Ich habe einen SATA Brenner.
Hier ist das Logfile, wenn ich K3B auf der Konsole starte:
21 21
QUrl("file:///home/armin/Dokumente/")
QUrl("file:///home/armin/Dokumente") will be expanded.
Loaded plugin "/usr/lib/qt/plugins/k3b/k3boggvorbisdecoder.so"
Loaded plugin "/usr/lib/qt/plugins/k3b/k3bwavedecoder.so"
Loaded plugin "/usr/lib/qt/plugins/k3b/k3bmpcdecoder.so"
Loaded plugin "/usr/lib/qt/plugins/k3b/k3bmaddecoder.so"
Loaded plugin "/usr/lib/qt/plugins/k3b/k3baudiometainforenamerplugin.so"
Loaded plugin "/usr/lib/qt/plugins/k3b/k3baudioprojectcddbplugin.so"
Loaded plugin "/usr/lib/qt/plugins/k3b/k3bflacdecoder.so"
Loaded plugin "/usr/lib/qt/plugins/k3b/k3bffmpegdecoder.so"
Loaded plugin "/usr/lib/qt/plugins/k3b/k3blibsndfiledecoder.so"
Loaded plugin "/usr/lib/qt/plugins/k3b/k3blameencoder.so"
Loaded plugin "/usr/lib/qt/plugins/k3b/k3bsoxencoder.so"
Loaded plugin "/usr/lib/qt/plugins/k3b/k3boggvorbisencoder.so"
Loaded plugin "/usr/lib/qt/plugins/k3b/k3bexternalencoder.so"
K3bQProcess::QProcess(0x0)
(K3b::Device::Device) "/dev/sr0" : init()
(K3b::Device::Device) "/dev/sr0" feature: CD Mastering
(K3b::Device::Device) "/dev/sr0" feature: CD Track At Once
(K3b::Device::Device) "/dev/sr0" feature: CD-RW Media Write Support
(K3b::Device::Device) "/dev/sr0" feature: DVD Read (MMC5)
(K3b::Device::Device) "/dev/sr0" feature: DVD+R
(K3b::Device::Device) "/dev/sr0" feature: DVD+RW
(K3b::Device::Device) "/dev/sr0" feature: DVD+R Double Layer
(K3b::Device::Device) "/dev/sr0" feature: BD Read
(K3b::Device::Device) "/dev/sr0" feature: BD Write
(K3b::Device::Device) "/dev/sr0" feature: DVD-R/-RW Write
(K3b::Device::Device) "/dev/sr0" feature: Rigid Restricted Overwrite
(K3b::Device::Device) "/dev/sr0" feature: Layer Jump Recording
(K3b::Device::Device) "/dev/sr0" unknown profile: 2
(K3b::Device::Device) "/dev/sr0" : buffer.size(): 60
(K3b::Device::Device) "/dev/sr0" : checking for TAO
(K3b::Device::Device) "/dev/sr0" : checking for SAO
(K3b::Device::Device) "/dev/sr0" : checking for SAO_R96P
(K3b::Device::Device) "/dev/sr0" : checking for SAO_R96R
(K3b::Device::Device) "/dev/sr0" : checking for RAW_R16
(K3b::Device::Device) "/dev/sr0" : checking for RAW_R96P
(K3b::Device::Device) "/dev/sr0" : checking for RAW_R96R
(K3b::Device::Device) "/dev/sr0" : Number of supported write speeds via GET PERFORMANCE: 1
(K3b::Device::Device) "/dev/sr0" : 6400 KB/s
(K3b::Device::DeviceManager) setting current write speed of device "/dev/sr0" to 6400
(K3b::Device::DeviceManager) found config entry for devicetype: "HL-DT-ST BD-RE BH16NS55"
no medium found
Devices:
Blockdevice: "/dev/sr0"
Vendor: "HL-DT-ST"
Description: "BD-RE BH16NS55"
Version: "1.02"
Write speed: 6400
Profiles: "DVD-ROM, DVD-R sequenziell, Zweischichtige DVD-R sequenziell, Zweischicht-DVD-R-Sprung, DVD-RAM, DVD-RW Eingeschränktes Überschreiben, DVD-RW sequenziell, DVD+RW, DVD+R, Zweischichtige DVD+R, CD-ROM, CD-R, CD-RW, BD-CD-ROM, BD-R sequenziell (SRM), BD-R Zufällig (RRM), BD-CD-R"
Read Cap: "DVD-ROM, DVD-R, DVD-R sequenziell, Zweischichtige DVD-R, Zweischichtige DVD-R sequenziell, Zweischicht-DVD-R-Sprung, DVD-RW, DVD-RW Eingeschränktes Überschreiben, DVD-RW sequenziell, DVD+RW, DVD+R, Zweischichtige DVD+RW, Zweischichtige DVD+R, CD-ROM, CD-R, CD-RW, BD-CD-ROM, BD-CD-R, BD-R sequenziell (SRM), BD-R sequenziell Pseudo-Überschreiben (SRM+POW), BD-R Zufällig (RRM), BD-CD-R"
Write Cap: "DVD-R, DVD-R sequenziell, Zweischichtige DVD-R, Zweischichtige DVD-R sequenziell, Zweischicht-DVD-R-Sprung, DVD-RW, DVD-RW Eingeschränktes Überschreiben, DVD-RW sequenziell, DVD+RW, DVD+R, Zweischichtige DVD+R, CD-R, CD-RW, BD-CD-R, BD-R sequenziell (SRM), BD-R sequenziell Pseudo-Überschreiben (SRM+POW), BD-R Zufällig (RRM), BD-CD-R"
Writing modes: "SAO, TAO, RAW, SAO/R96P, SAO/R96R, RAW/R16, RAW/R96P, RAW/R96R, Eingeschränktes Überschreiben, Sprung zwischen DVD-Schichten, Zufällige Aufnahme, Sequenzielle Aufnahme, Sequenzielle Aufnahme + POW"
kernel version: "5.15.12-1-MANJARO"
(K3b::Core) System problems:
- none -
- none -
kf.kio.core: "Die Datei oder der Ordner /data existiert nicht."
Qt: Session management error: networkIdsList argument is NULL
Was mir auffällt:
Wenn ich im Terminal einen Tab öffne, dann startet zsh obwohl bash auf der Konsole läuft.
Was ein Fehler sein könnte: auf der BD-RE, die schreiben will, kann der Superblock nicht gelesen werden.
