Hi all!
I’ve had a problem with my KDE not working starting yesterday, mostly a short while after login. I’ve since narrowed it down to the Event Calendar add-on.
I’m not sure, but I think there was an update or something to Google Calendar’s back-end and this is causing some problems with an older configuration. Or something else.
Whenever I remove its directory from ~/.local/share/plasma/plasmoids
, upon reboot everything’s fine again, except for the Event Calendar being missing, obviously. And when I reinstall it, everything goes haywire like previously. Hence, the problem is obviously there.
Now my question is, I have searched far-and-wide (OK, not that far, in the terminal, and not that wide either, about 80% screen width) for the panel’s layout, and/or the plasmoid’s configuration and am unable to find it. I want to delete it and re-configure the plasmoid to see if that helps.
Does anybody know where it keeps its configuration? If not, is there a relatively easy way for me to find out? If not, is there a more difficult way for me to find out?
P.S.:
I’ve been thinking and I really don’t see how this is necessary, but here it is my inxi
output anyway:
$ sudo inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.17.1-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64
root=UUID=9a26c8d0-43f4-44ad-a7d3-861d6f6cdbfa rw quiet
udev.log_priority=3
Console: pty pts/3 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Desktop System: Gigabyte product: Z370 HD3 v: N/A serial: N/A
Mobo: Gigabyte model: Z370 HD3-CF v: x.x serial: N/A
UEFI: American Megatrends v: F5 date: 10/30/2017
RAM: total: 15.58 GiB used: 4.91 GiB (31.5%)
Array-1: capacity: 64 GiB slots: 4 EC: None max-module-size: 16 GiB
note: est.
Device-1: ChannelA-DIMM0 type: no module installed
Device-2: ChannelA-DIMM1 type: no module installed
Device-3: ChannelB-DIMM0 type: DDR4
detail: synchronous unbuffered (unregistered) size: 8 GiB speed: 2133 MT/s
volts: curr: 1.2 min: 1.2 max: 1.2 width (bits): data: 64 total: 64
manufacturer: G.Skill part-no: F4-3000C16-8GSXKB serial: N/A
Device-4: ChannelB-DIMM1 type: DDR4
Info: model: Intel Core i7-8700 socket: LGA1151 (U3E1) note: check bits: 64
type: MT MCP arch: Coffee Lake family: 6 model-id: 0x9E (158)
stepping: 0xA (10) microcode: 0xEC
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 4386 high: 4509 min/max: 800/4600 base/boost: 4300/8300
scaling: driver: intel_pstate governor: performance volts: 1.1 V
ext-clock: 100 MHz cores: 1: 4506 2: 4476 3: 4302 4: 4462 5: 4454 6: 4509
7: 4352 8: 4407 9: 3851 10: 4458 11: 4487 12: 4375 bogomips: 76831
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht
hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
Type: l1tf
Device-1: NVIDIA GM206 [GeForce GTX 960] vendor: Gigabyte driver: nvidia
v: 510.60.02 alternate: nouveau,nvidia_drm pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:1401 class-ID: 0300
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 5120x1080 s-dpi: 97 s-size: 1341x283mm (52.80x11.14")
s-diag: 1371mm (53.96")
Monitor-1: DVI-D-0 pos: right res: 2560x1080 hz: 60 dpi: 97
size: 673x284mm (26.5x11.18") diag: 730mm (28.76") modes: N/A
Monitor-2: HDMI-0 pos: primary,left res: 2560x1080 hz: 60 dpi: 97
OpenGL: renderer: NVIDIA GeForce GTX 960/PCIe/SSE2
v: 4.6.0 NVIDIA 510.60.02 direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
class-ID: 0403
Device-2: NVIDIA GM206 High Definition Audio vendor: Gigabyte
bus-ID: 01:00.1 chip-ID: 10de:0fba class-ID: 0403
Sound Server-1: ALSA v: k5.17.1-3-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.49 running: yes
Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 8.41 TiB used: 2.88 TiB (34.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 960 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 3B7QCXE7 temp: 26.9 C scheme: GPT
SMART: yes health: PASSED on: 150d 11h cycles: 1,824
read-units: 41,062,249 [21.0 TB] written-units: 28,437,988 [14.5 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST5000VX0011-1T317X
family: Surveillance size: 4.55 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD rpm: 7200
serial: <filter> rev: VN02 temp: 32 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 23d 19h cycles: 1205
read: 53.27 TiB written: 13.16 TiB Pre-Fail: attribute: Spin_Retry_Count
value: 100 worst: 100 threshold: 97
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000DM000-1F2168
family: Desktop HDD.15 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD rpm: 5900
serial: <filter> rev: CC54 temp: 28 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 2y 299d 6h cycles: 2137
read: 55.88 TiB written: 37.13 TiB Old-Age: UDMA CRC errors: 13567
alert: Bad cable/connection? Pre-Fail: end-to-end: 99 threshold: 99
alert: FAILING_NOW attribute: Spin_Retry_Count value: 100 worst: 100
threshold: 97
ID-1: / raw-size: 224.58 GiB size: 220.06 GiB (97.99%)
used: 107.67 GiB (48.9%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2 label: N/A uuid: 9a26c8d0-43f4-44ad-a7d3-861d6f6cdbfa
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p3
maj-min: 259:3 label: N/A uuid: D563-DAB7
ID-3: /mnt/5TB raw-size: 4.55 TiB size: 4.51 TiB (99.19%)
used: 2.72 TiB (60.2%) fs: ext4 block-size: 4096 B dev: /dev/sda1
maj-min: 8:1 label: 5TB uuid: 953836d8-e355-4c6d-ac1a-0914b8414f50
ID-4: /run/timeshift/backup raw-size: 3.64 TiB size: 3.58 TiB (98.40%)
used: 62.5 GiB (1.7%) fs: ext4 block-size: 4096 B dev: /dev/sdb1
maj-min: 8:17 label: 4TB uuid: c47c5a52-db30-4aef-bcbc-af35b7b021fd
Kernel: swappiness: 10 (default 60) cache-pressure: 75 (default 100)
ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 1b3f894f-5481-4241-ace5-c129a0cdb412
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-3:2 info: Corsair K68 RGB Mechanical Gaming Keyboard
type: Keyboard,HID driver: usbfs interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 1b1c:1b4f class-ID: 0300 serial: <filter>
Device-2: 1-8:3 info: ROCCAT Kone EMP type: Mouse,Keyboard
power: 500mA chip-ID: 1e7d:2e24 class-ID: 0300
Hub-2: 2-0:1 info: Super-speed hub ports: 10 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 27.8 C mobo: 16.8 C gpu: nvidia temp: 28 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 74%
Processes: 349 Uptime: 40m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: apt: 0 pacman: 1735 lib: 446
Shell: Zsh (sudo) v: 5.8.1 running-in: yakuake inxi: 3.3.15
