Kamoso Webcam Doesn't Work
Kamoso doesn’t enable webcam, even though it detects laptop integrated webcam twice in the settings.
$ kamoso
Cyclic dependency detected between "file:///usr/lib/qt/qml/org/kde/kirigami.2/styles/org.kde.desktop.plasma/Units.qml" and "file:///usr/lib/qt/qml/org/kde/kirigami.2/styles/org.kde.desktop.plasma/Units.qml"
qrc:/qml/Mode.qml:23:28: Invalid property assignment: string expected - Assigning null to incompatible properties in QML is deprecated. This will become a compile error in future versions of Qt.
file:///usr/lib/qt/qml/org/kde/kirigami.2/private/globaltoolbar/ToolBarPageHeader.qml:43:9: QML ActionToolBar: Binding loop detected for property "actions"
file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/AbstractApplicationHeader.qml:153:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/AbstractApplicationHeader.qml:80:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/AbstractApplicationHeader.qml:102:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
qrc:/qml/Main.qml:96:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/OverlayDrawer.qml:291:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
file:///usr/lib/qt/qml/org/kde/kirigami.2/private/ActionButton.qml:209:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
file:///usr/lib/qt/qml/org/kde/kirigami.2/private/ActionButton.qml:201:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
file:///usr/lib/qt/qml/org/kde/kirigami.2/private/globaltoolbar/PageRowGlobalToolBarUI.qml:115: TypeError: Cannot read property 'globalToolBarStyle' of null
file:///usr/lib/qt/qml/org/kde/kirigami.2/private/globaltoolbar/PageRowGlobalToolBarUI.qml:60:17: Unable to assign [undefined] to QQmlListProperty<QObject>
error debugMessage: No file name specified for reading.
error on: "filesrc location=\"\" ! decodebin ! imagefreeze ! videoconvert ! identity name=last" "../gstreamer/plugins/elements/gstfilesrc.c(524): gst_file_src_start (): /GstPipeline:pipeline0/GstFileSrc:filesrc0"
error on: "filesrc location=\"\" ! decodebin ! imagefreeze ! videoconvert ! bulge name=last" "../gstreamer/plugins/elements/gstfilesrc.c(524): gst_file_src_start (): /GstPipeline:pipeline1/GstFileSrc:filesrc1"
@anks — I am also facing similar problem. See this issue. I tried Kamoso — and still the webcam doesnt work.
Can you please confirm whether for you the webcam works in google-meet or zoom?
I can confirm that it doesn’t work for me in other apps like zoom or chromium too.
Please provide from terminal:
v4l2-ctl --list-devices
Depending if you get
/dev/video1
or
/dev/video0
try to see if the webcam works in vlc for example with this command from terminal:
vlc v4l2:// :input-slave=alsa:// :v4l-vdev="/dev/video1"
Also if you want to test some controls, you run:
v4l2-ctl -d /dev/video1 --list-ctrls
More about you can find here:
https://wiki.archlinux.org/index.php/Webcam_setup
@anon89812132 — In my case, webcam doesnt work through vlc. I get the following error
[werunom@thinkpad ~]$ vlc v4l2:// :input-slave=alsa:// :v4l-vdev="/dev/video1"
VLC media player 3.0.11.1 Vetinari (revision 3.0.11.1-0-g52483f3ca2)
[0000564f425015b0] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
[00007f1df002aaf0] main decoder error: buffer deadlock prevented
You can try a different player, as per wiki. Do you get the same error?
Try for instance:
mpv --demuxer-lavf-format=video4linux2 --demuxer-lavf-o-set=input_format=mjpeg av://v4l2:/dev/video1
If you go trough that wiki you will see there are more options to test.
$  v4l2-ctl --list-devices
Laptop_Integrated_Webcam_2HDM:  (usb-0000:00:1a.0-1.4):
        /dev/video0
        /dev/video1
[00005574a81f8630] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
[00007f924802c030] main decoder error: buffer deadlock prevented
Your device is on video0 and not on video1
Change that and try again.
Getting same error as previous
Getting no output for this.
And did you try video0 ?
Yes, I tried for video0
