Hi all
I am new here as I’ve recently switched from CentOS to Manjaro.
I switched because I’ve been using Material Shell for a couple of years but it is no longer supported on Gnome 40.
Switching to Manjaro seemed like a reasonable option for me as I’d never used it before but am absolutely loving it so far.
Today I did a sudo pacman -Syu and pulled down a load of updates. When it updated, I suddenly had issues with GUI apps. Chromium, Calibre, VLC etc were struggling. You can see the GUI but none of the buttons are active. Even Nautilus was struggling and I couldn’t navigate anywhere via the GUI.
I logged out and logged in on X as opposed to Wayland and it fixed the problem straight away.
Do we have a way of rolling back the update on Manjaro so I can revert to a previous state?
I’m happy to continue using X as opposed to Wayland but would like to know for my own sanity.
Any help appreciated
Ash
