Kernel: 5.10.93-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: Latitude E7440 v: 00
serial: <superuser required> Chassis: type: 9 serial: <superuser required>
Mobo: Dell model: 06MFX3 v: A01 serial: <superuser required> UEFI: Dell
v: A28 date: 06/13/2019
ID-1: BAT0 charge: 33.0 Wh (85.1%) condition: 38.8/47.7 Wh (81.5%)
volts: 8.4 min: 7.4 model: SMP DELL 909H538 type: Li-ion serial: <filter>
status: N/A
RAM: total: 7.68 GiB used: 3.52 GiB (45.8%)
RAM Report:
Info: dual core model: Intel Core i5-4310U bits: 64 type: MT MCP
smt: enabled arch: Haswell rev: 1 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 1830 high: 2594 min/max: 800/3000 cores: 1: 956 2: 1371
3: 2400 4: 2594 bogomips: 20760
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sdbg sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xsave xsaveopt xtopology xtpr
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Dell driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0a16 class-ID: 0300
Device-2: Microdia Integrated Webcam type: USB driver: uvcvideo
bus-ID: 2-4:3 chip-ID: 0c45:64d2 class-ID: 0e02
Display: x11 server: X.org 1.21.1.3 compositor: kwin_x11 driver:
loaded: modesetting alternate: fbdev,vesa resolution: <missing: xdpyinfo>
Device-1: Intel Haswell-ULT HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
Device-2: Intel 8 Series HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
Sound Server-1: ALSA v: k5.10.93-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.43 running: yes
Device-1: Intel Ethernet I218-LM vendor: Dell driver: e1000e v: kernel
port: f080 bus-ID: 00:19.0 chip-ID: 8086:155a class-ID: 0200
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel bus-ID: 02:00.0
chip-ID: 8086:08b1 class-ID: 0280
bus-ID: 1-1.3:3 chip-ID: 8087:07dc class-ID: e001
Report: rfkill ID: hci0 rfk-id: 7 state: up address: see --recommends
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: f060 bus-ID: 00:1f.2 chip-ID: 8086:282a rev: N/A
class-ID: 0104
Local Storage: total: 1.14 TiB used: 0 KiB (0.0%)
ID-1: /dev/sda vendor: Crucial model: CT240BX500SSD1 size: 223.57 GiB
speed: 6.0 Gb/s type: SSD serial: <filter> rev: R013 scheme: GPT
ID-2: /dev/sdb type: USB model: External USB3.0 size: 931.51 GiB
type: N/A serial: <filter> rev: 0204 scheme: GPT
ID-3: /dev/sdc type: USB vendor: SanDisk model: Cruzer Force
size: 14.56 GiB type: N/A serial: <filter> rev: 1.27 scheme: MBR
Message: No partition data found.
ID-1: /dev/dm-0 mapped: ventoy size: 2.99 GiB fs: iso9660
ID-2: /dev/sda1 size: 300 MiB fs: vfat label: NO_LABEL uuid: 8194-3FAC
ID-3: /dev/sda2 size: 16 MiB fs: <superuser required> label: N/A
uuid: N/A
ID-4: /dev/sda3 size: 96.31 GiB fs: ntfs label: N/A
uuid: 7E5EB08C5EB03F29
ID-5: /dev/sda4 size: 126.95 GiB fs: ext4 label: N/A
uuid: 5bd7050e-f736-4eee-8c37-a1bdfb9a6f81
ID-6: /dev/sdb1 size: 839.84 GiB fs: ntfs label: Data
uuid: A666699466696651
ID-7: /dev/sdb2 size: 91.67 GiB fs: ext4 label: timeshift
uuid: ef797067-6d9b-42b0-8957-049f399b1e02
ID-8: /dev/sdc1 size: 14.53 GiB fs: vfat label: ventoy uuid: C340-1231
ID-9: /dev/sdc2 size: 32 MiB fs: vfat label: VTOYEFI uuid: 7506-0A74
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
Device-1: 1-1.3:3 info: Intel Bluetooth wireless interface
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:07dc class-ID: e001
Hub-3: 2-0:1 info: Hi-speed hub with single TT ports: 9 rev: 2.0
Device-1: 2-2:2 info: SanDisk Cruzer Force type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA
chip-ID: 0781:557d class-ID: 0806 serial: <filter>
Device-2: 2-4:3 info: Microdia Integrated Webcam type: Video
Hub-4: 3-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
Device-1: 3-3:2 info: JMicron / JMicron USA JMS578 SATA 6Gb/s
type: Mass Storage driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 896mA chip-ID: 152d:0578 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 56.0 C mobo: 39.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 3713
Processes: 200 Uptime: 2h 51m wakeups: 3 Init: systemd v: 250 Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1103 Shell: Zsh v: 5.8
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.12
I am using kde plasma wayland, When I connect my high refresh rate external display all the animations appear jittery, everything which moves appears to be vibrating. The display is detected as 120hz. All this issue disappears when i set the external display as 60 hz from 120hz, and then again to 120hz. I tried endeavouros also and no issue there.
