jDownloader2 doesn't start
Can’t get jDownloader to start: AUR (en) - jdownloader2
On the AUR page is also a tip for troubleshooting:
If anyone has the following issue: archlinux-java set a lower version of Java, start jdownloader, upgrade in the program, set Java version back to latest
But how would I do that on manjaro?
Thanks.
Error Message from console
jdownloader
[user JDownloader scope]
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by org.appwork.utils.ReflectionUtils (file:/home/myusername/.jd/JDownloader.jar) to field java.io.PrintStream.charOut
WARNING: Please consider reporting this to the maintainers of org.appwork.utils.ReflectionUtils
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
INFO >> CFG File does not exist: /home/myusername/.jd/cfg/org.appwork.utils.logging2.LogConfig.json
THREAD: 1
1|Log.L.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.builddecision.BuildDecisions(status) ] -> ClassPath: JDownloader.jar
1|Log.L.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.builddecision.BuildDecisions(status) ] ->            Manifest-Version: 1.0
1|Log.L.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.builddecision.BuildDecisions(status) ] ->            Ant-Version: Apache Ant 1.10.5
1|Log.L.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.builddecision.BuildDecisions(status) ] ->            Created-By: Appwork GmbH and JDownloader Community
1|Log.L.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.builddecision.BuildDecisions(status) ] ->            Main-Class: org.jdownloader.update.launcher.JDLauncher
1|Log.L.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.builddecision.BuildDecisions(status) ] ->            Add-Exports: java.desktop/sun.swing java.desktop/sun.swing.table java.desktop/sun.swing.plaf.synth java.desktop/com.sun.java.swing.plaf.windows java.desktop/sun.awt.shell java.desktop/com.sun.awt java.base/sun.security.action
1|Log.L.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.builddecision.BuildDecisions(status) ] ->            Add-Opens: java.desktop/javax.swing.plaf.synth java.desktop/javax.swing.plaf.basic java.desktop/javax.swing java.desktop/javax.swing.tree java.desktop/java.awt.event
1|Log.L.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.loggingv3.LogV3(info) ] -> Application Root: /home/myusername/.jd
SystemEntropyWorkaround:false
Multiple LogControllers Detected: org.appwork.utils.logging2.extmanager.LoggerFactory|Mode:NORMAL
Multiple LogControllers Detected: org.jdownloader.logging.LogController|org.jdownloader.logging.LogController@61dd025
1|Log.L.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.storage.JsonKeyValueStorage(<init>) ] -> CFG File does not exist: /home/myusername/.jd/cfg/org.jdownloader.update.lastchance.LastChanceConfig.json
THREAD: 1
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: awt.toolkit: sun.awt.X11.XToolkit
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.specification.version: 11
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: sun.cpu.isalist:
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: classloader_00000001: org.jdownloader.update.launcher.CL2
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: sun.jnu.encoding: UTF-8
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: classloader_00000000: org.jdownloader.update.launcher.ClassLoaderExtensionImpl
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: extlogmanager.avoidsystemclassloader.hack: org.jdownloader.updatev2.JDClassLoaderLauncher$JDCustomRootClassLoader@2ff4f00f
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.class.path: JDownloader.jar
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.vm.vendor: Arch Linux
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: sun.arch.data.model: 64
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.util.Arrays.useLegacyMergeSort: true
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.vendor.url: https://openjdk.java.net/
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: user.timezone: Europe/Berlin
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: os.name: Linux
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.vm.specification.version: 11
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: sun.java.launcher: SUN_STANDARD
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: user.country: US
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.net.preferIPv6Addresses: system
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: sun.boot.library.path: /usr/lib/jvm/java-11-openjdk/lib
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: sun.java.command: JDownloader.jar
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.rmi.server.useCodebaseOnly: true
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: jdk.debug: release
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: sun.cpu.endian: little
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: user.home: /home/myusername
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: user.language: en
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: LOG_INIT_DONE: 2 instances
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.specification.vendor: Oracle Corporation
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.version.date: 2025-04-15
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.home: /usr/lib/jvm/java-11-openjdk
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: file.separator: /
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.vm.compressedOopsMode: Zero based
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: line.separator:
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.specification.name: Java Platform API Specification
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.vm.specification.vendor: Oracle Corporation
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.awt.graphicsenv: sun.awt.X11GraphicsEnvironment
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: org.appwork.LoggerFactory: org.appwork.utils.logging2.LogSourceRedirector
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: sun.management.compiler: HotSpot 64-Bit Tiered Compilers
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: com.sun.jndi.rmi.object.trustURLCodebase: false
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.runtime.version: 11.0.27+6
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: user.name: myusername
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: path.separator: :
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: com.sun.jndi.cosnaming.object.trustURLCodebase: false
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: os.version: 6.15.3-1-MANJARO
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.runtime.name: OpenJDK Runtime Environment
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: file.encoding: UTF-8
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.vm.name: OpenJDK 64-Bit Server VM
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.vendor.url.bug: https://bugreport.java.com/bugreport/
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.io.tmpdir: /tmp
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.version: 11.0.27
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: user.dir: /home/myusername/.jd
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: os.arch: amd64
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.vm.specification.name: Java Virtual Machine Specification
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.awt.printerjob: sun.print.PSPrinterJob
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: k: 0dd0ecf7f742873d745106adea00b64a
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: sun.os.patch.level: unknown
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.util.logging.manager: org.appwork.utils.logging2.extmanager.ExtLogManager
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.library.path: /usr/java/packages/lib:/usr/lib64:/lib64:/lib:/usr/lib
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.vm.info: mixed mode
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.vendor: Arch Linux
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.vm.version: 11.0.27+6
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.specification.maintenance.version: 3
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: com.sun.jndi.ldap.object.trustURLCodebase: false
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: sun.io.unicode.encoding: UnicodeLittle
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.class.version: 55.0
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: PATH: /home/myusername/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/bin:/usr/lib/jvm/default/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl:/var/lib/snapd/snap/bin
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: LC_MEASUREMENT: de_DE.UTF-8
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: INVOCATION_ID: 30e78f18f67b4530b9c5816acfc3de48
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: XAUTHORITY: /run/user/1000/xauth_pKbzxh
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: LC_TELEPHONE: de_DE.UTF-8
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: CSF_StandardLiteDefaults: /usr/share/opencascade/resources/StdResource
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: XDG_DATA_DIRS: /home/myusername/.local/share/flatpak/exports/share:/var/lib/flatpak/exports/share:/usr/local/share:/usr/share:/var/lib/snapd/desktop
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: LC_TIME: de_DE.UTF-8
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: MOTD_SHOWN: pam
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: DBUS_SESSION_BUS_ADDRESS: unix:path=/run/user/1000/bus
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: XDG_CURRENT_DESKTOP: KDE
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: JOURNAL_STREAM: 9:23252
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: QT_AUTO_SCREEN_SCALE_FACTOR: 0
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: MAIL: /var/spool/mail/myusername
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: MOZ_PLUGIN_PATH: /usr/lib/mozilla/plugins
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: CSF_XCAFDefaults: /usr/share/opencascade/resources/StdResource
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: COLORTERM: truecolor
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: CSF_TObjDefaults: /usr/share/opencascade/resources/StdResource
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: LC_PAPER: de_DE.UTF-8
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: SESSION_MANAGER: local/host:@/tmp/.ICE-unix/1941,unix/host:/tmp/.ICE-unix/1941
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: LOGNAME: myusername
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: KONSOLE_DBUS_SERVICE: :1.50
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: PAM_KWALLET5_LOGIN: /run/user/1000/kwallet5.socket
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: CSF_SHMessage: /usr/share/opencascade/resources/SHMessage
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: MANAGERPID: 1719
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: PROFILEHOME:
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: PWD: /home/myusername/.jd
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: CSF_STEPDefaults: /usr/share/opencascade/resources/XSTEPResource
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: LANGUAGE:
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: WINDOWID: 94495391468048
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: KDE_SESSION_VERSION: 6
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: XKB_DEFAULT_MODEL: pc105
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: SHELL: /bin/bash
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: LC_ADDRESS: de_DE.UTF-8
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: KONSOLE_DBUS_SESSION: /Sessions/1
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: OLDPWD: /home/myusername/.jd
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: KDE_FULL_SESSION: true
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: CSF_XmlOcafResource: /usr/share/opencascade/resources/XmlOcafResource
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: XDG_SESSION_PATH: /org/freedesktop/DisplayManager/Session1
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: DEBUGINFOD_URLS: https://debuginfod.archlinux.org
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: CSF_MIGRATION_TYPES: /usr/share/opencascade/resources/StdResource/MigrationSheet.txt
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: CSF_LANGUAGE: us
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: CSF_MDTVTexturesDirectory: /usr/share/opencascade/resources/Textures
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: CSF_XSMessage: /usr/share/opencascade/resources/XSMessage
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: COLORFGBG: 15;0
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: SYSTEMD_EXEC_PID: 2242
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> AUTO_WRAPPED>
SysEnv: LS_COLORS: rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=01;05;37;41:mi=01;05;37;41:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;31:*.gz=01;
31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.jpg=01;35:*.jpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.ti
f=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=
01;35:*.emf=01;35:*.axv=01;35:*.anx=01;35:*.ogv=01;35:*.ogx=01;35:*.pdf=00;32:*.ps=00;32:*.txt=00;32:*.patch=00;32:*.diff=00;32:*.log=00;32:*.tex=00;32:*.doc=00;32:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.axa=00;36:*.oga=00;36:*.spx=00;36:*.xspf=00;36
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: XDG_SESSION_DESKTOP: KDE
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: SHLVL: 1
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: LC_IDENTIFICATION: de_DE.UTF-8
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: KDE_APPLICATIONS_AS_SCOPE: 1
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: MEMORY_PRESSURE_WRITE: c29tZSAyMDAwMDAgMjAwMDAwMAA=
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: LC_MONETARY: de_DE.UTF-8
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: ICEAUTHORITY: /run/user/1000/iceauth_txLlII
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: DRAWHOME: /usr/share/opencascade/resources/DrawResources
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: CSF_TObjMessage: /usr/share/opencascade/resources/TObj
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: CSF_StandardDefaults: /usr/share/opencascade/resources/StdResource
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: CSF_EXCEPTION_PROMPT: 1
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: MEMORY_PRESSURE_WATCH: /sys/fs/cgroup/user.slice/user-1000.slice/user@1000.service/app.slice/app-org.kde.yakuake@autostart.service/memory.pressure
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: TERM: xterm-256color
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: KDE_SESSION_UID: 1000
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: XDG_CONFIG_DIRS: /home/myusername/.config/kdedefaults:/etc/xdg
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: XDG_SEAT_PATH: /org/freedesktop/DisplayManager/Seat0
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: LANG: en_US.UTF-8
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: XDG_SESSION_ID: 2
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: XDG_SESSION_TYPE: wayland
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: DISPLAY: :1
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: SHELL_SESSION_ID: 5579cead384a44179be9ba690f0f594f
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: DRAWDEFAULT: /usr/share/opencascade/resources/DrawResources/DrawDefault
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: WAYLAND_DISPLAY: wayland-0
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: KONSOLE_VERSION: 250402
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: GTK_RC_FILES: /etc/gtk/gtkrc:/home/myusername/.gtkrc:/home/myusername/.config/gtkrc
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: XKB_DEFAULT_LAYOUT: de
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: LC_NAME: de_DE.UTF-8
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: XDG_SESSION_CLASS: user
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: MMGT_CLEAR: 1
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: CSF_IGESDefaults: /usr/share/opencascade/resources/XSTEPResource
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: CSF_ShadersDirectory: /usr/share/opencascade/resources/Shaders
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: CSF_OCCTResourcePath: /usr/share/opencascade/resources
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: JD_SCOPE: user
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: DESKTOP_SESSION: plasmawayland
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: CSF_PluginDefaults: /usr/share/opencascade/resources/StdResource
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: USER: myusername
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: GTK2_RC_FILES: /etc/gtk-2.0/gtkrc:/home/myusername/.gtkrc-2.0:/home/myusername/.config/gtkrc-2.0
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: XDG_MENU_PREFIX: plasma-
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: LC_NUMERIC: de_DE.UTF-8
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: XDG_SEAT: seat0
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: CASROOT: /usr
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: QT_WAYLAND_RECONNECT: 1
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: XDG_RUNTIME_DIR: /run/user/1000
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: XDG_VTNR: 1
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: HOME: /home/myusername
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: CSF_DrawPluginDefaults: /usr/share/opencascade/resources/DrawResources
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> jar:file:/home/myusername/.jd/JDownloader.jar!/version.nfo:
${updateclient.revision}
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> ant-version: Apache Ant 1.10.5
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> add-opens: java.desktop/javax.swing.plaf.synth java.desktop/javax.swin
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> add-exports: java.desktop/sun.swing java.desktop/sun.swing.table java.
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> created-by: Appwork GmbH and JDownloader Community
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> manifest-version: 1.0
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> main-class: org.jdownloader.update.launcher.JDLauncher
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> /home/myusername/.jd/JDownloader.jar- lastModified: 6/26/25, 9:29:01 PM
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.jdownloader.update.launcher.SecondLevelLauncher(init) ] -> Args: []
1|org.jdownloader.updatev2.restart.LinuxRestarter.log 7/6/25, 5:55:52 PM - INFO [ org.jdownloader.updatev2.restart.Restarter(<init>) ] -> Create Restarter
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.jdownloader.update.launcher.SecondLevelLauncher(init) ] -> Restart Controller init done in 6
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.jdownloader.update.launcher.SecondLevelLauncher(init) ] -> Parse Arguments
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.jdownloader.update.launcher.SecondLevelLauncher(init) ] -> Parameter Parse done in 0
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.jdownloader.update.launcher.SecondLevelLauncher(init) ] -> Single Instance Controller
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.jdownloader.update.launcher.SecondLevelLauncher(init) ] -> Single Instance init done in 27
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.jdownloader.update.launcher.SecondLevelLauncher(init) ] -> Init UpdateManager
1|Log.L.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.storage.JsonKeyValueStorage(<init>) ] -> CFG File does not exist: /home/myusername/.jd/cfg/org.jdownloader.updatev2.UpdateSettings.json
1|Log.L.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.storage.JsonKeyValueStorage(<init>) ] -> Load JSon Storage from Classpath url: jar:file:/home/myusername/.jd/JDownloader.jar!/cfg/updateclient/Setup.json
1|Log.L.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.storage.JsonKeyValueStorage(<init>) ] -> CFG File does not exist: /home/myusername/.jd/cfg/updateclient/Setup.json
1|Log.L.log 7/6/25, 5:55:52 PM - FINER [ org.appwork.loggingv3.LogV3(finer) ] -> Init StorageHandler for Interface:org.appwork.updatesys.client.Setup|Path:/home/myusername/.jd/cfg/updateclient/Setup
1|org.jdownloader.update.UpdateManager.log 7/6/25, 5:55:52 PM - FINE [ org.jdownloader.update.UpdateManager(<init>) ] -> ClientSetup 11
THREAD: 30
30|Log.L.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.storage.JsonKeyValueStorage(<init>) ] -> CFG File does not exist: /home/myusername/.jd/cfg/org.jdownloader.settings.InternetConnectionSettings.json
30|Log.L.log 7/6/25, 5:55:52 PM - FINER [ org.appwork.loggingv3.LogV3(finer) ] -> Init StorageHandler for Interface:org.jdownloader.updatev2.InternetConnectionSettings|Path:/home/myusername/.jd/cfg/org.jdownloader.settings.InternetConnectionSettings
30|Log.L.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.storage.JsonKeyValueStorage(<init>) ] -> Load JSon Storage from Classpath url: jar:file:/home/myusername/.jd/JDownloader.jar!/cfg/updateclient/HttpSettings.json
30|Log.L.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.storage.JsonKeyValueStorage(<init>) ] -> CFG File does not exist: /home/myusername/.jd/cfg/updateclient/HttpSettings.json
30|Log.L.log 7/6/25, 5:55:52 PM - FINER [ org.appwork.loggingv3.LogV3(finer) ] -> Init StorageHandler for Interface:org.appwork.updatesys.client.defaultimpl.http.UpdateHttpClientOptions|Path:/home/myusername/.jd/cfg/updateclient/HttpSettings
30|Log.L.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.storage.JsonKeyValueStorage(<init>) ] -> CFG File does not exist: /home/myusername/.jd/cfg/ProxySelector.json
30|Log.L.log 7/6/25, 5:55:52 PM - FINER [ org.appwork.loggingv3.LogV3(finer) ] -> Init StorageHandler for Interface:org.appwork.updatesys.client.defaultimpl.http.ProxySelectorSettings|Path:/home/myusername/.jd/cfg/ProxySelector
THREAD: 30
30|org.jdownloader.update.UpdateManager.log 7/6/25, 5:55:52 PM - WARNING [ org.jdownloader.update.UpdateManager$1(getDefaultValue) ] -> Namspace not set!
30|Log.L.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.storage.JsonKeyValueStorage(<init>) ] -> CFG File does not exist: /home/myusername/.jd/update/versioninfo/JD/extensions.json
30|Log.L.log 7/6/25, 5:55:52 PM - FINER [ org.appwork.loggingv3.LogV3(finer) ] -> Init StorageHandler for Interface:org.appwork.updatesys.client.extensions.ExtensionsStorage|Path:/home/myusername/.jd/update/versioninfo/JD/extensions
30|org.jdownloader.update.UpdateManager.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.updatesys.client.extensions.ExtensionManager(init) ] -> Installed Extensions: []
30|org.jdownloader.update.UpdateManager.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.updatesys.client.extensions.ExtensionManager(init) ] -> Requested Extension Installations: []
30|org.jdownloader.update.UpdateManager.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.updatesys.client.extensions.ExtensionManager(init) ] -> Requested Extension Uninstalls: []
30|org.jdownloader.update.UpdateManager.log 7/6/25, 5:55:52 PM - INFO [ org.jdownloader.update.JDUpdateClient$JDExtensionManager(init) ] -> Installed Extensions: []
30|org.jdownloader.update.UpdateManager.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.updatesys.client.FileList(<init>) ] -> FileList at /home/myusername/.jd/update/versioninfo/JD/filelist.txt Size: 0
30|Log.L.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.storage.JsonKeyValueStorage(<init>) ] -> CFG File does not exist: /home/myusername/.jd/cfg/org.appwork.updatesys.client.tracker.TrackConfig.json
THREAD: 1
1|org.jdownloader.update.UpdateManager.log 7/6/25, 5:55:52 PM - FINE [ org.jdownloader.update.UpdateManager(<init>) ] -> Client 45
30|Log.L.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.storage.JsonKeyValueStorage(<init>) ] -> CFG File does not exist: /home/myusername/.jd/update/versioninfo/JDU/extensions.json
30|Log.L.log 7/6/25, 5:55:52 PM - FINER [ org.appwork.loggingv3.LogV3(finer) ] -> Init StorageHandler for Interface:org.appwork.updatesys.client.extensions.ExtensionsStorage|Path:/home/myusername/.jd/update/versioninfo/JDU/extensions
THREAD: 30
30|org.jdownloader.update.UpdateManager.log 7/6/25, 5:55:52 PM - INFO [ org.appwork.updatesys.client.FileList(<init>) ] -> FileList at /home/myusername/.jd/update/versioninfo/JDU/filelist.txt Size: 0
THREAD: 1
1|org.jdownloader.update.UpdateManager.log 7/6/25, 5:55:52 PM - FINE [ org.jdownloader.update.UpdateManager(<init>) ] -> selfUpdateClient 2
1|org.jdownloader.update.UpdateManager.log 7/6/25, 5:55:52 PM - FINE [ org.jdownloader.update.UpdateManager(<init>) ] -> LastChanceInit 0
1|org.jdownloader.update.UpdateManager.log 7/6/25, 5:55:52 PM - FINE [ org.jdownloader.update.UpdateManager(<init>) ] -> setUpdateOnExitFlag 0
1|org.jdownloader.update.UpdateManager.log 7/6/25, 5:55:52 PM - FINE [ org.jdownloader.update.UpdateManager(<init>) ] -> CreateGui 4
1|org.jdownloader.update.UpdateManager.log 7/6/25, 5:55:52 PM - FINE [ org.jdownloader.update.UpdateManager(<init>) ] -> DefaultHandler 1
1|org.jdownloader.update.UpdateManager.log 7/6/25, 5:55:52 PM - FINE [ org.jdownloader.update.UpdateManager(<init>) ] -> SetDefaultHandler 0
1|org.jdownloader.update.UpdateManager.log 7/6/25, 5:55:52 PM - FINE [ org.jdownloader.update.UpdateManager(<init>) ] -> ProxySelector 0
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 7/6/25, 5:55:52 PM - INFO [ org.jdownloader.update.launcher.SecondLevelLauncher(init) ] -> Update Manager init done in 81
1|org.jdownloader.update.UpdateManager.log 7/6/25, 5:55:52 PM - INFO [ org.jdownloader.update.UpdateManager(finish) ] -> Current State:
1|org.jdownloader.update.UpdateManager.log 7/6/25, 5:55:52 PM - INFO [ org.jdownloader.update.UpdateManager(finish) ] -> Do Not ask Flag: false
1|org.jdownloader.update.UpdateManager.log 7/6/25, 5:55:52 PM - INFO [ org.jdownloader.update.UpdateManager(finish) ] -> Settings: {
 "countdownforinstallupdatesonexitbubble"         : 10000,
 "autohideguiiftherearenoupdatesenabled"          : false,
 "proxydialogonnoconnectionenabled"               : true,
 "selftestwritetimeout"                           : 60000,
 "lastsuccessfulconnection"                       : 0,
 "updateinterval"                                 : 600000,
 "autohideguiifsilentupdateswereinstalledenabled" : false,
 "doaskmebeforeinstallinganupdateenabled"         : false,
 "build"                                          : "",
 "jardiffenabled"                                 : true,
 "updateguialwaysontop"                           : true,
 "installupdatesonexitenabled"                    : true,
 "doaskbeforedownloadinganupdate"                 : false,
 "installupdatessilentlyifpossibleenabled"        : true,
 "autoupdatecheckenabled"                         : true,
 "installupdatesonexitpanelvisible"               : true,
 "selftestpolltimeout"                            : 60000
1|org.jdownloader.update.UpdateManager.log 7/6/25, 5:55:52 PM - INFO [ org.jdownloader.update.UpdateManager(finish) ] -> Client Revision: -1
1|org.jdownloader.update.UpdateManager.log 7/6/25, 5:55:52 PM - INFO [ org.jdownloader.update.UpdateManager(finish) ] -> Client Revision incl. Pending Installpackages: -1
1|org.jdownloader.update.UpdateManager.log 7/6/25, 5:55:52 PM - INFO [ org.jdownloader.update.UpdateManager(finish) ] -> Updater Client Revision: -1
1|org.jdownloader.update.UpdateManager.log 7/6/25, 5:55:52 PM - INFO [ org.jdownloader.update.UpdateManager(finish) ] -> Updater Client Revision incl. Pending Installpackages: -1
1|org.jdownloader.update.UpdateManager.log 7/6/25, 5:55:52 PM - INFO [ org.jdownloader.update.UpdateManager(finish) ] -> AWF Packages pending: []
1|org.jdownloader.update.UpdateManager.log 7/6/25, 5:55:52 PM - INFO [ org.jdownloader.update.UpdateManager(finish) ] -> SelfUpdate pending: false ([])
java.lang.UnsatisfiedLinkError: Can't load library: /usr/lib/jvm/java-11-openjdk/lib/libawt_xawt.so
        at java.base/java.lang.ClassLoader.loadLibrary(Unknown Source)
        at java.base/java.lang.Runtime.load0(Unknown Source)
        at java.base/java.lang.System.load(Unknown Source)
        at java.base/java.lang.ClassLoader$NativeLibrary.load0(Native Method)
        at java.base/java.lang.ClassLoader$NativeLibrary.load(Unknown Source)
        at java.base/java.lang.ClassLoader$NativeLibrary.loadLibrary(Unknown Source)
        at java.base/java.lang.ClassLoader.loadLibrary0(Unknown Source)
        at java.base/java.lang.Runtime.loadLibrary0(Unknown Source)
        at java.base/java.lang.System.loadLibrary(Unknown Source)
        at java.desktop/java.awt.Toolkit$3.run(Unknown Source)
        at java.base/java.security.AccessController.doPrivileged(Native Method)
        at java.desktop/java.awt.Toolkit.loadLibraries(Unknown Source)
        at java.desktop/java.awt.Toolkit.<clinit>(Unknown Source)
        at java.desktop/java.awt.EventQueue.isDispatchThread(Unknown Source)
        at java.desktop/javax.swing.SwingUtilities.isEventDispatchThread(Unknown Source)
        at org.appwork.utils.swing.EDTHelper.start(EDTHelper.java:146)
        at org.appwork.utils.swing.EDTHelper.start(EDTHelper.java:130)
        at org.appwork.utils.swing.EDTRunner.<init>(EDTRunner.java:45)
        at org.jdownloader.update.UpdateManager$20.<init>(UpdateManager.java:1414)
        at org.jdownloader.update.UpdateManager.setGuiVisible(UpdateManager.java:1414)
        at org.jdownloader.update.UpdateManager.finish(UpdateManager.java:440)
        at org.jdownloader.update.launcher.SecondLevelLauncher.init(SecondLevelLauncher.java:411)
        at org.jdownloader.update.launcher.SecondLevelLauncher.runMain(SecondLevelLauncher.java:237)
        at org.jdownloader.update.launcher.JDLauncherViaClassLoader.main(JDLauncherViaClassLoader.java:13)
        at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
        at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
        at java.base/java.lang.reflect.Method.invoke(Unknown Source)
        at org.jdownloader.updatev2.JDClassLoaderLauncher.main(JDClassLoaderLauncher.java:136)
        at org.jdownloader.update.launcher.JDLauncher.main(JDLauncher.java:8)
THREAD: 1
1|Log.L.log 7/6/25, 5:55:52 PM - SEVERE [ Log.L.log ] -> Exception thrown at org.jdownloader.update.launcher.SecondLevelLauncher.runMain(SecondLevelLauncher.java:241):
1|Log.L.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.loggingv3.LogV3(info) ] -> Translation file missing:org/appwork/utils/locale/AWUTranslation.en.lngUse Annotation Dev fallback
1|Log.L.log 7/6/25, 5:55:53 PM - FINE [ org.appwork.utils.swing.dialog.ExceptionDialog(<init>) ] -> Dialog    [null][null]
flag:  100100010000
title: Exception occured
msg:
An unexpected error occured.
JDownloader will try to fix this. If this happens again, please contact our support.
1|Log.L.log 7/6/25, 5:55:53 PM - FINER [ org.appwork.loggingv3.LogV3(finer) ] -> Read Config(URL): jar:file:/home/myusername/.jd/JDownloader.jar!/cfg/updateclient/Setup.updateservers.json
UpdateClient Proxy Vole 5
1|org.jdownloader.update.UpdateManager.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.updatesys.client.defaultimpl.http.HttpClientImpl(info) ] -> GET https://update.jdownloader.org/jcgi/lastchance?app=JD&pkh=12f1848a883e733ed40fffff0dae2f35&jh=1826f313742a2f3febe5579352910d66&rev=-1&srev=-1&urev=-1&surev=-1 via [Direct]
1|org.jdownloader.update.UpdateManager.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.updatesys.client.defaultimpl.http.HttpClientImpl(internalDownloadWithProxy) ] -> Try Proxy: Direct
1|org.jdownloader.update.UpdateManager.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.updatesys.client.defaultimpl.http.HttpClientImpl(info) ] -> Download to /tmp/lastChanceSrc17518173530116570427206120181867lch Size before: 0 bytes
1|org.jdownloader.update.UpdateManager.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.updatesys.client.defaultimpl.http.HttpBackend(log) ] -> ----------------Request Information-------------
URL: https://update.jdownloader.org/jcgi/lastchance?app=JD&pkh=12f1848a883e733ed40fffff0dae2f35&jh=1826f313742a2f3febe5579352910d66&rev=-1&srev=-1&urev=-1&surev=-1
URL-Parameters:
   app   : JD (REPO_NAME)
   pkh   : 12f1848a883e733ed40fffff0dae2f35 (PUBLIC_KEY_HASH)
   jh    : 1826f313742a2f3febe5579352910d66
   rev   : -1 (REPO_REVISION)
   srev  : -1 (REPO_INSTALLED_REVISION) (REPO_SUPER_REVISION)
   urev  : -1 (UPDATER_REVISION)
   surev : -1 (UPDATER_SUPER_REVISION)
SSLCipher: JVM|Protocol:TLSv1.2|CipherSuite:TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256
ConnectIP: update.jdownloader.org/2a01:4f8:211:1e8d:0:0:0:2:443
Connection-Timeout: 20000ms
Read-Timeout: 60000ms
----------------Request-------------------------
GET /jcgi/lastchance?app=JD&pkh=12f1848a883e733ed40fffff0dae2f35&jh=1826f313742a2f3febe5579352910d66&rev=-1&srev=-1&urev=-1&surev=-1 HTTP/1.1
Host: update.jdownloader.org
Accept-Language: en_US
User-Agent: JDownloader/201707061810
Accept-Charset: ISO-8859-1,utf-8;q=0.7,*;q=0.3
Connection: Close
Cache-Control: no-cache, no-store
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
Pragma: no-cache
----------------Response Information------------
Connection-Time: 88ms
Request-Time: 28ms
----------------Response------------------------
HTTP/1.1 404 Not Found
Date: Sun, 06 Jul 2025 15:55:53 GMT
Content-Length: 0
Connection: close
Server: AppWork GmbH FcgiServer
JCGI: 1 (HTTP_HEADER_FCGI)
UPD_SRV: 1
Strict-Transport-Security: max-age=15638400
1|org.jdownloader.update.UpdateManager.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.updatesys.client.defaultimpl.http.HttpClientImpl(info) ] -> No Last Chance Found. Good!
1|org.jdownloader.update.UpdateManager.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.updatesys.client.defaultimpl.http.HttpClientImpl(checkTryNextProxyOrGiveUp) ] -> Check if we can leave
1|org.jdownloader.update.UpdateManager.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.updatesys.client.defaultimpl.http.HttpClientImpl(checkTryNextProxyOrGiveUp) ] -> Invalid Response Code: org.appwork.utils.net.BasicHTTP.InvalidResponseCode: Invalid ResponseCode: 404
1|org.jdownloader.update.UpdateManager.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.updatesys.client.defaultimpl.http.HttpClientImpl(throwServerExceptions) ] -> Handle BasicHTTPException org.appwork.utils.net.BasicHTTP.BasicHTTPException: org.appwork.utils.net.BasicHTTP.ReadIOException: org.appwork.utils.net.BasicHTTP.InvalidResponseCode: Invalid ResponseCode: 404
1|Log.L.log 7/6/25, 5:55:53 PM - SEVERE [ Log.L.log ] -> Exception thrown at org.appwork.loggingv3.LogV3.log(LogV3.java:102):
java.lang.NoClassDefFoundError: Could not initialize class java.awt.Toolkit
        at org.appwork.shutdown.ShutdownController.requestShutdown(ShutdownController.java:407)
        at org.appwork.shutdown.ShutdownController.requestShutdown(ShutdownController.java:394)
        at org.appwork.shutdown.ShutdownController.requestShutdown(ShutdownController.java:387)
        at org.jdownloader.update.launcher.SecondLevelLauncher.runMain(SecondLevelLauncher.java:249)
1|org.appwork.shutdown.ShutdownController.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.shutdown.ShutdownController(log) ] -> Request Shutdown: org.appwork.shutdown.BasicShutdownRequest@5f9be66c
1|Log.L.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.loggingv3.LogV3(info) ] -> No Vetos
1|Log.L.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.loggingv3.LogV3(info) ] -> Fire onShutDownEvents:0
1|Log.L.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.loggingv3.LogV3(info) ] -> Create ExitThread
1|org.appwork.shutdown.ShutdownController.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.shutdown.ShutdownController(log) ] -> Wait for ShutdownThread:Thread[ShutdownThread:1751817353373|org.appwork.shutdown.BasicShutdownRequest@5f9be66c,5,main]|waitDuration:0
THREAD: 32
32|org.appwork.shutdown.ShutdownController.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.shutdown.ShutdownController(log) ] -> Exit Now(Controller): Code: 0
32|org.appwork.shutdown.ShutdownController.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.shutdown.ShutdownController(log) ] -> [1/8|Priority: 10000]ShutdownController: start item->org.appwork.utils.singleapp.SingleAppInstance$2 Priority: 10000
32|org.appwork.shutdown.ShutdownController.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.shutdown.ShutdownController(log) ] -> [1/8|Priority: 10000]ShutdownController: item ended after->1
32|org.appwork.shutdown.ShutdownController.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.shutdown.ShutdownController(log) ] -> [Done:1/8]
32|org.appwork.shutdown.ShutdownController.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.shutdown.ShutdownController(log) ] -> [2/8|Priority: 10000]ShutdownController: start item->flushing logs to disk
32|org.appwork.shutdown.ShutdownController.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.shutdown.ShutdownController(log) ] -> [2/8|Priority: 10000]ShutdownController: item ended after->6
32|org.appwork.shutdown.ShutdownController.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.shutdown.ShutdownController(log) ] -> [Done:2/8]
32|org.appwork.shutdown.ShutdownController.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.shutdown.ShutdownController(log) ] -> [3/8|Priority: 0]ShutdownController: start item->ShutdownEvent: Save JSonStorages
THREAD: 35
35|Log.L.log 7/6/25, 5:55:53 PM - FINER [ org.appwork.loggingv3.LogV3(finer) ] -> Start Saving Storage
35|Log.L.log 7/6/25, 5:55:53 PM - FINER [ org.appwork.loggingv3.LogV3(finer) ] -> ENDED Saving Storage
32|org.appwork.shutdown.ShutdownController.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.shutdown.ShutdownController(log) ] -> [3/8|Priority: 0]ShutdownController: item ended after->1
32|org.appwork.shutdown.ShutdownController.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.shutdown.ShutdownController(log) ] -> [Done:3/8]
32|org.appwork.shutdown.ShutdownController.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.shutdown.ShutdownController(log) ] -> [4/8|Priority: 0]ShutdownController: start item->ShutdownEvent: SaveAllStorageHandler
32|org.appwork.shutdown.ShutdownController.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.shutdown.ShutdownController(log) ] -> [4/8|Priority: 0]ShutdownController: item ended after->8
32|org.appwork.shutdown.ShutdownController.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.shutdown.ShutdownController(log) ] -> [Done:4/8]
32|org.appwork.shutdown.ShutdownController.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.shutdown.ShutdownController(log) ] -> [5/8|Priority: 0]ShutdownController: start item->ShutdownEvent: ProcessDelayedWrites num=0
32|org.appwork.shutdown.ShutdownController.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.shutdown.ShutdownController(log) ] -> [5/8|Priority: 0]ShutdownController: item ended after->1
32|org.appwork.shutdown.ShutdownController.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.shutdown.ShutdownController(log) ] -> [Done:5/8]
32|org.appwork.shutdown.ShutdownController.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.shutdown.ShutdownController(log) ] -> [6/8|Priority: -2147483648]ShutdownController: start item->org.jdownloader.updatev2.RestartController$1 Priority: -2147483648
32|org.appwork.shutdown.ShutdownController.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.shutdown.ShutdownController(log) ] -> [6/8|Priority: -2147483648]ShutdownController: item ended after->0
32|org.appwork.shutdown.ShutdownController.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.shutdown.ShutdownController(log) ] -> [Done:6/8]
32|org.appwork.shutdown.ShutdownController.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.shutdown.ShutdownController(log) ] -> [7/8|Priority: -2147483648]ShutdownController: start item->ShutdownEventWrapper Thread[Logging-Cleaner,5,main] - java.util.logging.LogManager$Cleaner Priority: -2147483648
32|org.appwork.shutdown.ShutdownController.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.shutdown.ShutdownController(log) ] -> [7/8|Priority: -2147483648]ShutdownController: item ended after->0
32|org.appwork.shutdown.ShutdownController.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.shutdown.ShutdownController(log) ] -> [Done:7/8]
32|org.appwork.shutdown.ShutdownController.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.shutdown.ShutdownController(log) ] -> [8/8|Priority: -2147483648]ShutdownController: start item->ShutdownEventWrapper Thread[Logging-Cleaner,5,main] - java.util.logging.LogManager$Cleaner Priority: -2147483648
32|org.appwork.shutdown.ShutdownController.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.shutdown.ShutdownController(log) ] -> [8/8|Priority: -2147483648]ShutdownController: item ended after->1
32|org.appwork.shutdown.ShutdownController.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.shutdown.ShutdownController(log) ] -> [Done:8/8]
32|org.appwork.shutdown.ShutdownController.log 7/6/25, 5:55:53 PM - INFO [ org.appwork.shutdown.ShutdownController(log) ] -> Shutdown Hooks Finished
Oracle is continually trying to make Java more secure.
This message means that jDownloader uses parts of Java that are declared unsafe in current Java versions.
The Java VM you have installed and running doesn’t dare run jDownloader because the program uses such deprecated features.
(Other Java versions are less restrictive.)
You need to give us more information to help you !
  1. what gives java --version
  2. what gives archlinux-java status
  3. What is the last version of java supported by jDownloader2 ?
    :footprints:
Ok, nvm I was able to fix it myself with archlinux-java:
$ archlinux-java status
Available Java environments:
  java-11-openjdk (default)
  java-24-openjdk
after issuing: sudo archlinux-java set java-24-openjdk
jDownloader2 started.
