I have some puzzlement over the disappearance of my system’s JAVA_HOME
environment variable.
After installing the stable updates of 2020-12-30 and rebooting, I did a minor cleanup of my system by removing some AUR packages, that appeared to need rebuilding, including Bisq
, and removing orphan packages, including jre10-openjdk-headless
Bisq depends on jre11-openjdk
which remains installed (indeed I reinstalled it). However when trying to build Bisq I now get an error that did not occur in previous builds:
ERROR: JAVA_HOME is not set and no 'java' command could be found in your PATH.
Please set the JAVA_HOME variable in your environment to match the
location of your Java installation.
==> ERROR: A failure occurred in build().
Aborting...
Obviously JAVA_HOME needs to be set, but where? What removed it? Is it a system level setting, that would have been set automatically, rather than user level? How should I proceed?
I have a snapshot of /home
and /
from before the updates but I cannot find JAVA_HOME in any of the .*
hidden files in my snapshot home directory.
