I’m trying to start jenkins (I want to learn the tool), installed it with yay -S jenkins
and enabled it with sudo systemctl enable jenkins
. When I look at it with status, everything is alright, but when I start the service, this is what is whows me:
× jenkins.service - Extendable continuous integration server
Loaded: loaded (/usr/lib/systemd/system/jenkins.service; enabled; preset: disabled)
Active: failed (Result: exit-code) since Sun 2023-04-30 13:08:18 CEST; 1s ago
Duration: 13ms
Process: 4321 ExecStart=/bin/sh -c eval $JENKINS_COMMAND_LINE (code=exited, status=127)
Main PID: 4321 (code=exited, status=127)
CPU: 7ms
...data... systemd[1]: Starting Extendable continuous integration server...
...data... systemd[1]: Started Extendable continuous integration server.
...data... jenkins[4324]: /bin/sh: line 1: /usr/lib/jvm/java-11-openjdk/jre/bin/java: File or directory doesn't exist
...data... systemd[1]: jenkins.service: Main process exited, code=exited, status=127/n/a
...data... systemd[1]: jenkins.service: Failed with result 'exit-code'.
I removed some personal data from that snippet. I’ll show you that java-11 is installed:
with pamac list -i | grep java
haskell-language-javascript 0.7.1.0-136 community 7,8 MB
java-environment-common 3-5 extra
java-runtime-common 3-5 extra 5,4 kB
with pamac list -i | grep jr
jre-openjdk 19.0.2.u7-2 extra 505,7 kB
jre-openjdk-headless 19.0.2.u7-2 extra 190,4 MB
jre11-openjdk 11.0.18.u10-2 extra 546,9 kB
jre11-openjdk-headless 11.0.18.u10-2 extra 167,5 MB
jre17-openjdk 17.0.6.u10-2 extra 505,7 kB
jre17-openjdk-headless 17.0.6.u10-2 extra 179,5 MB
jre8-openjdk 8.362.u09-1 extra 417,2 kB
jre8-openjdk-headless 8.362.u09-1 extra 104,1 MB
so… what’s failing? thanks for the help!
I also have a running docker container with jenkins in it, would love to understand how it interacts with my system, I believe having jenkins first in my system and then using it as a container will help me (I’m using the oficial jenkins docs)
