KDE Generic Icons instead of Manjaro Icons
I just ran an update this morning and I noticed that my desktop had a changed a little bit. On the taskbar, the dolphin icon is now a generic blue folder compared to previous green folder icon. Also the trash folder is now a gray trash can.
Is there a way to set the desktop back to default?
Thank you!
Hi,
You should read the update announcement threads prior to updating.
Particularly relevant to you is:
Ah, thank you for the reply. So basically, it’s working “as expected”?
Yes. Dolphin and SySe icons will get an ability to recognize your accent colors soon though thanks to our cooperation with KDE team.
