bdf2b3)
Dez 09 15:09:40 imac NetworkManager[983]: <info>  [1670569780.4326] audit: op="connection-add-activate" uuid="d3df40c7-fb75-424d-899c-898d27bdf2b3" name="Dif-tor heh smusma" pid=132255 uid=1000 result="success"
Dez 09 15:09:40 imac NetworkManager[983]: <info>  [1670569780.4329] device (wlp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Dez 09 15:09:40 imac NetworkManager[983]: <info>  [1670569780.4707] device (wlp3s0): set-hw-addr: reset MAC address to E4:CE:8F:55:2A:F5 (preserve)
Dez 09 15:09:40 imac NetworkManager[983]: <info>  [1670569780.4832] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Dez 09 15:09:40 imac NetworkManager[983]: <info>  [1670569780.4834] device (wlp3s0): Activation: (wifi) access point 'Dif-tor heh smusma' has security, but secrets are required.
Dez 09 15:09:40 imac NetworkManager[983]: <info>  [1670569780.4834] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Dez 09 15:09:40 imac NetworkManager[983]: <info>  [1670569780.5299] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Dez 09 15:09:40 imac NetworkManager[983]: <info>  [1670569780.5348] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Dez 09 15:09:40 imac NetworkManager[983]: <info>  [1670569780.5362] device (wlp3s0): Activation: (wifi) connection 'Dif-tor heh smusma' has security, and secrets exist.  No new secrets needed.
Dez 09 15:09:40 imac NetworkManager[983]: <info>  [1670569780.5363] Config: added 'ssid' value 'Dif-tor heh smusma'
Dez 09 15:09:40 imac NetworkManager[983]: <info>  [1670569780.5363] Config: added 'mode' value '2'
Dez 09 15:09:40 imac NetworkManager[983]: <info>  [1670569780.5363] Config: added 'frequency' value '2412'
Dez 09 15:09:40 imac NetworkManager[983]: <info>  [1670569780.5364] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256'
Dez 09 15:09:40 imac NetworkManager[983]: <info>  [1670569780.5364] Config: added 'psk' value '<hidden>'
Dez 09 15:09:40 imac wpa_supplicant[1071]: Note: nl80211 driver interface is not designed to be used with ap_scan=2; this can result in connection failures
Dez 09 15:09:40 imac wpa_supplicant[1071]: Using interface wlp3s0 with hwaddr e4:ce:8f:55:2a:f5 and ssid "Dif-tor heh smusma"
Dez 09 15:09:40 imac wpa_supplicant[1071]: wlp3s0: interface state UNINITIALIZED->ENABLED
Dez 09 15:09:40 imac wpa_supplicant[1071]: wlp3s0: AP-ENABLED
Dez 09 15:09:40 imac wpa_supplicant[1071]: wlp3s0: CTRL-EVENT-CONNECTED - Connection to e4:ce:8f:55:2a:f5 completed [id=0 id_str=]
Dez 09 15:09:40 imac NetworkManager[983]: <info>  [1670569780.5842] device (wlp3s0): supplicant interface state: disconnected -> completed
Dez 09 15:09:40 imac NetworkManager[983]: <info>  [1670569780.5842] device (wlp3s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Started Wi-Fi Hotspot "Dif-tor heh smusma"
Dez 09 15:09:40 imac NetworkManager[983]: <info>  [1670569780.5843] device (p2p-dev-wlp3s0): supplicant management interface state: disconnected -> completed
Dez 09 15:09:40 imac NetworkManager[983]: <info>  [1670569780.5844] device (wlp3s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Dez 09 15:09:40 imac NetworkManager[983]: <info>  [1670569780.6205] dnsmasq-manager: starting dnsmasq...
Dez 09 15:09:40 imac NetworkManager[983]: <info>  [1670569780.6220] device (wlp3s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Dez 09 15:09:40 imac dnsmasq[132643]: started, version 2.87 cachesize 150
Dez 09 15:09:40 imac dnsmasq[132643]: compile time options: IPv6 GNU-getopt DBus no-UBus i18n IDN2 DHCP DHCPv6 no-Lua TFTP conntrack ipset nftset auth cryptohash DNSSEC loop-detect inotify dumpfile
Dez 09 15:09:40 imac dnsmasq[132643]: chown of PID file /var/run/nm-dnsmasq-wlp3s0.pid failed: Operation not permitted
Dez 09 15:09:40 imac dnsmasq-dhcp[132643]: DHCP, IP range 10.42.0.10 -- 10.42.0.254, lease time 1h
Dez 09 15:09:40 imac dnsmasq[132643]: reading /etc/resolv.conf
Dez 09 15:09:40 imac dnsmasq[132643]: using nameserver 192.168.1.66#53
Dez 09 15:09:40 imac dnsmasq[132643]: using nameserver 192.168.1.65#53
Dez 09 15:09:40 imac dnsmasq[132643]: using nameserver 223.6.6.6#53
Dez 09 15:09:40 imac dnsmasq[132643]: using nameserver 223.5.5.5#53
Dez 09 15:09:40 imac dnsmasq[132643]: using nameserver 8.8.8.8#53
Dez 09 15:09:40 imac dnsmasq[132643]: using nameserver 8.8.8.4#53
Dez 09 15:09:40 imac dnsmasq[132643]: using nameserver 114.114.114.114#53
Dez 09 15:09:40 imac dnsmasq[132643]: cleared cache
Dez 09 15:09:40 imac NetworkManager[983]: <info>  [1670569780.6594] device (wlp3s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Dez 09 15:09:40 imac NetworkManager[983]: <info>  [1670569780.6605] device (wlp3s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Dez 09 15:09:40 imac NetworkManager[983]: <info>  [1670569780.6634] device (wlp3s0): Activation: successful, device activated.
Dez 09 15:09:40 imac NetworkManager[983]: <info>  [1670569780.8043] audit: op="statistics" interface="wlp3s0" ifindex=3 args="2000" pid=132255 uid=1000 result="success"
Dez 09 15:09:40 imac NetworkManager[983]: <info>  [1670569780.8155] audit: op="statistics" interface="wlp3s0" ifindex=3 args="500" pid=132275 uid=1000 result="success"
Dez 09 15:09:47 imac NetworkManager[983]: <info>  [1670569787.5398] audit: op="statistics" interface="enp2s0" ifindex=2 args="0" pid=132255 uid=1000 result="success"
Dez 09 15:09:47 imac NetworkManager[983]: <info>  [1670569787.5541] audit: op="statistics" interface="wlp3s0" ifindex=3 args="0" pid=132255 uid=1000 result="success"
Dez 09 15:09:47 imac NetworkManager[983]: <info>  [1670569787.5685] audit: op="statistics" interface="enp2s0" ifindex=2 args="500" pid=132275 uid=1000 result="success"
Dez 09 15:09:47 imac NetworkManager[983]: <info>  [1670569787.5852] audit: op="statistics" interface="enp2s0" ifindex=2 args="500" pid=132275 uid=1000 result="success"
Maybe your device does not support this?
Do you have a firewall?
My wireless adapter is Atheros AR93xx, which is irrelevant to that note. Somebody said that the warning is harmless.
The system has only iptables with docker’s default rules. I haven’t manually configure it.
I checked the filter table:
Chain FORWARD (policy DROP)
I try chaning the default policy to ACCEPT for the FORWARD chain. The internet is accessible again!
$ sudo iptables -t filter -P FORWARD ACCEPT
Thanks for your suggestion!
EDITED
To keep the default DROP policy of the FORWARD chain, use the following rules in stead of changing the chain policy (refer to Setting up a NAT gateway):
$ sudo iptables -A FORWARD -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT
$ sudo iptables -A FORWARD -i wlp3s0 -j ACCEPT
wlp3s0 is my wireless interface, replace it with actual name.
To preserve the rules after every boot, append them into /etc/iptables/iptables.rules, then enable the iptables systemd service.
Thank you, thank you. Your solution also solved my problem. Somehow I never thought of checking iptables.
