Why do you think so?
because the version that the package is built from is based on an old code version that does not work with the latest python release.
FYI, python is only an optional dependency for some scripts.
like bitcoin2john, which is the one that does not work anymore.
However, python-bsddb is not listed as optional dependency in those packages.
What tools? What doesn’t work?
as I said in my first message: bitcoin2john. it complains about a missing bsddb import:
$ bitcoin2john
/usr/bin/bitcoin2john:564: SyntaxWarning: "is not" with a literal. Did you mean "!="?
if len(txid) is not 64:
File "/usr/bin/bitcoin2john", line 34, in <module>
from bsddb.db import *
ModuleNotFoundError: No module named 'bsddb'
During handling of the above exception, another exception occurred:
File "/usr/bin/bitcoin2john", line 36, in <module>
from bsddb3.db import *
ModuleNotFoundError: No module named 'bsddb3'
but even after pacman -S python-bsddb it still does not work:
$ bitcoin2john
File "/usr/bin/bitcoin2john", line 823, in <module>
print >> sys.stderr, "Usage: %s [Bitcoin/Litecoin/PRiVCY wallet (.dat) files]" % sys.argv[0]
TypeError: unsupported operand type(s) for >>: 'builtin_function_or_method' and '_io.TextIOWrapper'. Did you mean "print(<message>, file=<output_stream>)"?
So does the john package in the extra repo.
I didn’t know/check. But the version from the aur, after being built, works correctly.
Why does it depend on it? Did you receive an error message? We should not have to play 20 Questions with you.
Yes, as I said in my first message. However, since I had already fixed it, I had lost the error messages and thought it was enough to explain what the issue was and how I fixed it.
Now I have re-installed the package from extra and reproduced the error, and reported the exact strings is this message.
Please provide enough information to help us help you.
I just honestly thought I did.
I also thought: "hey, it’s immediate to just run bitcoin2john <RETURN> and see what the error is…
