I did run into one of the Frameworks files, kcoreaddons, not installing. I will be looking into that.
Other than that, the system seems to run much snappier.
kcorecoreaddons was not part of this update. Did you skip the previous update (2024-12-23)? My system shows kcoreaddons (v6.9.0-3) as Install Date : Mon 23 Dec 2024 20:34:31
Also, could you please confirm which branch you are on? Your user profile says “Stable”, but this thread was moved from the “[Testing Update] 2025-01-04” topic. Stable branch’s last update was 2024-12-16.
I had skipped the previous update, yes.
Could you please also update your Forum Profile Preferences to reflect that you are now on Testing branch?
You can check which branch you are currently on by running the following command:
pacman-mirrors --get-branch
I switched to testing this morning.
Could you please retry updating after refreshing your mirror list:
sudo pacman-mirrors --continent && sudo pacman -Syu
Post the output including any errors/warnings/conflicts here.
Edit: changed pacman-mirrors command from fasttrack to the user’s continent.
Note:
The --fasttrack command, when combined with a positive integer, will produce a list with that number of random working mirrors and rank them by speed.
The only way for --fasttrack or -f to produce the fastest mirrors is to use no numeral or 0.
( sudo pacman-mirrors -f )
If we do not wish to ask people to rank all mirrors globally,
And because it has the effect of resetting any existing and possibly problematic mirror pool,
We could suggest --continent or --geoip.
( sudo pacman-mirrors --continent )
Thanks for that explanation. I originally copied the command from the Switching Branches - Manjaro wiki page. I’ve now updated my notes application that I use to store copy & paste replies for this forum to show “continent” rather than “fasttrack”.
I should add that, on my system, I use the global mirrors:
sudo pacman-mirrors --country Global
The fasttrack option is definately what you want. I think my problem updating kcoreaddons is some sort of conflict with xtra cmake modules. With a snow storm pending I may not be online much. Cheers.
Again, will you please:
I fail to see how that can be the case. Both are installed on my testing branch system without any issues:
pamac info kcoreaddons extra-cmake-modules
Version : 6.9.0-3
Description : Addons to QtCore
URL : https://community.kde.org/Frameworks
Licenses : LGPL-2.0-only LGPL-3.0-only
Repository : extra
Installed Size : 4.3 MB
Groups : kf6
Depends On : gcc-libs glibc qt6-base systemd-libs
Optional Dependencies : pyside6: Python bindings [Installed]
qt6-declarative: QML bindings [Installed]
Required By : ark audiocd-kio baloo baloo-widgets bluedevil bomber bovo breeze discover dolphin dolphin-plugins elisa
ffmpegthumbs filelight granatier gwenview haruna kaccounts-integration kaccounts-providers kactivitymanagerd
kamera kapman kate katomic kauth kblackbox kblocks kbookmarks kbounce kbreakout kcalc kcmutils kcolorchooser
kconfigwidgets kcontacts kcrash kde-cli-tools kde-gtk-config kdeconnect kded kdegraphics-thumbnailers
kdeplasma-addons kdesu kdialog kdiamond keditbookmarks kfilemetadata kfind kfourinline kget kglobalacceld
kgoldrunner khelpcenter kigo killbots kinfocenter kio kio-admin kio-extras kio-fuse kirigami-addons kiriki
kjobwidgets kjournald kjumpingcube klickety klines kmahjongg kmenuedit kmines knavalbattle knetwalk knewstuff
knights kolf kollision konquest konsole kpackage kparts kpat kpeople kpipewire kpmcore kpty kreversi kruler
krunner kscreen kscreenlocker kservice kshisen ksirk ksnakeduel kspaceduel ksquares ksshaskpass ksudoku ksvg
ksystemlog ksystemstats ktexteditor ktuberling kubrick kwallet kwalletmanager kwin kwrited kxmlgui libkcddb
libkdegames libkmahjongg libksysguard libplasma lskat marknote okular palapeli partitionmanager picmi
plasma-activities plasma-browser-integration plasma-desktop plasma-integration plasma-nm plasma-pa
plasma-systemmonitor plasma-thunderbolt plasma-workspace plasma5support polkit-kde-agent powerdevil
print-manager purpose qqc2-breeze-style sddm-kcm skladnik spectacle systemsettings xdg-desktop-portal-kde
yakuake
Optional For : falkon
Provides : --
Replaces : --
Conflicts With : --
Packager : Antonio Rojas <arojas@archlinux.org>
Build Date : Sun 15 Dec 2024 07:04:32
Install Reason : Installed as a dependency for another package
Validated By : Signature
Backup files : --
Version : 6.9.0-1
Description : Extra modules and scripts for CMake
Licenses : LGPL
Repository : extra
Installed Size : 2.1 MB
Groups : kf6
Depends On : cmake
Optional Dependencies : python-pyxdg: to generate fastlane metadata for Android apps
python-requests: to generate fastlane metadata for Android apps [Installed]
python-yaml: to generate fastlane metadata for Android apps [Installed]
Required By : --
Optional For : --
Provides : --
Replaces : --
Conflicts With : --
Packager : Tomaz Canabrava <tcanabrava@archlinux.org>
Build Date : Sat 14 Dec 2024 20:48:07
Install Date : Tue 17 Dec 2024 20:11:51
Install Reason : Explicitly installed
Backup files : --
Not really. At least not with a number. Did you read anything written?
going to be much more clear to everyone else if you follow the directions to share the output.
If you do come online again, before you post any other comments about fast-tracking or snowstorms, please try to focus on replying to direct assistance:
It does appear that you failed to paste results of your update attempt:
We think your problem updating kcoreaddons is caused by conflicts which YOU created by not updating properly.
The only way forward here is if you will follow, step by step, the instructions offered by people who do not have the same issues which you created.
If you have conflicts, you created them yourself by not properly updating and by jumping between branches without properly updating.
You are simply encouraging people to waste their time trying to help, whilst you ignore them.
This thread should now be paused until you paste the output from the above command.
[sudo] password for dougrrr:
::INFO => Mirror status: https://repo.manjaro.org/status.json
::INFO User generated mirror list
::INFO Custom mirror file saved: /var/lib/pacman-mirrors/custom-mirrors.json
::INFO Using default mirror file
::INFO Querying mirrors - This may take some time
0.521 Canada : https://mirror.csclub.uwaterloo.ca/manjaro/
0.385 Canada : https://mirror.xenyth.net/manjaro/
0.470 Canada : https://muug.ca/mirror/manjaro/
1.613 Costa_Rica : https://mirrors.ucr.ac.cr/manjaro/
0.479 United_States : http://mirror.fcix.net/manjaro/
0.339 United_States : https://nnenix.mm.fcix.net/manjaro/
0.542 United_States : https://ziply.mm.fcix.net/manjaro/
0.527 United_States : https://irltoolkit.mm.fcix.net/manjaro/
0.321 United_States : https://uvermont.mm.fcix.net/manjaro/
0.584 United_States : https://repo.ialab.dsu.edu/manjaro/
0.716 United_States : https://mirrors.ocf.berkeley.edu/manjaro/
0.320 United_States : https://mirror.math.princeton.edu/pub/manjaro/
0.359 United_States : https://mnvoip.mm.fcix.net/manjaro/
0.274 United_States : https://forksystems.mm.fcix.net/manjaro/
0.544 United_States : https://codingflyboy.mm.fcix.net/manjaro/
0.283 United_States : https://coresite.mm.fcix.net/manjaro/
0.593 United_States : https://ridgewireless.mm.fcix.net/manjaro/
0.552 United_States : https://opencolo.mm.fcix.net/manjaro/
0.436 United_States : https://southfront.mm.fcix.net/manjaro/
0.365 United_States : https://volico.mm.fcix.net/manjaro/
0.349 United_States : https://ohioix.mm.fcix.net/manjaro/
0.834 United_States : https://mirrors.sonic.net/manjaro/
0.358 United_States : https://mirrors.gigenet.com/manjaro/
0.453 United_States : https://nocix.mm.fcix.net/manjaro/
::INFO Writing mirror list
::United_States : https://forksystems.mm.fcix.net/manjaro/testing
::United_States : https://coresite.mm.fcix.net/manjaro/testing
::United_States : https://mirror.math.princeton.edu/pub/manjaro/testing
::United_States : https://uvermont.mm.fcix.net/manjaro/testing
::United_States : https://nnenix.mm.fcix.net/manjaro/testing
::United_States : https://ohioix.mm.fcix.net/manjaro/testing
::United_States : https://mirrors.gigenet.com/manjaro/testing
::United_States : https://mnvoip.mm.fcix.net/manjaro/testing
::United_States : https://volico.mm.fcix.net/manjaro/testing
::Canada : https://mirror.xenyth.net/manjaro/testing
::United_States : https://southfront.mm.fcix.net/manjaro/testing
::United_States : https://nocix.mm.fcix.net/manjaro/testing
::Canada : https://muug.ca/mirror/manjaro/testing
::United_States : http://mirror.fcix.net/manjaro/testing
::Canada : https://mirror.csclub.uwaterloo.ca/manjaro/testing
::United_States : https://irltoolkit.mm.fcix.net/manjaro/testing
::United_States : https://ziply.mm.fcix.net/manjaro/testing
::United_States : https://codingflyboy.mm.fcix.net/manjaro/testing
::United_States : https://opencolo.mm.fcix.net/manjaro/testing
::United_States : https://repo.ialab.dsu.edu/manjaro/testing
::United_States : https://ridgewireless.mm.fcix.net/manjaro/testing
::United_States : https://mirrors.ocf.berkeley.edu/manjaro/testing
::United_States : https://mirrors.sonic.net/manjaro/testing
::Costa_Rica : https://mirrors.ucr.ac.cr/manjaro/testing
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
core is up to date
extra is up to date
community is up to date
multilib is up to date
Further investigation on this I saw an error that the kcoreaddons file already exists. So, that is hopeful. Will try again later. Meanwhile, trying to keep all devices and power packs charged for this level 3 weather emergency. Later, everyone!
This shows no error.
(aside from the long dead community repo)
Where?
It was an error generated by pacman on install.
/usr/lib/libKF6CoreAddons.so.6.9.0
Well, that marks the second time you’ve marked one of your own posts as the Solution; neither of which was the solution to anything.
This topic is closed. It’s clearly going nowhere.
