Hi everyone, so I have a problem with the gpu, this helps me to run katago opencl, I have an amd radeon vega 8 Graphics, how can I make it work?
You may need to install the mesa-nonfree
codecs, which you can find (with instructions) here.
I installed them but they don’t solve the problem
Have you rebooted in the meantime?
Yes, I restarted the system but nothing
Well, I’m afraid I cannot offer any more help at this point. Hopefully someone more experienced with graphics and/or gaming will pitch in.
Proprietary components can be added with:
https://wiki.archlinux.org/title/AMDGPU_PRO#Installation
For OpenCL runtimes:
https://wiki.archlinux.org/title/GPGPU#AMD/ATI
Have you tried installing katago-opencl
from the AUR?
pamac build katago-opencl
I’m not familiar with this software, so maybe you also need katago-cpu
. In that case, you can install both of them at the same time…
pamac build katago-opencl katago-cpu
… or alternatively…
yay -S katago-opencl katago-cpu
But before you do this, make sure your system is fully up to date…
sudo pacman -Syu
AUR package katago-opencl 1.11.0-1 has been out of date since v1.12 released in January
but AUR package has not been flagged as out of date until 2023-09-25
Latest version v1.13.2 released 25 May 2023
