I installed Manjaro yesterday on my ROG laptop and I have not been able to get the sound to work, even trying to use the solutions I found on this forum. I can’t even diagnose the problem- it seems to me that the computer is able to detect the source of the sound, based on the fact that the audio volume screen is registering sound, but the speakers don’t play anything.
Now, I should point out that this machine started with Windows 11 on it, I’ve already installed Manjaro on another hard drive and removed the drive with Win11. I don’t know if that means anything, but I figure the question might be asked.
Here’s my inxi. I’ll try to answer any questions you might have.
Kernel: 6.6.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
root=UUID=03ca5d33-7b48-4a8a-ac38-78c7a4db0c1c rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_wayland vt: 1
Type: Laptop System: ASUSTeK product: ROG Strix G614JV_G614JV v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: G614JV v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: G614JV.321 date: 10/24/2023
ID-1: BAT0 charge: 89.3 Wh (100.0%) condition: 89.3/90.0 Wh (99.2%)
volts: 17.5 min: 16.0 model: AS3GYFG3KC R220358 type: Unknown
serial: <filter> status: full
Info: model: 13th Gen Intel Core i9-13980HX bits: 64 type: MST AMCP
arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
process: Intel 7 (10nm) family: 6 model-id: 0xB7 (183) stepping: 1
microcode: 0x11D
Topology: cpus: 1x cores: 24 mt: 8 tpc: 2 st: 16 threads: 32 smt: enabled
cache: L1: 2.1 MiB desc: d-16x32 KiB, 8x48 KiB; i-8x32 KiB, 16x64 KiB
L2: 32 MiB desc: 8x2 MiB, 4x4 MiB L3: 36 MiB desc: 1x36 MiB
Speed (MHz): avg: 812 high: 958 min/max: 800/5400:5600:4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 958 2: 800 3: 893 4: 800
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 822 14: 800
15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 21: 800 22: 800 23: 927
24: 800 25: 800 26: 800 27: 800 28: 800 29: 800 30: 800 31: 800 32: 800
bogomips: 154880
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
RSB filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Raptor Lake-S UHD Graphics vendor: ASUSTeK driver: i915
v: kernel arch: Gen-13 process: Intel 7 (10nm) built: 2022+ ports:
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 0000:00:02.0
chip-ID: 8086:a788 class-ID: 0300
Device-2: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile] vendor: ASUSTeK
driver: nvidia v: 545.29.06 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2023-11) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ bus-ID: 0000:01:00.0 chip-ID: 10de:28e0
class-ID: 0300
Device-3: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:4 chip-ID: 322e:2122
class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3
compositor: kwin_wayland driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915,nvidia display-ID: 0
Monitor-1: eDP-1 res: 1536x960 size: N/A modes: N/A
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: nvidia wayland: drv: iris x11: drv: iris
inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 23.3.3-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-S)
device-ID: 8086:a788 memory: 30.24 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.274 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4060 Laptop GPU driver: nvidia v: 545.29.06
device-ID: 10de:28e0 surfaces: xcb,xlib,wayland
Device-1: Intel vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3 chip-ID: 8086:7a50
class-ID: 0403
Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 0000:01:00.1 chip-ID: 10de:22be class-ID: 0403
API: ALSA v: k6.6.10-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
Device-1: Intel driver: iwlwifi v: kernel port: N/A bus-ID: 0000:00:14.3
chip-ID: 8086:7a70 class-ID: 0280
vendor: ASUSTeK driver: r8169 v: kernel port: 4000 bus-ID: 0000:6c:00.0
IF: enp108s0 state: down mac: <filter>
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0033
class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:a77f rev:
class-ID: 0104
Local Storage: total: 4.64 TiB used: 10.39 GiB (0.2%)
model: WD BLACK SN850X 1000GB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 620361WD temp: 48.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 model: XG7000-4TB 2280 size: 3.73 TiB
block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4
tech: SSD serial: <filter> fw-rev: SN13683 temp: 38.9 C scheme: MBR
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%) used: 10.39 GiB (1.1%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 48.0 C mobo: N/A
Fan Speeds (rpm): cpu: 2000
Processes: 483 Uptime: 0m wakeups: 0 Memory: total: 32 GiB note: est.
available: 30.97 GiB used: 2.36 GiB (7.6%) Init: systemd v: 255
Packages: pm: pacman pkgs: 1178 libs: 343 tools: gnome-software,pamac
pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 default: Bash v: 5.2.21
running-in: konsole inxi: 3.3.31
Moderator edit: Removed useless screenshot.
In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
