Can anyone tell me what these errors mean, please?
s
Mar 09 23:44:32 manjaro kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Mar 09 23:44:32 manjaro kernel: mtrr: your CPUs had inconsistent variable MTRR settings
Mar 09 23:44:32 manjaro kernel: mtrr: probably your BIOS does not setup all CPUs.
Mar 09 23:44:32 manjaro kernel: mtrr: corrected configuration.
Mar 09 23:44:32 manjaro kernel: HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
Mar 09 23:44:32 manjaro kernel: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
Mar 09 23:44:32 manjaro kernel: ACPI: Added _OSI(Module Device)
Mar 09 23:44:32 manjaro kernel: ACPI: Added _OSI(Processor Device)
Mar 09 23:44:32 manjaro kernel: ACPI: Added _OSI(3.0 _SCP Extensions)
Mar 09 23:44:32 manjaro kernel: ACPI: Added _OSI(Processor Aggregator Device)
Mar 09 23:44:32 manjaro kernel: ACPI: Added _OSI(Linux-Dell-Video)
Mar 09 23:44:32 manjaro kernel: ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
Mar 09 23:44:32 manjaro kernel: ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.GPLD], AE_ALREADY_EXIS>
Mar 09 23:44:32 manjaro kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
Mar 09 23:44:32 manjaro kernel: ACPI: Skipping parse of AML opcode: Method (0x0014)
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.TPLD], AE_ALREADY_EXIS>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.GUPC], AE_ALREADY_EXIS>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.TUPC], AE_ALREADY_EXIS>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS01._UPC], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS01._PLD], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS02._UPC], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS02._PLD], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS03._UPC], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS03._PLD], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS04._UPC], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS04._PLD], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS05._UPC], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS05._PLD], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS06._UPC], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS06._PLD], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS07._UPC], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS07._PLD], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS08._UPC], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS08._PLD], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS09._UPC], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS09._PLD], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS10._UPC], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS10._PLD], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS11._UPC], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS11._PLD], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS12._UPC], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS12._PLD], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS13._UPC], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS13._PLD], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS14._UPC], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS14._PLD], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR1._UPC], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR1._PLD], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
Mar 09 23:44:32 manjaro kernel: DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
Mar 09 23:44:32 manjaro kernel: DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
Mar 09 23:44:32 manjaro kernel: audit: initializing netlink subsys (disabled)
Mar 09 23:44:32 manjaro kernel: audit: type=2000 audit(1615358670.016:1): state=initialized audit_enabled=0 res=1
Mar 09 23:44:32 manjaro kernel: thermal_sys: Registered thermal governor 'fair_share'
Mar 09 23:44:32 manjaro kernel: thermal_sys: Registered thermal governor 'bang_bang'
Mar 09 23:44:32 manjaro kernel: thermal_sys: Registered thermal governor 'step_wise'
Mar 09 23:44:32 manjaro kernel: thermal_sys: Registered thermal governor 'user_space'
Mar 09 23:44:32 manjaro kernel: thermal_sys: Registered thermal governor 'power_allocator'
Mar 09 23:44:32 manjaro kernel: cpuidle: using governor ladder
Mar 09 23:44:32 manjaro kernel: cpuidle: using governor menu
Mar 09 23:44:32 manjaro kernel: ACPI: bus type PCI registered
Mar 09 23:44:32 manjaro kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
Mar 09 23:44:32 manjaro kernel: PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
Mar 09 23:44:32 manjaro kernel: PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
Mar 09 23:44:32 manjaro kernel: PCI: Using configuration type 1 for base access
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR2._UPC], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR2._PLD], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS01._UPC], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS01._PLD], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS02._UPC], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS02._PLD], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS03._UPC], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS03._PLD], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS04._UPC], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS04._PLD], AE_ALREADY>
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS05._UPC], AE_ALREADY_EXISTS (20200717/dswload2-326)
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS05._PLD], AE_ALREADY_EXISTS (20200717/dswload2-326)
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS06._UPC], AE_ALREADY_EXISTS (20200717/dswload2-326)
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS06._PLD], AE_ALREADY_EXISTS (20200717/dswload2-326)
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS07._UPC], AE_ALREADY_EXISTS (20200717/dswload2-326)
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS07._PLD], AE_ALREADY_EXISTS (20200717/dswload2-326)
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS08._UPC], AE_ALREADY_EXISTS (20200717/dswload2-326)
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS08._PLD], AE_ALREADY_EXISTS (20200717/dswload2-326)
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS09._UPC], AE_ALREADY_EXISTS (20200717/dswload2-326)
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS09._PLD], AE_ALREADY_EXISTS (20200717/dswload2-326)
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS10._UPC], AE_ALREADY_EXISTS (20200717/dswload2-326)
Mar 09 23:44:32 manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS10._PLD], AE_ALREADY_EXISTS (20200717/dswload2-326)
Even a point in the right direction would help.
Thank you.
