KDE copy files - speed issue when using multiple monitors
see previous post:
It’s strange, but it seems that reading/writing speed issues occur when using multiple monitors w/ KDE (possibly multiple taskbars as well).
I have tested w/ different systems and when I remove the screens on a multiscreen system, the copying speed is hundred times faster.
inxi -Fxxxz
  Kernel: 6.2.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 info: cairo-dock wm: kwin_x11
    vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
  Type: Desktop System: Dell product: OptiPlex 7040 v: N/A
    serial: <superuser required> Chassis: type: 3 serial: <superuser required>
  Mobo: Dell model: 0HD5W2 v: A00 serial: <superuser required>
    UEFI-[Legacy]: Dell v: 1.11.1 date: 10/10/2018
  Info: quad core model: Intel Core i7-6700 bits: 64 type: MT MCP smt: enabled
    arch: Skylake-S rev: 3 cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
  Speed (MHz): avg: 3400 min/max: 800/3400 cores: 1: 3400 2: 3400 3: 3400
    4: 3400 5: 3400 6: 3400 7: 3400 8: 3400 bogomips: 54417
  Device-1: Intel HD Graphics 530 vendor: Dell driver: i915 v: kernel
    arch: Gen-9 ports: active: DP-2,HDMI-A-1,HDMI-A-2 empty: DP-1,DP-3,HDMI-A-3
    bus-ID: 00:02.0 chip-ID: 8086:1912 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
    loaded: intel dri: i965 gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1848 s-dpi: 96 s-size: 1016x488mm (40.00x19.21")
    s-diag: 1127mm (44.37")
  Monitor-1: DP-2 mapped: DP2 pos: top-center model: Samsung SyncMaster
    serial: <filter> res: 1360x768 hz: 60 dpi: 84 size: 410x230mm (16.14x9.06")
    diag: 470mm (18.5") modes: max: 1360x768 min: 720x400
  Monitor-2: HDMI-A-1 mapped: HDMI1 pos: bottom-r model: Acer K242HL
    serial: <filter> res: 1920x1080 hz: 60 dpi: 92
    size: 530x300mm (20.87x11.81") diag: 609mm (24") modes: max: 1920x1080
    min: 720x400
  Monitor-3: HDMI-A-2 mapped: HDMI2 pos: primary,bottom-l model: Acer K242HL
    min: 720x400
  API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel HD Graphics 530 (SKL
    GT2) direct-render: Yes
  Device-1: Focusrite-Novation Focusrite Scarlett 2i2 type: USB
    driver: snd-usb-audio bus-ID: 1-4:3 chip-ID: 1235:8016 class-ID: fe01
  Device-2: USB MIDI Interface type: USB driver: snd-usb-audio bus-ID: 1-7:5
    chip-ID: fc02:0101 class-ID: 0103
  API: ALSA v: k6.2.12-1-MANJARO status: kernel-api with: aoss
    type: oss-emulator
  Server-1: sndiod v: N/A status: off
  Server-2: JACK v: 1.9.22 status: active with: a2jmidid status: active
  Server-3: PipeWire v: 0.3.70 status: off with: wireplumber status: off
  Server-4: PulseAudio v: 16.1 status: active with: pulseaudio-jack
    type: module
  Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b7 class-ID: 0200
  IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: wireguard1 state: unknown speed: N/A duplex: N/A mac: N/A
  Local Storage: total: 1.39 TiB used: 241 GiB (17.0%)
  ID-1: /dev/sda vendor: SanDisk model: SDSSDH3 500G size: 465.76 GiB
    speed: 6.0 Gb/s type: SSD serial: <filter> rev: 20RL scheme: GPT
  ID-2: /dev/sdb vendor: Silicon Power model: SPCC Solid State Disk
    size: 953.87 GiB speed: 6.0 Gb/s type: SSD serial: <filter> rev: 916a
    scheme: GPT
  ID-1: / size: 57.37 GiB used: 21.71 GiB (37.8%) fs: ext4 dev: /dev/sda2
  ID-2: /boot size: 511 MiB used: 159.2 MiB (31.1%) fs: vfat dev: /dev/sda1
  ID-3: /home size: 152.74 GiB used: 58.24 GiB (38.1%) fs: ext4
    dev: /dev/sda3
  System Temperatures: cpu: 30.0 C pch: 46.0 C mobo: N/A
  Processes: 256 Uptime: 6h 1m wakeups: 0 Memory: 31.11 GiB
  used: 3.6 GiB (11.6%) Init: systemd v: 252 default: graphical Compilers:
  gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman pkgs: 1472 Shell: Bash
  v: 5.1.16 running-in: konsole inxi: 3.3.26
Check and see if your BIOS has a setting for onboard VGA. If it is on, disable that. It can cause performance degradation of drives.
I tested with onboard and PCIE graphics systems (single and multiple monitors).
The problem only occurs with multiple monitors and it worsens again with 3 monitors compared to 2 monitors.
As soon as only a single monitor is used speed is fast again.
HI,
the kde dev are tuned here
