Go read announcements. You know, there is a reason there are announcements. Itās so same thing doesnāt get told 1000x to everyone that has a problem, goes on forum and just opens a new topic. There is also a search bar.
A ānewerā version of kpeoplevcard accidently existed, so to install the current version, either update with sudo pacman -Syu kpeoplevcard or sudo pacman -Syuu.
Every time there is a release of updates, an announcement is posted in the following subforum/category:
[Iām assuming you are on the standard Manjaro install which uses the āstableā repos.]
Please always read the first and second post of each update announcement before you upgrade your systems.
Post 1= summary of highlights in the update, post 2= potential issues users might face on update and what the solution is. Post 2 also lists the potential problems for previous recent updates, so the kpeoplevcard issue can also be found there.
I donāt post much nowadays but this spate of kpeoplevcard and jdk/jre threads⦠wow.
To be fair, itās pretty frustrating to see numerous threads opened on the same/related issues, especially when help is so near, in the second post. Some threads are just one or two rows away from each other, with similar titles. Or some users may post their already-answered question in the update thread itself without checking post 2.
Iām not a forum helper and even I was getting a little irritated on their behalf.
Iāve dug around and finally found the Announcements hidden away in a deep menu
All categories > Announcements > Stable updates
Iām just a guy that likes Manjaro because it (usually) causes me no hassle. I didnāt even know this page existed. Of course Iāll check it in future, but maybe it should be a bit more prominent. Iām not the only one to fall foul of this trap
But in addition, from what I can see, just click on āTopicsā on the left panel and it will give you the āLatestā view of all threads with new posts. With that view, itās very easy to see when there is a new thread for a āStableā update announcement.
So just go to the āLatestā view when you see your update indicator showing lots of new updates.
