I am using Kaffeine with a USB TV ( DVB-C) receiver, which finds all the channels, but I can’t add just one channel to the list. If I select multiple channels, Kaffeine crashes.
Welcome to the Manjaro Community @Lazlo1967
Could you please open kaffeine from a terminal and try adding the channel. If Kaffeine then crashes, do any error messages appear in the terminal?
Also, as a new forum user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
The Update Announcements should be checked frequently for important update related information.
These announcements contain a Known Issues and Solutions section and should generally be checked before posting a request for support.
Output of the following command formatted according to forum requirements (see links above) is often useful (and this or similar will usually be asked for in Support threads):
inxi -zv8
This gives some (privacy-filtered) information about your system.
Be prepared to provide more information and outputs from other commands when asked.
Hello scotty65 !
Than You for your answer, I will send what You requested.
[apa@NagyBarlang ~]$ inxi -zv8
Kernel: 6.12.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=dc61137a-3ad4-4d4a-af93-1c5f7d3efc11 rw quiet apparmor=1
Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.48 wm: xfwm4 v: 4.20.0
with: plank,xfce4-panel tools: light-locker,xfce4-screensaver vt: 7
dm: LightDM v: 1.32.0 Distro: Manjaro base: Arch Linux
Type: Laptop System: Acer product: Aspire A515-51G v: V2.02
serial: <superuser required>
Mobo: KBL model: Charmander_KL v: V2.02 serial: <superuser required>
part-nu: 0000000000000000 uuid: <superuser required> UEFI: Insyde v: 2.02
date: 01/03/2019
ID-1: BAT1 charge: 39.6 Wh (100.0%) condition: 39.6/48.9 Wh (81.0%)
volts: 15.3 min: 15.2 model: LG 0x4B384234314341 type: Li-ion
serial: <filter> status: full
System RAM: total: 8 GiB available: 7.63 GiB used: 1.73 GiB (22.6%)
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous unbuffered
(unregistered) size: 4 GiB speed: 2400 MT/s volts: curr: 1 min: 2 max: 2
width (bits): data: 64 total: 64 manufacturer: SK Hynix
part-no: HMA851S6AFR6N-UH serial: N/A
Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous unbuffered
(unregistered) size: 4 GiB speed: 2400 MT/s volts: curr: 1 min: 1.25
max: 2 width (bits): data: 64 total: 64 manufacturer: Kingston
part-no: 9905704-003.A00G serial: <filter>
Info: model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2017 process: Intel 14nm family: 6
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF6
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 400 min/max: 400/3400 scaling: driver: intel_pstate
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 bogomips: 28808
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
vulnerable
Device-1: Intel UHD Graphics 620 vendor: Acer Incorporated ALI driver: i915
v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: HDMI-A-1,eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:5917
class-ID: 0300
Device-2: NVIDIA GM108M [GeForce MX130] vendor: Acer Incorporated ALI
driver: nvidia v: 550.144.03 alternate: nouveau,nvidia_drm
non-free: 550/565.xx+ status: current (as of 2025-01; EOL~2026-12-xx)
arch: Maxwell code: GMxxx process: TSMC 28nm built: 2014-2019 pcie: gen: 1
speed: 2.5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:174d class-ID: 0302
Device-3: AVerMedia TD310 DVB-T/T2/C dongle driver: dvb_usb_af9035
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4.4:7
chip-ID: 07ca:1871 class-ID: 0000 serial: <filter>
Device-4: Quanta HD Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:6 chip-ID: 0408:a060
Display: x11 server: X.Org v: 21.1.16 compositor: xfwm4 v: 4.20.0 driver:
X: loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
dri: iris gpu: i915 display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x2160 s-dpi: 96 s-size: 509x572mm (20.04x22.52")
s-diag: 766mm (30.14")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: top model: Samsung S22F350
serial: <filter> built: 2017 res: mode: 1920x1080 hz: 60 scale: 100% (1)
dpi: 102 gamma: 1.2 chroma: red: x: 0.647 y: 0.337 green: x: 0.329
y: 0.616 blue: x: 0.145 y: 0.055 white: x: 0.314 y: 0.329
size: 477x268mm (18.78x10.55") diag: 547mm (21.5") ratio: 16:9
modes: 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800,
1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576, 720x480,
640x480, 720x400
Monitor-2: eDP-1 pos: primary,bottom model: BOE Display 0x06ba built: 2016
res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 142 gamma: 1.2 chroma: red:
x: 0.592 y: 0.345 green: x: 0.329 y: 0.573 blue: x: 0.149 y: 0.114 white:
x: 0.314 y: 0.329 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL Message: Unable to show GL data. glxinfo is missing.
Info: Tools: de: xfce4-display-settings gpu: nvidia-smi
x11: xdpyinfo, xprop, xrandr
Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
API: ALSA v: k6.12.19-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.1 status: active with: wireplumber
status: active tools: pw-cat,pw-cli,wpctl
Server-3: PulseAudio v: 17.0-43-g3e2bb status: active
with: pulseaudio-alsa type: plugin tools: pacat,pactl,pavucontrol
vendor: Acer Incorporated ALI driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.1 chip-ID: 10ec:8168
class-ID: 0200
IF: enp2s0f1 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Lite-On driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0042 class-ID: 0280
IF: wlp3s0 state: down mac: <filter>
Device-1: Lite-On Qualcomm Atheros QCA9377 Bluetooth driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:4
chip-ID: 04ca:3015 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 1.14 TiB used: 71.7 GiB (6.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Patriot model: Scorch M2
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 tech: SSD serial: <filter> fw-rev: E8FM11.5 temp: 49.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1J scheme: GPT
ID-1: / raw-size: 98.53 GiB size: 96.42 GiB (97.86%) used: 31.83 GiB (33.0%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: dc61137a-3ad4-4d4a-af93-1c5f7d3efc11
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: D963-2F50
ID-3: /home raw-size: 130.96 GiB size: 127.85 GiB (97.62%)
used: 39.87 GiB (31.2%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
label: N/A uuid: 1835b7e1-3da7-46ea-939d-97e650a08b3a
ID-1: swap-1 type: partition size: 8.69 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: b0779c15-4f0f-4f74-a5f4-b3b503c23da2
ID-1: /dev/sda1 maj-min: 8:1 size: 931.51 GiB fs: ext4 label: Adat
uuid: e9bc4f29-895e-41c9-8b29-8223d0a82504
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-1:2 info: Logitech G403 Prodigy Gaming Mouse type: mouse,HID
lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c083 class-ID: 0300
serial: <filter>
Hub-2: 1-4:3 info: Alcor Micro USB Hub ports: 4 rev: 2.0
chip-ID: 058f:6254 class-ID: 0900
Device-1: 1-4.1:5 info: Logitech F310 Gamepad [DirectInput Mode] type: HID
driver: logitech,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 30mA chip-ID: 046d:c216 class-ID: 0300
Device-2: 1-4.4:7 info: AVerMedia TD310 DVB-T/T2/C dongle type: Video
driver: dvb_usb_af9035 interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 07ca:1871 class-ID: 0000
serial: <filter>
Device-3: 1-5:4 info: Lite-On Qualcomm Atheros QCA9377 Bluetooth
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Device-4: 1-7:6 info: Quanta HD Webcam type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 0408:a060 class-ID: 0e02 serial: <filter>
Hub-3: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
System Temperatures: cpu: 43.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 1412 libs: 412 tools: pamac
pm: flatpak pkgs: 0
1: https://mirrors2.manjaro.org/stable/$repo/$arch
2: https://mirrors.manjaro.org/repo/stable/$repo/$arch
3: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
4: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
5: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 257
1: cpu: 300% command: ps pid: 7319 mem: 3.66 MiB (0.0%)
2: cpu: 15.6% command: Xorg pid: 1072 mem: 148.9 MiB (1.9%)
3: cpu: 12.5% command: brave pid: 7234 mem: 269.7 MiB (3.4%)
4: cpu: 7.4% command: brave pid: 7145 mem: 241.0 MiB (3.0%)
5: cpu: 7.4% command: xfce4-terminal pid: 7294 mem: 59.9 MiB (0.7%)
Memory top: 5 of 257
1: mem: 322.6 MiB (4.1%) command: brave pid: 7107 cpu: 7.3%
2: mem: 269.7 MiB (3.4%) command: brave pid: 7234 cpu: 12.5%
3: mem: 241.0 MiB (3.0%) command: brave pid: 7145 cpu: 7.4%
4: mem: 151.9 MiB (1.9%) command: brave pid: 7171 cpu: 0.9%
5: mem: 148.9 MiB (1.9%) command: Xorg pid: 1072 cpu: 15.6%
Processes: 257 Power: uptime: 21m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3.02 GiB services: upowerd,xfce4-power-manager
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Bash v: 5.2.37
running-in: xfce4-terminal inxi: 3.3.37
Than Kaffein runs in terminal and I scanned the channels and tried to add more channels, here are all messages:
[apa@NagyBarlang ~]$ kaffeine
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Detective" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Adventure" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Science Fiction" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Comedy" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Soap" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Romance" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Classical" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Adult" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "User defined" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Weather" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Magazine" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Documentary" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Discussion" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "User Defined" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Quiz" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Variety" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Talk" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Events" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Football" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Tennis" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Team" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Athletics" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Motor" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Water" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Winter" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Equestrian" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Martial" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Preschool" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "06 to 14" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "10 to 16" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Educational" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Cartoons" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Poprock" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Folk" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Jazz" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Opera" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Ballet" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Performance" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Fine Arts" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Religion" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Traditional" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Literature" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Cinema" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Experimental" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Press" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "New Media" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Fashion" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Advisory" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "People" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Nature" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Technology" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Medicine" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Foreign" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Social" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Further" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Language" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Travel" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Handicraft" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Motoring" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Fitness" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Cooking" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Shopping" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Gardening" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Original Language" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Black and White " msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Unpublished" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Live" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Planostereoscopic" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "User Defined 1" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "User Defined 2" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "User Defined 3" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "User Defined 4" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Undefined" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Movie" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "News" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Show" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Sports" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Children" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Music" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Culture" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Education" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Leisure" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Special" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Reserved" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Soap opera" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Mini-series" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Series" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Reality show" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Information" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Comical" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Erotic" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Raffle, television sales, prizing" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Debate/interview" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Other" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Report" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Biography" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Educative" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Auditorium" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Musical" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Making of" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Feminine" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Game show" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Country" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Health" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Raffle" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Television sales" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Prizing" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Interview" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Adult cartoon" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Interactive" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Policy" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "reserved" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "all audiences" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "10 years" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "12 years" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "14 years" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "16 years" msgid_plural: "" msgctxt: ""
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "18 years" msgid_plural: "" msgctxt: ""
20-03-25 10:47:00.596 [Warning ] QCommandLineParser: already having an option named "h"
20-03-25 10:47:00.596 [Warning ] QCommandLineParser: already having an option named "help-all"
20-03-25 10:47:00.596 [Warning ] QCommandLineParser: already having an option named "v"
20-03-25 10:47:01.026 [Info ] kaffeine.dvb: Using built-in dvb device manager
20-03-25 10:47:01.262 [Info ] kaffeine.dev: Found dvb device : Silicon Labs Si2168
20-03-25 10:47:01.869 [Warning ] kf.service.services: KServiceTypeTrader: serviceType "ThumbCreator" not found
20-03-25 10:47:01.870 [Warning ] kf.service.services: KServiceTypeTrader: serviceType "ThumbCreator" not found
20-03-25 10:47:02.186 [Warning ] kf.service.services: KServiceTypeTrader: serviceType "ThumbCreator" not found
20-03-25 10:47:36.046 [Info ] kaffeine.dvbsi: More than one teletext PID
20-03-25 10:47:42.845 [Warning ] kaffeine.dvbsi: Invalid descriptor
Szegmentálási hiba (core készült)
Last line in english : Segmentation fault (core created)
I’m a simple user I don’t know where is the core.
Thank You in advance, László
I’m really not sure what is causing the crash. kaffeine is a KDE app - I wonder if the issue is caused by something from KDE missing when running it on XFCE?
Hopefully someone else here will know more than me about this. I’ve never used kaffeine, so I’m just grasping at straws.
You could also look at the kaffeine bug list & Search results for ‘kaffeine’ - KDE Discuss.
There are also TV viewing alternatives available if you can’t find a fix for the Kaffeine crashing issue:
https://www.linuxtv.org/wiki/index.php/TV_Related_Software#Standalone_Software_to_Watch_Digital_TV
Ok, thanks!
My problem still exists, but I don’t seem to have any ideas or solutions.
A post was split to a new topic: The screen stays black. I can only hear audio
When I build it from source, it works.
