[prince@Bot ~]$ systemd-analyze
Startup finished in 4.127s (kernel) + 21.466s (userspace) = 25.593s
graphical.target reached after 21.465s in userspace
But it 1 minutes and 50 second to boot.
[prince@Bot ~]$ systemd-analyze blame
22.855s udisks2.service
14.843s polkit.service
12.606s systemd-journal-flush.service
6.182s dev-loop2.device
6.044s dev-loop3.device
5.680s dev-loop4.device
5.678s dev-sda4.device
5.438s dev-loop5.device
5.359s dev-loop0.device
4.822s dev-loop1.device
2.469s systemd-udevd.service
2.403s avahi-daemon.service
2.396s NetworkManager.service
2.333s systemd-logind.service
1.681s user@1000.service
1.328s upower.service
1.170s systemd-tmpfiles-setup-dev.service
944ms var-lib-snapd-snap-gnome\x2d3\x2d28\x2d1804-145.mount
665ms systemd-fsck-root.service
543ms var-lib-snapd-snap-gnome\x2d3\x2d28\x2d1804-161.mount
484ms modprobe@drm.service
481ms wpa_supplicant.service
437ms var-lib-snapd-snap-core18-2074.mount
429ms systemd-journald.service
398ms systemd-backlight@backlight:intel_backlight.service
382ms accounts-daemon.service
377ms systemd-modules-load.service
344ms systemd-random-seed.service
317ms dev-disk-by\x2duuid-352b6f20\x2d757d\x2d449a\x2db953\x2d330361e3dcb0.swap
300ms systemd-udev-trigger.service
299ms systemd-tmpfiles-setup.service
265ms var-lib-snapd-snap-gtk\x2dcommon\x2dthemes-1515.mount
211ms modprobe@fuse.service
210ms alsa-restore.service
204ms dev-hugepages.mount
202ms dev-mqueue.mount
200ms sys-kernel-debug.mount
199ms sys-kernel-tracing.mount
198ms kmod-static-nodes.service
198ms modprobe@configfs.service
191ms var-lib-snapd-snap-rambox-16.mount
142ms systemd-sysctl.service
94ms var-lib-snapd-snap-snapd-12398.mount
91ms systemd-update-utmp.service
75ms rtkit-daemon.service
74ms systemd-rfkill.service
55ms user-runtime-dir@1000.service
55ms systemd-remount-fs.service
33ms systemd-user-sessions.service
24ms sys-kernel-config.mount
9ms tmp.mount
8ms sys-fs-fuse-connections.mount
lines 29-52/52 (END)
But sum of these is more than 25 seconds as it shows in running command systemd-analyze
