As adviced by @nikgnomic to create new thread from Manjaro KDE Auto Mutes on Boot
Here is my inxi
Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=29e8c1bf-181d-44f6-ba23-d1fd69c09d6d ro quiet apparmor=1
security=apparmor resume=UUID=cfe38a00-9663-4d70-bcf5-993b0345d8a5
udev.log_priority=3 mitigations=off
Console: pty pts/6 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: ASUSTeK product: X542UN v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X542UN v: 1.0 serial: <filter>
UEFI: American Megatrends v: X542UN.303 date: 01/05/2018
ID-1: BAT0 charge: 37.3 Wh (100.0%) condition: 37.3/37.3 Wh (100.0%)
volts: 7.6 min: 7.6 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Not charging cycles: 48
Info: Quad Core model: Intel Core i5-8250U socket: BGA1356 (U3E1)
note: check bits: 64 type: MT MCP arch: Kaby Lake note: check family: 6
model-id: 8E (142) stepping: A (10) microcode: EA cache: L1: 256 KiB
L2: 6 MiB L3: 6 MiB
bogomips: 28808
Speed: 1409 MHz min/max: 400/3400 MHz base/boost: 1500/8300 volts: 0.6 V
ext-clock: 100 MHz Core speeds (MHz): 1: 1409 2: 1632 3: 904 4: 876 5: 1017
6: 1097 7: 1323 8: 2327
Type: l1tf mitigation: PTE Inversion; VMX: vulnerable
Type: mds status: Vulnerable; SMT vulnerable
Type: meltdown status: Vulnerable
Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
usercopy barriers only; no swapgs barriers
Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled
Type: srbds status: Vulnerable
Device-1: Intel UHD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX150] vendor: ASUSTeK driver: nvidia
v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1d10 class-ID: 0302
Device-3: IMC Networks USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-6:4 chip-ID: 13d3:5a01 class-ID: 0e02 serial: <filter>
Display: server: X.Org 1.20.13 compositor: kwin_x11 driver:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa display-ID: :0
screens: 1
Screen-1: 0 s-res: 1921x2400 s-dpi: 96 s-size: 507x634mm (20.0x25.0")
s-diag: 812mm (32")
Monitor-1: DP-1 res: 1920x1200 hz: 60 dpi: 89 size: 546x352mm (21.5x13.9")
diag: 650mm (25.6")
Monitor-2: HDMI-2 res: 1920x1200 hz: 60 dpi: 94 size: 518x324mm (20.4x12.8")
diag: 611mm (24.1")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.2.3
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: no
vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus-ID: 02:00.0
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: AzureWave driver: ath10k_pci v: kernel bus-ID: 03:00.0
chip-ID: 168c:0042 class-ID: 0280
IF: wlp3s0 state: down mac: <filter>
Device-1: IMC Networks type: USB driver: btusb v: 0.8 bus-ID: 1-8:5
chip-ID: 13d3:3496 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 1.36 TiB used: 740.96 GiB (53.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS541010B7E610
family: Travelstar Z5K1000 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD rpm: 5400
serial: <filter> rev: 1A03 temp: 39 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 146d 9h cycles: 2992
Old-Age: g-sense error rate: 6472
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WDS500G2B0B-00YS70 family: WD Blue / Red / Green SSDs
size: 465.76 GiB block-size: physical: 512 B logical: 512 B sata: 3.3
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 00WD temp: 33 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 115d 15h cycles: 2390
ID-1: / raw-size: 448.39 GiB size: 440.35 GiB (98.21%)
used: 101.5 GiB (23.0%) fs: ext4 block-size: 4096 B dev: /dev/sdb2
maj-min: 8:18
used: 300 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sdb1 maj-min: 8:17
ID-1: swap-1 type: partition size: 17.07 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb3 maj-min: 8:19
System Temperatures: cpu: 44.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2600
Processes: 254 Uptime: 1h 1m wakeups: 1 Memory: 15.52 GiB
used: 5.47 GiB (35.3%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1486 lib: 429 flatpak: 0
Shell: Bash (sudo) v: 5.1.8 running-in: kitty inxi: 3.3.08
And the alsa info
upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.5.0
!!Script ran on: Wed Nov 3 11:34:01 UTC 2021
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer: ASUSTeK COMPUTER INC.
Product Name: X542UN
Product Version: 1.0
Firmware Version: X542UN.303
System SKU:
Board Vendor: ASUSTeK COMPUTER INC.
Board Name: X542UN
!!ACPI Device Status Information
/sys/bus/acpi/devices/ACPI000C:00/status 15
/sys/bus/acpi/devices/ATK3001:00/status 15
/sys/bus/acpi/devices/ATK4002:00/status 15
/sys/bus/acpi/devices/ELAN1200:00/status 15
/sys/bus/acpi/devices/INT33A1:00/status 15
/sys/bus/acpi/devices/INT3400:00/status 15
/sys/bus/acpi/devices/INT3403:04/status 15
/sys/bus/acpi/devices/INT3403:05/status 15
/sys/bus/acpi/devices/INT3403:06/status 15
/sys/bus/acpi/devices/INT3403:07/status 15
/sys/bus/acpi/devices/INT344B:00/status 15
/sys/bus/acpi/devices/INT3F0D:00/status 15
/sys/bus/acpi/devices/LNXPOWER:00/status 1
/sys/bus/acpi/devices/LNXPOWER:01/status 1
/sys/bus/acpi/devices/LNXPOWER:02/status 1
/sys/bus/acpi/devices/LNXPOWER:03/status 1
/sys/bus/acpi/devices/LNXPOWER:04/status 1
/sys/bus/acpi/devices/LNXPOWER:05/status 1
/sys/bus/acpi/devices/LNXPOWER:06/status 1
/sys/bus/acpi/devices/LNXPOWER:07/status 1
/sys/bus/acpi/devices/LNXPOWER:08/status 1
/sys/bus/acpi/devices/LNXPOWER:09/status 1
/sys/bus/acpi/devices/LNXPOWER:0a/status 1
/sys/bus/acpi/devices/LNXPOWER:0b/status 1
/sys/bus/acpi/devices/LNXPOWER:0c/status 1
/sys/bus/acpi/devices/LNXPOWER:0d/status 1
/sys/bus/acpi/devices/LNXPOWER:0e/status 1
/sys/bus/acpi/devices/LNXPOWER:0f/status 1
/sys/bus/acpi/devices/LNXPOWER:10/status 1
/sys/bus/acpi/devices/LNXPOWER:11/status 1
/sys/bus/acpi/devices/LNXPOWER:12/status 1
/sys/bus/acpi/devices/LNXPOWER:13/status 1
/sys/bus/acpi/devices/LNXVIDEO:01/status 15
/sys/bus/acpi/devices/MSFT0101:00/status 15
/sys/bus/acpi/devices/PNP0103:00/status 15
/sys/bus/acpi/devices/PNP0C02:03/status 3
/sys/bus/acpi/devices/PNP0C02:05/status 3
/sys/bus/acpi/devices/PNP0C0A:03/status 31
/sys/bus/acpi/devices/PNP0C0C:00/status 15
/sys/bus/acpi/devices/PNP0C0E:00/status 11
/sys/bus/acpi/devices/PNP0C0F:00/status 9
/sys/bus/acpi/devices/PNP0C0F:01/status 9
/sys/bus/acpi/devices/PNP0C0F:02/status 9
/sys/bus/acpi/devices/PNP0C0F:03/status 9
/sys/bus/acpi/devices/PNP0C0F:04/status 9
/sys/bus/acpi/devices/PNP0C0F:05/status 9
/sys/bus/acpi/devices/PNP0C0F:06/status 9
/sys/bus/acpi/devices/PNP0C0F:07/status 9
/sys/bus/acpi/devices/device:11/status 15
/sys/bus/acpi/devices/device:63/status 15
/sys/bus/acpi/devices/device:76/status 11
!!Kernel Information
Kernel release: 5.14.10-1-MANJARO
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: k5.14.10-1-MANJARO
Library version: 1.2.5.1
Utilities version: 1.2.5.1
!!Loaded ALSA modules
snd_hda_intel (card 0)
!!Sound Servers on this system
PipeWire:
Installed - Yes (/usr/bin/pipewire)
Running - No
Pulseaudio:
Installed - Yes (/usr/bin/pulseaudio)
Running - Yes
Jack:
Installed - Yes (/usr/bin/jackd)
Running - No
!!Soundcards recognised by ALSA
0 [PCH ]: HDA-Intel - HDA Intel PCH
HDA Intel PCH at 0xef528000 irq 131
!!PCI Soundcards installed in the system
00:1f.3 Audio device [0403]: Intel Corporation Sunrise Point-LP HD Audio [8086:9d71] (rev 21)
Subsystem: ASUSTeK Computer Inc. Device [1043:1a00]
!!Loaded sound module options
!!Module: snd_hda_intel
align_buffer_size : -1
bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
beep_mode : N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
dmic_detect : Y
enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
enable_msi : -1
id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
pm_blacklist : Y
position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
power_save : 1
power_save_controller : Y
probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
single_cmd : -1
snoop : -1
!!Sysfs card info
!!Card: /sys/class/sound/card0
Driver: /sys/bus/pci/drivers/snd_hda_intel
Tree:
!!HDA-Intel Codec information
--startcollapse--
Codec: Realtek ALC294
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x10ec0294
Subsystem Id: 0x10431a00
Revision Id: 0x100004
No Modem Function Group found
Default PCM:
rates [0x560]: 44100 48000 96000 192000
bits [0xe]: 16 20 24
formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
Power states: D0 D1 D2 D3 D3cold CLKSTOP EPSS
Power: setting=D0, actual=D0
GPIO: io=4, o=0, i=0, unsolicited=1, wake=0
IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[2]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[3]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Speaker Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=Out, idx=0, ofs=0
Amp-Out caps: ofs=0x57, nsteps=0x57, stepsize=0x02, mute=0
Amp-Out vals: [0x00 0x00]
Converter: stream=0, channel=0
PCM:
rates [0x60]: 44100 48000
formats [0x1]: PCM
Power states: D0 D1 D2 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Headphone Playback Volume", index=0, device=0
Device: name="ALC294 Analog", type="Audio", device=0
Amp-Out vals: [0x3b 0x3b]
PCM:
formats [0x1]: PCM
Node 0x04 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x05 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x06 [Audio Output] wcaps 0x411: Stereo
PCM:
rates [0x40]: 48000
formats [0x1]: PCM
Node 0x07 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Amp-In caps: ofs=0x17, nsteps=0x3f, stepsize=0x02, mute=1
Amp-In vals: [0x97 0x97]
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x24
Node 0x08 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Control: name="Capture Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=0, ofs=0
Control: name="Capture Switch", index=0, device=0
Amp-In vals: [0x34 0x34]
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x23
Node 0x09 [Audio Input] wcaps 0x10051b: Stereo Amp-In
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x22
Node 0x0a [Audio Input] wcaps 0x100711: Stereo Digital
SDI-Select: 0
Digital:
Digital category: 0x0
IEC Coding Type: 0x0
PCM:
formats [0x1]: PCM
Connection: 1
0x1f
Node 0x0b [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0c [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0d [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0e [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0f [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x10 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x11 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x12 [Pin Complex] wcaps 0x40040b: Stereo Amp-In
Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
Amp-In vals: [0x00 0x00]
Pincap 0x00000020: IN
Pin Default 0x40000000: [N/A] Line Out at Ext N/A
Conn = Unknown, Color = Unknown
DefAssociation = 0x0, Sequence = 0x0
Pin-ctls: 0x00:
Node 0x13 [Pin Complex] wcaps 0x40040b: Stereo Amp-In
Control: name="Internal Mic Boost Volume", index=1, device=0
Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
Conn = 1/8, Color = Black
DefAssociation = 0xf, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x14 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Speaker Playback Switch", index=0, device=0
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-Out vals: [0x80 0x80]
Pincap 0x00010010: OUT EAPD
EAPD 0x2: EAPD
Pin Default 0x90170110: [Fixed] Speaker at Int N/A
Conn = Analog, Color = Unknown
DefAssociation = 0x1, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Unsolicited: tag=00, enabled=0
Connection: 1
0x02
Node 0x15 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Pincap 0x0001001c: OUT HP EAPD Detect
EAPD 0x2: EAPD
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Connection: 3
0x02* 0x03 0x06
Node 0x16 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Pincap 0x00010014: OUT EAPD Detect
EAPD 0x2: EAPD
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Connection: 2
0x02* 0x03
Node 0x17 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
EAPD 0x2: EAPD
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Connection: 3
0x02* 0x03 0x06
Node 0x18 [Pin Complex] wcaps 0x400481: Stereo
Pincap 0x00000024: IN Detect
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Node 0x19 [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Control: name="Headset Mic Boost Volume", index=0, device=0
Pincap 0x00003724: IN Detect
Vref caps: HIZ 50 GRD 80 100
Misc = NO_PRESENCE
Pin-ctls: 0x24: IN VREF_80
Node 0x1a [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Misc = NO_PRESENCE
Pin-ctls: 0x00: VREF_HIZ
Node 0x1b [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Control: name="Internal Mic Boost Volume", index=0, device=0
Pincap 0x00013734: IN OUT EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x90a70140: [Fixed] Mic at Int N/A
DefAssociation = 0x4, Sequence = 0x0
Misc = NO_PRESENCE
Connection: 2
0x02* 0x03
Node 0x1c [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x1d [Pin Complex] wcaps 0x400400: Mono
Pin Default 0x4047bb05: [N/A] SPDIF Out at Ext N/A
Conn = Analog, Color = UNKNOWN
DefAssociation = 0x0, Sequence = 0x5
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400581: Stereo
Pincap 0x00000014: OUT Detect
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x06
Node 0x1f [Pin Complex] wcaps 0x400681: Stereo Digital
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
Processing caps: benign=0, ncoeff=130
Node 0x21 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Headphone Playback Switch", index=0, device=0
EAPD 0x2: EAPD
Pin Default 0x04211030: [Jack] HP Out at Ext Right
DefAssociation = 0x3, Sequence = 0x0
Pin-ctls: 0xc0: OUT HP
Unsolicited: tag=01, enabled=1
Connection: 2
0x02 0x03*
Node 0x22 [Audio Selector] wcaps 0x300101: Stereo
Connection: 4
0x19* 0x1a 0x1b 0x12
Node 0x23 [Audio Selector] wcaps 0x300101: Stereo
Connection: 4
0x19 0x1a 0x1b* 0x13
Node 0x24 [Audio Selector] wcaps 0x300101: Stereo
Connection: 3
0x12* 0x13 0x18
Node 0x25 [Vendor Defined Widget] wcaps 0xf00000: Mono
Codec: Intel Kabylake HDMI
Address: 2
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x8086280b
Subsystem Id: 0x80860101
Revision Id: 0x100000
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Power states: D0 D3 CLKSTOP EPSS
Power: setting=D0, actual=D0, Clock-stop-OK
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x02 [Audio Output] wcaps 0x6611: 8-Channels Digital
Digital: Enabled KAE
PCM:
rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
bits [0x1a]: 16 24 32
formats [0x5]: PCM AC3
Power states: D0 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x6611: 8-Channels Digital
PCM:
Node 0x04 [Audio Output] wcaps 0x6611: 8-Channels Digital
PCM:
Node 0x05 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pincap 0x0b000094: OUT Detect HBR HDMI DP
Pin Default 0x18560010: [Jack] Digital Out at Int HDMI
Conn = Digital, Color = Unknown
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x06 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x07 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x08 [Vendor Defined Widget] wcaps 0xf00000: Mono
--endcollapse--
!!ALSA Device nodes
crw-rw----+ 1 root audio 116, 11 Nov 3 18:36 /dev/snd/controlC0
crw-rw----+ 1 root audio 116, 9 Nov 3 18:36 /dev/snd/hwC0D0
crw-rw----+ 1 root audio 116, 10 Nov 3 18:36 /dev/snd/hwC0D2
crw-rw----+ 1 root audio 116, 3 Nov 3 18:37 /dev/snd/pcmC0D0c
crw-rw----+ 1 root audio 116, 2 Nov 3 19:33 /dev/snd/pcmC0D0p
crw-rw----+ 1 root audio 116, 8 Nov 3 18:37 /dev/snd/pcmC0D10p
crw-rw----+ 1 root audio 116, 4 Nov 3 18:37 /dev/snd/pcmC0D3p
crw-rw----+ 1 root audio 116, 5 Nov 3 18:37 /dev/snd/pcmC0D7p
crw-rw----+ 1 root audio 116, 6 Nov 3 18:37 /dev/snd/pcmC0D8p
crw-rw----+ 1 root audio 116, 7 Nov 3 18:37 /dev/snd/pcmC0D9p
crw-rw----+ 1 root audio 116, 1 Nov 3 18:36 /dev/snd/seq
crw-rw----+ 1 root audio 116, 33 Nov 3 18:36 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 60 Nov 3 18:36 .
drwxr-xr-x 3 root root 300 Nov 3 18:36 ..
lrwxrwxrwx 1 root root 12 Nov 3 18:36 pci-0000:00:1f.3 -> ../controlC0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC294 Analog [ALC294 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card PCH
Card sysdefault:0 'PCH'/'HDA Intel PCH at 0xef528000 irq 131'
Mixer name : 'Realtek ALC294'
Components : 'HDA:10ec0294,10431a00,00100004 HDA:8086280b,80860101,00100000'
Controls : 56
Simple ctrls : 17
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 87
Mono: Playback 59 [68%] [-21.00dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 87 [100%] [0.00dB] [on]
Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'Speaker',0
Mono:
Front Left: Playback 0 [0%] [-65.25dB] [off]
Front Right: Playback 0 [0%] [-65.25dB] [off]
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Mono: Playback [off]
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'IEC958',3
Mono: Playback [on]
Simple mixer control 'IEC958',4
Mono: Playback [on]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 63
Front Left: Capture 52 [83%] [21.75dB] [on]
Front Right: Capture 52 [83%] [21.75dB] [on]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Disabled'
Simple mixer control 'Headset Mic',0
Capabilities: cswitch cswitch-joined cswitch-exclusive
Capture exclusive group: 0
Capture channels: Mono
Mono: Capture [off]
Simple mixer control 'Headset Mic Boost',0
Capabilities: volume
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Internal Mic',0
Mono: Capture [on]
Simple mixer control 'Internal Mic 1',0
Mono: Capture [off]
Simple mixer control 'Internal Mic Boost',0
Limits: 0 - 3
Simple mixer control 'Internal Mic Boost',1
Limits: 0 - 3
!!Alsactl output
--startcollapse--
state.PCH {
control.1 {
iface MIXER
name 'Headphone Playback Volume'
value.0 87
value.1 87
comment {
access 'read write'
type INTEGER
count 2
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.2 {
iface MIXER
name 'Headphone Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.3 {
iface MIXER
name 'Speaker Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 -6525
dbvalue.1 -6525
control.4 {
iface MIXER
name 'Speaker Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.5 {
iface MIXER
name 'Auto-Mute Mode'
value Disabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.6 {
iface MIXER
name 'Capture Source'
value 'Internal Mic'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'Headset Mic'
item.1 'Internal Mic'
item.2 'Internal Mic 1'
control.7 {
iface MIXER
name 'Capture Volume'
value.0 52
value.1 52
comment {
access 'read write'
type INTEGER
count 2
range '0 - 63'
dbmin -1725
dbmax 3000
dbvalue.0 2175
dbvalue.1 2175
control.8 {
iface MIXER
name 'Capture Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.9 {
iface MIXER
name 'Headset Mic Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.10 {
iface MIXER
name 'Internal Mic Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.11 {
iface MIXER
index 1
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.12 {
iface MIXER
name 'Master Playback Volume'
value 59
comment {
access 'read write'
type INTEGER
count 1
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 -2100
control.13 {
iface MIXER
name 'Master Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.14 {
iface CARD
name 'Headset Mic Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.15 {
iface CARD
name 'Internal Mic Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.16 {
iface CARD
index 1
value true
comment {
access read
type BOOLEAN
count 1
control.17 {
iface CARD
name 'Headphone Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.18 {
iface CARD
name 'Speaker Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.19 {
iface PCM
name 'Playback Channel Map'
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.20 {
iface PCM
name 'Capture Channel Map'
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.21 {
iface CARD
name 'HDMI/DP,pcm=3 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.22 {
iface MIXER
name 'IEC958 Playback Con Mask'
value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.23 {
iface MIXER
name 'IEC958 Playback Pro Mask'
value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.24 {
iface MIXER
name 'IEC958 Playback Default'
value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.25 {
iface MIXER
name 'IEC958 Playback Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.26 {
iface PCM
device 3
name ELD
value ''
comment {
access 'read volatile'
type BYTES
count 0
control.27 {
iface CARD
name 'HDMI/DP,pcm=7 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.28 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.29 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.30 {
iface MIXER
index 1
comment {
access 'read write'
type IEC958
count 1
control.31 {
iface MIXER
index 1
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.32 {
iface PCM
device 7
name ELD
value ''
comment {
type BYTES
count 0
control.33 {
iface CARD
name 'HDMI/DP,pcm=8 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.34 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.35 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.36 {
iface MIXER
index 2
comment {
access 'read write'
type IEC958
count 1
control.37 {
iface MIXER
index 2
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.38 {
iface PCM
device 8
name ELD
value ''
comment {
type BYTES
count 0
control.39 {
iface CARD
name 'HDMI/DP,pcm=9 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.40 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.41 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.42 {
iface MIXER
index 3
comment {
access 'read write'
type IEC958
count 1
control.43 {
iface MIXER
index 3
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.44 {
iface PCM
device 9
name ELD
value ''
comment {
type BYTES
count 0
control.45 {
iface CARD
name 'HDMI/DP,pcm=10 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.46 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.47 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.48 {
iface MIXER
index 4
comment {
access 'read write'
type IEC958
count 1
control.49 {
iface MIXER
index 4
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.50 {
iface PCM
device 10
name ELD
value ''
comment {
type BYTES
count 0
control.51 {
iface PCM
device 3
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.52 {
iface PCM
device 7
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.53 {
iface PCM
device 8
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.54 {
iface PCM
device 9
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.55 {
iface PCM
device 10
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.56 {
iface MIXER
name 'PCM Playback Volume'
value.0 255
value.1 255
comment {
access 'read write user'
type INTEGER
count 2
range '0 - 255'
tlv '0000000100000008ffffec1400000014'
dbmin -5100
dbmax 0
dbvalue.0 0
dbvalue.1 0
--endcollapse--
!!All Loaded Modules
8250_dw
ac97_bus
acpi_pad
acpi_thermal_rel
aesni_intel
af_alg
agpgart
algif_hash
algif_skcipher
asus_nb_wmi
asus_wireless
asus_wmi
ath
ath10k_core
ath10k_pci
atkbd
bluetooth
bnep
btbcm
btintel
btrtl
btusb
cdrom
cec
cfg80211
cmac
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
drm
drm_kms_helper
dw_dmac
ecc
ecdh_generic
ee1004
ext4
fat
fb_sys_fops
fuse
ghash_clmulni_intel
hid_elecom
hid_multitouch
i2c_algo_bit
i2c_hid
i2c_hid_acpi
i2c_i801
i2c_smbus
i8042
i915
iTCO_vendor_support
iTCO_wdt
idma64
int3400_thermal
int3403_thermal
int340x_thermal_zone
intel_cstate
intel_gtt
intel_lpss
intel_lpss_pci
intel_pch_thermal
intel_pmc_bxt
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_soc_dts_iosf
intel_tcc_cooling
intel_uncore
intel_xhci_usb_role_switch
ip_tables
irqbypass
jbd2
joydev
kvm
kvm_intel
ledtrig_audio
libarc4
libphy
libps2
loop
mac80211
mac_hid
mbcache
mc
mdio_devres
mei
mei_hdcp
mei_me
mousedev
mxm_wmi
ns
nvidia
nvidia_drm
nvidia_modeset
overlay
pcspkr
processor_thermal_device
processor_thermal_device_pci_legacy
processor_thermal_mbox
processor_thermal_rapl
processor_thermal_rfim
qrtr
r8169
rapl
realtek
rfcomm
rfkill
rng_core
roles
serio
serio_raw
sg
snd
snd_compress
snd_hda_codec
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_codec_realtek
snd_hda_core
snd_hda_ext_core
snd_hda_intel
snd_hwdep
snd_intel_dspcfg
snd_intel_sdw_acpi
snd_pcm
snd_pcm_dmaengine
snd_soc_acpi
snd_soc_acpi_intel_match
snd_soc_core
snd_soc_hdac_hda
snd_soc_skl
snd_soc_sst_dsp
snd_soc_sst_ipc
snd_timer
soundcore
sparse_keymap
spi_pxa2xx_platform
squashfs
sr_mod
syscopyarea
sysfillrect
sysimgblt
tpm
tpm_crb
tpm_tis
tpm_tis_core
ttm
uinput
usbhid
uvcvideo
vfat
video
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
vmmon
vmw_vmci
wmi
wmi_bmof
x86_pkg_temp_thermal
x_tables
xhci_pci
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x12 0x40000000
0x13 0x411111f0
0x14 0x90170110
0x15 0x411111f0
0x16 0x411111f0
0x17 0x411111f0
0x18 0x411111f0
0x19 0x411111f0
0x1a 0x411111f0
0x1b 0x90a70140
0x1d 0x4047bb05
0x1e 0x411111f0
0x1f 0x411111f0
0x21 0x04211030
/sys/class/sound/hwC0D0/driver_pin_configs:
0x13 0x90a60160
0x19 0x04a11120
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
/sys/class/sound/hwC0D2/init_pin_configs:
0x05 0x18560010
0x06 0x18560010
0x07 0x18560010
/sys/class/sound/hwC0D2/driver_pin_configs:
/sys/class/sound/hwC0D2/user_pin_configs:
/sys/class/sound/hwC0D2/init_verbs:
/sys/class/sound/hwC0D2/hints:
!!ALSA/HDA dmesg
[ 0.221335] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.221335] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.221335] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.409999] pci 0000:01:00.0: reg 0x30: [mem 0xef000000-0xef07ffff pref]
[ 0.410029] pci 0000:01:00.0: Enabling HDA controller
[ 0.410760] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ 3.728583] iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=4, TCOBASE=0x0400)
[ 3.729284] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[ 3.731896] iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 3.776200] pcieport 0000:00:1c.5: AER: can't find device of ID00e5
[ 3.777816] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 3.801344] input: ELAN1200:00 04F3:303E Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-ELAN1200:00/0018:04F3:303E.0004/input/input16
[ 3.825072] mousedev: PS/2 mouse device common for all mice
[ 3.876035] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC294: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 3.876040] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 3.876043] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 3.876045] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 3.876046] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 3.876047] snd_hda_codec_realtek hdaudioC0D0: Headset Mic=0x19
[ 3.876049] snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x1b
[ 3.876051] snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x13
[ 3.880107] ath10k_pci 0000:03:00.0: qca9377 hw1.1 target 0x05020001 chip_id 0x003821ff sub 1a3b:2b31
[ 4.222046] input: ELECOM TrackBall Mouse HUGE TrackBall as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/0003:056E:010D.0003/input/input18
[ 4.247929] nvidia 0000:01:00.0: Enabling HDA controller
[ 4.278095] elecom 0003:056E:010D.0003: input,hiddev97,hidraw3: USB HID v1.11 Mouse [ELECOM TrackBall Mouse HUGE TrackBall] on usb-0000:00:14.0-4/input0
[ 4.531143] pcieport 0000:00:1c.5: AER: can't find device of ID00e5
[ 4.558038] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input20
[ 4.558190] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input21
[ 4.558322] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input22
[ 4.558416] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input23
[ 4.558504] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input24
[ 4.558591] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input25
[ 4.936802] ACPI Warning: \_SB.PCI0.RP01.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210604/nsarguments-61)
