While I booted to manjaro, the following text shows up, (but does not boot to manjaro.):
Local_Disk: clean, 323579/2031616 files, 3533243/8126208 blocks.
Guys, I need help.
Guys, I need help.
The info is not an error - it is just info the filesystem is clean.
Your display manager is not starting - this can be caused by graphic driver, display manager config or display manager theme.
Can you post /var/log/Xorg.0.log ?
[ 10.526] (--) Log file renamed from "/var/log/Xorg.pid-519.log" to "/var/log/Xorg.0.log"
[ 10.527]
X.Org X Server 1.21.1.3
[ 10.527] Current Operating System: Linux afzal-hppavilionnotebook 5.15.28-1-MANJARO #1 SMP PREEMPT Fri Mar 11 14:12:57 UTC 2022 x86_64
[ 10.527] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=9e8f416e-f402-4ae3-8d51-785e40d0f584 rw quiet apparmor=1 security=apparmor udev.log_priority=3
[ 10.527]
[ 10.527] Current version of pixman: 0.40.0
[ 10.527] Before reporting problems, check http://wiki.x.org
[ 10.527] Markers: (--) probed, (**) from config file, (==) default setting,
[ 10.527] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Mar 20 21:15:27 2022
[ 10.527] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 10.527] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 10.527] Parse error on line 1 of section InputClass in file /etc/X11/xorg.conf.d/50-synaptics.conf
"ection" is not a valid keyword in this section.
[ 10.527] (EE) Problem parsing the config file
[ 10.527] (EE) Error parsing the config file
[ 10.527] (EE)
Fatal server error:
[ 10.527] (EE) no screens found(EE)
[ 10.527] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 10.527] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 10.527] (EE)
[ 10.527] (EE) Server terminated with error (1). Closing log file.
How can I fix the display manager?
Do I need to chroot using manjaro live installer?
Check your config - you have - quite obviously - edited a configuration and made a spelling error.
You have not provided info on your environment - info that could be important - it could be the change in qt libraries which is causing it.
inxi -Fxxx
@linux-aarhus thanks.
This problem occurred after I installed synaptics driver using pacman.
Anyways, I went to the file:
And found that at the first line the mistake was “ection” which I corrected “section” by doing a
chroot using a live kde plasma manjaro installer.
Thank you so much!
(BTW, I did not edit the “/etc/X11/xorg.conf.d/50-synaptics.conf” file.)
I wonder when that file was created, and by which package, and how it contained a glaring typo? ![]()
Apparently, as of the latest database, the package xf86-input-synaptics version 1.9.1-3 provides the file:
/usr/share/X11/xorg.conf.d/70-synaptics.conf
But I can’t figure out what provides 50-synaptics.conf, let alone copies it to /etc/X11/xorg.conf.d/, let alone contains the typo.
The package is inherited from Arch - and the original conf is installed in /usr tree as 70-synaptics.conf.
The file with the spelling error can only exist if you created it.
