Hi everyone!
TL;DR: custom locale doesn’t work with KDE apps. Details below:
I created a custom locale file I copied /usr/share/i18n/locales/hu_HU to /usr/share/i18n/locales/en_HU
And I modified only the LC_TIME section:
LC_TIME
abday "Sun";"Mon";"Tue";"Wed";"Thu";"Fri";"Sat"
day "Sunday";/
"Monday";/
"Tuesday";/
"Wednesday";/
"Thursday";/
"Friday";/
"Saturday"
abmon "Jan";"Feb";/
"Mar";"Apr";/
"May";"Jun";/
"Jul";"Aug";/
"Sept";"Oct";/
"Nov";"Dec"
mon "January";/
"February";/
"March";/
"April";/
"May";/
"June";/
"July";/
"August";/
"September";/
"October";/
"November";/
"December"
d_t_fmt "%Y. %b. %-e., %A, %H:%M:%S %Z"
d_fmt "%Y-%m-%d"
t_fmt "%H:%M:%S"
am_pm "";""
t_fmt_ampm "%H:%M:%S"
date_fmt "%Y. %b. %-e., %A, %H:%M:%S %Z"
week 7;19971130;4
first_weekday 2
END LC_TIME
then
sudo localedef -i en_HU -f UTF-8 en_HU.UTF-8
then
I manually added the following to /etc/locale.gen :
en_HU.UTF-8 UTF-8
then
sudo locale-gen
It returned something like this:
en_HU.UTF-8...done
then changed the LC_TIME=en_HU.UTF-8 in /etc/locale.conf and in /etc/default/locale .
Then rebooted the system.
In konsole the date commands returns the wanted format.
The problem is, my KDE apps like dolphin, Digital CLock widget, etc uses en_US locale for time. And there is no option for en_HU in the GUI settings.
If I set LC_TIME to en_GB or something non-custom locale, then every KDE app use those locales.
So the question is:
What am I missing or what I did wrong?
You could try manually editing ~/.config/plama-localerc, but at your own risk, and I would recommend that…
you make a backup copy of it first; and…
you do it in a tty, while completely logged out of Plasma.
I do not really wish to do that, because non-custom locales works without any modification of this file.
Well, then all I can do is point you toward this tutorial below.
Difficulty: ★☆☆☆☆
Locale Errors
Locale errors are not always obvious and some applications simply stop working without any hints at all - e.g. Gnome Terminal is very sensitive to incorrect configuration of locale.
TL:DR
As root edit the file /etc/locale.gen
Enable the needed locales - including en_US.UTF-8 UTF-8 as fallback.
Rebuild the locale database using the locale-gen script
Calamares installer
The Calamares installer adds the locales chosen to the end of /etc/locale.gen so check the …
Beyond that, my hands are tied.
Thanks for the additional information.
It seems to me the KDE do not read changes in locale.
localectl
System Locale: LANG=en_US.UTF-8
LC_NUMERIC=hu_HU.UTF-8
LC_TIME=en_HU.UTF-8
LC_MONETARY=hu_HU.UTF-8
LC_PAPER=hu_HU.UTF-8
LC_NAME=hu_HU.UTF-8
LC_ADDRESS=hu_HU.UTF-8
LC_TELEPHONE=hu_HU.UTF-8
LC_MEASUREMENT=hu_HU.UTF-8
LC_IDENTIFICATION=hu_HU.UTF-8
VC Keymap: hu
X11 Layout: hu
and
locale -a
C
C.UTF-8
en_HU.utf8
en_US.utf8
hu_HU.utf8
POSIX
Maybe it is a bug
you may have forgotten the modify /etc/locale.gen accordingly before executing localegen
No i haven’t.
cat /etc/locale.gen | grep -v "^#"
en_US.UTF-8 UTF-8
hu_HU.UTF-8 UTF-8
en_HU.UTF-8 UTF-8
Ups - I missed that - sorry.
I cannot say what is out of phase - but you can use en_DK as a starting point for a custom file as this is a locale which is mixing elements.
cat /usr/share/i18n/locales/en_DK
Perhaps you just need to edit .config/plasma-localerc to contain
[Formats]
LANG=en_HU.UTF-8
If I add my custom locale to this file as LC_TIME=en_HU.UTF-8 it still don’t work.
I even tried: Locale - ArchWiki 4.2
I installed gnome for science, I modified nothing else. It works with the gnome UI.
Thanks for the en_DK tip,
system
Closed
25 September 2023 17:40
10
