@nemecic Thanks for the feed-back. Please consider leaving a below that post.
@HotlineMiami As you’re the OP (Original poster) and that one solved it for you too, consider pushing the three dots … and then the Solution button below my post as well, so anyone googling your question and finding it will be seeing the solution in your question.
Next day Update! Unfrtunately, this is not the solution for me… I use Breath2 theme, i cleaned the Network cache etc… Yesterday, it temporarily worked. Today, the same old lag. I have to reboot to make the system work properly again. Any other people see the problem still exist?
Ok… I came to the conclusion that, i don’t know what’s goin’ on XD. It now logs out/logs in fine. Some hours ago, it didn’t. With the same configurations and everything.
If any new fix appears, i’ll have a look. Until then, thanks for the answers/help guys.
