KDE freeze every few seconds with Nvidia driver
Hi there,
I’ve got a problem on a fresh installation of Manjaro KDE on a freshly built PC.
I booted the installation media with proprietary drivers and got instantly a message from kwin that the desktop effects were restarted due to graphics reset (the original message was in german so I translated it manually, hope this is accurate), leading to a not responding desktop. The only thing that was usable was the installer window. So I clicked through the installation as normal and was thinking, maybe it’s just a problem with the live image and will be fixed after the installation is finished.
Sadly after rebooting the kwin message pops up every few seconds, leading once again to a not responding desktop environment.
I switched to TTY2 and made a complete system update with pamac and made a reboot, problem is still there. I then managed to click through the settings to the hardware point (took about 15 minutes), the graphics card is listed there with “unknown” and the video-nvidia is ticked at “installed”.
Once again on TTY2 I checked the installed hardware and the graphics cards model is listed without any problem, with only the proprietary driver.
I reinstalled all packages related to the nvidia driver and rebooted again, problem is still there.
Then I made a fresh install, again with proprietary drivers, same problem. (Thought maybe something went wrong on the first go).
After that I made a fresh install again, but this time with open source drivers. I also had some issues on the live image (flickering background image) but after booting into the finished installation everything was fine, no errors from kwin.
Even the login process was much quicker as before with the proprietary driver.
Long story short:
I’ve read everywhere that you should use the proprietary driver when using a nvidia gpu, because nouveau has several disadvantages and problems which the proprietary driver hasn’t.
I don’t really know how to solve this and, maybe even more important, I don’t know if it’s worth the effort when nouveau just runs fine.
I have to say that I’m still on the workbench with this new PC so no part of the productive enviroment is connected at the moment. I want to connect 3 (maybe 4 in the future) wqhd monitors to this, at the moment there is just one of them connected.
Has someone experience with this and could give me a hint?
provide system info:
inxi -Faz
mhwd -l && mhwd -li
use formatting, click this icon in editor: </> and copy the output there
inxi -Faz output:
  Kernel: 5.15.65-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    root=UUID=ef93ace5-143b-4522-9a5a-8c42a63e1fcf rw quiet
    udev.log_priority=3
  Console: pty pts/1 DM: SDDM Distro: Manjaro Linux base: Arch Linux
  Type: Desktop System: Gigabyte product: X570 I AORUS PRO WIFI v: -CF
    serial: <superuser required>
  Mobo: Gigabyte model: X570 I AORUS PRO WIFI v: x.x
    serial: <superuser required> UEFI: American Megatrends v: F32
    date: 01/18/2021
  Device-1: hidpp_battery_0 model: Logitech Wireless Solar Keyboard K750
    serial: <filter> charge: 100% rechargeable: yes status: full
  Device-2: hidpp_battery_1 model: Logitech Marathon Mouse/Performance Plus
    M705 serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3 gen: 4
    level: v3 built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25)
    model-id: 0x21 (33) stepping: 2 microcode: N/A
  Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
    L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
    L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 2542 high: 3588 min/max: 2200/5083 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2475 2: 2872
    3: 2868 4: 2871 5: 2870 6: 2872 7: 2870 8: 2868 9: 2196 10: 2192 11: 2196
    12: 2191 13: 2190 14: 2194 15: 2194 16: 2198 17: 3588 18: 2869 19: 2874
    20: 2868 21: 2869 22: 2868 23: 2873 24: 2873 25: 2193 26: 2193 27: 2193
    28: 2194 29: 2189 30: 2194 31: 2196 32: 2194 bogomips: 217248
    prctl and seccomp
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA GA106 [Geforce RTX 3050] vendor: PNY driver: nouveau
    v: kernel non-free: 515.xx+ status: current (as of 2022-08) arch: Ampere
    code: GAxxx process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
    speed: 16 GT/s lanes: 8 link-max: lanes: 16 ports: active: DP-3
    empty: DP-1,DP-2,HDMI-A-1 bus-ID: 09:00.0 chip-ID: 10de:2507
    class-ID: 0300
  Display: x11 server: X.org v: 1.21.1.4 compositor: kwin_x11 driver: X:
    loaded: modesetting alternate: fbdev,vesa gpu: nouveau tty: 80x24
  Monitor-1: DP-3 model: Dell P2719HC serial: <filter> built: 2018
    res: 1920x1080 dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23")
    diag: 686mm (27") ratio: 16:9 modes: max: 1920x1080 min: 720x400
  Message: GL data unavailable in console. Try -G --display
  Device-1: NVIDIA GA106 High Definition Audio vendor: PNY
    driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
    link-max: lanes: 16 bus-ID: 09:00.1 chip-ID: 10de:228e class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
    bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
  Sound Server-1: ALSA v: k5.15.65-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.57 running: no
  Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0
  IF: enp4s0 state: down mac: <filter>
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp5s0 state: up mac: <filter>
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
    bus-ID: 1-2:3 chip-ID: 8087:0029 class-ID: e001
  Local Storage: total: 931.51 GiB used: 14.22 GiB (1.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B
    speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter> rev: 5B2QGXA7
    temp: 37.9 C scheme: GPT
  ID-1: / raw-size: 931.22 GiB size: 930.76 GiB (99.95%) used: 14.22 GiB
    (1.5%) fs: xfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB
    (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 32.8 C mobo: 30.0 C
  Processes: 486 Uptime: 4m wakeups: 5 Memory: 62.74 GiB used: 1.5 GiB (2.4%)
  Init: systemd v: 251 default: graphical tool: systemctl Compilers:
  gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1089 libs: 306
  tools: pamac Shell: Bash v: 5.1.16 running-in: pty pts/1 (SSH) inxi: 3.3.21
mhwd -l && mhwd -li:
> 0000:09:00.0 (0300:10de:2507) Display controller nVidia Corporation:
          video-nvidia            2021.11.04               false            PCI
    video-nvidia-470xx            2021.11.04               false            PCI
           video-linux            2018.05.04                true            PCI
> Installed PCI configs:
how is the nvidia connected? via cable or directly plugged in the motherboard?
provide logs:
journalctl -b0 -p4 --no-pager
Directly plugged into the motherboard.
Okt 04 17:38:05 ahcli298 kernel:  #17 #18 #19 #20 #21 #22 #23 #24 #25 #26 #27 #28 #29 #30 #31
Okt 04 17:38:05 ahcli298 kernel: usb: port power management may be unreliable
Okt 04 17:38:05 ahcli298 kernel: vboxdrv: loading out-of-tree module taints kernel.
Okt 04 17:38:05 ahcli298 kernel: VBoxNetAdp: Successfully started.
Okt 04 17:38:05 ahcli298 kernel: VBoxNetFlt: Successfully started.
Okt 04 17:38:05 ahcli298 kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Okt 04 17:38:05 ahcli298 kernel: ACPI Warning: SystemIO range 0x0000000000000B00-0x0000000000000B08 conflicts with OpRegion 0x0000000000000B00-0x0000000000000B0F (\GSA1.SMBI) (20210730/utaddress-204)
Okt 04 17:38:06 ahcli298 systemd[866]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Okt 04 17:38:06 ahcli298 kernel: iwlwifi 0000:05:00.0: api flags index 2 larger than supported by driver
Okt 04 17:38:06 ahcli298 kernel: thermal thermal_zone2: failed to read out thermal zone (-61)
Okt 04 17:38:06 ahcli298 vmnet-dhcpd[1017]: exiting.
Okt 04 17:38:07 ahcli298 vmnet-dhcpd[1045]: exiting.
Okt 04 17:38:07 ahcli298 systemd[1]: vmware.service: Failed with result 'exit-code'.
Okt 04 17:38:07 ahcli298 kernel: kauditd_printk_skb: 30 callbacks suppressed
Okt 04 17:38:07 ahcli298 systemd[1057]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Okt 04 17:38:07 ahcli298 systemd[1057]: Failed to start Update XDG user dir configuration.
Okt 04 17:38:07 ahcli298 sddm-greeter[1065]: QFont::fromString: Invalid description '(empty)'
Okt 04 17:38:07 ahcli298 sddm-greeter[1065]: QObject: Cannot create children for a parent that is in a different thread.
                                             (Parent is QGuiApplication(0x7ffcd27c9b00), parent's thread is QThread(0x55789d365450), current thread is QThread(0x55789d798250)
Okt 04 17:38:07 ahcli298 sddm-greeter[1065]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Okt 04 17:38:07 ahcli298 sddm-greeter[1065]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Okt 04 17:38:07 ahcli298 sddm-greeter[1065]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
Okt 04 17:38:07 ahcli298 sddm-greeter[1065]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Okt 04 17:38:08 ahcli298 sddm-greeter[1065]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Okt 04 17:38:08 ahcli298 sddm-greeter[1065]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.17'
Okt 04 17:38:16 ahcli298 kernel: kauditd_printk_skb: 11 callbacks suppressed
Okt 05 00:00:15 ahcli298 systemd[1]: pkgfile-update.service: Failed with result 'exit-code'.
Okt 05 00:00:15 ahcli298 systemd[1]: Failed to start pkgfile database update.
Okt 05 11:07:45 ahcli298 sddm-helper[1955]: [PAM] authenticate: Fehler bei Authentifizierung
Okt 05 11:07:45 ahcli298 sddm[967]: Authentication error: "Fehler bei Authentifizierung"
Okt 05 11:07:45 ahcli298 sddm[967]: Auth: sddm-helper exited with 1
Okt 05 11:07:49 ahcli298 ksplashqml[1980]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
Okt 05 11:07:49 ahcli298 ksplashqml[1980]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:82:29: Unable to assign int to QEasingCurve
Okt 05 11:07:49 ahcli298 ksmserver[2037]: Qt: Session management error: networkIdsList argument is NULL
Okt 05 11:07:49 ahcli298 kwin_x11[2040]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Okt 05 11:07:49 ahcli298 kwin_x11[2040]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Okt 05 11:07:49 ahcli298 ksmserver[2037]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.10'
Okt 05 11:07:49 ahcli298 plasmashell[2124]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Okt 05 11:07:49 ahcli298 plasmashell[2124]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Okt 05 11:07:49 ahcli298 kwin_x11[2040]: kwin_platform_x11_standalone: glSwapInterval is unsupported
Okt 05 11:07:49 ahcli298 kwin_x11[2040]: QObject::connect(KWin::InputMethod, KWin::EffectsHandlerImpl): invalid nullptr parameter
Okt 05 11:07:49 ahcli298 backlighthelper[2195]: org.kde.powerdevil: no kernel backlight interface found
Okt 05 11:07:49 ahcli298 kded5[2039]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.10'
Okt 05 11:07:49 ahcli298 org_kde_powerdevil[2153]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Okt 05 11:07:49 ahcli298 org_kde_powerdevil[2153]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Okt 05 11:07:49 ahcli298 org_kde_powerdevil[2153]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Okt 05 11:07:49 ahcli298 org_kde_powerdevil[2153]: org.kde.powerdevil: The profile  "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
Okt 05 11:07:50 ahcli298 plasmashell[2124]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:70:5: QML Connections: Detected function "onConfigurationChanged" in Connections element. This is probably intended to be a signal handler but no signal of the target matches the name.
Okt 05 11:07:50 ahcli298 plasmashell[2124]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:70:5: QML Connections: Detected function "onRepaintNeeded" in Connections element. This is probably intended to be a signal handler but no signal of the target matches the name.
Okt 05 11:07:50 ahcli298 plasmashell[2124]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:67: TypeError: Cannot read property 'wallpaper' of null
Okt 05 11:07:50 ahcli298 plasmashell[2124]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:71: TypeError: Cannot read property 'wallpaper' of null
Okt 05 11:07:50 ahcli298 plasmashell[2124]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Okt 05 11:07:50 ahcli298 plasmashell[2124]: requesting unexisting screen -1
Okt 05 11:07:50 ahcli298 plasmashell[2124]: org.kde.plasma.containmentlayoutmanager: Error: cannot change the containment to AppletsLayout
Okt 05 11:07:50 ahcli298 plasmashell[2124]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:179: TypeError: Cannot read property 'containmentDisplayHints' of null
Okt 05 11:07:50 ahcli298 plasmashell[2124]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:271: TypeError: Cannot read property 'location' of null
Okt 05 11:07:50 ahcli298 plasmashell[2124]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Okt 05 11:07:50 ahcli298 plasmashell[2124]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:532:9: QML Label: Binding loop detected for property "height"
Okt 05 11:07:50 ahcli298 plasmashell[2124]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:497:13: QML Label: Binding loop detected for property "height"
Okt 05 11:07:50 ahcli298 plasmashell[2124]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/ConfigOverlay.qml:312:17: QML SpinBox: Binding loop detected for property "implicitWidth"
Okt 05 11:07:50 ahcli298 plasmashell[2124]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/ConfigOverlay.qml:304:17: QML Heading: Binding loop detected for property "verticalAlignment"
Okt 05 11:07:50 ahcli298 plasmashell[2124]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:554:5: QML Label: Binding loop detected for property "height"
Okt 05 11:07:50 ahcli298 plasmashell[2124]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
Okt 05 11:07:50 ahcli298 plasmashell[2124]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Okt 05 11:07:50 ahcli298 plasmashell[2124]: file:///usr/share/plasma/plasmoids/org.kde.plasma.volume/contents/ui/main.qml:603:39: Invalid property assignment: string expected - Assigning null to incompatible properties in QML is deprecated. This will become a compile error in future versions of Qt.
Okt 05 11:07:51 ahcli298 plasmashell[2124]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:167:9: QML HiddenItemsView: Binding loop detected for property "implicitHeight"
Okt 05 11:07:51 ahcli298 plasmashell[2124]: requesting unexisting screen -1
Okt 05 11:07:51 ahcli298 plasmashell[2124]: org.kde.plasma.containmentlayoutmanager: Error: cannot change the containment to AppletsLayout
Okt 05 11:07:51 ahcli298 plasmashell[2124]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:17:1: QML MouseArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Okt 05 11:07:51 ahcli298 plasmashell[2124]: Both point size and pixel size set. Using pixel size.
Okt 05 11:07:51 ahcli298 plasmashell[2124]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/Tooltip.qml:55:9: QML GridLayout (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Okt 05 11:07:51 ahcli298 plasmashell[2124]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Okt 05 11:07:51 ahcli298 pulseaudio[2365]: stat('/etc/pulse/default.pa.d'): Datei oder Verzeichnis nicht gefunden
Okt 05 11:07:51 ahcli298 plasmashell[2124]: org.kde.plasma.pulseaudio: No object for name "auto_null.monitor"
Okt 05 11:07:51 ahcli298 plasmashell[2124]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Okt 05 11:07:52 ahcli298 plasmashell[2124]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Okt 05 11:07:53 ahcli298 plasmashell[2124]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Okt 05 11:07:54 ahcli298 plasmashell[2124]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Okt 05 11:07:55 ahcli298 plasmashell[2124]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Okt 05 11:07:55 ahcli298 plasmashell[2124]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Okt 05 11:07:59 ahcli298 kernel: kauditd_printk_skb: 16 callbacks suppressed
Okt 05 11:08:19 ahcli298 kwin_x11[2040]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 26224, resource id: 4194338, major code: 18 (ChangeProperty), minor code: 0
Okt 05 11:08:29 ahcli298 plasmashell[2124]: trying to show an empty dialog
Okt 05 11:08:37 ahcli298 plasmashell[2124]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Okt 05 11:08:37 ahcli298 plasmashell[2124]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Okt 05 11:08:40 ahcli298 kwin_x11[2040]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 30836, resource id: 27263110, major code: 18 (ChangeProperty), minor code: 0
Okt 05 11:08:40 ahcli298 kwin_x11[2040]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 30950, resource id: 27263111, major code: 18 (ChangeProperty), minor code: 0
Okt 05 11:08:44 ahcli298 kwin_x11[2040]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32541, resource id: 27263113, major code: 18 (ChangeProperty), minor code: 0
Okt 05 11:08:55 ahcli298 kwin_x11[2040]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 33968, resource id: 60817434, major code: 18 (ChangeProperty), minor code: 0
Okt 05 11:08:55 ahcli298 kwin_x11[2040]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 33980, resource id: 27263115, major code: 18 (ChangeProperty), minor code: 0
Okt 05 11:08:56 ahcli298 kwin_x11[2040]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 34288, resource id: 56623135, major code: 18 (ChangeProperty), minor code: 0
Okt 05 11:08:56 ahcli298 kwin_x11[2040]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 34304, resource id: 27263116, major code: 18 (ChangeProperty), minor code: 0
Okt 05 11:09:00 ahcli298 plasmashell[2124]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Okt 05 11:10:22 ahcli298 plasmashell[2124]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
check if you have disabled baloo: system settings/file search and uncheck all options, click apply
also try with a newer kernel, install the 5.19, install nvidia drivers and test …
and provide again logs when you have installed the nvidia:
baloo was enabled, I disabled it as recommended.
I installed kernel 5.19 and video-nvidia and uninstalled video-linux.
Output from journalctl before reboot:
Okt 06 11:43:24 ahcli298 kernel:  #17 #18 #19 #20 #21 #22 #23 #24 #25 #26 #27 #28 #29 #30 #31
Okt 06 11:43:24 ahcli298 kernel: usb: port power management may be unreliable
Okt 06 11:43:24 ahcli298 kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Okt 06 11:43:24 ahcli298 kernel: ACPI Warning: SystemIO range 0x0000000000000B00-0x0000000000000B08 conflicts with OpRegion 0x0000000000000B00-0x0000000000000B0F (\GSA1.SMBI) (20220331/utaddress-204)
Okt 06 11:43:24 ahcli298 kernel: iwlwifi 0000:05:00.0: Direct firmware load for iwlwifi-cc-a0-72.ucode failed with error -2
Okt 06 11:43:24 ahcli298 kernel: iwlwifi 0000:05:00.0: api flags index 2 larger than supported by driver
Okt 06 11:43:24 ahcli298 kernel: thermal thermal_zone2: failed to read out thermal zone (-61)
Okt 06 11:43:24 ahcli298 systemd[1]: vmware.service: Failed with result 'exit-code'.
Okt 06 11:43:24 ahcli298 systemd[800]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Okt 06 11:43:25 ahcli298 sddm[722]: Failed to read display number from pipe
Okt 06 11:43:25 ahcli298 vmnet-dhcpd[825]: exiting.
Okt 06 11:43:25 ahcli298 sddm[722]: Attempt 1 starting the Display server on vt 1 failed
Okt 06 11:43:25 ahcli298 vmnet-dhcpd[839]: exiting.
Okt 06 11:43:25 ahcli298 systemd[1]: vmware-networks-server.service: Failed with result 'exit-code'.
Okt 06 11:43:25 ahcli298 systemd[1]: Failed to start VMware Networks.
Okt 06 11:43:27 ahcli298 kernel: kauditd_printk_skb: 27 callbacks suppressed
Okt 06 11:43:27 ahcli298 systemd[929]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Okt 06 11:43:27 ahcli298 systemd[929]: Failed to start Update XDG user dir configuration.
Okt 06 11:43:27 ahcli298 sddm-greeter[938]: QFont::fromString: Invalid description '(empty)'
Okt 06 11:43:27 ahcli298 sddm-greeter[938]: QObject: Cannot create children for a parent that is in a different thread.
                                            (Parent is QGuiApplication(0x7fffe96ad3f0), parent's thread is QThread(0x5602b41d3450), current thread is QThread(0x5602b4604f60)
Okt 06 11:43:27 ahcli298 xdg-desktop-portal-kde[965]: qt.qpa.xcb: could not connect to display
Okt 06 11:43:27 ahcli298 xdg-desktop-portal-kde[965]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
                                                      Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb.
Okt 06 11:43:27 ahcli298 sddm-greeter[938]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Okt 06 11:43:27 ahcli298 systemd-coredump[1003]: [🡕] Process 965 (xdg-desktop-por) of user 967 dumped core.
                                                 Module linux-vdso.so.1 with build-id 1bec817aa8e8d6a151ba4f355252509a26f0f4b8
                                                 Module libuuid.so.1 with build-id 9057a530e6b3b0e71f24602a0039c490c9a0b5a1
                                                 Module libxcb-util.so.1 with build-id b1e4c01b388a3bd7a0a9ad384865b61f5f1d4a24
                                                 Module libxkbcommon-x11.so.0 with build-id 90654f41d9fe91c74bef6672a8b57ab34418b27a
                                                 Module libICE.so.6 with build-id a78252e65631a98d7935f1bca668c2fe1d6bbb53
                                                 Module libSM.so.6 with build-id 66cef8ae9a7848679be78dd26fd47e05110d03b5
                                                 Module libxcb-xinput.so.0 with build-id 409ee697e2b16243bf1fc6429e672f2359033388
                                                 Module libxcb-xkb.so.1 with build-id bad7e1eb65df04a6b2d676a08f68844856edaace
                                                 Module libxcb-xinerama.so.0 with build-id 5d2ab2683447d9bb7bcc49c058dfa06bcb65560d
                                                 Module libxcb-xfixes.so.0 with build-id e231a68d00ee4cfa12a2c31e755a9e2c1e7be450
                                                 Module libxcb-sync.so.1 with build-id 13025f6de23a271636ad321c77eda98801e62e8e
                                                 Module libxcb-shape.so.0 with build-id f9aab9846b5e3523bd534f8a845f36a37d42b3fa
                                                 Module libxcb-render.so.0 with build-id b1ca498d665807ab0ccdafbe8070853efd058173
                                                 Module libxcb-render-util.so.0 with build-id 32609134bf1b73183d07a66f6bd65c94b4542460
                                                 Module libxcb-randr.so.0 with build-id c914473ab7592ed5cf5c191200faaac1089c12ad
                                                 Module libxcb-shm.so.0 with build-id 828fec4d856e2710e732ea8d92c3f250c807b1c2
                                                 Module libxcb-image.so.0 with build-id 0e6feae23e34658646dbd63d11f899c92c5d3c79
                                                 Module libxcb-icccm.so.4 with build-id 5eb9288df14c7f50af1e8db26c37e19d78bf0978
                                                 Module libX11-xcb.so.1 with build-id f92352eae0a30aea89d11beb22367fa985288925
                                                 Module libQt5XcbQpa.so.5 with build-id 22a26a78db099a7a86274c88f67252ec78b8cc41
                                                 Module libqxcb.so with build-id 1fdbc58e0182862fe58a8b652b794def082a3ca0
                                                 Module libdl.so.2 with build-id 414d1d630bc04818a150b9c73e4493f3395e8869
                                                 Module libgmp.so.10 with build-id 26cec2ebe94cc5c4cb99e6988717347222b324fd
                                                 Module libhogweed.so.6 with build-id 5c4a99ad0aabe13bd9b517f92ab339436a2bc1f2
                                                 Module libnettle.so.8 with build-id 6a26cbe6819abc8c57668f80ca8c8160fd85e29e
                                                 Module libunistring.so.2 with build-id 617dbf3d3d6f85d6556a7a036e23845e95490158
                                                 Module libidn2.so.0 with build-id b16e7570b102789b13ff77289762dbfe3f8f46bc
                                                 Module libbrotlienc.so.1 with build-id 74adbc62e4fbb5da9d37b5aa458471f4130862ff
                                                 Module libp11-kit.so.0 with build-id cc372ea3c28c4d3dfc633b4d2e933c8584d2af16
                                                 Module libbrotlicommon.so.1 with build-id acfd597a977c8087bb6184383daae2e828a9ce42
                                                 Module libgpg-error.so.0 with build-id 4738b8a9478177c202cccd64e0eb65d3dea2bfae
                                                 Module libresolv.so.2 with build-id 2e70cfe9f2972fb13487eeefcb10e4afafed6157
                                                 Module libkeyutils.so.1 with build-id ac405ddd17be10ce538da3211415ee50c8f8df79
                                                 Module libkrb5support.so.0 with build-id 9a22a372b2157fb05da1bad94b92d9617513af81
                                                 Module libcom_err.so.2 with build-id 3360a28740ffbbd5a5c0c21d09072445908707e5
                                                 Module libk5crypto.so.3 with build-id 47d53a3ea2b172eb3db1be0ae0272c7c045267e8
                                                 Module libkrb5.so.3 with build-id 1fc969c1f54103d87e400237751b4804569a2730
                                                 Module libpthread.so.0 with build-id 3954d7fd57fa4db438d0ccdd8e2c6f7cc97c2e46
                                                 Module libusbmuxd-2.0.so.6 with build-id fd9f05e7f5b0da4e15972f75b61fd9b4b9f06dbe
                                                 Module libtasn1.so.6 with build-id fa2f7a5bfbcda1481ab5875d5744730ea1be8fb1
                                                 Module libgnutls.so.30 with build-id e849ad24d363553f5ddc88d43926e1ab2601ada9
                                                 Module libbrotlidec.so.1 with build-id 66c54e9301f7e102ecc1d88547e5f0e8a056fe22
                                                 Module libexpat.so.1 with build-id 52f685635e8711c1164d20a1ef8acd3840312094
                                                 Module libogg.so.0 with build-id ca0cae30a809f10db1f16e54a23b4e5ff7b2c54c
                                                 Module libvorbis.so.0 with build-id f4e086347f6c1a66eb73cfe13974a29bd39aabca
                                                 Module libpcre2-8.so.0 with build-id 917fc43d2c9f8539a3e324555c6c73886e8000a8
                                                 Module libicudata.so.71 with build-id 4fef196388e678deb881978139e125e20ee2d94d
                                                 Module liblz4.so.1 with build-id 84ea95d811dad359e94e100ebe6a746294ffe8a7
                                                 Module libgcrypt.so.20 with build-id 8bf3cb884124273640de797a3e77d86c98434ea4
                                                 Module libcap.so.2 with build-id 9b38b08de708f439a9d0a4f8b9914151bc8d4b50
                                                 Module libblkid.so.1 with build-id fb2c5d3c17aac74758a3eb80a2bc1c16bcf183b1
                                                 Module libgraphite2.so.3 with build-id ce58945ebb55b86d3a4e717b6eae29efc4720d8e
                                                 Module libGLX.so.0 with build-id d2c37fb8ec3bc53c67c013b0c6ac63ec086c8883
                                                 Module libGLdispatch.so.0 with build-id 7879a881271650eff97c35aff7a8674859c5ae94
                                                 Module liblzma.so.5 with build-id d08f5868cd5adcc6b7c53bf1725aac65bd4539cd
                                                 Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
                                                 Module libXdmcp.so.6 with build-id d864159ab0008415667db8d5f251696d75c90df2
                                                 Module libXau.so.6 with build-id d9d5e8277140f1a86d3a07d9b52b1703c0a2f9a8
                                                 Module libcrypto.so.1.1 with build-id 7981ea3d69f3c28e46ee312a815af96eab93775c
                                                 Module libssl.so.1.1 with build-id e6b1f97a5b60b4248c49dfc5b11f53f281b507d0
                                                 Module libgssapi_krb5.so.2 with build-id a10eaeef6e9969e80048d247666a3af155716afc
                                                 Module libplist-2.0.so.3 with build-id f16bdd42b3d750ba0a150d286248f5dc50cc76cb
                                                 Module libimobiledevice-1.0.so.6 with build-id bc258677480403cc2df4f0efcfc97e06af826ddc
                                                 Module libudev.so.1 with build-id 8c459883f08a1890f2f1daa9f6eeaae357e9e790
                                                 Module libKF5GlobalAccel.so.5 with build-id dfc766d1818cc24b9e82d7dc6977bff57162e616
                                                 Module libxkbcommon.so.0 with build-id 6cf66eead3fcc20fe5df10162bfbcdcdc8b2a183
                                                 Module libfreetype.so.6 with build-id f89dd5502e75aca28fb5c3ccd0dbd26fe822bfef
                                                 Module libfontconfig.so.1 with build-id 36be6951b8c1e42a7dd05684a37400fc8ef9147c
                                                 Module libwayland-cursor.so.0 with build-id 46a637dbcbb02d6712a201f177377b66598b9121
                                                 Module libXext.so.6 with build-id 17beadf1cb40d41ab36629db3b4eed74110678a7
                                                 Module libltdl.so.7 with build-id 6a619e7b85ea9702e595881863bc9e599565e8a0
                                                 Module libtdb.so.1 with build-id f2bdb5ac97b6addf2026d93b08c8d15defcd9bb8
                                                 Module libvorbisfile.so.3 with build-id 45d2551167a616d448beb033ba49394831992887
                                                 Module libglib-2.0.so.0 with build-id 3ef8f9239c93af698703b12c5c6738fe0129eaa7
                                                 Module libzstd.so.1 with build-id ab54c2881f53ab314e134f3e08c76d504376dd5d
                                                 Module libpcre2-16.so.0 with build-id 8ad49680a3f743a5241632a400d0de30aeaa54dd
                                                 Module libicuuc.so.71 with build-id 633fdc0c5385d916571f6140e7a978ad0630ef55
                                                 Module libicui18n.so.71 with build-id 6fd5c97fd2808ee29958bf809656d5885e7e8963
                                                 Module libdouble-conversion.so.3 with build-id 74bfa78f70f9ae1f759f0ae383fbc7f6f7faf6f8
                                                 Module libsystemd.so.0 with build-id ef3e323faf54271c824851913c119a7767c6bff1
                                                 Module libdbus-1.so.3 with build-id 6dece245a58f1549ed98431e1242f487e8ebf9a2
                                                 Module libKF5DBusAddons.so.5 with build-id 5eb888d8927faddb8d56c8ff6a693e2cce655e5c
                                                 Module ld-linux-x86-64.so.2 with build-id 075a6ad9f1c3f9cbb5f3301186bbe68c6a477808
                                                 Module libmount.so.1 with build-id 9064fc3620c42e6f7aed38119f0a3ec39fca9a37
                                                 Module libacl.so.1 with build-id 27869ed0219ade5d2ffd50eaee11f967187faa8b
                                                 Module libKF5AuthCore.so.5 with build-id da9ff08c6e52c1ef73cfb30a8c37201731c688fc
                                                 Module libKF5Crash.so.5 with build-id 5ab2ca0fc5fa2dea833bb39525117bf40b85d137
                                                 Module libmd4c.so.0 with build-id 2151dba72cdc9960097e6e960a58a2f03c8bb96e
                                                 Module libharfbuzz.so.0 with build-id 0083e085bcb9cb3869e5cb05fbcd9736c41434ab
                                                 Module libz.so.1 with build-id fefe3219a96d682ec98fcfb78866b8594298b5a2
                                                 Module libpng16.so.16 with build-id 14d3b3cc9d61ec1b7c1f86bdf108218a99364945
                                                 Module libGL.so.1 with build-id 6f65953140bc8a2aba47c9d492658dc61891393e
                                                 Module libQt5QmlModels.so.5 with build-id 75ac4ba2a588a639d18be70e47f2b106930ac1a5
                                                 Module libgcc_s.so.1 with build-id 85db482c4585a328d95ec41124337a967bb24d8f
                                                 Module libKF5Archive.so.5 with build-id 819ae3371588dfb743e88c23a417bcbcc2a94694
                                                 Module libQt5Svg.so.5 with build-id 7db0284946e4871e7f9effc797f1dee6b7cb1be6
                                                 Module libxcb-keysyms.so.1 with build-id 507bdc94868b9b1f9d95e31c492694f2513da88d
                                                 Module libxcb.so.1 with build-id 13d677412a71468381b11092915d231f664d18d3
                                                 Module libm.so.6 with build-id 2c8ff1d29b255da5b7371efd5caf57444d622838
                                                 Module libQt5Xml.so.5 with build-id f67bcabb5df91d3dd74fb54fd53421bcd089b9f4
                                                 Module libKF5Codecs.so.5 with build-id bf96c60657188e783178682f28ba9db0ea507aa2
                                                 Module libKF5WidgetsAddons.so.5 with build-id f0abc3bee1fad21ec45b3188ce079b852e2fee80
                                                 Module libKF5GuiAddons.so.5 with build-id d02d92f5bdc155cea56f6c8a709ad60fa56b9317
                                                 Module libKF5ConfigWidgets.so.5 with build-id 60a779885da8389a2d94e258c09a9877b10c4b23
                                                 Module libQt5Network.so.5 with build-id 4ef4fd4a75511783248e62c378fe446cfa4ccc91
                                                 Module libKF5Completion.so.5 with build-id 0b50881b27f40a463706296b458b6f68c99f672d
                                                 Module libKF5JobWidgets.so.5 with build-id 58ac1e987656afcbecf92a8400a13f4dbd458a92
                                                 Module libKF5KIOGui.so.5 with build-id 15fb3141a045d1d4c63535c25cebe7332ee72efe
                                                 Module libKF5Solid.so.5 with build-id e74245c3a71b508d6d27dd5c30fef851c784d4ae
                                                 Module libKF5XmlGui.so.5 with build-id 12dbceba1d2c8b4024175f04c32c7ce59921c767
                                                 Module libKF5Bookmarks.so.5 with build-id 6008e6c2825cba8cea47c90aa66622d0c7006a57
                                                 Module libffi.so.8 with build-id fb5dba105458f179a9153659f3ccd8e1056a2f35
                                                 Module libQt5WaylandClient.so.5 with build-id 032f7f11d4e8511b03ff65222f387e69913adfbf
                                                 Module libdbusmenu-qt5.so.2 with build-id 346cd54093968d3de9e61cc329e9512d248dce18
                                                 Module libXtst.so.6 with build-id eaf941ac9100f7854ebc0d512979d2fc6e87d461
                                                 Module libQt5X11Extras.so.5 with build-id 78547956b3be2e12eece7fa5e9fa9f161b022c50
                                                 Module libX11.so.6 with build-id 21e886e968772b7964d646f54c1faecc56734de9
                                                 Module libQt5TextToSpeech.so.5 with build-id 593099f8617753c871f48e5951f368c3a863e1cf
                                                 Module libcanberra.so.0 with build-id 8ddef69c9b84a86062c88a59510639cd908fc6d3
                                                 Module libc.so.6 with build-id 90b9e4f641f8752292698389f241cbf0ff49d687
                                                 Module libstdc++.so.6 with build-id 735a3d0cc7699fd69337361cba4aedb644b2a7ed
                                                 Module libQt5Core.so.5 with build-id 10f403c84cef570e5302c7b1f0d8db34f8293f71
                                                 Module libQt5DBus.so.5 with build-id 80839ec0184277ea0382ce3fdc7f84eaebb4dff9
                                                 Module libKF5CoreAddons.so.5 with build-id 0c1e61a987dcc5a413145ce6f4b3e9130d478885
                                                 Module libKF5I18n.so.5 with build-id 8b01b131521ee05f8dd1cdc649e8989a403f89e2
                                                 Module libKF5ConfigCore.so.5 with build-id 3a7aadabb9f7166cacb72f765b328e10c66fbfa8
                                                 Module libKF5Service.so.5 with build-id 9aa3259c2748aaa0c6bb8ad3a2d2a5c2a12264d5
                                                 Module libKF5KIOCore.so.5 with build-id 259587c6684343e9bd0ea1b998e84d57033cad09
                                                 Module libQt5Qml.so.5 with build-id 22231cfcf29a284259109c7862fb6e72406b131a
                                                 Module libQt5Gui.so.5 with build-id c3306c1f059a4d83b3ece5ca28ce2a147fc154e3
                                                 Module libQt5Quick.so.5 with build-id 7943b27c49d44215357f6219398a7b376dcf4cbd
                                                 Module libQt5Widgets.so.5 with build-id 7948b4cf67a2e204665689ba69adedcb6ec9f7e7
                                                 Module libKF5ConfigGui.so.5 with build-id 7ceed534598952ecd8bf33ad51b7d0b6db177d07
                                                 Module libKF5ItemViews.so.5 with build-id 056d51112983ee6da4ebeab5da319f58b3543f3f
                                                 Module libQt5PrintSupport.so.5 with build-id c2adb3cc1c1891fbd2099b4285dc59e045edfe1c
                                                 Module libKF5IconThemes.so.5 with build-id 4df7a5f6480a88fd05d6643cdf07638b2c76d4cc
                                                 Module libKF5WindowSystem.so.5 with build-id afc9a1c136b0d640c853e1f451c15bcda90d0575
                                                 Module libKF5KIOWidgets.so.5 with build-id 7c732f0ef6ac9a794468dd6562bcb4fe50bc60fe
                                                 Module libKF5KIOFileWidgets.so.5 with build-id 65786d4c4e326b7284b114c610ddbaf28610c974
                                                 Module libwayland-client.so.0 with build-id 515c72111400d7bdbfbdfcec78d597e4986a5943
                                                 Module libKF5WaylandClient.so.5 with build-id 3bc9e53fdd7340d5d77aa731c529189626b61533
                                                 Module libKF5Notifications.so.5 with build-id b80091b385d6d74d1492928b2c465a0bc6822772
                                                 Module xdg-desktop-portal-kde with build-id 27e57ac12655c1d88c4f219fb1d0fa5d2f87403c
                                                 Stack trace of thread 965:
                                                 #0  0x00007f8c3b8a249c n/a (libc.so.6 + 0x8849c)
                                                 #1  0x00007f8c3b852958 raise (libc.so.6 + 0x38958)
                                                 #2  0x00007f8c3b83c53d abort (libc.so.6 + 0x2253d)
                                                 #3  0x00007f8c3be9fede _ZNK14QMessageLogger5fatalEPKcz (libQt5Core.so.5 + 0x9fede)
                                                 #4  0x00007f8c3cb3caa5 _ZN22QGuiApplicationPrivate25createPlatformIntegrationEv (libQt5Gui.so.5 + 0x13caa5)
                                                 #5  0x00007f8c3cb3d109 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt5Gui.so.5 + 0x13d109)
                                                 #6  0x00007f8c3c0921ab _ZN23QCoreApplicationPrivate4initEv (libQt5Core.so.5 + 0x2921ab)
                                                 #7  0x00007f8c3cb3d1b9 _ZN22QGuiApplicationPrivate4initEv (libQt5Gui.so.5 + 0x13d1b9)
                                                 #8  0x00007f8c3d975e0e _ZN19QApplicationPrivate4initEv (libQt5Widgets.so.5 + 0x175e0e)
                                                 #9  0x000055765fa8d0c6 n/a (xdg-desktop-portal-kde + 0x1e0c6)
                                                 #10 0x00007f8c3b83d290 n/a (libc.so.6 + 0x23290)
                                                 #11 0x00007f8c3b83d34a __libc_start_main (libc.so.6 + 0x2334a)
                                                 #12 0x000055765fa8e535 n/a (xdg-desktop-portal-kde + 0x1f535)
                                                 Stack trace of thread 1000:
                                                 #0  0x00007f8c3b914e5f __poll (libc.so.6 + 0xfae5f)
                                                 #1  0x00007f8c3a56fe2f n/a (libglib-2.0.so.0 + 0xabe2f)
                                                 #2  0x00007f8c3a5180d2 g_main_context_iteration (libglib-2.0.so.0 + 0x540d2)
                                                 #3  0x00007f8c3c0d750c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d750c)
                                                 #4  0x00007f8c3c08532c _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x28532c)
                                                 #5  0x00007f8c3bee749f _ZN7QThread4execEv (libQt5Core.so.5 + 0xe749f)
                                                 #6  0x00007f8c3c8f2cba n/a (libQt5DBus.so.5 + 0x23cba)
                                                 #7  0x00007f8c3bee42ba n/a (libQt5Core.so.5 + 0xe42ba)
                                                 #8  0x00007f8c3b8a074d n/a (libc.so.6 + 0x8674d)
                                                 #9  0x00007f8c3b922700 n/a (libc.so.6 + 0x108700)
Okt 06 11:43:27 ahcli298 systemd[929]: plasma-xdg-desktop-portal-kde.service: Main process exited, code=dumped, status=6/ABRT
Okt 06 11:43:27 ahcli298 systemd[929]: plasma-xdg-desktop-portal-kde.service: Failed with result 'core-dump'.
Okt 06 11:43:27 ahcli298 systemd[929]: Failed to start Xdg Desktop Portal For KDE.
Okt 06 11:43:28 ahcli298 sddm-greeter[938]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Okt 06 11:43:28 ahcli298 sddm-greeter[938]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
Okt 06 11:43:28 ahcli298 sddm-greeter[938]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Okt 06 11:43:28 ahcli298 sddm-greeter[938]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Okt 06 11:43:28 ahcli298 sddm-greeter[938]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.23'
Okt 06 11:43:34 ahcli298 kernel: kauditd_printk_skb: 19 callbacks suppressed
Okt 06 11:43:52 ahcli298 xdg-desktop-por[943]: Failed to create settings proxy: Fehler beim Aufruf von StartServiceByName für org.freedesktop.impl.portal.desktop.kde: Zeitüberschreitung wurde erreicht
Okt 06 11:43:52 ahcli298 xdg-desktop-por[943]: No skeleton to export
Okt 06 11:44:17 ahcli298 xdg-desktop-por[943]: Failed to create file chooser proxy: Fehler beim Aufruf von StartServiceByName für org.freedesktop.impl.portal.desktop.kde: Zeitüberschreitung wurde erreicht
Okt 06 11:44:17 ahcli298 xdg-desktop-por[943]: No skeleton to export
Okt 06 11:44:42 ahcli298 xdg-desktop-por[943]: Failed to create app chooser proxy: Fehler beim Aufruf von StartServiceByName für org.freedesktop.impl.portal.desktop.kde: Zeitüberschreitung wurde erreicht
Okt 06 11:44:42 ahcli298 xdg-desktop-por[943]: No skeleton to export
Okt 06 11:44:58 ahcli298 systemd[929]: xdg-desktop-portal.service: start operation timed out. Terminating.
Okt 06 11:44:58 ahcli298 systemd[929]: xdg-desktop-portal.service: Failed with result 'timeout'.
Okt 06 11:44:58 ahcli298 systemd[929]: Failed to start Portal service.
Okt 06 12:46:48 ahcli298 sddm-helper[1160]: [PAM] authenticate: Fehler bei Authentifizierung
Okt 06 12:46:48 ahcli298 sddm[722]: Authentication error: "Fehler bei Authentifizierung"
Okt 06 12:46:48 ahcli298 sddm[722]: Auth: sddm-helper exited with 1
Okt 06 12:46:53 ahcli298 pipewire[1286]: mod.rt: Can't find xdg-portal: (null)
Okt 06 12:46:53 ahcli298 pipewire[1286]: mod.rt: found session bus but no portal
Okt 06 12:46:53 ahcli298 pipewire-media-session[1287]: mod.rt: Can't find xdg-portal: (null)
Okt 06 12:46:53 ahcli298 pipewire-media-session[1287]: mod.rt: found session bus but no portal
Okt 06 12:46:53 ahcli298 ksplashqml[1221]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
Okt 06 12:46:53 ahcli298 ksplashqml[1221]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:82:29: Unable to assign int to QEasingCurve
Okt 06 12:46:53 ahcli298 ksmserver[1300]: Qt: Session management error: networkIdsList argument is NULL
Okt 06 12:46:53 ahcli298 ksmserver[1300]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.20'
Okt 06 12:46:53 ahcli298 kwin_x11[1303]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Okt 06 12:46:53 ahcli298 kwin_x11[1303]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Okt 06 12:46:53 ahcli298 plasmashell[1351]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Okt 06 12:46:53 ahcli298 plasmashell[1351]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Okt 06 12:46:53 ahcli298 kded5[1302]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.20'
Okt 06 12:46:54 ahcli298 kwin_x11[1303]: kwin_platform_x11_standalone: glSwapInterval is unsupported
Okt 06 12:46:54 ahcli298 backlighthelper[1466]: org.kde.powerdevil: no kernel backlight interface found
Okt 06 12:46:54 ahcli298 org_kde_powerdevil[1426]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Okt 06 12:46:54 ahcli298 org_kde_powerdevil[1426]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Okt 06 12:46:54 ahcli298 kwin_x11[1303]: QObject::connect(KWin::InputMethod, KWin::EffectsHandlerImpl): invalid nullptr parameter
Okt 06 12:46:54 ahcli298 kded5[1302]: kscreen.kded: PowerDevil SuspendSession action not available!
Okt 06 12:46:54 ahcli298 plasmashell[1351]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Okt 06 12:46:54 ahcli298 plasmashell[1351]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Okt 06 12:46:54 ahcli298 org_kde_powerdevil[1426]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Okt 06 12:46:54 ahcli298 org_kde_powerdevil[1426]: org.kde.powerdevil: The profile  "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
Okt 06 12:46:54 ahcli298 plasmashell[1351]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:70:5: QML Connections: Detected function "onConfigurationChanged" in Connections element. This is probably intended to be a signal handler but no signal of the target matches the name.
Okt 06 12:46:54 ahcli298 plasmashell[1351]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:70:5: QML Connections: Detected function "onRepaintNeeded" in Connections element. This is probably intended to be a signal handler but no signal of the target matches the name.
Okt 06 12:46:54 ahcli298 plasmashell[1351]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:67: TypeError: Cannot read property 'wallpaper' of null
Okt 06 12:46:54 ahcli298 plasmashell[1351]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:71: TypeError: Cannot read property 'wallpaper' of null
Okt 06 12:46:54 ahcli298 plasmashell[1351]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Okt 06 12:46:54 ahcli298 plasmashell[1351]: org.kde.plasma.containmentlayoutmanager: Error: cannot change the containment to AppletsLayout
Okt 06 12:46:54 ahcli298 kwin_x11[1303]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1524, resource id: 4194338, major code: 18 (ChangeProperty), minor code: 0
Okt 06 12:46:54 ahcli298 plasmashell[1351]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:179: TypeError: Cannot read property 'containmentDisplayHints' of null
Okt 06 12:46:54 ahcli298 plasmashell[1351]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:271: TypeError: Cannot read property 'location' of null
Okt 06 12:46:54 ahcli298 plasmashell[1351]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Okt 06 12:46:54 ahcli298 plasmashell[1351]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:532:9: QML Label: Binding loop detected for property "height"
Okt 06 12:46:54 ahcli298 plasmashell[1351]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:497:13: QML Label: Binding loop detected for property "height"
Okt 06 12:46:54 ahcli298 plasmashell[1351]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/ConfigOverlay.qml:312:17: QML SpinBox: Binding loop detected for property "implicitWidth"
Okt 06 12:46:54 ahcli298 plasmashell[1351]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/ConfigOverlay.qml:304:17: QML Heading: Binding loop detected for property "verticalAlignment"
Okt 06 12:46:54 ahcli298 plasmashell[1351]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:554:5: QML Label: Binding loop detected for property "height"
Okt 06 12:46:54 ahcli298 plasmashell[1351]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
Okt 06 12:46:54 ahcli298 plasmashell[1351]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Okt 06 12:46:55 ahcli298 plasmashell[1351]: file:///usr/share/plasma/plasmoids/org.kde.plasma.volume/contents/ui/main.qml:603:39: Invalid property assignment: string expected - Assigning null to incompatible properties in QML is deprecated. This will become a compile error in future versions of Qt.
Okt 06 12:46:55 ahcli298 plasmashell[1351]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:167:9: QML HiddenItemsView: Binding loop detected for property "implicitHeight"
Okt 06 12:46:55 ahcli298 plasmashell[1351]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:17:1: QML MouseArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Okt 06 12:46:55 ahcli298 plasmashell[1351]: Both point size and pixel size set. Using pixel size.
Okt 06 12:46:55 ahcli298 plasmashell[1351]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/Tooltip.qml:55:9: QML GridLayout (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Okt 06 12:46:55 ahcli298 plasmashell[1351]: org.kde.plasma.containmentlayoutmanager: Error: cannot change the containment to AppletsLayout
Okt 06 12:46:55 ahcli298 plasmashell[1351]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Okt 06 12:46:55 ahcli298 pulseaudio[1614]: stat('/etc/pulse/default.pa.d'): Datei oder Verzeichnis nicht gefunden
Okt 06 12:46:55 ahcli298 plasmashell[1351]: org.kde.plasma.pulseaudio: No object for name "auto_null.monitor"
Okt 06 12:46:57 ahcli298 plasmashell[1351]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Okt 06 12:46:57 ahcli298 plasmashell[1351]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Okt 06 12:46:58 ahcli298 plasmashell[1351]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Okt 06 12:46:59 ahcli298 plasmashell[1351]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Okt 06 12:47:00 ahcli298 plasmashell[1351]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Okt 06 12:47:00 ahcli298 plasmashell[1351]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Okt 06 12:47:03 ahcli298 systemd[929]: xdg-permission-store.service: Failed with result 'exit-code'.
Okt 06 12:47:03 ahcli298 systemd[929]: xdg-document-portal.service: Failed with result 'exit-code'.
Okt 06 12:47:03 ahcli298 kernel: kauditd_printk_skb: 9 callbacks suppressed
Okt 06 12:47:04 ahcli298 kwin_x11[1303]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4637, resource id: 29360252, major code: 18 (ChangeProperty), minor code: 0
Okt 06 12:47:04 ahcli298 kwin_x11[1303]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4678, resource id: 29360253, major code: 18 (ChangeProperty), minor code: 0
Okt 06 12:48:36 ahcli298 kwin_x11[1303]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 8795, resource id: 29360261, major code: 18 (ChangeProperty), minor code: 0
Okt 06 12:48:36 ahcli298 systemsettings[1939]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:200:9: QML MouseArea: Binding loop detected for property "width"
Okt 06 12:48:37 ahcli298 kwin_x11[1303]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9387, resource id: 81788934, major code: 18 (ChangeProperty), minor code: 0
Okt 06 12:48:37 ahcli298 systemsettings[1939]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Okt 06 12:48:37 ahcli298 plasma-discover[1952]: QObject::startTimer: Timers cannot have negative intervals
Okt 06 12:48:37 ahcli298 kwin_x11[1303]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9839, resource id: 79691792, major code: 18 (ChangeProperty), minor code: 0
Okt 06 12:48:37 ahcli298 kwin_x11[1303]: qt.qpa.xcb: QXcbConnection: XCB error: 12 (BadColor), sequence: 9905, resource id: 79691788, major code: 81 (InstallColormap), minor code: 0
Okt 06 12:48:37 ahcli298 kwin_x11[1303]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9906, resource id: 79691789, major code: 18 (ChangeProperty), minor code: 0
Okt 06 12:48:37 ahcli298 kwin_x11[1303]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9936, resource id: 79691789, major code: 15 (QueryTree), minor code: 0
Okt 06 12:48:40 ahcli298 systemsettings[1939]: QLayout::removeWidget: Cannot remove a null widget.
Okt 06 12:48:48 ahcli298 systemsettings[1939]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Okt 06 12:48:48 ahcli298 systemsettings[1939]: file:///usr/lib/qt/qml/QtQuick/Controls.2/org.kde.desktop/private/TextFieldContextMenu.qml:159:5: QML MenuItem: Binding loop detected for property "implicitWidth"
Okt 06 12:49:21 ahcli298 kwin_x11[1303]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13992, resource id: 77594799, major code: 18 (ChangeProperty), minor code: 0
Okt 06 12:49:21 ahcli298 kwin_x11[1303]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13996, resource id: 29360263, major code: 18 (ChangeProperty), minor code: 0
Okt 06 12:49:30 ahcli298 systemsettings[2059]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:200:9: QML MouseArea: Binding loop detected for property "width"
Okt 06 12:49:30 ahcli298 systemsettings[2059]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Okt 06 12:49:30 ahcli298 kwin_x11[1303]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 16988, resource id: 81788934, major code: 18 (ChangeProperty), minor code: 0
Okt 06 12:49:30 ahcli298 plasma-discover[2072]: QObject::startTimer: Timers cannot have negative intervals
Okt 06 12:49:30 ahcli298 kwin_x11[1303]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 17181, resource id: 79691789, major code: 12 (ConfigureWindow), minor code: 0
Okt 06 12:49:30 ahcli298 kwin_x11[1303]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 17182, resource id: 79691789, major code: 25 (SendEvent), minor code: 0
Okt 06 12:49:30 ahcli298 kwin_x11[1303]: kwin_core: XCB error: 3 (BadWindow), sequence: 17185, resource id: 79691789, major code: 129 (SHAPE), minor code: 3 (Combine)
Okt 06 12:49:30 ahcli298 kwin_x11[1303]: kwin_core: XCB error: 3 (BadWindow), sequence: 17186, resource id: 79691789, major code: 129 (SHAPE), minor code: 3 (Combine)
Okt 06 12:49:30 ahcli298 kwin_x11[1303]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 17190, resource id: 79691789, major code: 18 (ChangeProperty), minor code: 0
Okt 06 12:49:30 ahcli298 kwin_x11[1303]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 17191, resource id: 79691789, major code: 20 (GetProperty), minor code: 0
Okt 06 12:49:30 ahcli298 kwin_x11[1303]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 17260, resource id: 79691792, major code: 18 (ChangeProperty), minor code: 0
Okt 06 12:49:30 ahcli298 kwin_x11[1303]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 17263, resource id: 79691789, major code: 20 (GetProperty), minor code: 0
Okt 06 12:49:30 ahcli298 kwin_x11[1303]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 17264, resource id: 79691789, major code: 18 (ChangeProperty), minor code: 0
Okt 06 12:49:30 ahcli298 kwin_x11[1303]: qt.qpa.xcb: QXcbConnection: XCB error: 12 (BadColor), sequence: 17327, resource id: 79691788, major code: 81 (InstallColormap), minor code: 0
Okt 06 12:49:30 ahcli298 kwin_x11[1303]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 17328, resource id: 79691789, major code: 18 (ChangeProperty), minor code: 0
Okt 06 12:49:30 ahcli298 kwin_x11[1303]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 17354, resource id: 79691789, major code: 15 (QueryTree), minor code: 0
Okt 06 12:49:30 ahcli298 plasmashell[1351]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 10804, resource id: 79691789, major code: 3 (GetWindowAttributes), minor code: 0
Okt 06 12:49:30 ahcli298 plasmashell[1351]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 10805, resource id: 79691789, major code: 2 (ChangeWindowAttributes), minor code: 0
Okt 06 12:49:32 ahcli298 systemsettings[2059]: file:///usr/lib/qt/qml/org/kde/kirigami.2/PlaceholderMessage.qml:239:5: QML Heading: Binding loop detected for property "verticalAlignment"
Okt 06 12:49:34 ahcli298 systemsettings[2059]: file:///usr/lib/qt/qml/org/kde/kirigami.2/PlaceholderMessage.qml:239:5: QML Heading: Binding loop detected for property "verticalAlignment"
Okt 06 12:49:39 ahcli298 systemsettings[2059]: file:///usr/lib/qt/qml/QtQuick/Controls.2/org.kde.desktop/private/TextFieldContextMenu.qml:159:5: QML MenuItem: Binding loop detected for property "implicitWidth"
Okt 06 12:50:40 ahcli298 kded5[1302]: kf.service.services: The desktop entry file "/usr/share/applications/kcm_krunnersettings.desktop" has Type= "Application" but no Exec line
Okt 06 12:50:40 ahcli298 kded5[1302]: kf.service.sycoca: Invalid Service :  "/usr/share/applications/kcm_krunnersettings.desktop"
Okt 06 12:51:05 ahcli298 kded5[1302]: kf.service.services: The desktop entry file "/usr/share/applications/kcm_krunnersettings.desktop" has Type= "Application" but no Exec line
Okt 06 12:51:05 ahcli298 kded5[1302]: kf.service.sycoca: Invalid Service :  "/usr/share/applications/kcm_krunnersettings.desktop"
Okt 06 12:53:38 ahcli298 kernel: kauditd_printk_skb: 14 callbacks suppressed
Okt 06 12:53:45 ahcli298 kwin_x11[1303]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 14597, resource id: 77594807, major code: 18 (ChangeProperty), minor code: 0
Okt 06 12:53:45 ahcli298 kwin_x11[1303]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 14621, resource id: 29360283, major code: 18 (ChangeProperty), minor code: 0
Okt 06 12:54:18 ahcli298 kwin_x11[1303]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 25013, resource id: 79692729, major code: 18 (ChangeProperty), minor code: 0
Okt 06 12:54:18 ahcli298 kwin_x11[1303]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 25017, resource id: 29360284, major code: 18 (ChangeProperty), minor code: 0
After reboot the mentioned problem is there again. Desktop freezes every few seconds and is not usable. Everytime it happens the kwin-message pops up.
Output from journalctl (captured via ssh):
Okt 06 13:00:32 ahcli298 kernel:  #17 #18 #19 #20 #21 #22 #23 #24 #25 #26 #27 #28 #29 #30 #31
Okt 06 13:00:32 ahcli298 kernel: usb: port power management may be unreliable
Okt 06 13:00:32 ahcli298 kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Okt 06 13:00:32 ahcli298 kernel: ACPI Warning: SystemIO range 0x0000000000000B00-0x0000000000000B08 conflicts with OpRegion 0x0000000000000B00-0x0000000000000B0F (\GSA1.SMBI) (20220331/utaddress-204)
Okt 06 13:00:32 ahcli298 kernel: iwlwifi 0000:05:00.0: Direct firmware load for iwlwifi-cc-a0-72.ucode failed with error -2
Okt 06 13:00:32 ahcli298 kernel: iwlwifi 0000:05:00.0: api flags index 2 larger than supported by driver
Okt 06 13:00:32 ahcli298 kernel: thermal thermal_zone2: failed to read out thermal zone (-61)
Okt 06 13:00:33 ahcli298 kernel: nvidia: loading out-of-tree module taints kernel.
Okt 06 13:00:33 ahcli298 kernel: nvidia: module license 'NVIDIA' taints kernel.
Okt 06 13:00:33 ahcli298 kernel: Disabling lock debugging due to kernel taint
Okt 06 13:00:33 ahcli298 kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  515.76  Mon Sep 12 19:21:56 UTC 2022
Okt 06 13:00:33 ahcli298 kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
Okt 06 13:00:34 ahcli298 systemd[751]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Okt 06 13:00:34 ahcli298 systemd[1]: vmware.service: Failed with result 'exit-code'.
Okt 06 13:00:34 ahcli298 vmnetBridge[777]: Can't open vmnet device /dev/vmnet0 (No such device or address).
Okt 06 13:00:34 ahcli298 kernel: kauditd_printk_skb: 27 callbacks suppressed
Okt 06 13:00:34 ahcli298 vmnet-dhcpd[914]: exiting.
Okt 06 13:00:34 ahcli298 vmnet-dhcpd[928]: exiting.
Okt 06 13:00:34 ahcli298 systemd[1]: vmware-networks-server.service: Failed with result 'exit-code'.
Okt 06 13:00:34 ahcli298 systemd[1]: Failed to start VMware Networks.
Okt 06 13:00:35 ahcli298 systemd[942]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Okt 06 13:00:35 ahcli298 systemd[942]: Failed to start Update XDG user dir configuration.
Okt 06 13:00:35 ahcli298 sddm-greeter[951]: QFont::fromString: Invalid description '(empty)'
Okt 06 13:00:35 ahcli298 sddm-greeter[951]: QObject: Cannot create children for a parent that is in a different thread.
                                            (Parent is QGuiApplication(0x7fff3a951d20), parent's thread is QThread(0x555823a51450), current thread is QThread(0x555823b2f340)
Okt 06 13:00:35 ahcli298 sddm-greeter[951]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Okt 06 13:00:35 ahcli298 xdg-desktop-portal-kde[977]: qt.qpa.xcb: could not connect to display
Okt 06 13:00:35 ahcli298 xdg-desktop-portal-kde[977]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Okt 06 13:00:35 ahcli298 systemd-coredump[982]: [🡕] Process 977 (xdg-desktop-por) of user 967 dumped core.
                                                Stack trace of thread 977:
                                                #0  0x00007efe2a4a249c n/a (libc.so.6 + 0x8849c)
                                                #1  0x00007efe2a452958 raise (libc.so.6 + 0x38958)
                                                #2  0x00007efe2a43c53d abort (libc.so.6 + 0x2253d)
                                                #3  0x00007efe2aa9fede _ZNK14QMessageLogger5fatalEPKcz (libQt5Core.so.5 + 0x9fede)
                                                #4  0x00007efe2b73caa5 _ZN22QGuiApplicationPrivate25createPlatformIntegrationEv (libQt5Gui.so.5 + 0x13caa5)
                                                #5  0x00007efe2b73d109 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt5Gui.so.5 + 0x13d109)
                                                #6  0x00007efe2ac921ab _ZN23QCoreApplicationPrivate4initEv (libQt5Core.so.5 + 0x2921ab)
                                                #7  0x00007efe2b73d1b9 _ZN22QGuiApplicationPrivate4initEv (libQt5Gui.so.5 + 0x13d1b9)
                                                #8  0x00007efe2c575e0e _ZN19QApplicationPrivate4initEv (libQt5Widgets.so.5 + 0x175e0e)
                                                #9  0x00005614155f20c6 n/a (xdg-desktop-portal-kde + 0x1e0c6)
                                                #10 0x00007efe2a43d290 n/a (libc.so.6 + 0x23290)
                                                #11 0x00007efe2a43d34a __libc_start_main (libc.so.6 + 0x2334a)
                                                #12 0x00005614155f3535 n/a (xdg-desktop-portal-kde + 0x1f535)
                                                Stack trace of thread 979:
                                                #0  0x00007efe2a514e5f __poll (libc.so.6 + 0xfae5f)
                                                #1  0x00007efe290c6e2f n/a (libglib-2.0.so.0 + 0xabe2f)
                                                #2  0x00007efe2906f0d2 g_main_context_iteration (libglib-2.0.so.0 + 0x540d2)
                                                #3  0x00007efe2acd750c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d750c)
                                                #4  0x00007efe2ac8532c _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x28532c)
                                                #5  0x00007efe2aae749f _ZN7QThread4execEv (libQt5Core.so.5 + 0xe749f)
                                                #6  0x00007efe2b4a4cba n/a (libQt5DBus.so.5 + 0x23cba)
                                                #7  0x00007efe2aae42ba n/a (libQt5Core.so.5 + 0xe42ba)
                                                #8  0x00007efe2a4a074d n/a (libc.so.6 + 0x8674d)
                                                #9  0x00007efe2a522700 n/a (libc.so.6 + 0x108700)
Okt 06 13:00:35 ahcli298 systemd[942]: plasma-xdg-desktop-portal-kde.service: Main process exited, code=dumped, status=6/ABRT
Okt 06 13:00:35 ahcli298 systemd[942]: plasma-xdg-desktop-portal-kde.service: Failed with result 'core-dump'.
Okt 06 13:00:35 ahcli298 systemd[942]: Failed to start Xdg Desktop Portal For KDE.
Okt 06 13:00:36 ahcli298 sddm-greeter[951]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Okt 06 13:00:36 ahcli298 sddm-greeter[951]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
Okt 06 13:00:36 ahcli298 sddm-greeter[951]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Okt 06 13:00:36 ahcli298 sddm-greeter[951]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Okt 06 13:00:36 ahcli298 kernel: NVRM: GPU at PCI:0000:09:00: GPU-5f4e383d-96cb-7afb-6bc2-1fbff8e760b8
Okt 06 13:00:36 ahcli298 kernel: NVRM: Xid (PCI:0000:09:00): 32, pid=951, name=sddm-greeter, Channel ID 00000013 intr0 00040000
Okt 06 13:00:40 ahcli298 kernel: kauditd_printk_skb: 19 callbacks suppressed
Okt 06 13:01:00 ahcli298 xdg-desktop-por[955]: Failed to create settings proxy: Fehler beim Aufruf von StartServiceByName für org.freedesktop.impl.portal.desktop.kde: Zeitüberschreitung wurde erreicht
Okt 06 13:01:00 ahcli298 xdg-desktop-por[955]: No skeleton to export
Okt 06 13:01:03 ahcli298 kernel: kauditd_printk_skb: 7 callbacks suppressed
Okt 06 13:01:25 ahcli298 xdg-desktop-por[955]: Failed to create file chooser proxy: Fehler beim Aufruf von StartServiceByName für org.freedesktop.impl.portal.desktop.kde: Zeitüberschreitung wurde erreicht
Okt 06 13:01:25 ahcli298 xdg-desktop-por[955]: No skeleton to export
Okt 06 13:01:50 ahcli298 xdg-desktop-por[955]: Failed to create app chooser proxy: Fehler beim Aufruf von StartServiceByName für org.freedesktop.impl.portal.desktop.kde: Zeitüberschreitung wurde erreicht
Okt 06 13:01:50 ahcli298 xdg-desktop-por[955]: No skeleton to export
Okt 06 13:02:05 ahcli298 systemd[942]: xdg-desktop-portal.service: start operation timed out. Terminating.
Okt 06 13:02:05 ahcli298 systemd[942]: xdg-desktop-portal.service: Failed with result 'timeout'.
Okt 06 13:02:05 ahcli298 systemd[942]: Failed to start Portal service.
you have there errors from xdg-desktop-portal … so try to reinstall it:
sudo pacman -S xdg-desktop-portal xdg-desktop-portal-kde
reboot, if it didnt helped post output from:
find /etc/X11/ -name "*.conf"
sudo dmesg -l err,warn,emerg,alert,crit
I think the Problem is solved.
After reinstalling the xdg packages I checked the BIOS version. I’ve seen that there a some updates available and flashed them.
Now there is a short flickering from time to time (about every 10-15 minutes), I can live with that and think this will be fixed in a driver update.
Thank you for your help!
well glad that it partially worked, but im not satisfied … i wanted to add some parameter in the nvidia that may also help with freezes, so if you want to try it, post the output from the commands above
I had a similar problem and @anon89812132 solved it for me. It is explained here: MMU Fault: ENGINE HOST0 HUBCLIENT_ESC faulted @ 0x0_00000000. Fault is of type FAULT_PDE ACCESS_TYPE_VIRT_READ - #3 by vfbsilva
What i would do, is enable early KMS. Edit the /etc/mkinitcpio.conf and make the MODULES line like this:
MODULES=(nvidia nvidia_modeset nvidia_uvm nvidia_drm)
Then edit /etc/default/grub and make the GRUB_CMDLINE_LINUX line like
GRUB_CMDLINE_LINUX="nvidia-drm.modeset=1"
From terminal run:
sudo mkinitcpio -P
sudo update-grub
