Kbuildsycoca5 returns ' "applications.menu" not found '
I’ve been having an odd issue after installing a large update yesterday, where krunner no longer recognises applications as things it can trigger. This is pretty inconvenient, since I use i3 as my window manager and generally don’t have another way to run applications besides whatever launcher. I’ve done some searching and found a post that suggested running kbuildsycoca5 --noincremental; this returned the following potentially indicative response:
"applications.menu" not found in ("/home/USER/.config/menus", "/etc/xdg/menus")
What do I need to do to regenerate this applications.menu file?
You need to use kbuildsycoca6, not kbuildsycoca5. I would also recommend completely logging out of Plasma, logging in at a tty, stopping sddm, emptying your ~/.cache/, and running kbuildsycoca6 from there. :point_down:
sudo systemctl stop sddm
rm -rf ~/.cache/*
kbuildsycoca6 --noincremental
sudo systemctl reboot
I tried following those instructions exactly (except ‘logging out of Plasma’ since I’m in i3, Plasma shouldn’t be running); and kbuildsycoca6 returned exactly the same error message and seems to have had no effect.
extra/plasma-workspace 6.0.4-1.0 (plasma)
etc/xdg/menus/plasma-applications.menu
Set XDG_MENU_PREFIX accordingly and retry.
Then, logout of i3 and follow the same instructions given;
and possibly a reboot also, before logging in again.
Ah, yep, I think the issue is that $XDG_MENU_PREFIX is empty, but the applications menu file is plasma-applications.menu. I can bandaid it with a symlink to applications.menu, but I’d rather find the correct way to permanently set $XDG_MENU_PREFIX to "plasma-".
The document you linked to says nothing about setting that variable beyond this rather unhelpfully minimal summary -
In this case the $XDG_MENU_PREFIX environment variable must be set by the system to reflect the .menu file that is being used.
If the system isn’t setting that variable, how do I set it myself, or force the system to set it the way I want it?
(bizarrely, rofi -show drun has all the applications just fine; it’s only krunner that’s failing to recognise them)
https://wiki.archlinux.org/title/XDG_MIME_Applications#Empty_MIME_associations_/_open_with_menu_in_KDE
I usually put big global env vars in /etc/environment, but it says .xinitrc.
This all seems more complex than I understand at this point. I’m giving up and switching to rofi, which seems to be 95% of what I need and has no problems at all.
