Hi,
Has anyone been able to install Jellyfin on Raspberry Pi 4 ?
The package is available in AUR but installation fails as some dependencies (dot net) are not available.
Thanks.
I know @Strit runs it in a docker image. Have you tried to build dot net?
https://github.com/archlinux/svntogit-community/tree/packages/dotnet-core/trunk
Will give it a shot.
I am not that much tech savvy
Small time troubleshooting I can do, anyways will give it a shot.
Remember to add ‘aarch64’ to arch= in the pkgbuild.
In aur there are bin packages, with them you don’t need to install the dotnet dependencies. The only problem the packages are on RC version.
Just look for jellyfin-server-bin and jellyfin-web-bin
