RT: When will be manjaro ready ?
description: KDE Plasma Desktop
version: 5.23.0
pkgrel: 2
repo: extra
url: Arch Linux - plasma-desktop 5.23.0-2 (x86_64)
version: 5.23.0
pkgrel: 2
repo: extra
As per usual … Things generally trickle from Arch>Manjaro-Unstable>Manjaro-Testing>Manjaro-Stable.
So … its currently in Unstable, and you can either switch to that branch or wait.
How do you know KDE 5.23 is available in the Unstable branch ? Is there a way to know what packages are available in Unstable ?
Thank you very much for that fast reply ! So unstable branch is pretty close to Arch repo. Do you know if there is a delay for the Unstable branch to get the package once it has been release in the Arch repo ?
I updated yesterday and got the 5.23 in unstable
It goes Arch stable → Manjaro-Unstable → Manjaro-Testing → Manjaro-Stable as @cscs mentioned earlier in the thread.
You are on the Unstable branch, I assume. Do you have more problems with updates or packages or anything related to that? I’m on Testing and don’t have any stability problem whatsoever.
How would you consider the stability of Unstable ?
I haven’t noticed any issues at all.I’ve been on unstable about a year now and haven’t had any issues.
Okay. Thank you all for your replies.
What are you annoyed about ?
Probably that thing they said.
Ok your right, that must be it. I’m installing it right now. It just came up in the testing branch. Is there really any big new features ?
and it is buggy:
As stated elsewhere you can always use the ‘classic’ style, or any number of other variants … you dont need to use KDE’s new default. The one I am using ‘unibody’ hasnt even been updated for 2 years … and works fine.
