I’m happy to use Wayland!
However, when I launch VirtualBox and start a virtual machine, everything works fine until I switch to full-screen mode.
After that, the mouse can no longer switch properly between the host and the guest — it doesn’t work inside the VM, and even becomes unresponsive in the host’s browser.
Is there any solution to this? Thanks!
Also, here is the output of inxi -zv8 under X11:
$ inxi -zv8
Kernel: 6.1.135-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
clocksource: hpet avail: acpi_pm
root=UUID=c88f5257-3476-44bc-8d68-fde2b5aceff8 rw processor.max_cstate=5
idle=nomwait quiet splash udev.log_priority=3
Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.13.0
Type: Laptop System: LENOVO product: 20YM v: Lenovo ThinkBook 16p Gen 2
serial: <superuser required> Chassis: type: 10 v: Lenovo ThinkBook 16p Gen 2
Mobo: LENOVO model: LNVNB161216 v: SDK0L77769 WIN
serial: <superuser required> part-nu: LENOVO_MT_20YM_BU_idea_FM_ThinkBook
16p G2 ACH uuid: <superuser required> UEFI: LENOVO v: GXCN50WW
date: 01/22/2024
ID-1: BAT0 charge: 62.8 Wh (97.8%) condition: 64.2/71.0 Wh (90.5%)
volts: 15.4 min: N/A model: SMP L20M4PD3 type: Li-poly serial: <filter>
status: not charging cycles: 116
System RAM: total: 24 GiB available: 22.84 GiB used: 4.2 GiB (18.4%)
(unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64
manufacturer: Micron Technology part-no: 4ATF1G64HZ-3G2E1 serial: N/A
(unregistered) size: 16 GiB speed: 3200 MT/s volts: note: check curr: 1
manufacturer: Micron Technology part-no: 8ATF2G64HZ-3G2E2 serial: <filter>
Info: model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 3 level: v3 note: check built: 2021-22
microcode: 0xA500011
desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 4058 min/max: 1200/3200 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 4058 2: 4058 3: 4058
4: 4058 5: 4058 6: 4058 7: 4058 8: 4058 9: 4058 10: 4058 11: 4058 12: 4058
13: 4058 14: 4058 15: 4058 16: 4058 bogomips: 102268
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spec_rstack_overflow mitigation: safe RET
affected
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 570.144 alternate: nouveau,nvidia_drm
non-free: 550-570.xx+ status: current (as of 2025-04; EOL~2026-12-xx)
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie:
gen: 2 speed: 5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none off: DP-3 empty: DP-4,eDP-2 bus-ID: 01:00.0
chip-ID: 10de:2520 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
Radeon Mobile Series] vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
empty: DP-1,DP-2 bus-ID: 06:00.0 chip-ID: 1002:1638 class-ID: 0300
temp: 56.0 C
Device-3: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:3 chip-ID: 04f2:b71f
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia dri: radeonsi
gpu: amdgpu,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1600 s-dpi: 90 s-size: 1262x451mm (49.69x17.76")
s-diag: 1340mm (52.76")
Monitor-1: DP-3 mapped: DP-1-0 note: disabled pos: left model: DP
serial: <filter> built: 2022 res: N/A dpi: 92 gamma: 1.2 chroma: red:
x: 0.651 y: 0.329 green: x: 0.329 y: 0.624 blue: x: 0.149 y: 0.051 white:
x: 0.314 y: 0.329 size: 530x300mm (20.87x11.81") diag: 609mm (24")
ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x720,
1024x768, 800x600, 720x576, 720x480, 640x480
Monitor-2: eDP-1 pos: primary,right model-id: CSO 0x1603 built: 2020 res:
mode: 2560x1600 hz: 60 scale: 100% (1) dpi: 189 gamma: 1.2 chroma: red:
x: 0.647 y: 0.325 green: x: 0.294 y: 0.596 blue: x: 0.137 y: 0.063 white:
x: 0.318 y: 0.329 size: 344x215mm (13.54x8.46") diag: 406mm (16")
ratio: 16:10 modes: 2560x1600, 1920x1200, 1920x1080, 1600x1200,
1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720, 1024x768, 800x600,
640x480
API: EGL v: 1.5 hw: drv: nvidia nouveau drv: nvidia drv: amd radeonsi
platforms: device: 0 drv: nvidia device: 1 drv: nouveau device: 2
drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia surfaceless:
drv: nvidia x11: drv: radeonsi inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 25.0.4-arch1.1
renoir ACO DRM 3.49 6.1.135-1-MANJARO) device-ID: 1002:1638
memory: 500 MiB unified: no
API: Vulkan v: 1.4.309 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3060 Laptop GPU driver: nvidia v: 570.144 device-ID: 10de:2520
surfaces: xcb,xlib device: 1 type: integrated-gpu name: AMD Radeon
Graphics (RADV RENOIR) driver: mesa radv v: 25.0.4-arch1.1
device-ID: 1002:1638 surfaces: xcb,xlib
Device-1: NVIDIA GA106 High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:228e class-ID: 0403
Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
vendor: Lenovo driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.5
chip-ID: 1022:15e2 class-ID: 0480
vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.6
chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.1.135-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.4.2 status: off with: pipewire-media-session
status: active tools: pw-cat,pw-cli
Server-4: PulseAudio v: 17.0-43-g3e2bb status: active
with: pulseaudio-alsa type: plugin tools: pacat,pactl
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:2723 class-ID: 0280
IF-ID-1: docker0 state: down mac: <filter>
IF-ID-2: Mihomo state: unknown speed: 10 Mbps duplex: full mac: N/A
IP v6: <filter> scope: global
IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
IF-ID-3: vboxnet0 state: down mac: <filter>
IP v6: <filter> virtual: proto kernel_ll scope: link
Info: services: mld, NetworkManager, sshd, systemd-timesyncd,
wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:3 chip-ID: 8087:0029
class-ID: e001
Local Storage: total: 1.38 TiB used: 973.49 GiB (69.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBPNTY-512G-1101 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 11190001 temp: 30.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: Western Digital
model: WD Blue SN570 1TB SSD size: 931.51 GiB block-size: physical: 512 B
fw-rev: 234100WD temp: 39.9 C scheme: GPT
ID-1: / raw-size: 95.37 GiB size: 93.31 GiB (97.84%) used: 66.75 GiB (71.5%)
fs: ext4 dev: /dev/nvme1n1p5 maj-min: 259:11 label: N/A
uuid: c88f5257-3476-44bc-8d68-fde2b5aceff8
ID-2: /boot/efi raw-size: 977 MiB size: 975.1 MiB (99.80%)
used: 14.4 MiB (1.5%) fs: vfat dev: /dev/nvme1n1p4 maj-min: 259:10
label: N/A uuid: 3D30-3B0E
ID-3: /home raw-size: 392.79 GiB size: 385.55 GiB (98.16%)
used: 332.07 GiB (86.1%) fs: ext4 dev: /dev/nvme1n1p6 maj-min: 259:12
label: N/A uuid: 797ae684-18b4-42a5-ad52-ff465e7cb3ac
ID-4: /run/media/ling/Data raw-size: 275.69 GiB size: 275.69 GiB (100.00%)
used: 198.09 GiB (71.9%) fs: ntfs dev: /dev/nvme0n1p4 maj-min: 259:4
label: Data uuid: 220A1A7A0A1A4AE5
ID-5: /run/media/ling/游戏 raw-size: 419.5 GiB size: 419.5 GiB (100.00%)
used: 375.87 GiB (89.6%) fs: ntfs dev: /dev/nvme1n1p2 maj-min: 259:8
label: \xe6\xb8\xb8\xe6\x88\x8f uuid: 921A2D221A2D04B7
ID-1: swap-1 type: partition size: 22.89 GiB used: 708.5 MiB (3.0%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:9 label: N/A
uuid: b7f90d14-5248-45cf-ada6-454cfe5d6afa
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 260 MiB fs: vfat label: SYSTEM_DRV
uuid: 0049-0D24
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 200 GiB fs: ntfs
label: Windows-SSD uuid: AACE4A75CE4A39B9
ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 1000 MiB fs: ntfs label: N/A
uuid: 94F02633F0261C4C
ID-5: /dev/nvme1n1p1 maj-min: 259:7 size: 16 MiB fs: <superuser required>
Device-1: 1-2:2 info: Logitech G502 X LIGHTSPEED type: mouse,keyboard,HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 046d:c098 class-ID: 0300
serial: <filter>
Device-2: 1-3:3 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0029 class-ID: e001
Device-3: 1-4:4 info: Elan Micro ELAN:Fingerprint type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 04f3:0c4b class-ID: 0000
Device-1: 3-2:2 info: Logitech USB Receiver type: mouse,keyboard,HID
lanes: 1 mode: 1.1 power: 98mA chip-ID: 046d:c547 class-ID: 0300
Device-2: 3-3:3 info: Chicony Integrated Camera type: video
lanes: 1 mode: 2.0 power: 500mA chip-ID: 04f2:b71f class-ID: 0e02
serial: <filter>
Device-3: 3-4:4 info: Integrated Express ITE Device(8296) type: keyboard
lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:c916 class-ID: 0301
System Temperatures: cpu: 71.6 C mobo: N/A gpu: amdgpu temp: 57.0 C
Fan Speeds (rpm): N/A
Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 1853 libs: 461 tools: pamac,yay
pm: flatpak pkgs: 0
Active pacman repo servers in: /etc/pacman.conf
1: https://repo.archlinuxcn.org/$arch
2: https://mirrors.aliyun.com/archlinuxcn/$arch
1: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 369
1: cpu: 71.9% command: baloo_file_extractor pid: 7529
mem: 283.5 MiB (1.2%)
2: cpu: 30.3% command: plasmashell pid: 7184 mem: 611.3 MiB (2.6%)
3: cpu: 16.2% command: ToDesk pid: 7561 mem: 287.3 MiB (1.2%)
4: cpu: 14.8% command: Xorg pid: 6920 mem: 248.5 MiB (1.0%)
5: cpu: 13.1% command: mihomo pid: 8047 mem: 92.0 MiB (0.3%)
Memory top: 5 of 369
1: mem: 611.3 MiB (2.6%) command: plasmashell pid: 7184 cpu: 30.3%
2: mem: 287.3 MiB (1.2%) command: ToDesk pid: 7561 cpu: 16.2%
3: mem: 286.8 MiB (1.2%) command: kwin_x11 pid: 7124 cpu: 6.9%
4: mem: 283.5 MiB (1.2%) command: baloo_file_extractor pid: 7529
cpu: 71.9%
5: mem: 248.5 MiB (1.0%) command: Xorg pid: 6920 cpu: 14.8%
Processes: 369 Power: uptime: 11m states: freeze,mem,disk suspend: s2idle
image: 9.12 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 257 default: graphical tool: systemctl
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.37 running-in: konsole inxi: 3.3.38
