Hello everyone, before to start here is my inxi -Fazy
Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=5090276d-927b-4d3a-a229-e6890a438f3f rw quiet acpi_backlight=video
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: HUAWEI product: BOHK-WAX9X v: M1040 serial: <filter>
Mobo: HUAWEI model: BOHK-WAX9X-PCB v: M1040 serial: <filter> UEFI: HUAWEI
v: 1.05 date: 12/04/2019
ID-1: BAT1 charge: 37.9 Wh condition: 42.3/41.6 Wh (102%) volts: 12.7/11.5
model: Sunwoda-H HB4692J5ECW-31 type: Li-ion serial: <filter>
status: Not charging cycles: 22
Topology: Quad Core model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen+ family: 17 (23) model-id: 18 (24)
stepping: 1 microcode: 8108109 L2 cache: 2048 KiB
bogomips: 33550
Speed: 1223 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz):
1: 1223 2: 1239 3: 1240 4: 1370 5: 1272 6: 1230 7: 1288 8: 1226
disabled, RSB filling
Device-1: AMD Picasso vendor: Huawei driver: amdgpu v: kernel
bus ID: 03:00.0 chip ID: 1002:15d8
Device-2: IMC Networks type: USB driver: uvcvideo bus ID: 1-4.2:4
chip ID: 13d3:56f9 serial: <filter>
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: amdgpu
FAILED: ati unloaded: modesetting alternate: fbdev,vesa display ID: :0
screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: AMD RAVEN (DRM 3.38.0 5.8.6-1-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.1.7 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Huawei
driver: snd_hda_intel v: kernel bus ID: 03:00.1 chip ID: 1002:15de
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Huawei
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x bus ID: 03:00.5
chip ID: 1022:15e2
Device-3: AMD Family 17h HD Audio vendor: Huawei driver: snd_hda_intel
v: kernel bus ID: 03:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.8.6-1-MANJARO
Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: & Tele RSH driver: rtw_8822ce v: N/A modules: rtw88_8822ce
port: 2000 bus ID: 02:00.0 chip ID: 10ec:c822
Local Storage: total: 238.47 GiB used: 101.25 GiB (42.5%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: PC SN730 SDBPNTY-256G-1027
size: 238.47 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: 11110000 scheme: GPT
ID-1: / raw size: 238.17 GiB size: 233.43 GiB (98.01%)
used: 101.25 GiB (43.4%) fs: ext4 dev: /dev/nvme0n1p2
System Temperatures: cpu: 45.9 C mobo: N/A gpu: amdgpu temp: 45 C
Processes: 238 Uptime: 22h 12m Memory: 6.79 GiB used: 2.25 GiB (33.2%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 10.0.1 Packages:
pacman: 1333 lib: 358 flatpak: 0 Shell: Zsh v: 5.8 running in: konsole
inxi: 3.1.05
So, as title says it just worked and stopped working after the update. I get an update on testing and it stopped working, days ago. Then I decided to come back to stable and it worked again for few days until the latest update. How my problem is different from a similar post posted in august? Because in my case webcam is working perfectly in the browser, telegram and even cheese. The problem appeared only after the update of kamoso. If I run kamoso with sudo the webcam is working.
This is the output when i try to launch kamoso from terminal
~ >>> kamoso
Cyclic dependency detected between "file:///usr/lib/qt/qml/org/kde/kirigami.2/styles/org.kde.desktop.plasma/Units.qml" and "file:///usr/lib/qt/qml/org/kde/kirigami.2/styles/org.kde.desktop.plasma/Units.qml"
qrc:/qml/Mode.qml:23:28: Invalid property assignment: string expected - Assigning null to incompatible properties in QML is deprecated. This will become a compile error in future versions of Qt.
file:///usr/lib/qt/qml/org/kde/kirigami.2/private/globaltoolbar/ToolBarPageHeader.qml:43:9: QML ActionToolBar: Binding loop detected for property "actions"
file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/AbstractApplicationHeader.qml:153:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/AbstractApplicationHeader.qml:80:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/AbstractApplicationHeader.qml:102:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
qrc:/qml/Main.qml:103:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
qrc:/qml/Main.qml:53:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/OverlayDrawer.qml:291:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
file:///usr/lib/qt/qml/org/kde/kirigami.2/private/ActionButton.qml:209:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
file:///usr/lib/qt/qml/org/kde/kirigami.2/private/ActionButton.qml:201:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
file:///usr/lib/qt/qml/org/kde/kirigami.2/private/globaltoolbar/PageRowGlobalToolBarUI.qml:115: TypeError: Cannot read property 'globalToolBarStyle' of null
file:///usr/lib/qt/qml/org/kde/kirigami.2/private/globaltoolbar/PageRowGlobalToolBarUI.qml:60:17: Unable to assign [undefined] to QQmlListProperty<QObject>
For the rest manjaro is working perfectly, and with kernel updates annoying bugs like touchpad not working after suspend aren’t frequent anymore, at least it didn’t happen from weeks yet.
Thank you in advance to whoever will try to help.
