Interesting thread, thought it was just me - the Super keys haven’t launched the menu for some time now (don’t know kow long. I didn’t notice until recently). I’ll try the suggestions in this thread & see if it fixes it.
N.B. I had the panels crash some time back; maybe this is something to do with it. I just replaced them.
After I ran that command, it instantly started working again. Prior to this, no amount of rebinding to ALT+F1, or removing and re-adding the actual Launcher widget, would get it to work. And prior to that, I most certainly didn’t change any shortcuts. This problem started happening out of the blue as far as I could tell.
Hi - I’m new to Manjaro and was experiencing this annoyance. I tried various fixes in this thread, but none of them worked for me. However, I think I’ve found out my issue. I’ve been switching between different themes since it’s a new install. I noticed that this is related to why my Meta key isn’t mapped to open the Application Launcher. Let me explain.
As I’m new to Manjaro, I don’t know the underlying theming mechanisms, but from what I understand is that you’re able to add numerous Application Launcher Widgets to a Panel. As such, each Application Launcher Widget is unique and has their own internal configuration, including keyboard shortcuts, which I assume this all boils up to a desktop layout configuration somewhere.
Now, by out of the box, Manjaro had mapped the Meta key to the ALW and in my case, that mapping mysteriously stopped working. My hypothesis for this is that as I changed themes and selected Use desktop layout from theme, the stock Manjaro configurations (including the mapped Meta key to ALW) was effectively overwritten. The culprit seems to be Use desktop layout from theme option. I’m not blaming that option, because that’s probably its expected behavior.
My solution:
Select the theme I’d like to use
Right-click the panel → Edit Panel
Hover over the Application Launcher Widget → Configure → Keyboard Shortcuts
Add the Meta (Windows) key (I had to use Meta-F1, since it requires 2+ key combination`)
Escape out of editing the panel
Press Meta key and test if it opens up
From this point on, you’ll want to remember to not select Use desktop layout from theme or else your mapping will be gone when you switch themes, unless the theme provides that mapping by default (is that even possible?).
Yes, it’s annoying and it was fixed (and works with a new account).
However, before it was ‘fixed’ you could use ksuperkey.
The good news is - it still works.
pamac install ksuperkey
Reset the shortcut to Alt+F1
Set ksuperkey in autostart.
Log off.
The other way to manage it, and I use this for umenu which I’m testing this week, is to use Ctrl+z for menu…
Also remember Krunner - zero shortcuts for that if you’re on desktop (just type and it comes up). Sometimes I forget and open the menu - and wonder why I wasted all that time hitting the Meta key
No, I set it there first. The truth is that even the main plasma panel has the same problem - not long after using a fresh desktop it lost the ability to open with Meta.
Doesn’t seem to work for me. And whenever it breaks seems to happen after using an application that’s trying to steal all keyboard input (remote sessions, virtual machines, etc).
Method:activateLauncherMenu in qdbusviewer ( org.kde.plasmashell > PlasmaShell > org.kde.PlasmaShell > activateLauncherMenu) is also not opening Application Launcher for me.
Launcher is opening fine with mouse click but meta key is still not Application launcher.
Update:
Meta key fixed after reassigning launcher shortcut to Alt+F1. Now launcher is opening with both meta key and Alt+F1. Method:activateLauncherMenu in qdbusviewer is also working fine (I have undo changes in kwin config and have reconfigured it).
I was using Latte dock, which worked fine with the meta key.
After I uninstalled Latte, I could not get Alt+F1 to work.
I ended up binding Meta+F1 and it only takes Meta to open the launcher.
