KDE 6.7 running on OpenGL instead of Vulkan
After the testing update on 17-07-2026 KDE is running on OpenGL instead of Vulkan and I get the following warning in journalctl -b.
Jul 18 12:14:17 My-Machine kwin_wayland[711]: Device AMD Radeon RX Vega M GL Graphics (RADV VEGAM) misses required Vulkan extensions
Jul 18 12:14:17 My-Machine kwin_wayland[711]: VK_EXT_image_drm_format_modifier
My system has an iGPU (Intel HD Graphics 630) and dGPU (AMD Radeon RX Vega M GL) which both support Vulkan.
inxi -zv8
  Kernel: 7.1.3-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-7.1-x86_64
    root=UUID=ca0fb9dc-ae10-46f2-a467-6c788f67cecc rw rootflags=subvol=@
    quiet splash resume=UUID=a044a1dc-dfd0-493a-b7d8-18cbe3abe8c1
    udev.log_priority=3 sysrq_always_enabled=1 zswap.enabled=1
  Desktop: KDE Plasma v: 6.7.3 tk: Qt v: N/A info: frameworks v: 6.28.0
    wm: kwin_wayland vt: 2 dm: N/A Distro: Manjaro base: Arch Linux
  Type: Convertible System: Dell product: XPS 15 9575 v: N/A
    serial: <superuser required> Chassis: type: 31 serial: <superuser required>
  Mobo: Dell model: 0C32VW v: A00 serial: <superuser required> part-nu: 080D
    uuid: <superuser required> Firmware: UEFI vendor: Dell v: 1.28.0
    date: 07/11/2023
  ID-1: BAT0 charge: 22.5 Wh (50.6%) condition: 44.4/75 Wh (59.2%)
    volts: 11.54 min: 11.4 model: BYD DELL TMFYT8C type: Li-poly
    serial: <filter> charging: status: not charging type: custom
    avail: adaptive,custom,fast,standard,trickle cycles: N/A
  System RAM: total: 16 GiB available: 15.46 GiB used: 6.49 GiB (42.0%)
  Array-1: capacity: 16 GiB slots: 1 modules: 1 EC: None
  Device-1: Motherboard type: DDR4 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: 2400 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: SK Hynix
    part-no: HMAA51S6AMR6N-UH serial: N/A
  Info: model: Intel Core i7-8705G bits: 64 type: MT MCP arch: Kaby Lake
    gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 9 microcode: 0xF8
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
    desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 800 min/max: 800/4100 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 bogomips: 49599
    smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    vulnerable
  Device-1: Intel Kaby Lake-H GT2 [HD Graphics 630] vendor: Dell driver: i915
    v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
    active: eDP-1 empty: DP-1,DP-2,DP-3 bus-ID: 00:02.0 chip-ID: 8086:591b
    class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Polaris 22 XL [Radeon RX Vega
    M GL] vendor: Dell driver: amdgpu v: kernel arch: GCN-4
    code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3
    speed: 8 GT/s lanes: 8 bus-ID: 01:00.0 chip-ID: 1002:694e class-ID: 0380
    temp: 50.0 C
  Device-3: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2 chip-ID: 0bda:58f4
  Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
    compositor: kwin_wayland driver: X: loaded: amdgpu,modesetting
    alternate: fbdev,vesa dri: iris,radeonsi gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: Sharp 0x148d built: 2018 res: mode: 2560x1440
    hz: 60 scale: 125% (1.25) to: 2048x1152 dpi: 284 gamma: 1.2 chroma: red:
    x: 0.667 y: 0.325 green: x: 0.208 y: 0.737 blue: x: 0.145 y: 0.047 white:
    x: 0.318 y: 0.337 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: 3840x2160
  API: EGL v: 1.5 hw: drv: intel iris drv: amd radeonsi platforms: device: 0
    drv: radeonsi device: 1 drv: iris device: 2 drv: swrast gbm: drv: radeonsi
    surfaceless: drv: radeonsi wayland: drv: iris x11: drv: iris
  API: OpenGL v: 4.6 vendor: intel mesa v: 26.1.4-arch1.1 glx-v: 1.4
    direct-render: yes renderer: Mesa Intel HD Graphics 630 (KBL GT2)
    device-ID: 8086:591b memory: 15.09 GiB unified: yes display-ID: :0.0
  API: Vulkan v: 1.4.350 layers: 13 device: 0 type: integrated-gpu
    name: Intel HD Graphics 630 (KBL GT2) driver: mesa intel v: 26.1.4-arch1.1
    device-ID: 8086:591b surfaces: N/A device: 1 type: discrete-gpu name: AMD
    Radeon RX Vega M GL Graphics (RADV VEGAM) driver: mesa radv
    v: 26.1.4-arch1.1 device-ID: 1002:694e surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: amdgpu_top wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: Intel HM175/QM175/CM238 HD Audio vendor: Dell
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
    chip-ID: 8086:a171 class-ID: 0403
  API: ALSA v: k7.1.3-3-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.8 status: active with: 1: pipewire-pulse
  Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
    vendor: Rivet Networks Killer 1435 Wireless-AC driver: ath10k_pci v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:003e
    class-ID: 0280 temp: 41.0 C
  Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
    rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-2.2:3
    chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
  IF: enp0s20f0u2u2 state: down mac: <filter>
  Device-1: Foxconn / Hon Hai driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:4 chip-ID: 0489:e0a2
    class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.2
    lmp-v: 8 status: discoverable: no pairing: no class-ID: 6c0000
  Local Storage: total: 1.82 TiB used: 179.14 GiB (9.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT2000T710SSD8
    size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 126 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: PBCR5103 temp: 36.9 C
    scheme: GPT
  ID-1: / raw-size: 1.8 TiB size: 1.8 TiB (100.00%) used: 179.14 GiB (9.7%)
    fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3 label: Manjaro
    uuid: ca0fb9dc-ae10-46f2-a467-6c788f67cecc
    used: 664 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: EFI
    uuid: FF0B-6823
  ID-3: /home raw-size: 1.8 TiB size: 1.8 TiB (100.00%)
    used: 179.14 GiB (9.7%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
    label: Manjaro uuid: ca0fb9dc-ae10-46f2-a467-6c788f67cecc
  ID-4: /home/<filter>/mnt/Dropbox raw-size: N/A size: 2.01 TiB
    used: 340.63 GiB (16.6%) fs: fuse.rclone remote: Dropbox:
  ID-5: /home/<filter>/mnt/GDrive raw-size: N/A size: 102 GiB
    used: 84.74 GiB (83.1%) fs: fuse.rclone remote: GDrive:
  ID-6: /home/<filter>/mnt/OneDrive raw-size: N/A size: 205 GiB
    used: 143.4 GiB (70.0%) fs: fuse.rclone remote: OneDrive:
  ID-7: /var/cache raw-size: 1.8 TiB size: 1.8 TiB (100.00%)
  ID-8: /var/log raw-size: 1.8 TiB size: 1.8 TiB (100.00%)
  Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: yes
  ID-1: swap-1 type: partition size: 17.58 GiB used: 0 KiB (0.0%)
    priority: -1 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: a044a1dc-dfd0-493a-b7d8-18cbe3abe8c1
  Device-1: 1-1:2 info: Realtek Integrated_Webcam_HD type: video
    driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 0bda:58f4 class-ID: 0e02
    serial: <filter>
  Hub-2: 1-2:3 info: VIA Labs VL820 Hub ports: 5 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2820
  Device-1: 1-2.1:6 info: Bizlink DELL DA300 type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 06c4:c412 class-ID: 0300
    serial: <filter>
  Device-2: 1-2.3:8 info: Lite-On USB Multimedia Keyboard type: keyboard,HID
    chip-ID: 04ca:0027 class-ID: 0300
  Device-3: 1-6:4 info: Foxconn / Hon Hai type: bluetooth driver: btusb
    interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 100mA chip-ID: 0489:e0a2 class-ID: e001
  Device-4: 1-10:9 info: Shenzhen Goodix Fingerprint Reader
    type: abstract (modem),CDC-data driver: N/A interfaces: 2 rev: 2.0
    chip-ID: 27c6:5395 class-ID: 0a00 serial: <filter>
  Device-5: 1-11:7 info: Logitech G502 Mouse type: mouse,HID
    lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c07d class-ID: 0300
    serial: <filter>
  Hub-3: 2-0:1 info: super-speed hub ports: 8 rev: 3.0
  Hub-4: 2-2:2 info: VIA Labs VL820 Hub ports: 4 rev: 3.1
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0820
  Device-1: 2-2.2:3 info: Realtek RTL8153 Gigabit Ethernet Adapter
    type: Network driver: r8152 interfaces: 1 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 288mA
  System Temperatures: cpu: 54.0 C pch: 41.5 C mobo: 39.0 C sodimm: 44.0 C
    gpu: amdgpu temp: 50.0 C
  Fan Speeds (rpm): cpu: 0
  Packages: pm: pacman pkgs: 1827 libs: 472 tools: pamac,yay pm: flatpak
    pkgs: 0
    1: https://mirror.aarnet.edu.au/pub/manjaro/testing/$repo/$arch
    2: https://mirrors.sonic.net/manjaro/testing/$repo/$arch
    3: https://coresite.mm.fcix.net/manjaro/testing/$repo/$arch
    4: https://ftp.lysator.liu.se/pub/manjaro/testing/$repo/$arch
    5: https://ftp.psnc.pl/linux/manjaro/testing/$repo/$arch
Processes:
  CPU top: 5 of 309
  1: cpu: 11.5% command: librewolf pid: 4589 mem: 827.0 MiB (5.2%)
  2: cpu: 4.7% command: kwin_wayland pid: 2660 mem: 314.5 MiB (1.9%)
  3: cpu: 4.4% command: librewolf pid: 5068 mem: 425.6 MiB (2.6%)
  4: cpu: 2.4% command: librewolf pid: 74358 mem: 377.0 MiB (2.3%)
  5: cpu: 1.8% command: librewolf pid: 4858 mem: 300.3 MiB (1.8%)
  Memory top: 5 of 309
  1: mem: 827.0 MiB (5.2%) command: librewolf pid: 4589 cpu: 11.5%
  2: mem: 425.6 MiB (2.6%) command: librewolf pid: 5068 cpu: 4.4%
  3: mem: 411.0 MiB (2.5%) command: librewolf pid: 72539 cpu: 1.7%
  4: mem: 385.4 MiB (2.4%) command: librewolf pid: 6445 cpu: 1.0%
  5: mem: 384.9 MiB (2.4%) command: librewolf pid: 68702 cpu: 0.9%
  Processes: 309 Power: uptime: 1h 11m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 6.14 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 261 default: graphical
    tool: systemctl
  Compilers: clang: 22.1.8 gcc: 16.1.1 Shell: Zsh v: 5.9.2
    running-in: konsole inxi: 3.3.41
kwin info
Version
KWin version: 6.7.3
Qt Version: 6.11.1
Qt compile version: 6.11.1
XCB compile version: 1.17.0
Operation Mode: Wayland
Build Options
KWIN_BUILD_DECORATIONS: yes
KWIN_BUILD_TABBOX: yes
KWIN_BUILD_ACTIVITIES: yes
HAVE_X11_XCB: yes
X11
Vendor: The X.Org Foundation
Vendor Release: 12401013
Protocol Version/Revision: 11/0
SHAPE: yes; Version: 0x11
RANDR: yes; Version: 0x14
Composite: yes; Version: 0x4
RENDER: yes; Version: 0xb
XFIXES: yes; Version: 0x50
SYNC: yes; Version: 0x31
RES: yes; Version: 0x12
Decoration
Plugin: org.kde.breeze
Theme:
Plugin recommends border size: None
onAllDesktopsAvailable: true
alphaChannelSupported: true
closeOnDoubleClickOnMenu: false
alwaysShowExcludeFromCapture: false
decorationButtonsLeft: 0, 2, 12
decorationButtonsRight: 6, 3, 4, 5
borderSize: 0
gridUnit: 10
font: Noto Sans,10,-1,0,400,0,0,0,0,0,0,0,0,0,0,1,,0,0
smallSpacing: 2
largeSpacing: 10
LogicalOutput backend
Atomic Mode Setting on GPU 0: true
Cursor
themeName: breeze_cursors
themeSize: 24
Options
focusPolicy: ClickToFocus
xwaylandCrashPolicy: 1
xwaylandMaxCrashCount: 3
nextFocusPrefersMouse: false
clickRaise: true
autoRaise: false
autoRaiseInterval: 0
delayFocusInterval: 0
separateScreenFocus: true
placement: 5
activationDesktopPolicy: SwitchToOtherDesktop
focusPolicyIsReasonable: true
borderSnapZone: 10
windowSnapZone: 10
centerSnapZone: 0
snapOnlyWhenOverlapping: false
edgeBarrier: 100
cornerBarrier: 1
rollOverDesktops: false
perOutputVirtualDesktops: false
focusStealingPreventionLevel: 1
operationTitlebarDblClick: 5000
operationMaxButtonLeftClick: 5000
operationMaxButtonMiddleClick: 5013
operationMaxButtonRightClick: 5012
commandActiveTitlebar1: MouseRaise
commandActiveTitlebar2: MouseNothing
commandActiveTitlebar3: MouseOperationsMenu
commandInactiveTitlebar1: MouseActivateAndRaise
commandInactiveTitlebar2: MouseNothing
commandInactiveTitlebar3: MouseOperationsMenu
commandWindow1: MouseActivateRaiseOnReleaseAndPassClick
commandWindow2: MouseActivateAndPassClick
commandWindow3: MouseActivateAndPassClick
commandWindowWheel: MouseNothing
commandAll1: MouseUnrestrictedMove
commandAll2: MouseToggleRaiseAndLower
commandAll3: MouseUnrestrictedResize
keyCmdAllModKey: 16777250
doubleClickBorderToMaximize: true
condensedTitle: false
electricBorderMaximize: true
electricBorderTiling: true
electricBorderAllScreenCorner: true
electricBorderCornerRatio: 0.25
borderlessMaximizedWindows: true
killPingTimeout: 5000
compositingMode: 1
allowTearing: true
interactiveWindowMoveEnabled: true
pictureInPictureHomeCorner: BottomRightCorner
pictureInPictureMargin: 20
overlayVirtualKeyboardOnWindows: false
Screen Edges
desktopSwitching: false
desktopSwitchingMovingClients: false
cursorPushBackDistance: 1x1
actionTopLeft: 0
actionTop: 0
actionTopRight: 0
actionRight: 0
actionBottomRight: 0
actionBottom: 0
actionBottomLeft: 0
actionLeft: 0
Screens
Number of Screens: 1
Screen 0:
Enabled: 1
Geometry: 0,0,2048x1152
Physical size: 344x194mm
Scale: 1.25
Refresh Rate: 59961
Adaptive Sync: incapable
Compositing
Compositing is active
Compositing Type: OpenGL
OpenGL vendor string: Intel
OpenGL renderer string: Mesa Intel(R) HD Graphics 630 (KBL GT2)
OpenGL version string: 4.6 (Core Profile) Mesa 26.1.4-arch1.1
OpenGL platform interface: EGL
OpenGL shading language version string: 4.60
Driver: Intel
GPU class: Kaby Lake
OpenGL version: 4.6
GLSL version: 4.60
Mesa version: 26.1.4
X server version: 1.24.1
Linux kernel version: 7.1.3
Direct rendering: Requires strict binding: no
Virtual Machine:  no
OpenGL 2 Shaders are used
Loaded Effects:
shakecursor
outputlocator
colorpicker
zoom
blur
sessionquit
logout
login
slidingpopups
slidingnotifications
windowaperture
slide
glide
squash
scale
maximize
fullscreen
frozenapp
fadingpopups
dimscreen
dialogparent
windowview
tileseditor
overview
highlightwindow
blendchanges
startupfeedback
systembell
screentransform
kscreen
Currently Active Effects:
blur
Effect Settings:
shakecursor:
outputlocator:
colorpicker:
zoom:
zoomFactor: 1.2
mouseTracking: 0
focusDelay: 350
moveFactor: 20
targetZoom: 1
blur:
sessionquit:
pluginId: sessionquit
isActiveFullScreenEffect: false
logout:
pluginId: logout
login:
pluginId: login
slidingpopups:
slideInDuration: 50
slideOutDuration: 50
slidingnotifications:
windowaperture:
pluginId: windowaperture
slide:
horizontalGap: 45
verticalGap: 20
slideBackground: true
glide:
duration: 40
inRotationEdge: Top
inRotationAngle: 3
inDistance: 30
inOpacity: 0.4
outRotationEdge: Bottom
outRotationAngle: 3
outDistance: 30
outOpacity: 0
squash:
pluginId: squash
scale:
pluginId: scale
maximize:
pluginId: maximize
fullscreen:
pluginId: fullscreen
frozenapp:
pluginId: frozenapp
fadingpopups:
pluginId: fadingpopups
dimscreen:
pluginId: dimscreen
dialogparent:
pluginId: dialogparent
windowview:
activeView:
delegate:
animationDuration: 75
ignoreMinimized: false
mode:
partialActivationFactor: 0
gestureInProgress: false
searchText:
selectedIds:
tileseditor:
activeView:
delegate:
animationDuration: 200
overview:
activeView:
delegate:
filterWindows: true
organizedGrid: true
overviewPartialActivationFactor: 0
overviewGestureInProgress: false
transitionPartialActivationFactor: 0
transitionGestureInProgress: false
gridPartialActivationFactor: 0
gridGestureInProgress: false
searchText:
highlightwindow:
blendchanges:
startupfeedback:
type: 1
systembell:
screentransform:
kscreen:
Loaded Plugins:
BounceKeysPlugin
KeyNotificationPlugin
MouseKeysPlugin
SlowKeysPlugin
StickyKeysPlugin
TouchpadShortcutsPlugin
buttonsrebind
eis
krunnerintegration
nightlight
screencast
screenshot
Available Plugins:
BounceKeysPlugin
MouseKeysPlugin
SlowKeysPlugin
StickyKeysPlugin
buttonsrebind
eis
gamecontroller
krunnerintegration
nightlight
screencast
screenshot
vulkaninfo --summary
VULKANINFO
Vulkan Instance Version: 1.4.350
Instance Extensions: count = 26
VK_EXT_acquire_drm_display : extension revision 1
VK_EXT_acquire_xlib_display : extension revision 1
VK_EXT_debug_report : extension revision 10
VK_EXT_debug_utils : extension revision 2
VK_EXT_direct_mode_display : extension revision 1
VK_EXT_display_surface_counter : extension revision 1
VK_EXT_headless_surface : extension revision 1
VK_EXT_layer_settings : extension revision 2
VK_EXT_surface_maintenance1 : extension revision 1
VK_EXT_swapchain_colorspace : extension revision 5
VK_KHR_device_group_creation : extension revision 1
VK_KHR_display : extension revision 23
VK_KHR_external_fence_capabilities : extension revision 1
VK_KHR_external_memory_capabilities : extension revision 1
VK_KHR_external_semaphore_capabilities : extension revision 1
VK_KHR_get_display_properties2 : extension revision 1
VK_KHR_get_physical_device_properties2 : extension revision 2
VK_KHR_get_surface_capabilities2 : extension revision 1
VK_KHR_portability_enumeration : extension revision 1
VK_KHR_surface : extension revision 25
VK_KHR_surface_maintenance1 : extension revision 1
VK_KHR_surface_protected_capabilities : extension revision 1
VK_KHR_wayland_surface : extension revision 6
VK_KHR_xcb_surface : extension revision 6
VK_KHR_xlib_surface : extension revision 6
VK_LUNARG_direct_driver_loading : extension revision 1
Instance Layers: count = 13
VK_LAYER_FROG_gamescope_wsi_x86_64 Gamescope WSI (XWayland Bypass) Layer (x86_64) 1.3.221 version 1
VK_LAYER_INTEL_nullhw INTEL NULL HW 1.1.73 version 1
VK_LAYER_MANGOHUD_overlay_x86 Vulkan Hud Overlay 1.3.0 version 1
VK_LAYER_MANGOHUD_overlay_x86_64 Vulkan Hud Overlay 1.3.0 version 1
VK_LAYER_MESA_anti_lag Open-source implementation of the VK_AMD_anti_lag extension. 1.4.303 version 1
VK_LAYER_MESA_device_select Linux device selection layer 1.4.303 version 1
VK_LAYER_MESA_overlay Mesa Overlay layer 1.4.303 version 1
VK_LAYER_MESA_screenshot Mesa Screenshot layer 1.4.303 version 1
VK_LAYER_MESA_vram_report_limit Limit reported VRAM 1.4.303 version 1
VK_LAYER_VALVE_steam_fossilize_32 Steam Pipeline Caching Layer 1.3.207 version 1
VK_LAYER_VALVE_steam_fossilize_64 Steam Pipeline Caching Layer 1.3.207 version 1
VK_LAYER_VALVE_steam_overlay_32 Steam Overlay Layer 1.3.207 version 1
VK_LAYER_VALVE_steam_overlay_64 Steam Overlay Layer 1.3.207 version 1
Devices:
GPU0:
apiVersion = 1.4.354
driverVersion = 26.1.4
vendorID = 0x8086
deviceID = 0x591b
deviceType = PHYSICAL_DEVICE_TYPE_INTEGRATED_GPU
deviceName = Intel(R) HD Graphics 630 (KBL GT2)
driverID = DRIVER_ID_INTEL_OPEN_SOURCE_MESA
driverName = Intel open-source Mesa driver
driverInfo = Mesa 26.1.4-arch1.1
conformanceVersion = 1.4.0.0
deviceUUID = 86801b59-0400-0000-0002-000000000000
driverUUID = a660239f-1435-24ec-3d49-51584393043d
GPU1:
vendorID = 0x1002
deviceID = 0x694e
deviceType = PHYSICAL_DEVICE_TYPE_DISCRETE_GPU
deviceName = AMD Radeon RX Vega M GL Graphics (RADV VEGAM)
driverID = DRIVER_ID_MESA_RADV
driverName = radv
deviceUUID = 00000000-0100-0000-0000-000000000000
driverUUID = 414d442d-4d45-5341-2d44-525600000000
I’ve poked around and tried a few things, but I can’t really find the info I need to resolve this issue. Any ideas?
EDIT: I thought kwin was using vulkan prior to 6.7 but apparenlty vulkan support is new in 6.7. However it seems to be trying to use Vulkan from my dGPU and failing (which it shouldn’t because it supports it) but also not using my iGPU which also has vulkan support.
Have you tried to deactivate the iGPU and run only the dGPU? Does that work?
For me your inxi looks fine (just my educated guess, cause i running a ryzen and deactivated the igpu)
Any findings in journalctl?
journalctl --user-unit plasma-kwin_wayland --boot 0
Ideally, because it’s a laptop I’d like it the other way around. I have not found a way to disable the dGPU in a way that doesn’t cause other issues, and I can’t simply pull it out for testing either since it’s embedded in the CPU.
The output I put in my original post were the only related entries in my syslog.
I’m not sure if this is related to the issue, but there is a change coming in Plasma 6.8 - I wonder if it might have been backported to Plasma 6.7.3?
Exactly! I knew there was something. That’s exactly the news story I was trying to remember.
That indeed sounds like they’ve changed plans and opted for tried and tested approach for now. I can only guess there was a deal breaker somewhere that changed the plan. Thanks for the link :+1:
