Just recently installed Manjaro with proprietary nvidia drivers. if i run
nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
and
inxi -G
Graphics: Device-1: Intel 3rd Gen Core processor Graphics driver: i915 v: kernel
Device-2: NVIDIA GF108GLM [NVS 5200M] driver: N/A
Device-3: Microdia Dell Integrated HD Webcam type: USB driver: uvcvideo
Display: x11 server: X.Org 1.20.11 driver: loaded: intel resolution: 1600x900
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 21.1.5
last time i tried to install, i ended up in a tty screen and had to reinstall.
Hi @Tygalive , and welcome!
It would seem to me that that GPU is not supported by the latest, and thus default nvidia drivers. It requires a version from 304.135 to 390.132 .
So have a look at this: [Support/How-To] Compile old/legacy Nvidia Proprietary Drivers [2020-12-30 Update Issue]
Thank you, let me go through and update
Tried the linked instructions. on windows my system runs 390xx and also here on linux 390xx is preinstalled by mwhd but the instructions build 340xx
cd nvidia-340xx-utils && makepkg -si
loading packages...
resolving dependencies...
:: nvidia-340xx-utils and nvidia-390xx-utils are in conflict (nvidia-utils). Remove nvidia-390xx-utils? [y/N] y
:: removing nvidia-390xx-utils breaks dependency 'nvidia-390xx-utils' required by lib32-nvidia-390xx-utils
:: removing nvidia-390xx-utils breaks dependency 'nvidia-390xx-utils=390.144' required by linux510-nvidia-390xx
==> WARNING: Failed to install built package(s).
here it also says that it has failed to install the packages as they conflict with already existing 390xx drivers
Fabby
10 August 2021 09:29
5
Tygalive:
NVIDIA GF108GLM
I can’t find the GeForce 108 in neither the 340 series nor the 390 series driver in the “supported products” page although a lot of other Fermi-based adapters are supported by the 340 series:
GeForce 100M Series (Notebooks):
GeForce GTS 160M, GeForce GTS 150M, GeForce GT 130M, GeForce GT 120M, GeForce G 110M, GeForce G 105M, GeForce G 103M, GeForce G 102M
Can you provide a full inxi please?
Thank you for responding. actually from nvidia’s website Quadro Desktop/Quadro Notebook Driver Release 410 | R410 U2 (411.63) | Windows 10 64-bit | NVIDIA the driver would be 410.
Kernel: 5.10.56-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=4c91aac4-9ed1-4639-8f43-bd72b9c47e61 rw
resume=UUID=4c91aac4-9ed1-4639-8f43-bd72b9c47e61 resume_offset=151234560
quiet udev.log_priority=3
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: Latitude E6530 v: 01 serial: <filter>
Chassis: type: 9 serial: <filter>
Mobo: Dell model: 07Y85M v: A00 serial: <filter> BIOS: Dell v: A17
date: 08/19/2015
ID-1: BAT0 charge: 22.7 Wh (100.0%) condition: 22.7/99.9 Wh (22.7%)
volts: 12.5 min: 11.1 model: SMP DELL P6YD623 type: Li-ion serial: <filter>
status: Full
RAM: total: 15.54 GiB used: 5.19 GiB (33.4%)
Info: Dual Core model: Intel Core i7-3520M bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
cache: L2: 4 MiB bogomips: 23132
Speed: 1196 MHz min/max: 1200/3600 MHz Core speeds (MHz): 1: 1196 2: 1196
3: 1196 4: 1196
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida
lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat
pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic
xsave xsaveopt xtopology xtpr
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: Dell driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
alternate: nouveau, nvidia_drm, nvidia bus-ID: 01:00.0 chip-ID: 10de:0dfc
class-ID: 0300
bus-ID: 1-1.5:4 chip-ID: 0c45:643f class-ID: 0e02
loaded: intel display-ID: :0 screens: 1
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x237mm (16.7x9.3")
s-diag: 485mm (19.1")
Monitor-1: LVDS1 res: 1600x900 dpi: 120 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
v: 4.2 Mesa 21.1.6 compat-v: 3.0 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
Device-2: NVIDIA GF108 High Definition Audio driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:0bea class-ID: 0403
Sound Server-1: ALSA v: k5.10.56-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: yes
Device-1: Intel 82579LM Gigabit Network vendor: Dell driver: e1000e
v: kernel port: f080 bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
Device-2: Broadcom BCM43228 802.11a/b/g/n vendor: Dell driver: wl v: kernel
modules: bcma port: f040 bus-ID: 03:00.0 chip-ID: 14e4:4359 class-ID: 0280
Device-3: Dell DW5560 miniPCIe HSPA+ Mobile Broadband Modem type: USB
driver: cdc_acm,cdc_mbim,cdc_wdm bus-ID: 2-1.6:8 chip-ID: 413c:818e
class-ID: 0202 serial: <filter>
IF: wwp0s29u1u6i6 state: down mac: <filter>
Device-1: Dell BCM20702A0 Bluetooth Module type: USB driver: btusb v: 0.8
bus-ID: 1-1.4:3 chip-ID: 413c:8197 class-ID: fe01 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 7 state: up address: see --recommends
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: f060 bus-ID: 00:1f.2 chip-ID: 8086.282a rev: 04 class-ID: 0104
Local Storage: total: 1.2 TiB used: 1.01 TiB (84.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM048-2E7172
type: HDD rpm: 5400 serial: <filter> rev: 0001 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD3200BEVT-75A23T0 size: 298.09 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 1A01 scheme: MBR
ID-1: / raw-size: 931.51 GiB size: 929.79 GiB (99.82%)
used: 782.97 GiB (84.2%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 4c91aac4-9ed1-4639-8f43-bd72b9c47e61
ID-2: /run/media/richard/353035b8-2494-4459-bbba-a5ef76cde84d
raw-size: 298.09 GiB size: 297.95 GiB (99.95%) used: 252.7 GiB (84.8%)
fs: xfs dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: 353035b8-2494-4459-bbba-a5ef76cde84d
ID-1: swap-1 type: file size: 40 GiB used: 1.7 MiB (0.0%) priority: -2
file: /swapfile
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.4:3 info: Dell BCM20702A0 Bluetooth Module type: Bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 413c:8197
Device-2: 1-1.5:4 info: Microdia Dell Integrated HD Webcam type: Video
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.6:8 info: Dell DW5560 miniPCIe HSPA+ Mobile Broadband Modem
type: Communication,Abstract (modem),CDC-Data
driver: cdc_acm,cdc_mbim,cdc_wdm interfaces: 11 rev: 2.0 speed: 480 Mb/s
chip-ID: 413c:818e class-ID: 0202 serial: <filter>
Device-2: 2-1.8:4 info: Broadcom BCM5880 Secure Applications Processor with
fingerprint swipe sensor
type: Smart Card driver: N/A interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 0a5c:5801 class-ID: 0b00 serial: <filter>
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-2:2 info: Microdia USB Device type: Keyboard,Mouse
power: 100mA chip-ID: 0c45:0820 class-ID: 0301
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 53.0 C mobo: 39.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 2771
Processes: 279 Uptime: 18h 48m wakeups: 7 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1504 lib: 378
Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.06
Thank you for the assistance. will update once done.
omano
10 August 2021 12:43
9
That’s the thing, the 340 driver build instructions are not for a hybrid setup as far as I know.
Fabby
10 August 2021 13:29
10
I found this:
Thank you @Fabby
Thank you @omano
Installed bumblebee.
system
Closed
17 August 2021 07:26
12
