/opt/kaspersky/kesl/libexec/kesl-gui: /opt/kaspersky/kesl/lib64/libstdc++.so.6: version `GLIBCXX_3.4.30' not found (required by /usr/lib/libicuuc.so.72)
Is it possible to either build a shortcut for this or autoexecute it on system startup?
The KESL packages are not being updated but YAY does download and execute the following configuration files listed on the AUR page:
kesl.ini
kesl.install
kesl.start.conf
So I’m wondering why uninstall and reinstall of kesl-gui and kesl doesn’t work.
I did manually execute “systemctrl stop kesl” several times over the last week, to free some RAM (had only 4GB and no SWAP at that time).
kesl-gui was kept running by me, though kesl was stopped manually as specified above.
I did not bother to stop kesl-gui because its memory footprint is tiny.
Maybe this tampering broke something in kesl-gui and so it won’t load now without LD_PRELOAD?
Here is a pop up message I get when i try to execute kesl-gui using the kesl-gui desktop shortcut (that was created by AUR during install) using right click and the 'open with create launcher on the panel’ option on the right click menu:
Failed to add plugin to the panel
GDBus.Error: Org.freedesktop.dbus.error: ServiceUnknown: The name org.xfce.Panel was not provided by any .service files
Use same command? You can probably just overwrite kaspersky libstdc++.so.6 and it will work.
And system ones are. That was my point - package is unmaintained. And it uses some system libs and it has some own libs, so the result is unsurprising.
