After update kde global shortcuts are not working anymore.
If looked what has already been written in the forum:
Another KDE Global Shortcut question
I do have these files in .config/
“kglobalshortcutsrc”
“khotkeysrc”
If understand correctly above issue, I may have to delete “khotkeysrc” because it is not used anymore?? Than it should work?
Deleting the khotkeysrc file will not make kglobalshortcutsrc work. As mentioned, the khotkeys is related to Custom Shortcuts as done the “old way”, while Shortcuts aka Global Shortcuts will save everything user related shortcuts in kglobalshortcutsrc and now it has a Custom Shortcut Service to make things compatible with the old ways, but my guess is that you need to configure those custom shortcuts there.
If you open Settings > Shortcuts you should have a list with Kwin, plasma etc applications. If all are empty, then there is an issue. If there are entries, simply restart the system.
Seems so
(if not delete both)
Worst case is that you need to re-do your custom key-settings, because those files are only user settings not system settings
The original poster of that quote beat me to the answer ![]()
A restart did not solve the problem. E.g. using “Alt+Tab” does not work.
Here the content of kglobalshortcutsrc
What can I do?
[ActivityManager]
_k_friendly_name=Aktivitätenverwaltung
switch-to-activity-e35cf50c-a5a7-450e-bd94-cc9b139856d9=none,none,Zu Aktivität „Standard“ wechseln[Clementine]
_k_friendly_name=Clementine
next_album=none,none,Next album
next_track=none,none,Nächster Titel
play_pause=none,none,Wiedergabe/Pause
prev_track=none,none,Vorherigen Titel
stop=none,none,Anhalten[KDE Keyboard Layout Switcher]
Switch to Next Keyboard Layout=none,none,Auf nächste Tastaturbelegung umschalten
_k_friendly_name=Umschaltung der Tastaturbelegung[kaccess]
Toggle Screen Reader On and Off=Meta+Alt+S,Meta+Alt+S,Screenreader ein-/ausschalten
_k_friendly_name=Zugangshilfen[kcm_touchpad]
Disable Touchpad=Touchpad Off,Touchpad Off,Touchpad abschalten
Enable Touchpad=Touchpad On,Touchpad On,Touchpad aktivieren
Toggle Touchpad=Touchpad Toggle,Touchpad Toggle,Touchpad umschalten
_k_friendly_name=Touchpad[kded5]
Show System Activity=Ctrl+Esc,Ctrl+Esc,Systemaktivität anzeigen
_k_friendly_name=KDE Daemon
display=Display\tMeta+P,Display\tMeta+P,Anzeige wechseln[khotkeys]
_k_friendly_name=Dienst für eigene Kurzbefehle
{d03619b6-9b3c-48cc-9d9c-a2aadb485550}=none,none,Suchen[kmix]
_k_friendly_name=Lautstärke
decrease_microphone_volume=Microphone Volume Down,Microphone Volume Down,Mikrofonlautstärke verringern
decrease_volume=Volume Down,Volume Down,Lautstärke verringern
increase_microphone_volume=Microphone Volume Up,Microphone Volume Up,Mikrofonlautstärke erhöhen
increase_volume=Volume Up,Volume Up,Lautstärke erhöhen
mic_mute=Microphone Mute\tMeta+Volume Mute,Microphone Mute\tMeta+Volume Mute,Mikrofon stummschalten
mute=Volume Mute,Volume Mute,Stummschalten[ksmserver]
Halt Without Confirmation=none,Ohne Rückfrage herunterfahren
Lock Session=Screensaver\tMeta+L,Meta+L\tScreensaver,Sitzung sperren
Log Out=Ctrl+Alt+Del,Ctrl+Alt+Del,Abmelden
Log Out Without Confirmation=none,Ohne Rückfrage abmelden
Reboot Without Confirmation=none,Ohne Rückfrage neu starten
_k_friendly_name=Sitzungsverwaltung[kwin]
Activate Window Demanding Attention=Meta+Ctrl+A,Meta+Ctrl+A,Fenster aktivieren\, das Aufmerksamkeit erfordert
Decrease Opacity=none,Die Deckkraft des aktiven Fensters um 5 % verringern
Expose=Ctrl+F9,Ctrl+F9,Fenster der aktuellen Arbeitsfläche anzeigen
ExposeAll=Ctrl+F10\tLaunch (C),Ctrl+F10\tLaunch (C),Fenster aller Arbeitsflächen anzeigen
ExposeClass=Ctrl+F7,Ctrl+F7,Fenster zeigen umschalten (Fensterklasse)
ExposeClassCurrentDesktop=none,none,Toggle Present Windows (Window class on current desktop)
Increase Opacity=none,Die Deckkraft des aktiven Fensters um 5 % erhöhen
Invert Screen Colors=none,Bildschirmfarben umkehren
Kill Window=Meta+Ctrl+Esc,Meta+Ctrl+Esc,Fenster beseitigen
MoveMouseToCenter=Meta+F6,Meta+F6,Mauszeiger zentrieren
MoveMouseToFocus=Meta+F5,Meta+F5,Mauszeiger in den Fokus verschieben
MoveZoomDown=none,none,Vergrößerten Bereich nach unten verschieben
MoveZoomLeft=none,none,Vergrößerten Bereich nach links verschieben
MoveZoomRight=none,none,Vergrößerten Bereich nach rechts verschieben
MoveZoomUp=none,none,Vergrößerten Bereich nach oben verschieben
Overview=Meta+W,Meta+W,Übersicht umschalten
Setup Window Shortcut=none,Kurzbefehl für Fenster einrichten
Show Desktop=Meta+D,Meta+D,Peek at Desktop
ShowDesktopGrid=Meta+F8,Meta+F8,Arbeitsflächen-Raster anzeigen
Suspend Compositing=Alt+Shift+F12,Alt+Shift+F12,Compositing aussetzen
Switch One Desktop Down=Meta+Ctrl+Down,Meta+Ctrl+Down,Eine Arbeitsfläche nach unten
Switch One Desktop Up=Meta+Ctrl+Up,Meta+Ctrl+Up,Eine Arbeitsfläche nach oben
Switch One Desktop to the Left=Meta+Ctrl+Left,Meta+Ctrl+Left,Eine Arbeitsfläche nach links
Switch One Desktop to the Right=Meta+Ctrl+Right,Meta+Ctrl+Right,Eine Arbeitsfläche nach rechts
Switch Window Down=Meta+Alt+Down,Meta+Alt+Down,Zum Fenster darunter wechseln
Switch Window Left=Meta+Alt+Left,Meta+Alt+Left,Zum Fenster links wechseln
Switch Window Right=Meta+Alt+Right,Meta+Alt+Right,Zum Fenster rechts wechseln
Switch Window Up=Meta+Alt+Up,Meta+Alt+Up,Zum Fenster darüber wechseln
Switch to Desktop 1=Ctrl+F1,Ctrl+F1,Auf Arbeitsfläche 1 umschalten
Switch to Desktop 10=none,Auf Arbeitsfläche 10 umschalten
Switch to Desktop 11=none,Auf Arbeitsfläche 11 umschalten
Switch to Desktop 12=none,Auf Arbeitsfläche 12 umschalten
Switch to Desktop 13=none,Auf Arbeitsfläche 13 umschalten
Switch to Desktop 14=none,Auf Arbeitsfläche 14 umschalten
Switch to Desktop 15=none,Auf Arbeitsfläche 15 umschalten
Switch to Desktop 16=none,Auf Arbeitsfläche 16 umschalten
Switch to Desktop 17=none,Auf Arbeitsfläche 17 umschalten
Switch to Desktop 18=none,Auf Arbeitsfläche 18 umschalten
Switch to Desktop 19=none,Auf Arbeitsfläche 19 umschalten
Switch to Desktop 2=Ctrl+F2,Ctrl+F2,Auf Arbeitsfläche 2 umschalten
Switch to Desktop 20=none,Auf Arbeitsfläche 20 umschalten
Switch to Desktop 3=Ctrl+F3,Ctrl+F3,Auf Arbeitsfläche 3 umschalten
Switch to Desktop 4=Ctrl+F4,Ctrl+F4,Auf Arbeitsfläche 4 umschalten
Switch to Desktop 5=none,Auf Arbeitsfläche 5 umschalten
Switch to Desktop 6=none,Auf Arbeitsfläche 6 umschalten
Switch to Desktop 7=none,Auf Arbeitsfläche 7 umschalten
Switch to Desktop 8=none,Auf Arbeitsfläche 8 umschalten
Switch to Desktop 9=none,Auf Arbeitsfläche 9 umschalten
Switch to Next Desktop=none,Zur nächsten Arbeitsfläche umschalten
Switch to Next Screen=none,Zum nächsten Bildschirm umschalten
Switch to Previous Desktop=none,Zur vorherigen Arbeitsfläche umschalten
Switch to Previous Screen=none,Zum vorherigen Bildschirm umschalten
Switch to Screen 0=none,Auf Bildschirm 0 umschalten
Switch to Screen 1=none,Auf Bildschirm 1 umschalten
Switch to Screen 2=none,Auf Bildschirm 2 umschalten
Switch to Screen 3=none,Auf Bildschirm 3 umschalten
Switch to Screen 4=none,Auf Bildschirm 4 umschalten
Switch to Screen 5=none,Auf Bildschirm 5 umschalten
Switch to Screen 6=none,Auf Bildschirm 6 umschalten
Switch to Screen 7=none,Auf Bildschirm 7 umschalten
Toggle Night Color=none,none,Nachtfarben umschalten
Toggle Window Raise/Lower=none,Fenster nach vorne/hinten
Walk Through Desktop List=none,Nächster Eintrag in Arbeitsflächenliste
Walk Through Desktop List (Reverse)=none,Nächster Eintrag in Arbeitsflächenliste (Gegenrichtung)
Walk Through Desktops=none,Zwischen Arbeitsflächen umschalten
Walk Through Desktops (Reverse)=none,Zwischen Arbeitsflächen umschalten (Gegenrichtung)
Walk Through Windows=Alt+Tab,Alt+Tab,Zwischen Fenstern wechseln
Walk Through Windows (Reverse)=Alt+Shift+Backtab,Alt+Shift+Backtab,Zwischen Fenstern wechseln (Gegenrichtung)
Walk Through Windows Alternative=none,Alternatives Wechseln zwischen Fenstern
Walk Through Windows Alternative (Reverse)=none,Alternatives Wechseln zwischen Fenstern (Gegenrichtung)
Walk Through Windows of Current Application=Alt+,Alt+,Zwischen Fenstern der aktuellen Anwendung wechseln
Walk Through Windows of Current Application (Reverse)=Alt+~,Alt+~,Zwischen Fenstern der aktuellen Anwendung wechseln (Gegenrichtung)
Walk Through Windows of Current Application Alternative=none,Alternatives Wechseln zwischen Fenstern der aktuellen Anwendung
Walk Through Windows of Current Application Alternative (Reverse)=none,Alternatives Wechseln zwischen Fenstern der aktuellen Anwendung (Gegenrichtung)
Window Above Other Windows=none,Fenster im Vordergrund halten
Window Below Other Windows=none,Fenster im Hintergrund halten
Window Close=Alt+F4,Alt+F4,Fenster schließen
Window Fullscreen=none,Fenster auf Vollbildgröße
Window Grow Horizontal=none,Fenster waagerecht maximieren
Window Grow Vertical=none,Fenster senkrecht maximieren
Window Lower=none,Fenster nach hinten
Window Maximize=Meta+PgUp,Meta+PgUp,Fenster maximieren
Window Maximize Horizontal=none,Fenster waagerecht maximieren
Window Maximize Vertical=none,Fenster senkrecht maximieren
Window Minimize=Meta+PgDown,Meta+PgDown,Fenster minimieren
Window Move=none,Fenster verschieben
Window Move Center=none,Fenster zentrieren
Window No Border=none,Fensterumrandung ausblenden
Window On All Desktops=none,Fenster auf allen Arbeitsflächen anzeigen
Window One Desktop Down=Meta+Ctrl+Shift+Down,Meta+Ctrl+Shift+Down,Fenster eine Arbeitsfläche nach unten
Window One Desktop Up=Meta+Ctrl+Shift+Up,Meta+Ctrl+Shift+Up,Fenster eine Arbeitsfläche nach oben
Window One Desktop to the Left=Meta+Ctrl+Shift+Left,Meta+Ctrl+Shift+Left,Fenster eine Arbeitsfläche nach links
Window One Desktop to the Right=Meta+Ctrl+Shift+Right,Meta+Ctrl+Shift+Right,Fenster eine Arbeitsfläche nach rechts
Window Operations Menu=Alt+F3,Alt+F3,Fensteraktionen-Menü
Window Pack Down=none,Fenster nach unten verschieben
Window Pack Left=none,Fenster nach links verschieben
Window Pack Right=none,Fenster nach rechts verschieben
Window Pack Up=none,Fenster nach oben verschieben
Window Quick Tile Bottom=Meta+Down,Meta+Down,Fenster am unteren Bildschirmrand anordnen
Window Quick Tile Bottom Left=none,Fenster am linken unteren Bildschirmrand anordnen
Window Quick Tile Bottom Right=none,Fenster am rechten unteren Bildschirmrand anordnen
Window Quick Tile Left=Meta+Left,Meta+Left,Fenster am linken Bildschirmrand anordnen
Window Quick Tile Right=Meta+Right,Meta+Right,Fenster am rechten Bildschirmrand anordnen
Window Quick Tile Top=Meta+Up,Meta+Up,Fenster am oberen Bildschirmrand anordnen
Window Quick Tile Top Left=none,Fenster am linken oberen Bildschirmrand anordnen
Window Quick Tile Top Right=none,Fenster am rechten oberen Bildschirmrand anordnen
Window Raise=none,Fenster nach vorne
Window Resize=none,Fenstergröße ändern
Window Shade=none,Fensterheber betätigen
Window Shrink Horizontal=none,Shrink Window Horizontally
Window Shrink Vertical=none,Shrink Window Vertically
Window to Desktop 1=none,Fenster auf Arbeitsfläche 1
Window to Desktop 10=none,Fenster auf Arbeitsfläche 10
Window to Desktop 11=none,Fenster auf Arbeitsfläche 11
Window to Desktop 12=none,Fenster auf Arbeitsfläche 12
Window to Desktop 13=none,Fenster auf Arbeitsfläche 13
Window to Desktop 14=none,Fenster auf Arbeitsfläche 14
Window to Desktop 15=none,Fenster auf Arbeitsfläche 15
Window to Desktop 16=none,Fenster auf Arbeitsfläche 16
Window to Desktop 17=none,Fenster auf Arbeitsfläche 17
Window to Desktop 18=none,Fenster auf Arbeitsfläche 18
Window to Desktop 19=none,Fenster auf Arbeitsfläche 19
Window to Desktop 2=none,Fenster auf Arbeitsfläche 2
Window to Desktop 20=none,Fenster auf Arbeitsfläche 20
Window to Desktop 3=none,Fenster auf Arbeitsfläche 3
Window to Desktop 4=none,Fenster auf Arbeitsfläche 4
Window to Desktop 5=none,Fenster auf Arbeitsfläche 5
Window to Desktop 6=none,Fenster auf Arbeitsfläche 6
Window to Desktop 7=none,Fenster auf Arbeitsfläche 7
Window to Desktop 8=none,Fenster auf Arbeitsfläche 8
Window to Desktop 9=none,Fenster auf Arbeitsfläche 9
Window to Next Desktop=none,Fenster auf nächste Arbeitsfläche verschieben
Window to Next Screen=Meta+Shift+Right,Meta+Shift+Right,Fenster auf nächsten Bildschirm verschieben
Window to Previous Desktop=none,Fenster auf vorherige Arbeitsfläche verschieben
Window to Previous Screen=Meta+Shift+Left,Meta+Shift+Left,Fenster auf vorherigen Bildschirm verschieben
Window to Screen 0=none,Fenster auf Bildschirm 0
Window to Screen 1=none,Fenster auf Bildschirm 1
Window to Screen 2=none,Fenster auf Bildschirm 2
Window to Screen 3=none,Fenster auf Bildschirm 3
Window to Screen 4=none,Fenster auf Bildschirm 4
Window to Screen 5=none,Fenster auf Bildschirm 5
Window to Screen 6=none,Fenster auf Bildschirm 6
Window to Screen 7=none,Fenster auf Bildschirm 7
_k_friendly_name=KWin
view_actual_size=Meta+0,Meta+0,Auf Originalgröße zoomen
view_zoom_in=Meta++,Meta++,Vergrößern
view_zoom_out=Meta±,Meta±,Verkleinern[mediacontrol]
_k_friendly_name=Mediensteuerung
mediavolumedown=none,none,Medienspieler leiser
mediavolumeup=none,none,Medienspieler lauter
nextmedia=Media Next,Media Next,Nächstes Medium wiedergeben
pausemedia=Media Pause,Media Pause,Medienwiedergabe anhalten
playmedia=none,none,Medienwiedergabe starten
playpausemedia=Media Play,Media Play,Medienwiedergabe starten/anhalten
previousmedia=Media Previous,Media Previous,Vorheriges Medium wiedergeben
stopmedia=Media Stop,Media Stop,Medienwiedergabe anhalten[org.kde.dolphin.desktop]
_k_friendly_name=Dolphin
_launch=Meta+E,Meta+E,Dolphin[org.kde.konsole.desktop]
NewTab=none,none,Ein neues Unterfenster öffnen
NewWindow=none,none,Ein neues Fenster öffnen
_k_friendly_name=Konsole
_launch=none,none,Konsole[org.kde.krunner.desktop]
RunClipboard=Alt+Shift+F2,Alt+Shift+F2,Befehl mit dem Inhalt der Zwischenablage ausführen
_k_friendly_name=KRunner
_launch=Alt+Space\tAlt+F2\tSearch,Alt+Space\tAlt+F2\tSearch,KRunner[org.kde.plasma.emojier.desktop]
_k_friendly_name=Emoji-Auswahl
_launch=Meta+.,Meta+.,Emoji-Auswahl[org.kde.spectacle.desktop]
ActiveWindowScreenShot=Meta+Print,Meta+Print,Aktives Fenster aufnehmen
CurrentMonitorScreenShot=none,none,Aktuellen Bildschirm aufnehmen
FullScreenScreenShot=Shift+Print,Shift+Print,Gesamte Arbeitsfläche aufnehmen
OpenWithoutScreenshot=none,none,Spectacle ohne Aufnahme starten
RectangularRegionScreenShot=Meta+Shift+Print,Meta+Shift+Print,Rechteckigen Bereich aufnehmen
WindowUnderCursorScreenShot=Meta+Ctrl+Print,Meta+Ctrl+Print,Fenster unter dem Mauszeiger aufnehmen
_k_friendly_name=Spectacle
_launch=Print,Print,Spectacle starten[org_kde_powerdevil]
Decrease Keyboard Brightness=Keyboard Brightness Down,Keyboard Brightness Down,Helligkeit der Tastatur-Hintergrundbeleuchtung verringern
Decrease Screen Brightness=Monitor Brightness Down,Monitor Brightness Down,Bildschirmhelligkeit verringern
Hibernate=Hibernate,Hibernate,Ruhezustand
Increase Keyboard Brightness=Keyboard Brightness Up,Keyboard Brightness Up,Helligkeit der Tastatur-Hintergrundbeleuchtung erhöhen
Increase Screen Brightness=Monitor Brightness Up,Monitor Brightness Up,Bildschirmhelligkeit erhöhen
PowerDown=Power Down,Power Down,Abschalten
PowerOff=Power Off,Power Off,Ausschalten
Sleep=Sleep,Sleep,Standby-Modus
Toggle Keyboard Backlight=Keyboard Light On/Off,Keyboard Light On/Off,Hintergrundbeleuchtung der Tastatur umschalten
Turn Off Screen=none,none,Bildschirm ausschalten
_k_friendly_name=Energieverwaltung[plasmashell]
_k_friendly_name=Plasma
activate task manager entry 1=Meta+1,Meta+1,Fensterleisteneintrag 1 aktivieren
activate task manager entry 10=none,Meta+0,Fensterleisteneintrag 10 aktivieren
activate task manager entry 2=Meta+2,Meta+2,Fensterleisteneintrag 2 aktivieren
activate task manager entry 3=Meta+3,Meta+3,Fensterleisteneintrag 3 aktivieren
activate task manager entry 4=Meta+4,Meta+4,Fensterleisteneintrag 4 aktivieren
activate task manager entry 5=Meta+5,Meta+5,Fensterleisteneintrag 5 aktivieren
activate task manager entry 6=Meta+6,Meta+6,Fensterleisteneintrag 6 aktivieren
activate task manager entry 7=Meta+7,Meta+7,Fensterleisteneintrag 7 aktivieren
activate task manager entry 8=Meta+8,Meta+8,Fensterleisteneintrag 8 aktivieren
activate task manager entry 9=Meta+9,Meta+9,Fensterleisteneintrag 9 aktivieren
activate widget 24=none,none,Miniprogramm Anwendungsübersicht aktivieren
activate widget 27=none,none,Miniprogramm Anwendungsübersicht aktivieren
clear-history=none,Bisherigen Inhalt der Zwischenablage löschen
clipboard_action=Meta+Ctrl+X,Meta+Ctrl+X,Automatic Action Popup Menu
cycle-panels=Meta+Alt+P,Meta+Alt+P,Tastaturfokus zwischen Kontrollleisten umschalten
cycleNextAction=none,Next History Item
cyclePrevAction=none,Previous History Item
edit_clipboard=none,Inhalt bearbeiten …
manage activities=Meta+Q,Meta+Q,Aktivitätenwechsler anzeigen
next activity=Meta+Tab,Meta+Tab,Zwischen Aktivitäten wechseln
previous activity=Meta+Shift+Tab,Meta+Shift+Tab,Zwischen Aktivitäten wechseln (Gegenrichtung)
repeat_action=Meta+Ctrl+R,Meta+Ctrl+R,Manually Invoke Action on Current Clipboard
show dashboard=Ctrl+F12,Ctrl+F12,Arbeitsfläche anzeigen
show-barcode=none,Strichcode anzeigen …
show-on-mouse-pos=Meta+V,Meta+V,Open Klipper at Mouse Position
stop current activity=Meta+S,Meta+S,Aktuelle Aktivität anhalten
switch to next activity=none,Zur nächsten Aktivität wechseln
switch to previous activity=none,Zur vorherigen Aktivität wechseln
toggle do not disturb=none,Nicht stören umschalten[systemsettings.desktop]
_k_friendly_name=Systemeinstellungen
_launch=Tools,Tools,Systemeinstellungen
kcm-kscreen=none,none,Anzeige-Einrichtung
kcm-lookandfeel=none,none,Globales Design
kcm-users=none,none,Benutzer
powerdevilprofilesconfig=none,none,Energiesparen
screenlocker=none,none,Bildschirmsperre
I don’t see anything on it to prevent it from working. In principle, even without that file in your home, you should still have the defaults, and then get that file regenerated with those defaults. Try to move it as a _back file and reboot, check if defaults plasma shortcuts work, and then compare the files. Maybe you will notice something that i’m missing at the moment.
This did not help for kglobalshortcutsrc
But now I have come a little closer to the problem. I have Notebook. On the notebook keyboard the shortcuts still work. But since some of the recent manjaro updates the external keyboard, which I usually use, the shortcuts do not work anymore even thoug the keyboards works still perfectly for normal entering of keys. Thus something may have changed in the drivers.
