KDE freezes for a few secs
The screen, but sound still play. No idea the LOG to look at if there is one. Sorry, no real details.
The firefox version currently in all three of the branches is 141.0-1. I recommend using that one instead.
No update listed in Package manager. Does BTRFS make a snapshot to boot from if updating the sys makes it unbootable?
sudo pacman-mirrors -f && sudo pacman -Fy && sudo pacman -Syu
Note: If you installed firefox from the Mozilla website — you did after all put this thread in Third-party Applications — then your package manager has no knowledge of it existing on your system.
I don’t use the snapshotting feature, but as I understand it, tools like snapper — if you have that installed — will normally create a snapshot every time you update the system.
It isn’y just Firefox, it is the whole sys, sorry. I pressed the supper key when it happened again & KDE was frozen also. I will get snapper, then update the sys. so I can booth bak to that if update skrews up.
My guess is it’s Nvidia, man. Now you know why I avoid that junk like the plague. :grin:
It was on Manjaro when I installed, PM lists it so it knows.
Then it’s not a third-party application, is it? :stuck_out_tongue:
Third-party Applications is for things that were not installed by way of the package manager, and which are not from the AUR, or Snap/Flatpak. :wink:
I’ve moved the thread to Software & Applications. :wink:
I didn’t think to try the super key before I posted the topic. I will rename it, Or request delete & start a topic in KDE/
Thread moved to KDE Plasma. :wink:
Well I just saw a notification, so there’s a new update (I see an icon in my taskbar showing the news) - but it’s a FRESH update, so this could be a mirror issue - I have only one active mirror now.
Step 1. Open Konsole, copy and paste this command:
sudo pacman-mirrors --continent && pacman-mirrors
Step 2. Use your mouse to select the text in Konsole, right click and copy command output and then paste it here like this:
Pacman-mirrors version 5.0
Local mirror status for testing branch
Mirror #1   OK  00:08   Singapore  http://ossmirror.mycloud.services/os/linux/manjaro/
Step 3. Again, in Konsole:
sudo pacman -Syu
  • Copy that text command output again.
  • Click on the :gear: Cog icon and select Hide Details
  • Press your ~ three times to type ~~~ and press ⏎Enter
  • ctrlV paste it.
  • Press ⏎Enter and type ~~~ again at the end.
Like this:
Summary
ra/haskell-ansi-wl-pprint                 0.6.9-477                0.6.9-479                  0.00 MiB       0.05 MiB
extra/haskell-assoc                          1.1.1-28                 1.1.1-30                   0.00 MiB       0.01 MiB
extra/haskell-async                          2.2.5-109                2.2.5-111                  0.00 MiB       0.06 MiB
extra/haskell-attoparsec                     0.14.4-106               0.14.4-107                 0.00 MiB       0.38 MiB
extra/haskell-base-compat-batteries          0.12.3-10                0.12.3-12                  0.00 MiB       0.07 MiB
extra/haskell-base-orphans                   0.9.1-10                 0.9.1-12                   0.00 MiB       0.04 MiB
extra/haskell-bifunctors                     5.6-189                  5.6-191                    0.00 MiB       0.38 MiB
extra/haskell-call-stack                     0.4.0-244                0.4.0-246                  0.00 MiB       0.02 MiB
extra/haskell-case-insensitive               1.2.1.0-234              1.2.1.0-235                0.00 MiB       0.04 MiB
extra/haskell-colour                         2.3.6-268                2.3.6-270                  0.00 MiB       0.15 MiB
extra/haskell-comonad                        5.0.9-46                 5.0.9-48                   0.00 MiB       0.09 MiB
extra/haskell-data-fix                       0.3.4-1                  0.3.4-2                    0.00 MiB       0.04 MiB
extra/haskell-diff                           0.4.1-106                0.4.1-107                  0.00 MiB       0.06 MiB
extra/haskell-distributive                   0.6.2.1-242              0.6.2.1-243                0.00 MiB       0.04 MiB
extra/haskell-dlist                          1.0-280                  1.0-281                    0.00 MiB       0.05 MiB
extra/haskell-fgl                            5.8.3.0-30               5.8.3.0-31                 0.00 MiB       0.31 MiB
extra/haskell-foldable1-classes-compat       0.1-189                  0.1-191                    0.00 MiB       0.07 MiB
extra/haskell-free                           5.2-45                   5.2-46                    -0.01 MiB       0.53 MiB
extra/haskell-generically                    0.1.1-18                 0.1.1-19                   0.00 MiB       0.01 MiB
extra/haskell-hashable                       1.4.4.0-94               1.4.4.0-96                 0.00 MiB       0.10 MiB
extra/haskell-indexed-traversable            0.1.4-102                0.1.4-104                  0.00 MiB       0.11 MiB
extra/haskell-indexed-traversable-instances  0.1.2-51                 0.1.2-52                   0.00 MiB       0.02 MiB
extra/haskell-integer-logarithms             1.0.4-7                  1.0.4-8                    0.00 MiB       0.03 MiB
extra/haskell-invariant                      0.6.4-17                 0.6.4-18                   0.00 MiB       0.16 MiB
extra/haskell-kan-extensions                 5.2.7-6                  5.2.7-7                    0.00 MiB       0.19 MiB
extra/haskell-lens                           5.2.3-110                5.2.3-111                  0.00 MiB       1.41 MiB
extra/haskell-megaparsec                     9.6.1-31                 9.6.1-32                   0.00 MiB       0.40 MiB
extra/haskell-onetuple                       0.4.2-44                 0.4.2-46                   0.00 MiB       0.01 MiB
extra/haskell-optparse-applicative           0.17.1.0-94              0.17.1.0-96                0.00 MiB       0.26 MiB
extra/haskell-os-string                      2.0.7-36                 2.0.7-38                   0.00 MiB       0.16 MiB
extra/haskell-primitive                      0.8.0.0-23               0.8.0.0-25                 0.00 MiB       0.25 MiB
extra/haskell-profunctors                    5.6.3-5                  5.6.3-6                    0.00 MiB       0.28 MiB
extra/haskell-quickcheck                     2.14.3-152               2.14.3-154                 0.00 MiB       0.51 MiB
extra/haskell-random                         1.2.1.2-93               1.2.1.2-95                 0.00 MiB       0.22 MiB
extra/haskell-reflection                     2.1.9-6                  2.1.9-7                    0.00 MiB       0.21 MiB
extra/haskell-regex-tdfa                     1.3.2.4-11               1.3.2.4-12                 0.00 MiB       0.45 MiB
extra/haskell-resourcet                      1.2.6-82                 1.2.6-83                   0.00 MiB       0.08 MiB
extra/haskell-rio                            0.1.22.0-156             0.1.22.0-157               0.00 MiB       0.24 MiB
extra/haskell-safe-exceptions                0.1.7.4-52               0.1.7.4-53                 0.00 MiB       0.03 MiB
extra/haskell-scientific                     0.3.7.0-145              0.3.7.0-146                0.00 MiB       0.10 MiB
extra/haskell-semialign                      1.3-40                   1.3-41                     0.00 MiB       0.13 MiB
extra/haskell-semigroupoids                  6.0.1-23                 6.0.1-24                   0.00 MiB       0.33 MiB
extra/haskell-splitmix                       0.1.0.5-83               0.1.0.5-85                 0.00 MiB       0.04 MiB
extra/haskell-strict                         0.5-74                   0.5-76                     0.00 MiB       0.16 MiB
extra/haskell-tasty                          1.4.3-136                1.4.3-138                  0.00 MiB       0.25 MiB
extra/haskell-text-short                     0.1.6-30                 0.1.6-31                   0.00 MiB       0.07 MiB
extra/haskell-these                          1.2.1-12                 1.2.1-14                   0.00 MiB       0.10 MiB
extra/haskell-time-compat                    1.9.6.1-128              1.9.6.1-129                0.00 MiB       0.06 MiB
extra/haskell-transformers-base              0.4.6-133                0.4.6-134                  0.00 MiB       0.02 MiB
extra/haskell-typed-process                  0.2.13.0-1               0.2.13.0-2                 0.00 MiB       0.07 MiB
extra/haskell-unliftio                       0.2.25.1-19              0.2.25.1-20                0.00 MiB       0.21 MiB
extra/haskell-unordered-containers           0.2.20-59                0.2.20-60                  0.00 MiB       0.25 MiB
extra/haskell-uuid-types                     1.0.6-19                 1.0.6-20                   0.00 MiB       0.06 MiB
extra/haskell-vector                         0.13.2.0-13              0.13.2.0-17                0.00 MiB       1.32 MiB
extra/haskell-void                           0.7.3-234                0.7.3-235                  0.00 MiB       0.01 MiB
extra/haskell-witherable                     0.4.2-158                0.4.2-159                  0.00 MiB       0.12 MiB
core/install-grub                            2:2.12.r350.g0e367796-1  2:2.12.r350.g0e367796-2    0.00 MiB       0.01 MiB
extra/kid3-common                            3.9.6-3                  3.9.7-1                    0.11 MiB       2.95 MiB
extra/kid3-qt                                3.9.6-3                  3.9.7-1                    0.01 MiB       0.16 MiB
extra/kmonad                                 0.4.3-64                 0.4.4-2                    3.44 MiB       1.38 MiB
core/less                                    1:668-1                  1:679-1                    0.01 MiB       0.14 MiB
multilib/lib32-libx11                        1.8.12-1                 1.8.12-2                   0.00 MiB       0.61 MiB
multilib/lib32-llvm-libs                     1:20.1.6-1               1:20.1.8-1                 0.01 MiB      42.41 MiB
multilib/lib32-nspr                          4.36-1                   4.37-1                     0.00 MiB       0.11 MiB
multilib/lib32-nss                           3.113.1-1                3.114-1                    0.01 MiB       1.09 MiB
extra/libao                                  1.2.2-6                  1.2.2-7                    0.00 MiB       0.05 MiB
extra/libimagequant                          4.3.4-1                  4.4.0-1                   -0.01 MiB       0.26 MiB
extra/libopenmpt                             0.8.1-1                  0.8.2-1                    0.00 MiB       0.87 MiB
extra/libvlc                                 3.0.21-26                3.0.21-27                  0.00 MiB       0.66 MiB
extra/libxnvctrl                             575.64-1                 575.64.05-1                0.00 MiB       0.09 MiB
core/linux612                                6.12.39-1                6.12.40-1                  0.06 MiB     139.63 MiB
extra/linux612-virtualbox-host-modules       7.1.12-2                 7.1.12-4                   0.00 MiB       0.46 MiB
core/linux615                                6.15.7-1                 6.15.8-1                   0.05 MiB     142.86 MiB
core/linux615-headers                        6.15.7-1                 6.15.8-1                   0.00 MiB      38.67 MiB
extra/linux615-virtualbox-host-modules       7.1.12-2                 7.1.12-4                   0.00 MiB       0.47 MiB
core/man-pages                               6.14-1                   6.15-1                     0.02 MiB       5.51 MiB
extra/mhwd-db                                20250113-1               20250724-1                 0.00 MiB       0.01 MiB
extra/mhwd-nvidia                            575.64.03-1              575.64.05-1                0.00 MiB       0.03 MiB
extra/mympd                                  21.0.1-2                 22.0.2-1                   0.02 MiB       0.87 MiB
extra/npm                                    11.4.2-1                 11.4.2-2                   0.36 MiB       1.40 MiB
core/nspr                                    4.36-1                   4.37-1                     0.00 MiB       0.19 MiB
core/nss                                     3.113.1-1                3.114-1                    0.00 MiB       1.62 MiB
extra/opencv                                 4.12.0-1                 4.12.0-2                   0.00 MiB      28.69 MiB
extra/ostree                                 2025.3-1                 2025.4-1                   0.00 MiB       0.81 MiB
extra/parallel                               20250622-1               20250722-2                 0.00 MiB       0.33 MiB
extra/perl-path-tiny                         0.148-2                  0.150-1                   -0.04 MiB       0.04 MiB
extra/phonon-qt6                             4.12.0-4                 4.12.0-5                   0.02 MiB       0.41 MiB
extra/phonon-qt6-vlc                         0.12.0-3                 0.12.0-5                   0.03 MiB       0.12 MiB
extra/pixman                                 0.46.2-1                 0.46.4-1                   0.00 MiB       0.28 MiB
extra/python-click                           8.1.8-1                  8.2.1-1                   -0.01 MiB       0.21 MiB
extra/python-setproctitle                    1.3.5-1                  1.3.6-1                    0.00 MiB       0.01 MiB
extra/qt6-declarative                        6.9.1-1                  6.9.1-2                    0.00 MiB      15.23 MiB
extra/qt6-webengine                          6.9.1-1                  6.9.1-2                    0.03 MiB      87.11 MiB
extra/shellcheck                             0.10.0-69                0.10.0-70                  0.00 MiB       3.27 MiB
extra/sticky                                 1.24-1                   1.25-1                     0.00 MiB       0.14 MiB
extra/superfile                              1.3.1-2                  1.3.2-1                   -0.01 MiB       4.97 MiB
extra/tevent                                 1:0.16.2-1               1:0.17.0-1                 0.00 MiB       0.06 MiB
extra/vivaldi                                7.5.3735.54-1            7.5.3735.56-1             -0.84 MiB     164.66 MiB
extra/vlc                                    3.0.21-26                3.0.21-27                  0.00 MiB       6.08 MiB
extra/vlc-cli                                3.0.21-26                3.0.21-27                  0.00 MiB       0.01 MiB
extra/vlc-gui-qt                             3.0.21-26                3.0.21-27                  0.00 MiB       1.03 MiB
extra/vlc-plugin-a52dec                      3.0.21-26                3.0.21-27                  0.00 MiB       0.01 MiB
extra/vlc-plugin-alsa                        3.0.21-26                3.0.21-27                  0.00 MiB       0.02 MiB
extra/vlc-plugin-archive                                              3.0.21-27                  0.02 MiB       0.01 MiB
extra/vlc-plugin-dav1d                       3.0.21-26                3.0.21-27                  0.00 MiB       0.01 MiB
extra/vlc-plugin-dbus                        3.0.21-26                3.0.21-27                  0.00 MiB       0.03 MiB
extra/vlc-plugin-dbus-screensaver            3.0.21-26                3.0.21-27                  0.00 MiB       0.01 MiB
extra/vlc-plugin-faad2                       3.0.21-26                3.0.21-27                  0.00 MiB       0.01 MiB
extra/vlc-plugin-flac                        3.0.21-26                3.0.21-27                  0.00 MiB       0.01 MiB
extra/vlc-plugin-gnutls                      3.0.21-26                3.0.21-27                  0.00 MiB       0.01 MiB
extra/vlc-plugin-inflate                     3.0.21-26                3.0.21-27                  0.00 MiB       0.01 MiB
extra/vlc-plugin-journal                     3.0.21-26                3.0.21-27                  0.00 MiB       0.01 MiB
extra/vlc-plugin-jpeg                        3.0.21-26                3.0.21-27                  0.00 MiB       0.01 MiB
extra/vlc-plugin-lua                         3.0.21-26                3.0.21-27                  0.00 MiB       0.30 MiB
extra/vlc-plugin-mpg123                      3.0.21-26                3.0.21-27                  0.00 MiB       0.01 MiB
extra/vlc-plugin-ogg                                                  3.0.21-27                  0.13 MiB       0.06 MiB
extra/vlc-plugin-opus                        3.0.21-26                3.0.21-27                  0.00 MiB       0.01 MiB
extra/vlc-plugin-png                         3.0.21-26                3.0.21-27                  0.00 MiB       0.01 MiB
extra/vlc-plugin-pulse                       3.0.21-26                3.0.21-27                  0.00 MiB       0.02 MiB
extra/vlc-plugin-shout                       3.0.21-26                3.0.21-27                  0.00 MiB       0.01 MiB
extra/vlc-plugin-speex                       3.0.21-26                3.0.21-27                  0.00 MiB       0.02 MiB
extra/vlc-plugin-tag                         3.0.21-26                3.0.21-27                  0.00 MiB       0.04 MiB
extra/vlc-plugin-theora                      3.0.21-26                3.0.21-27                  0.00 MiB       0.01 MiB
extra/vlc-plugin-twolame                     3.0.21-26                3.0.21-27                  0.00 MiB       0.01 MiB
extra/vlc-plugin-vorbis                      3.0.21-26                3.0.21-27                  0.00 MiB       0.02 MiB
extra/vlc-plugin-vpx                         3.0.21-26                3.0.21-27                  0.00 MiB       0.01 MiB
extra/vlc-plugin-xml                         3.0.21-26                3.0.21-27                  0.00 MiB       0.01 MiB
extra/vlc-plugins-base                       3.0.21-26                3.0.21-27                  0.00 MiB       1.92 MiB
extra/vlc-plugins-video-output               3.0.21-26                3.0.21-27                  0.00 MiB       0.15 MiB
extra/webapp-manager                         1.4.0-1                  1.4.0-2                    0.00 MiB       0.08 MiB
extra/yazi                                   25.5.31-1                25.5.31-2                  0.07 MiB       5.59 MiB
extra/yt-dlp                                 2025.06.30-1             2025.07.21-1               0.09 MiB       4.97 MiB
Total Download Size:    765.55 MiB
Total Installed Size:  1942.22 MiB
Net Upgrade Size:         3.24 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
 opencv-4.12.0-2-x86_64                       28.7 MiB  2.84 MiB/s 00:10 [----------------------------------------] 100%
 digikam-8.7.0-3-x86_64                       28.8 MiB  2.54 MiB/s 00:11 [----------------------------------------] 100%
 lib32-llvm-libs-1:20.1.8-1-x86_64            42.4 MiB  3.43 MiB/s 00:12 [----------------------------------------] 100%
 vlc-3.0.21-27-x86_64                          6.1 MiB  5.44 MiB/s 00:01 [----------------------------------------] 100%
 qt6-declarative-6.9.1-2-x86_64               15.2 MiB  5.25 MiB/s 00:03 [----------------------------------------] 100%
 man-pages-6.15-1-any                          5.5 MiB  3.30 MiB/s 00:02 [----------------------------------------] 100%
 linux615-headers-6.15.8-1-x86_64             38.7 MiB  2.64 MiB/s 00:15 [----------------------------------------] 100%
 yazi-25.5.31-2-x86_64                         5.6 MiB  2.21 MiB/s 00:03 [----------------------------------------] 100%
 fwupd-2.0.13-1-x86_64                         5.1 MiB  2.72 MiB/s 00:02 [----------------------------------------] 100%
 superfile-1.3.2-1-x86_64                      5.0 MiB  3.50 MiB/s 00:01 [----------------------------------------] 100%
 shellcheck-0.10.0-70-x86_64                   3.3 MiB  3.22 MiB/s 00:01 [----------------------------------------] 100%
 yt-dlp-2025.07.21-1-any                       5.0 MiB  2.46 MiB/s 00:02 [----------------------------------------] 100%
 flashrom-1.6.0-1-x86_64                       5.0 MiB  3.10 MiB/s 00:02 [----------------------------------------] 100%
 kid3-common-3.9.7-1-x86_64                    3.0 MiB  2.51 MiB/s 00:01 [----------------------------------------] 100%
 gettext-0.26-1-x86_64                         2.8 MiB  2.01 MiB/s 00:01 [----------------------------------------] 100%
 haskell-lens-5.2.3-111-x86_64              1444.7 KiB  3.01 MiB/s 00:00 [----------------------------------------] 100%
 vlc-plugins-base-3.0.21-27-x86_64          1969.0 KiB  1983 KiB/s 00:01 [----------------------------------------] 100%
 nss-3.114-1-x86_64                         1655.3 KiB  1446 KiB/s 00:01 [----------------------------------------] 100%
 npm-11.4.2-2-any                           1436.6 KiB  1381 KiB/s 00:01 [----------------------------------------] 100%
 haskell-aeson-2.1.2.1-108-x86_64           1202.1 KiB  1171 KiB/s 00:01 [----------------------------------------] 100%
 vlc-gui-qt-3.0.21-27-x86_64                1056.8 KiB  15.2 MiB/s 00:00 [----------------------------------------] 100%
 haskell-vector-0.13.2.0-17-x86_64          1353.0 KiB   971 KiB/s 00:01 [----------------------------------------] 100%
 kmonad-0.4.4-2-x86_64                      1409.3 KiB   860 KiB/s 00:02 [----------------------------------------] 100%
 lib32-nss-3.114-1-x86_64                   1115.3 KiB  1682 KiB/s 00:01 [----------------------------------------] 100%
 libopenmpt-0.8.2-1-x86_64                   891.0 KiB  2.50 MiB/s 00:00 [----------------------------------------] 100%
 djvulibre-3.5.29-1-x86_64                  1056.6 KiB  1482 KiB/s 00:01 [----------------------------------------] 100%
 ostree-2025.4-1-x86_64                      832.3 KiB  2.51 MiB/s 00:00 [----------------------------------------] 100%
 mympd-22.0.2-1-x86_64                       888.2 KiB  1866 KiB/s 00:00 [----------------------------------------] 100%
 libvlc-3.0.21-27-x86_64                     676.3 KiB  1415 KiB/s 00:00 [----------------------------------------] 100%
 lib32-libx11-1.8.12-2-x86_64                622.3 KiB  1058 KiB/s 00:01 [----------------------------------------] 100%
 haskell-free-5.2-46-x86_64                  545.0 KiB  1172 KiB/s 00:00 [----------------------------------------] 100%
 haskell-quickcheck-2.14.3-154-x86_64        525.0 KiB  1190 KiB/s 00:00 [----------------------------------------] 100%
 fastfetch-2.48.1-1-x86_64                   502.5 KiB  1381 KiB/s 00:00 [----------------------------------------] 100%
 linux615-virtualbox-host-modules-7.1.1...   479.6 KiB  1023 KiB/s 00:00 [----------------------------------------] 100%
 linux612-virtualbox-host-modules-7.1.1...   474.7 KiB   995 KiB/s 00:00 [----------------------------------------] 100%
 haskell-regex-tdfa-1.3.2.4-12-x86_64        463.2 KiB   990 KiB/s 00:00 [----------------------------------------] 100%
 phonon-qt6-4.12.0-5-x86_64                  419.0 KiB  1251 KiB/s 00:00 [----------------------------------------] 100%
 haskell-bifunctors-5.6-191-x86_64           393.4 KiB  1144 KiB/s 00:00 [----------------------------------------] 100%
 ca-certificates-mozilla-3.114-1-x86_64      398.6 KiB  1038 KiB/s 00:00 [----------------------------------------] 100%
 haskell-megaparsec-9.6.1-32-x86_64          405.9 KiB   875 KiB/s 00:00 [----------------------------------------] 100%
 haskell-attoparsec-0.14.4-107-x86_64        393.1 KiB   771 KiB/s 00:01 [----------------------------------------] 100%
 parallel-20250722-2-any                     337.0 KiB  1404 KiB/s 00:00 [----------------------------------------] 100%
 qt6-webengine-6.9.1-2-x86_64                 87.1 MiB  3.80 MiB/s 00:23 [----------------------------------------] 100%
 haskell-fgl-5.8.3.0-31-x86_64               321.4 KiB   986 KiB/s 00:00 [----------------------------------------] 100%
 haskell-semigroupoids-6.0.1-24-x86_64       333.0 KiB   812 KiB/s 00:00 [----------------------------------------] 100%
 vlc-plugin-lua-3.0.21-27-x86_64             310.1 KiB  1197 KiB/s 00:00 [----------------------------------------] 100%
 haskell-profunctors-5.6.3-6-x86_64          289.8 KiB   837 KiB/s 00:00 [----------------------------------------] 100%
 libimagequant-4.4.0-1-x86_64                265.1 KiB   794 KiB/s 00:00 [----------------------------------------] 100%
 haskell-optparse-applicative-0.17.1.0-...   262.2 KiB   773 KiB/s 00:00 [----------------------------------------] 100%
 fluidsynth-2.4.7-1-x86_64                   258.3 KiB  1158 KiB/s 00:00 [----------------------------------------] 100%
 pixman-0.46.4-1-x86_64                      284.6 KiB   549 KiB/s 00:01 [----------------------------------------] 100%
 haskell-tasty-1.4.3-138-x86_64              255.1 KiB   721 KiB/s 00:00 [----------------------------------------] 100%
 haskell-primitive-0.8.0.0-25-x86_64         253.5 KiB   896 KiB/s 00:00 [----------------------------------------] 100%
 haskell-random-1.2.1.2-95-x86_64            224.0 KiB   752 KiB/s 00:00 [----------------------------------------] 100%
 haskell-rio-0.1.22.0-157-x86_64             242.1 KiB   654 KiB/s 00:00 [----------------------------------------] 100%
 haskell-unordered-containers-0.2.20-60...   251.7 KiB   662 KiB/s 00:00 [----------------------------------------] 100%
 python-click-8.2.1-1-any                    212.4 KiB   500 KiB/s 00:00 [----------------------------------------] 100%
 haskell-unliftio-0.2.25.1-20-x86_64         210.7 KiB   403 KiB/s 00:01 [----------------------------------------] 100%
 haskell-kan-extensions-5.2.7-7-x86_64       191.7 KiB   680 KiB/s 00:00 [----------------------------------------] 100%
 haskell-reflection-2.1.9-7-x86_64           210.2 KiB   589 KiB/s 00:00 [----------------------------------------] 100%
 nspr-4.37-1-x86_64                          196.5 KiB   447 KiB/s 00:00 [----------------------------------------] 100%
 haskell-adjunctions-4.4.3-24-x86_64         166.0 KiB   340 KiB/s 00:00 [----------------------------------------] 100%
 haskell-invariant-0.6.4-18-x86_64           164.0 KiB  1301 KiB/s 00:00 [----------------------------------------] 100%
 haskell-os-string-2.0.7-38-x86_64           164.1 KiB   850 KiB/s 00:00 [----------------------------------------] 100%
 kid3-qt-3.9.7-1-x86_64                      165.5 KiB   482 KiB/s 00:00 [----------------------------------------] 100%
 haskell-strict-0.5-76-x86_64                162.4 KiB   666 KiB/s 00:00 [----------------------------------------] 100%
 vlc-plugins-video-output-3.0.21-27-x86_64   157.6 KiB   955 KiB/s 00:00 [----------------------------------------] 100%
 less-1:679-1-x86_64                         148.1 KiB   446 KiB/s 00:00 [----------------------------------------] 100%
 sticky-1.25-1-any                           139.0 KiB   239 KiB/s 00:01 [----------------------------------------] 100%
 haskell-semialign-1.3-41-x86_64             132.1 KiB   378 KiB/s 00:00 [----------------------------------------] 100%
 haskell-colour-2.3.6-270-x86_64             154.7 KiB   236 KiB/s 00:01 [----------------------------------------] 100%
 haskell-witherable-0.4.2-159-x86_64         126.7 KiB   354 KiB/s 00:00 [----------------------------------------] 100%
 phonon-qt6-vlc-0.12.0-5-x86_64              120.2 KiB   765 KiB/s 00:00 [----------------------------------------] 100%
 haskell-indexed-traversable-0.1.4-104-...   111.1 KiB   501 KiB/s 00:00 [----------------------------------------] 100%
 lib32-nspr-4.37-1-x86_64                    109.4 KiB   547 KiB/s 00:00 [----------------------------------------] 100%
 haskell-hashable-1.4.4.0-96-x86_64           99.5 KiB   610 KiB/s 00:00 [----------------------------------------] 100%
 haskell-these-1.2.1-14-x86_64                99.5 KiB   809 KiB/s 00:00 [----------------------------------------] 100%
 haskell-scientific-0.3.7.0-146-x86_64       105.9 KiB   466 KiB/s 00:00 [----------------------------------------] 100%
 haskell-comonad-5.0.9-48-x86_64              97.0 KiB   567 KiB/s 00:00 [----------------------------------------] 100%
 libxnvctrl-575.64.05-1-x86_64                93.2 KiB   527 KiB/s 00:00 [----------------------------------------] 100%
 webapp-manager-1.4.0-2-any                   86.2 KiB   473 KiB/s 00:00 [----------------------------------------] 100%
 haskell-base-compat-batteries-0.12.3-1...    75.8 KiB   332 KiB/s 00:00 [----------------------------------------] 100%
 haskell-resourcet-1.2.6-83-x86_64            79.6 KiB   312 KiB/s 00:00 [----------------------------------------] 100%
 haskell-ansi-terminal-types-0.11.5-60-...    74.6 KiB   602 KiB/s 00:00 [----------------------------------------] 100%
 haskell-foldable1-classes-compat-0.1-1...    74.6 KiB   561 KiB/s 00:00 [----------------------------------------] 100%
 haskell-text-short-0.1.6-31-x86_64           73.8 KiB   572 KiB/s 00:00 [----------------------------------------] 100%
 haskell-typed-process-0.2.13.0-2-x86_64      73.3 KiB   341 KiB/s 00:00 [----------------------------------------] 100%
 haskell-time-compat-1.9.6.1-129-x86_64       65.4 KiB   271 KiB/s 00:00 [----------------------------------------] 100%
 haskell-uuid-types-1.0.6-20-x86_64           64.7 KiB   249 KiB/s 00:00 [----------------------------------------] 100%
 haskell-diff-0.4.1-107-x86_64                63.7 KiB   671 KiB/s 00:00 [----------------------------------------] 100%
 vlc-plugin-ogg-3.0.21-27-x86_64              61.0 KiB   598 KiB/s 00:00 [----------------------------------------] 100%
 haskell-async-2.2.5-111-x86_64               59.7 KiB   375 KiB/s 00:00 [----------------------------------------] 100%
 tevent-1:0.17.0-1-x86_64                     58.1 KiB   461 KiB/s 00:00 [----------------------------------------] 100%
 haskell-ansi-wl-pprint-0.6.9-479-x86_64      55.0 KiB   444 KiB/s 00:00 [----------------------------------------] 100%
 perl-path-tiny-0.150-1-any                   40.4 KiB   860 KiB/s 00:00 [----------------------------------------] 100%
 haskell-dlist-1.0-281-x86_64                 49.1 KiB   663 KiB/s 00:00 [----------------------------------------] 100%
 libao-1.2.2-7-x86_64                         54.6 KiB   278 KiB/s 00:00 [----------------------------------------] 100%
 haskell-ansi-terminal-1.0.2-20-x86_64        51.1 KiB   254 KiB/s 00:00 [----------------------------------------] 100%
 vlc-plugin-tag-3.0.21-27-x86_64              39.0 KiB   291 KiB/s 00:00 [----------------------------------------] 100%
 haskell-case-insensitive-1.2.1.0-235-x...    39.0 KiB   394 KiB/s 00:00 [----------------------------------------] 100%
 haskell-distributive-0.6.2.1-243-x86_64      38.4 KiB   312 KiB/s 00:00 [----------------------------------------] 100%
 haskell-splitmix-0.1.0.5-85-x86_64           37.4 KiB   181 KiB/s 00:00 [----------------------------------------] 100%
 haskell-base-orphans-0.9.1-12-x86_64         36.0 KiB   205 KiB/s 00:00 [----------------------------------------] 100%
 haskell-data-fix-0.3.4-2-x86_64              36.5 KiB   177 KiB/s 00:00 [----------------------------------------] 100%
 vlc-plugin-dbus-3.0.21-27-x86_64             33.6 KiB   206 KiB/s 00:00 [----------------------------------------] 100%
 haskell-safe-exceptions-0.1.7.4-53-x86_64    33.3 KiB  92.9 KiB/s 00:00 [----------------------------------------] 100%
 haskell-integer-logarithms-1.0.4-8-x86_64    29.4 KiB  94.3 KiB/s 00:00 [----------------------------------------] 100%
 mhwd-nvidia-575.64.05-1-any                  28.1 KiB   160 KiB/s 00:00 [----------------------------------------] 100%
 haskell-indexed-traversable-instances-...    24.7 KiB  94.8 KiB/s 00:00 [----------------------------------------] 100%
 haskell-transformers-base-0.4.6-134-x86_64   22.2 KiB  97.5 KiB/s 00:00 [----------------------------------------] 100%
 linux612-6.12.40-1-x86_64                   139.6 MiB  4.92 MiB/s 00:28 [----------------------------------------] 100%
 vlc-plugin-alsa-3.0.21-27-x86_64             17.9 KiB   408 KiB/s 00:00 [----------------------------------------] 100%
 vlc-plugin-pulse-3.0.21-27-x86_64            21.8 KiB  99.9 KiB/s 00:00 [----------------------------------------] 100%
 haskell-call-stack-0.4.0-246-x86_64          17.3 KiB  90.0 KiB/s 00:00 [----------------------------------------] 100%
 vlc-plugin-vorbis-3.0.21-27-x86_64           15.8 KiB  71.6 KiB/s 00:00 [----------------------------------------] 100%
 vlc-plugin-speex-3.0.21-27-x86_64            15.8 KiB  58.2 KiB/s 00:00 [----------------------------------------] 100%
 python-setproctitle-1.3.6-1-x86_64           14.9 KiB  94.6 KiB/s 00:00 [----------------------------------------] 100%
 vlc-plugin-opus-3.0.21-27-x86_64             14.9 KiB   164 KiB/s 00:00 [----------------------------------------] 100%
 vlc-plugin-theora-3.0.21-27-x86_64           14.2 KiB   240 KiB/s 00:00 [----------------------------------------] 100%
 haskell-assoc-1.1.1-30-x86_64                13.4 KiB   154 KiB/s 00:00 [----------------------------------------] 100%
 vlc-plugin-gnutls-3.0.21-27-x86_64           13.4 KiB  82.0 KiB/s 00:00 [----------------------------------------] 100%
 vlc-cli-3.0.21-27-x86_64                     12.8 KiB  53.5 KiB/s 00:00 [----------------------------------------] 100%
 vlc-plugin-flac-3.0.21-27-x86_64             12.5 KiB  46.2 KiB/s 00:00 [----------------------------------------] 100%
 vlc-plugin-faad2-3.0.21-27-x86_64            12.2 KiB  45.0 KiB/s 00:00 [----------------------------------------] 100%
 mhwd-db-20250724-1-any                       11.9 KiB  44.3 KiB/s 00:00 [----------------------------------------] 100%
 vlc-plugin-vpx-3.0.21-27-x86_64              10.0 KiB  65.7 KiB/s 00:00 [----------------------------------------] 100%
 vlc-plugin-jpeg-3.0.21-27-x86_64             11.7 KiB  47.7 KiB/s 00:00 [----------------------------------------] 100%
 vlc-plugin-png-3.0.21-27-x86_64               9.3 KiB   141 KiB/s 00:00 [----------------------------------------] 100%
 vlc-plugin-archive-3.0.21-27-x86_64          11.3 KiB  54.1 KiB/s 00:00 [----------------------------------------] 100%
 vlc-plugin-shout-3.0.21-27-x86_64            10.2 KiB  44.1 KiB/s 00:00 [----------------------------------------] 100%
 haskell-onetuple-0.4.2-46-x86_64              9.6 KiB  37.6 KiB/s 00:00 [----------------------------------------] 100%
 vlc-plugin-twolame-3.0.21-27-x86_64           9.2 KiB  36.5 KiB/s 00:00 [----------------------------------------] 100%
 vlc-plugin-mpg123-3.0.21-27-x86_64            9.1 KiB  44.9 KiB/s 00:00 [----------------------------------------] 100%
 vlc-plugin-dav1d-3.0.21-27-x86_64             9.0 KiB  74.5 KiB/s 00:00 [----------------------------------------] 100%
 vlc-plugin-dbus-screensaver-3.0.21-27-...     8.1 KiB  79.3 KiB/s 00:00 [----------------------------------------] 100%
 vlc-plugin-inflate-3.0.21-27-x86_64           7.8 KiB  55.9 KiB/s 00:00 [----------------------------------------] 100%
 vlc-plugin-a52dec-3.0.21-27-x86_64            8.7 KiB  52.0 KiB/s 00:00 [----------------------------------------] 100%
 vlc-plugin-xml-3.0.21-27-x86_64               7.8 KiB  38.5 KiB/s 00:00 [----------------------------------------] 100%
 haskell-void-0.7.3-235-x86_64                 7.2 KiB  84.5 KiB/s 00:00 [----------------------------------------] 100%
 install-grub-2:2.12.r350.g0e367796-2-x...     6.6 KiB   212 KiB/s 00:00 [----------------------------------------] 100%
 vlc-plugin-journal-3.0.21-27-x86_64           7.1 KiB  47.9 KiB/s 00:00 [----------------------------------------] 100%
 haskell-generically-0.1.1-19-x86_64           6.9 KiB  64.6 KiB/s 00:00 [----------------------------------------] 100%
 linux615-6.15.8-1-x86_64                    142.9 MiB  4.58 MiB/s 00:31 [----------------------------------------] 100%
 vivaldi-7.5.3735.56-1-x86_64                164.7 MiB  4.80 MiB/s 00:34 [----------------------------------------] 100%
 Total (144/144)                             765.6 MiB  22.1 MiB/s 00:35 [----------------------------------------] 100%
(144/144) checking keys in keyring                                       [----------------------------------------] 100%
(144/144) checking package integrity                                     [----------------------------------------] 100%
(144/144) loading package files                                          [----------------------------------------] 100%
(144/144) checking for file conflicts                                    [----------------------------------------] 100%
(144/144) checking available disk space                                  [----------------------------------------] 100%
(1/4) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(2/4) Removing linux initcpios...
(3/4) Remove DKMS modules
==> dkms remove --no-depmod v4l2loopback/0.15.0 -k 6.15.7-1-MANJARO
==> depmod 6.15.7-1-MANJARO
(4/4) Unregistering Haskell modules...
(  1/144) upgrading ca-certificates-mozilla                              [----------------------------------------] 100%
(  2/144) upgrading libopenmpt                                           [----------------------------------------] 100%
(  3/144) upgrading pixman                                               [----------------------------------------] 100%
(  4/144) upgrading opencv                                               [----------------------------------------] 100%
(  5/144) upgrading nspr                                                 [----------------------------------------] 100%
(  6/144) upgrading nss                                                  [----------------------------------------] 100%
(  7/144) upgrading qt6-declarative                                      [----------------------------------------] 100%
(  8/144) upgrading qt6-webengine                                        [----------------------------------------] 100%
(  9/144) upgrading gettext                                              [----------------------------------------] 100%
( 10/144) upgrading digikam                                              [----------------------------------------] 100%
( 11/144) upgrading djvulibre                                            [----------------------------------------] 100%
( 12/144) upgrading fastfetch                                            [----------------------------------------] 100%
( 13/144) upgrading flashrom                                             [----------------------------------------] 100%
( 14/144) upgrading fluidsynth                                           [----------------------------------------] 100%
( 15/144) upgrading fwupd                                                [----------------------------------------] 100%
( 16/144) upgrading haskell-base-orphans                                 [----------------------------------------] 100%
( 17/144) upgrading haskell-distributive                                 [----------------------------------------] 100%
( 18/144) upgrading haskell-foldable1-classes-compat                     [----------------------------------------] 100%
( 19/144) upgrading haskell-indexed-traversable                          [----------------------------------------] 100%
( 20/144) upgrading haskell-comonad                                      [----------------------------------------] 100%
( 21/144) upgrading haskell-bifunctors                                   [----------------------------------------] 100%
( 22/144) upgrading haskell-profunctors                                  [----------------------------------------] 100%
( 23/144) upgrading haskell-os-string                                    [----------------------------------------] 100%
( 24/144) upgrading haskell-hashable                                     [----------------------------------------] 100%
( 25/144) upgrading haskell-unordered-containers                         [----------------------------------------] 100%
( 26/144) upgrading haskell-semigroupoids                                [----------------------------------------] 100%
( 27/144) upgrading haskell-transformers-base                            [----------------------------------------] 100%
( 28/144) upgrading haskell-free                                         [----------------------------------------] 100%
( 29/144) upgrading haskell-void                                         [----------------------------------------] 100%
( 30/144) upgrading haskell-adjunctions                                  [----------------------------------------] 100%
( 31/144) upgrading haskell-onetuple                                     [----------------------------------------] 100%
( 32/144) upgrading haskell-splitmix                                     [----------------------------------------] 100%
( 33/144) upgrading haskell-random                                       [----------------------------------------] 100%
( 34/144) upgrading haskell-quickcheck                                   [----------------------------------------] 100%
( 35/144) upgrading haskell-integer-logarithms                           [----------------------------------------] 100%
( 36/144) upgrading haskell-primitive                                    [----------------------------------------] 100%
( 37/144) upgrading haskell-scientific                                   [----------------------------------------] 100%
( 38/144) upgrading haskell-attoparsec                                   [----------------------------------------] 100%
( 39/144) upgrading haskell-base-compat-batteries                        [----------------------------------------] 100%
( 40/144) upgrading haskell-data-fix                                     [----------------------------------------] 100%
( 41/144) upgrading haskell-dlist                                        [----------------------------------------] 100%
( 42/144) upgrading haskell-generically                                  [----------------------------------------] 100%
( 43/144) upgrading haskell-colour                                       [----------------------------------------] 100%
( 44/144) upgrading haskell-ansi-terminal-types                          [----------------------------------------] 100%
( 45/144) upgrading haskell-ansi-terminal                                [----------------------------------------] 100%
( 46/144) upgrading haskell-ansi-wl-pprint                               [----------------------------------------] 100%
( 47/144) upgrading haskell-optparse-applicative                         [----------------------------------------] 100%
( 48/144) upgrading haskell-tasty                                        [----------------------------------------] 100%
( 49/144) upgrading haskell-vector                                       [----------------------------------------] 100%
( 50/144) upgrading haskell-indexed-traversable-instances                [----------------------------------------] 100%
( 51/144) upgrading haskell-assoc                                        [----------------------------------------] 100%
( 52/144) upgrading haskell-these                                        [----------------------------------------] 100%
( 53/144) upgrading haskell-semialign                                    [----------------------------------------] 100%
( 54/144) upgrading haskell-strict                                       [----------------------------------------] 100%
( 55/144) upgrading haskell-text-short                                   [----------------------------------------] 100%
( 56/144) upgrading haskell-time-compat                                  [----------------------------------------] 100%
( 57/144) upgrading haskell-uuid-types                                   [----------------------------------------] 100%
( 58/144) upgrading haskell-witherable                                   [----------------------------------------] 100%
( 59/144) upgrading haskell-aeson                                        [----------------------------------------] 100%
( 60/144) upgrading haskell-async                                        [----------------------------------------] 100%
( 61/144) upgrading haskell-call-stack                                   [----------------------------------------] 100%
( 62/144) upgrading haskell-case-insensitive                             [----------------------------------------] 100%
( 63/144) upgrading haskell-diff                                         [----------------------------------------] 100%
( 64/144) upgrading haskell-fgl                                          [----------------------------------------] 100%
( 65/144) upgrading haskell-invariant                                    [----------------------------------------] 100%
( 66/144) upgrading haskell-kan-extensions                               [----------------------------------------] 100%
( 67/144) upgrading haskell-reflection                                   [----------------------------------------] 100%
( 68/144) upgrading haskell-lens                                         [----------------------------------------] 100%
( 69/144) upgrading haskell-megaparsec                                   [----------------------------------------] 100%
( 70/144) upgrading haskell-regex-tdfa                                   [----------------------------------------] 100%
( 71/144) upgrading haskell-resourcet                                    [----------------------------------------] 100%
( 72/144) upgrading haskell-typed-process                                [----------------------------------------] 100%
( 73/144) upgrading haskell-safe-exceptions                              [----------------------------------------] 100%
( 74/144) upgrading haskell-unliftio                                     [----------------------------------------] 100%
( 75/144) upgrading haskell-rio                                          [----------------------------------------] 100%
( 76/144) upgrading install-grub                                         [----------------------------------------] 100%
:: To use the new features provided in this GRUB update, it is recommended
   to install it to the MBR or UEFI. Due to potential configuration
   incompatibilities, it is advised to run both, installation and generation
   of configuration:
     # UEFI: https://wiki.archlinux.org/title/GRUB#Installation
     # BIOS: https://wiki.archlinux.org/title/GRUB#Installation_2
( 77/144) upgrading kid3-common                                          [----------------------------------------] 100%
( 78/144) upgrading kid3-qt                                              [----------------------------------------] 100%
( 79/144) upgrading kmonad                                               [----------------------------------------] 100%
( 80/144) upgrading less                                                 [----------------------------------------] 100%
( 81/144) upgrading lib32-libx11                                         [----------------------------------------] 100%
( 82/144) upgrading lib32-llvm-libs                                      [----------------------------------------] 100%
( 83/144) upgrading lib32-nspr                                           [----------------------------------------] 100%
( 84/144) upgrading lib32-nss                                            [----------------------------------------] 100%
( 85/144) upgrading libao                                                [----------------------------------------] 100%
( 86/144) upgrading libimagequant                                        [----------------------------------------] 100%
( 87/144) upgrading libvlc                                               [----------------------------------------] 100%
( 88/144) upgrading libxnvctrl                                           [----------------------------------------] 100%
( 89/144) upgrading linux612                                             [----------------------------------------] 100%
( 90/144) upgrading linux612-virtualbox-host-modules                     [----------------------------------------] 100%
( 91/144) upgrading linux615                                             [----------------------------------------] 100%
( 92/144) upgrading linux615-headers                                     [----------------------------------------] 100%
( 93/144) upgrading linux615-virtualbox-host-modules                     [----------------------------------------] 100%
( 94/144) upgrading man-pages                                            [----------------------------------------] 100%
( 95/144) upgrading mhwd-nvidia                                          [----------------------------------------] 100%
( 96/144) upgrading mhwd-db                                              [----------------------------------------] 100%
( 97/144) upgrading mympd                                                [----------------------------------------] 100%
( 98/144) upgrading npm                                                  [----------------------------------------] 100%
( 99/144) upgrading ostree                                               [----------------------------------------] 100%
(100/144) upgrading parallel                                             [----------------------------------------] 100%
(101/144) upgrading perl-path-tiny                                       [----------------------------------------] 100%
(102/144) upgrading vlc-plugin-alsa                                      [----------------------------------------] 100%
(103/144) upgrading vlc-plugin-a52dec                                    [----------------------------------------] 100%
(104/144) installing vlc-plugin-archive                                  [----------------------------------------] 100%
(105/144) upgrading vlc-plugin-dav1d                                     [----------------------------------------] 100%
(106/144) upgrading vlc-plugin-dbus                                      [----------------------------------------] 100%
(107/144) upgrading vlc-plugin-dbus-screensaver                          [----------------------------------------] 100%
(108/144) upgrading vlc-plugin-faad2                                     [----------------------------------------] 100%
(109/144) upgrading vlc-plugin-flac                                      [----------------------------------------] 100%
(110/144) upgrading vlc-plugin-gnutls                                    [----------------------------------------] 100%
(111/144) upgrading vlc-plugin-inflate                                   [----------------------------------------] 100%
(112/144) upgrading vlc-plugin-jpeg                                      [----------------------------------------] 100%
(113/144) upgrading vlc-plugin-journal                                   [----------------------------------------] 100%
(114/144) upgrading vlc-plugin-mpg123                                    [----------------------------------------] 100%
(115/144) installing vlc-plugin-ogg                                      [----------------------------------------] 100%
(116/144) upgrading vlc-plugin-opus                                      [----------------------------------------] 100%
(117/144) upgrading vlc-plugin-png                                       [----------------------------------------] 100%
(118/144) upgrading vlc-plugin-shout                                     [----------------------------------------] 100%
(119/144) upgrading vlc-plugin-speex                                     [----------------------------------------] 100%
(120/144) upgrading vlc-plugin-tag                                       [----------------------------------------] 100%
(121/144) upgrading vlc-plugin-theora                                    [----------------------------------------] 100%
(122/144) upgrading vlc-plugin-twolame                                   [----------------------------------------] 100%
(123/144) upgrading vlc-plugin-vorbis                                    [----------------------------------------] 100%
(124/144) upgrading vlc-plugin-vpx                                       [----------------------------------------] 100%
(125/144) upgrading vlc-plugin-xml                                       [----------------------------------------] 100%
(126/144) upgrading vlc-plugins-base                                     [----------------------------------------] 100%
(127/144) upgrading phonon-qt6-vlc                                       [----------------------------------------] 100%
(128/144) upgrading phonon-qt6                                           [----------------------------------------] 100%
New optional dependencies for phonon-qt6
    qt6-tools: Designer plugin [installed]
(129/144) upgrading python-click                                         [----------------------------------------] 100%
(130/144) upgrading python-setproctitle                                  [----------------------------------------] 100%
(131/144) upgrading shellcheck                                           [----------------------------------------] 100%
(132/144) upgrading sticky                                               [----------------------------------------] 100%
(133/144) upgrading superfile                                            [----------------------------------------] 100%
(134/144) upgrading tevent                                               [----------------------------------------] 100%
(135/144) upgrading vivaldi                                              [----------------------------------------] 100%
(136/144) upgrading vlc-cli                                              [----------------------------------------] 100%
(137/144) upgrading vlc-plugin-lua                                       [----------------------------------------] 100%
(138/144) upgrading vlc-plugin-pulse                                     [----------------------------------------] 100%
(139/144) upgrading vlc-plugins-video-output                             [----------------------------------------] 100%
(140/144) upgrading vlc-gui-qt                                           [----------------------------------------] 100%
(141/144) upgrading vlc                                                  [----------------------------------------] 100%
New optional dependencies for vlc
    vlc-plugin-freetype: for subtitle and on screen display text rendering support
    vlc-plugin-notify: for notification support
    vlc-plugin-srt: for SRT subtitle file support
(142/144) upgrading webapp-manager                                       [----------------------------------------] 100%
(143/144) upgrading yazi                                                 [----------------------------------------] 100%
New optional dependencies for yazi
    7zip: for archive extraction and preview [installed]
    chafa: for ASCII image preview as fallback [installed]
    fzf: for quick file subtree navigation [installed]
    imagemagick: for image and font preview [installed]
    resvg: for SVG preview
    wl-clipboard: for Wayland clipboard support
    xclip: for X11 clipboard support [installed]
    xsel: for X11 clipboard support [installed]
    zoxide: for historical directories navigation [installed]
(144/144) upgrading yt-dlp                                               [----------------------------------------] 100%
( 1/24) Creating system user accounts...
( 2/24) Reloading system manager configuration...
( 3/24) Reloading user manager configuration...
( 4/24) Restarting marked services...
( 5/24) Creating temporary files...
( 6/24) Reloading device manager configuration...
( 7/24) Arming ConditionNeedsUpdate...
( 8/24) Rebuilding certificate stores...
( 9/24) Updating module dependencies...
(10/24) Install DKMS modules
==> dkms install --no-depmod v4l2loopback/0.15.0 -k 6.15.8-1-MANJARO
==> depmod 6.15.8-1-MANJARO
==> ERROR: Missing 6.12.40-1-MANJARO kernel headers for module v4l2loopback/0.15.0.
(11/24) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: 'default'
==> Using default configuration file: '/etc/mkinitcpio.conf'
  -> -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64.img
==> Starting build: '6.12.40-1-MANJARO'
  -> Running build hook: [base]
  -> Running build hook: [udev]
  -> Running build hook: [microcode]
  -> Running build hook: [kms]
  -> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
  -> Running build hook: [fsck]
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.12-x86_64.img'
  -> Early uncompressed CPIO image generation successful
==> Initcpio image generation successful
==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: 'fallback'
  -> -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: 'ast'
==> WARNING: Possibly missing firmware for module: 'xhci_pci_renesas'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> WARNING: Possibly missing firmware for module: 'wd719x'
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> WARNING: Possibly missing firmware for module: 'aic94xx'
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.12-x86_64-fallback.img'
==> Building image from preset: /etc/mkinitcpio.d/linux615.preset: 'default'
  -> -k /boot/vmlinuz-6.15-x86_64 -g /boot/initramfs-6.15-x86_64.img
==> Starting build: '6.15.8-1-MANJARO'
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.15-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux615.preset: 'fallback'
  -> -k /boot/vmlinuz-6.15-x86_64 -g /boot/initramfs-6.15-x86_64-fallback.img -S autodetect
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.15-x86_64-fallback.img'
(12/24) Refreshing PackageKit...
(13/24) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-6.15-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.15-x86_64.img
Found initrd fallback image: /boot/initramfs-6.15-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.12-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.12-x86_64.img
Found initrd fallback image: /boot/initramfs-6.12-x86_64-fallback.img
Warning: os-prober will not be executed to detect other bootable partitions.
Systems on them will not be added to the GRUB boot configuration.
Check GRUB_DISABLE_OS_PROBER documentation entry.
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
(14/24) Reloading system bus configuration...
(15/24) Checking for old perl modules...
(16/24) Registering Haskell modules...
(17/24) Compiling GSettings XML schema files...
(18/24) Updating icon theme caches...
(19/24) Removing old packages from pacman cache...
Removing old installed packages...
==> no candidate packages found for pruning
Removing old uninstalled packages...
(20/24) Looking for Pacnew/Pacsave created.
(21/24) Checking which packages need to be rebuilt
foreign plex-htpc
(22/24) Updating the info directory file...
(23/24) Updating the desktop file MIME type cache...
(24/24) Updating the vlc plugin cache...
After that, just sit tight and wait for a response. If you already ran the update, you should see something more like this:
sudo pacman -Syu
:: Synchronising package databases...
 core is up to date
 extra is up to date
 multilib is up to date
 there is nothing to do
⮞ pacdiff -o
No output from pacdiff -o
You will likely get a LOT more output from this:
journalctl -p3 -xb --no-hostname
So once again, copy the output, click the COG icon to HIDE DETAILS.
Type ~~~ ⏎Enter then Ctrl+V paste then ~~~ again at the end.
If you manage to get this far, then we will see your post, then we can go with pamac and sort AUR and stuff :wink:
I think @Edward78’s problems are most likely caused by his use of the so-called “open” Nvidia drivers — which aren’t really open; only their kernel header is, while the rest of the driver remains a proprietary, binary-only blob.
  journalctl -p3 -xb --no-hostname                                                               ✔
Jul 24 10:12:07 kernel: hid-generic 0003:045E:0823.0002: No inputs registered, leaving
Jul 24 10:12:16 bluetoothd[620]: src/adv_monitor.c:btd_adv_monitor_power_down() Unexpected NULL btd_adv_monit>
Jul 24 10:12:16 org_kde_powerdevil[947]: [   947] Error(s) opening ddc devices
Jul 24 10:12:16 org_kde_powerdevil[947]: [   947] Error EACCES(-13): Permission denied opening /dev/i2c-0
Jul 24 10:12:16 org_kde_powerdevil[947]: [   947] Error EACCES(-13): Permission denied opening /dev/i2c-1
Jul 24 10:12:16 org_kde_powerdevil[947]: [   947] Error EACCES(-13): Permission denied opening /dev/i2c-2
lines 1-6/6 (END)
Mod edit: took care of your formatting
When I am in Firefox, I knoe it is KDE (super key does nothing). I am doing nothing specail. Have no idea where to look for any info, FF 140.0.4 (64-bit).
STEP by STEP.
Start at Number 1.
I had a similar issue. Specifically when playing back video on Firefox the system would sometimes freeze for 30 seconds or so. My system is all AMD so it might not be related, but I tracked it down to a bug with plasma-powerdevil. Apparently it’s fixed in Plasma 6.4. My current workaround is to mask plasma-powerdevil.service.
What .log do I look at to see the prob.? Because of the whole update thing breaking Masnjaro, this is happening on the reinstalled version, but it is racent.
KDE Plasma Version: 6.3.5
KDE Frameworks Version: 6.14.0
Qt Version: 6.9.0
Kernel Version: 6.12.28-1-MANJARO (64-bit)
Graphics Platform: Wayland
Processors: 16 Ă— AMD Ryzen 7 5800X 8-Core Processor
Memory: 31.3 GiB of RAM
Graphics Processor: NVIDIA GeForce RTX 3060 Ti
Manufacturer: Gigabyte Technology Co., Ltd.
Product Name: B550I AORUS PRO AX
I feel like I should update, but not wanting to break Manjaro again & the failsafe doesn’t boot also when this happens.
You are using the nouveau driver because you’re running Wayland instead of X11, but what was the reason why you chose to go with Wayland in the first place?
If the update breaks your system, then you are most likely better off just using X11 and the proprietary Nvidia driver instead. Plasma does still support X11. :man_shrugging:
I think the Nvidia driver breaks the sys on update, KDE falsshes twice then it goes to black screen & the only thing there is a still working cyrsor &hno right click( & whate ever app autostarts. All the black screens after updte threads say it is nvidia. How do I find out wht KDE freezes?
That’s what you said about the nouveau driver as well.
So if both nouveau and the proprietary Nvidia driver break your system on updating, then there’s only one solution, which is to yank that Nvidia card out of your computer and install an AMD card instead.
And then you can have a trouble-free graphical experience, and you can run Wayland.
