Hi guys.
The described behavior started after updating my system this week. It has been working properly many years until now. When I change the graphical output to external screen only, it actually displays the opened windows but the mouse and keyboard events are not being displayed and registered on the external screen and it is unresponsive. E.g. when I right click, nothing is changed on external screen (the screen is absolutely unresponsive, nothing is re-drawn), but when I unplug the USB-C cable, I see that the event has been registered on laptop screen and popup menu is displayed there. It seems like that the initial image only is being rendered on external screen when plugged in, but followup up rendering is not happening there.
I have AMD CPU, NVIDIA GPU with NVIDIA drivers, KDE Plasma. Kernel 6.6.83-1 (but tried 5.15 and 5.10, both LTS with no change)
Thank you for any help.
Ivan
inxi -Fazy
Kernel: 6.6.83-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
clocksource: hpet avail: acpi_pm
root=UUID=0d7dd8d2-5033-4426-b6f7-e730c567d49a rw reboot=acpi quiet
cryptdevice=UUID=b41f2397-ab3a-4c16-92ee-5fd375ab7887:luks-b41f2397-ab3a-4c16-92ee-5fd375ab7887
root=/dev/mapper/luks-b41f2397-ab3a-4c16-92ee-5fd375ab7887
resume=/dev/mapper/luks-c689292a-59bc-4223-857a-b313ac769f7c
udev.log_priority=3 nvidia_drm.modeset=1
Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A info: frameworks v: 6.12.0
Type: Laptop System: LENOVO product: 20YM v: Lenovo ThinkBook 16p Gen 2
serial: <superuser required> Chassis: type: 10 v: Lenovo ThinkBook 16p Gen 2
Mobo: LENOVO model: LNVNB161216 v: SDK0J40697 WIN
serial: <superuser required> part-nu: LENOVO_MT_20YM_BU_idea_FM_ThinkBook
16p G2 ACH uuid: <superuser required> UEFI: LENOVO v: GXCN43WW
date: 06/15/2022
ID-1: BAT0 charge: 61.1 Wh (100.0%) condition: 61.1/71.0 Wh (86.1%)
volts: 15.4 min: N/A model: SMP L20M4PD3 type: Li-poly serial: <filter>
status: full cycles: 344
Info: model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 3 level: v3 note: check built: 2021-22
microcode: 0xA500011
desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 400 min/max: 400/4463 scaling: driver: amd-pstate-epp
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400 15: 400 16: 400
bogomips: 102254
affected
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 570.133.07 alternate: nouveau,nvidia_drm
non-free: 550/565.xx+ status: current (as of 2025-01; EOL~2026-12-xx)
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie:
gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none empty: DP-3,DP-4,eDP-2 bus-ID: 01:00.0
chip-ID: 10de:2520 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
Radeon Mobile Series] vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
empty: DP-1,DP-2 bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300
temp: 40.0 C
Device-3: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2 chip-ID: 04f2:b71f
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_x11 driver: X: loaded: amdgpu,nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 676x423mm (26.61x16.65")
s-diag: 797mm (31.4")
Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0x1296 built: 2020 res:
mode: 2560x1600 hz: 60 scale: 100% (1) dpi: 189 gamma: 1.2
size: 344x215mm (13.54x8.46") diag: 406mm (16") ratio: 16:10 modes:
max: 2560x1600 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: radeonsi
inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: amd mesa v: 25.0.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir
ACO DRM 3.54 6.6.83-1-MANJARO) device-ID: 1002:1638 memory: 500 MiB
unified: no
API: Vulkan v: 1.4.304 layers: 6 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3060 Laptop GPU driver: N/A device-ID: 10de:2520
surfaces: xcb,xlib device: 1 type: integrated-gpu name: AMD Radeon
Graphics (RADV RENOIR) driver: N/A device-ID: 1002:1638 surfaces: xcb,xlib
de: kscreen-console,kscreen-doctor gpu: nvidia-smi wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: NVIDIA GA106 High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228e
class-ID: 0403
Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
vendor: Lenovo driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5
chip-ID: 1022:15e2 class-ID: 0480
vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6
chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.6.83-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.1 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 17.0-43-g3e2bb status: active with:
tools: pacat,pactl
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:2723 class-ID: 0280
IF-ID-1: br-6d1e7bc2a3bc state: down mac: <filter>
IF-ID-2: br-c663af40b22f state: down mac: <filter>
IF-ID-3: docker0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:3 chip-ID: 8087:0029
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 3 state: up address: <filter> bt-v: 5.2
lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c010c
Local Storage: total: 476.94 GiB used: 227.6 GiB (47.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBPNTY-512G-1101 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 11190001 temp: 28.9 C scheme: GPT
ID-1: / raw-size: 97.65 GiB size: 95.56 GiB (97.86%) used: 54.64 GiB (57.2%)
fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-b41f2397-ab3a-4c16-92ee-5fd375ab7887
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 30.9 MiB (12.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 294.92 GiB size: 289.23 GiB (98.07%)
used: 172.93 GiB (59.8%) fs: ext4 dev: /dev/dm-2 maj-min: 254:2
mapped: luks-a20a9f6b-a6cb-4535-b7d9-20f7aeaacb4b
ID-1: swap-1 type: partition size: 4.2 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/dm-1 maj-min: 254:1
mapped: luks-c689292a-59bc-4223-857a-b313ac769f7c
System Temperatures: cpu: 50.8 C mobo: N/A gpu: amdgpu temp: 41.0 C
Fan Speeds (rpm): N/A
Memory: total: 16 GiB note: est. available: 14.99 GiB used: 6.63 GiB (44.2%)
Processes: 427 Power: uptime: 1h 40m states: freeze,mem,disk
suspend: s2idle wakeups: 0 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 5.98 GiB services: org_kde_powerdevil,upowerd
Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 1974 libs: 482 tools: pamac,yay
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.37 running-in: konsole inxi: 3.3.37
hwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2025.01.13 false PCI
video-linux 2024.05.06 true PCI
cat /etc/X11/mhwd.d/nvidia.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 520.56.06
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
VendorName "NVIDIA Corporation"
ChipId 0x0
ChipRev 0x0
IRQ 0
Option "NoLogo" "1"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Extensions"
Option "COMPOSITE" "Enable"
EndSection
Section "InputClass"
Identifier "Keyboard Defaults"
MatchIsKeyboard "yes"
Option "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
