Hello,
Is there any know issue related to KDE Plama or Manjaro that is automatic changing desktop set up?
It’s a second time this weak, and just after the latest Stable update (19/nov/2021), I shut down my PC without any issue but when I do log on everything related to the desktop is changed, the wallpaper back to default one, the icon sizes back to default one, preview checkbox is marked, files in the the desktop are auto arranged in the grid and all my widget are gone. Very strange.
Below an image as I set up again
Below issued one back to standard configuration
Kernel: 5.16.0-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
root=UUID=dfa33105-8d9e-4555-9174-609a71216485 ro quiet apparmor=1
security=apparmor resume=UUID=493ccde5-7f80-4bf5-b22c-98ce796aade6
udev.log_priority=3
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Gigabyte model: GA-870A-UD3 v: x.x
serial: <superuser required> BIOS: Award v: F5 date: 08/01/2011
RAM: total: 7.76 GiB used: 2.45 GiB (31.6%)
Info: Quad Core model: AMD Phenom II X4 965 bits: 64 type: MCP arch: K10
family: 10 (16) model-id: 4 stepping: 3 microcode: 10000C8 cache:
L1: 512 KiB L2: 2 MiB L3: 6 MiB bogomips: 27333
Speed: 800 MHz min/max: 800/3400 MHz boost: disabled Core speeds (MHz):
1: 800 2: 3400 3: 800 4: 800
Flags: 3dnow 3dnowext 3dnowprefetch abm apic clflush cmov cmp_legacy
constant_tsc cpuid cr8_legacy cx16 cx8 de extapic extd_apicid fpu fxsr
fxsr_opt ht hw_pstate ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext
monitor msr mtrr nonstop_tsc nopl npt nrip_save nx osvw pae pat pdpe1gb pge
pni popcnt pse pse36 rdtscp rep_good sep skinit sse sse2 sse4a svm svm_lock
syscall tsc vme vmmcall wdt
Type: spec_store_bypass status: Not affected
Type: spectre_v2
mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Micro-Star MSI driver: amdgpu v: kernel bus-ID: 01:00.0
chip-ID: 1002:67df class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: DVI-D-0 res: 1920x1080 hz: 60 dpi: 96
size: 510x290mm (20.1x11.4") diag: 587mm (23.1")
OpenGL: renderer: AMD Radeon RX 570 Series (POLARIS10 DRM 3.44.0
5.16.0-1-MANJARO LLVM 13.0.0)
v: 4.6 Mesa 21.2.5 direct render: Yes
Device-1: AMD SBx00 Azalia vendor: Gigabyte GA-880GMA-USB3
driver: snd_hda_intel v: kernel bus-ID: 00:14.2 chip-ID: 1002:4383
class-ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Sound Server-1: ALSA v: k5.16.0-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
vendor: Gigabyte driver: r8169 v: kernel port: 9e00 bus-ID: 06:00.0
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 2.48 TiB used: 1.74 TiB (70.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 240GB
size: 223.58 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 00RL scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Corsair model: Corsair Force GS
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 5.07 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Patriot model: Burst size: 223.57 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
serial: <filter> rev: KB.3 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: Crucial model: CT120BX100SSD1
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: MU01 scheme: GPT
ID-5: /dev/sde maj-min: 8:64 vendor: Western Digital model: WD20PURZ-85GU6Y0
type: HDD rpm: 5400 serial: <filter> rev: 0A80 scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH22NS50 rev: TN02
dev-links: cdrom
ID-1: / raw-size: 214.77 GiB size: 210.4 GiB (97.96%)
used: 95.52 GiB (45.4%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33
label: LINUX-SSD uuid: dfa33105-8d9e-4555-9174-609a71216485
ID-2: /home/<filter>/Games raw-size: 111.79 GiB size: 109.47 GiB (97.93%)
used: 61 GiB (55.7%) fs: ext4 dev: /dev/sdd1 maj-min: 8:49
label: LINUX-GAMES uuid: ef7d7ba9-f8da-4419-b9a3-ca9e2232da86
ID-3: /home/<filter>/HDD-DATA-2T raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 1.58 TiB (87.0%) fs: ntfs dev: /dev/sde1 maj-min: 8:65 label: DATA_2T
uuid: 28A6726FA6723CFE
dev: /dev/sdc2 maj-min: 8:34 label: N/A
uuid: 493ccde5-7f80-4bf5-b22c-98ce796aade6
ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: ntfs label: System Reserved
uuid: E680DA2C5F90FD24
ID-2: /dev/sda2 maj-min: 8:2 size: 223.48 GiB fs: ntfs label: WIN-SSD
uuid: 07492E03A516286B
ID-3: /dev/sdb1 maj-min: 8:17 size: 119.24 GiB fs: ntfs label: WIN-GAMES
uuid: EAE6EE7DE6EE4A01
Hub-1: 1-0:1 info: Full speed or root hub ports: 5 rev: 2.0 speed: 480 Mb/s
Hub-2: 2-0:1 info: Full speed or root hub ports: 5 rev: 2.0 speed: 480 Mb/s
Hub-3: 3-0:1 info: Full speed or root hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-4: 4-0:1 info: Full speed or root hub ports: 5 rev: 1.1 speed: 12 Mb/s
chip-ID: 1d6b:0001 class-ID: 0900
Hub-5: 5-0:1 info: Full speed or root hub ports: 5 rev: 1.1 speed: 12 Mb/s
Hub-6: 6-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-7: 7-0:1 info: Full speed or root hub ports: 4 rev: 1.1 speed: 12 Mb/s
Device-1: 7-3:2 info: SINO WEALTH USB KEYBOARD type: Keyboard,HID
power: 100mA chip-ID: 258a:0001 class-ID: 0300
Device-2: 7-4:3 info: Pixart Imaging Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 093a:2521 class-ID: 0301
Hub-8: 8-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-9: 9-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 36.9 C mobo: N/A gpu: amdgpu temp: 48.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 188
Processes: 255 Uptime: 23m wakeups: 0 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1537 pacman: 1522 lib: 451
flatpak: 15 Shell: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.09
